View Full Version : Park Avenue
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14
  1. Climate Control
  2. What all have you done to your Park Avenue?
  3. fuel cap door '86 park ave
  4. 95 PA check engine light
  5. 2000PA Intermittent power loss/warning messages
  6. Transmisson Shifting Problem
  7. lesabre - seats
  8. Diagnosing herky jerky problem with NemiSys scan tool
  9. 91 Buick Park Ave Shuts off and comes back on while driving
  10. What an awesome site!
  11. Vehicle speed sensor?
  12. Factors affecting FI pulse width, 95 PA Ultra
  13. 92 Park Avenue tranny issues.
  14. Doesn't seem like I have power brakes any more
  15. Ye Old Dreaded Upper Manifold Plenum (3800 Series II)
  16. 1989 Electra T-Type Trouble Codes 22 & 41
  17. 1999 PA - Not hearing the supercharger "Whine"
  18. 92 Park runs rough when hot
  19. 1995 Buick Park Ave. Ultra...cannot Find Starter!!!
  20. 92 Park Avenue rough idle/popping through exhaust
  21. Voltage problem
  22. 99 Park Ave Ultra stalling and cutting off....What's wrong??
  23. remote transmitter diagram
  24. Ignition coil questions
  25. Regular Gas OK in an Ultra?
  26. Help.. Power loss to fuel pump!
  27. GM Canada being sued over engine gaskets
  28. 1994 PASC 60,000 miles
  29. 97PA - TCC Lockup Converter
  30. 99 Park ave ultra.......odor?
  31. Series II swap into a 92 Park Avenue
  32. Vacuum tank question
  33. Will new alarm system allow me to remote open my doors.
  34. 92 PA Ultra Running Very Rich
  35. confused with 2 things 91 PA
  36. 91 PA Rear Bearings
  37. 95 PA and stalling
  38. 1997 PA Rain Sensing Wipers
  39. 97 pa ultra bad motor mounts which one
  40. 89 Vin C DS halfshaft removal problems :(
  41. 1993 PA-Buick trunk wont fully close.
  42. Trunk will not fully close.
  43. vibration on 94 park avenue
  44. Park Ave Wont Go Into Pak
  45. 1997 Park Avenue AC Compressor
  46. 97 pa trans fluid change...
  47. Can not open hood on 91 PA!
  48. 1989 PA 3.8L misfire : ignition coil pin-out schematic?
  49. 1997 Intermittent Power Window Problem
  50. Door locks and radio antenna stopped working on PAU '93
  51. 1998 Park Ave ticking when accelerating
  52. Weird tach problem on 97 ultra
  53. Sun-Moon roof glass removal
  54. 92 PA engine upgrade
  55. Sometimes my car does start
  56. Indicator Light
  57. Highbeam, turn signal switch replacement
  58. Door lock delay redux
  59. 93 pa won't turn over
  60. Heads Up Display
  61. Supercharger Oil Level Check
  62. Temp to high
  63. Headlights
  64. 1998 Park Avenue Driver Side window problem
  65. OBS II Question for '96 Buick PA
  66. 92 PA starting difficulty ?
  67. ELC problem
  68. 95 pa jerking
  69. 93 pa 3.8 --easy question
  70. 1995 transmission slipping
  71. 99 Park ave power seat problem
  72. 91'-96' part numbers and identification
  73. Where can I find new armrest for '93 PAU
  74. Remote stopped working on '93 Ultra
  75. No cruise control on PAU '93
  76. Suspension Parts
  77. Possible alternator porblem. Advice please?
  78. How hard is it to replace the heater
  79. Window Trouble Update
  80. 3.8L Throttle Body help
  81. 1990 Park Avenue Heating Problem
  82. 1990 Park Avenue Heating Problem
  83. 1990 Park Avenue Heating Problem
  84. How to decrease noise from PAU93?
  85. 92 Buick PA Starting problem
  86. 92 Buick PA Starting problem
  87. 92 Buick PA Starting problem
  88. Dash lights up like a christmas tree?
  89. Park Avenue pictures
  90. Transmission?
  91. 91 Pa fuse pannel
  92. Helpppp No Power - 92'pa!!!
  93. Helpppp No Power - 92'pa!!!
  94. lltension pulley
  95. What a Dork, I overfilled my power steering..now what??
  96. Are those lights?
  97. 91 Park Ave Parking lights won't shut off
  98. 89 Electra T-Type Error codes 22 and 41
  99. Sub-frame alignment help!!!
  100. 1997 Drivers Side Window Motor
  101. Body control module
  102. 91 pa service manual needed
  103. need some advice on 89 Park Avenue
  104. '85 Park Ave. dash noise
  105. 1991 PA -> Need tranny interchange info ...
  106. 93' 3.8 stalling
  107. 2002 Park Avenue Ultra Dual Zone Climate Issue
  108. 1996 Prk Avenue Transmission Shudder
  109. Custom aftermarket grille?
  110. HUGE Security Problem
  111. 91 PA, won't start if it's too soon after shutting it off
  112. Multi Function Switch?
  113. Fuse for Blower Motor
  114. 1991 Park Ave.. removing the rear deck/seat
  115. 1991- upper intake plenum- no gasket??
  116. Tensioner assembly removal help- 91 PA
  117. Adding cornering lamps
  118. 91 PA Starting Problem
  119. 94 PA Weird No Start Problem
  120. 91 PA fuel leaking sending unit/hose connection
  121. Door locks and trunk release doesn't work
  122. Lock Up Torque converter problems& Programable Steering?
  123. 92 pa dies
  124. '91 PA Hard to start when warm
  125. 92 buick park ave runs when it wants
  126. Delco platinum or standard plugs?
  127. Will a 96 PA hood release cable fit a 91 PA?
  128. 92 PAU Suspension (Dynaride)
  129. 98 PA Ultra Trouble Codes
  130. Possessed 89 PA
  131. 89 pa transmission modulator
  132. bad strut?
  133. Just bought 94 PA Ultra.
  134. 95 PA windshield wipers went belly up
  135. 94 PA Auto door locks not working!
  136. Over $2,000 for a windshield!?
  137. Why Flatrater, Why??
  138. 92 park ave. hesitatates after stopping
  139. keys locked in car
  140. Newbie....lookin For Mods..........
  141. Unknown electrical component..??
  142. Rough Idle, no codes
  143. No Start 86 Buick Electra
  144. Scanning an 89 Park Avenue, will this work?
  145. 89 pa
  146. Black box
  147. 92 Park Avenue Ultra
  148. 89 PA, bad starter?
  149. 93 park ave headlites
  150. Need A Trans Shop In Nj
  151. Park AVe information
  152. Just bought it some questions - please
  153. 97 pa trunk pull down
  154. Fuel Pump Fuse Location
  155. did i make a booboo???
  156. 92 PA, poor air flow
  157. Will Not Start
  158. HELP PLEASE. Need Advice!
  159. euro lights
  160. 89 Park Avenue
  161. automatic climate control - dual zone
  162. 97 pa headlights
  163. 1995 PA Oil Pan removal
  164. 92 PAU rear defroster
  165. 1997 PA door lock delay
  166. No spark 91PAU
  167. 2000 Park ave programing new key?
  168. 2001 Park Avenue ride
  169. 92 Park Avenue tension pulley
  170. engine oil
  171. Changing Plugs on 1996 park ave
  172. metal gas tanks
  173. supercharger for 94
  174. 98 PA air struts
  175. Change wipers on '94 Park Avenue
  176. 97 pk ave supercharger
  177. Engine rocking and Motormounts question.
  178. Engine Movement?
  179. Engine stalls and dies, security light is always on.
  180. Surge, skipping under load
  181. The 1988 Holden Commodore VN
  182. Car Dies Right after Starting It
  183. 94 dual heating climate control problems
  184. 92 Park Avenue
  185. 91 Park Avenue EGR Valve
  186. 97 PA Paint Flaking Off
  187. Checking the IAC for operation
  188. WARNING! Automatic Carwash!
  189. 97 Park Ave - Supercharger Oil
  190. loud clunk when turning right
  191. 93 PA no airflow but the fan running fullspeed
  192. 97 Park Ave, no heat, drivers side only
  193. PA 93 0-62mph time
  194. Stalls: Suggestions Please!
  195. Circuit Breakers/Windows
  196. "Gurgle" noise in 98 PASC under load.
  197. Reports External Temperature 140F.
  198. Battery draining/Alternator good
  199. turn signal problem - 97 park avenue
  200. 1998 Park Avenue door handle replacment
  201. 1992 PA Water Pump
  202. Help help Help help
  203. Water leak '92 Ultra
  204. Adapter for aftermarket power antenna...
  205. Cigarette Lighter blowing fuses
  206. blower motor issues
  207. timing on a 91 PA
  208. Rear Park Assist
  209. 1991 PA headlights
  210. How long Oxygen Sensors last?
  211. engine fire prevention
  212. 91 PA idles rough
  213. 94 Park Avenue : Heat/Fan issue
  214. removing steering column panels-98 PA
  215. Any ABS out there?
  216. 1997 Park IP Fuse Box Location
  217. Hood Latch Cable
  218. 91 Park Ave Supercharger?
  219. GPS/DVD in-dash on late model PA?
  220. 91 Park Avenue Dies
  221. Voltage meter reading high
  222. BRAKE (!) Light comes on with hard acceleration
  223. Security problem?
  224. `97 engine squealing problem
  225. Wiper malfunction
  226. Service Engine Light 94 PA
  227. Starting Problems
  228. electric windows malfunction
  229. Recall - INTERIOR SYSTEMS:SHOULDER BELTS
  230. can't defog PA
  231. 93 PA keyless entry
  232. Replacing EGR Valve
  233. No spark when starting (?)electronic ignition~ (1994)
  234. Headlights "Blink" with Brake light
  235. 1994 park ave, dies every 2-3 days
  236. concert sound II
  237. cold tranny won't shift from Park until warm-up happens
  238. no heat in cabin, 93 pa. engine running hot
  239. 98 PA 120K, suddanly stalled
  240. 2001 Ultra just stops and shuts off while driving
  241. Compatible seats?
  242. getting car out of park
  243. need help removing climate control
  244. All new tranny problem!
  245. replaceing 91 PA level control struts
  246. Good Bye 91PA
  247. everythings just shuts off
  248. HELP.....PLEASE! 91 Buick Park Ave
  249. what's the difference?
  250. Thanks
