View Full Version : Park Avenue
Pages :
1 2 3 4 5 6 7 8 [ 9]
10 11 12
- instrument lights and radio lights
- Rear windows do not open entirely
- 1996 Park Avenue - No Air Blowing Out Of Vents
- Car runs like POO especially when HOT outside
- Temp sensor location for 1992 Park Ave.
- gas prices and an ultra... bummer..
- Hot Temp
- 1991 park avenue
- 1992 park avenue climate control error codes
- O2 Sensor - Bank 1 Sensor 2
- 92 Park Ave fuel filter removal...HELP!
- 1991 Park Ave Engine keeps dying
- It wont start
- Buick vs. Mazda?
- Air induction for the early Ultras
- front end
- Life expectancy of 4T60?
- 91 Park Avenue A/C Code 152
- security light stays on in dash
- Power trunk release motor
- Turn Signal problem for 1998 buick park avenue
- price for a rebuilt transmission?
- 88 Type T Electra, the horn this time.
- 97 Park Ave spark plug change
- 1987 PA with rattling/hammering sound
- Instrument Panel lights wont work
- Help! 92 Park Avenue died, won't start!
- Coolant Change
- Park Avenue Exhaust Diagram
- What is this Part?
- 91 Park Ave Electrical Problem
- A/C Cold on pass. side
- 95 PA replacement antenna mast
- Dropping Buick?....no good
- Oil Pressure Blues
- Rear Strut Replacement on 98 PA
- Desperately Need Help - 1995 Pa Ultra
- PA mods
- TPS - damaged again
- Electrical Problems - No accessory power: gauges, windows, radio, heat/ac
- Plastic interior cover
- radiator replacement
- wheres the fuel regulator?
- hesitation under load = fuel presure regulator
- Park Ave. radios
- noise when turning right FIX
- Scan Tool / DLC question
- PA Trouble Code 26- On Board Diagnostics
- 1990 PA blower fan ont shut off
- 1997 Pa
- Help! Vibration problem even while in Park
- SE light (Service engine)
- 93 Park Avenue Ultra Constant Low Battery / Drain
- buick park avenue
- Relay part #
- '97 Park Ave Pass. Power Seat
- 97 p/a lumbar or bust?
- 97' park ave drivers window defunct
- Removing Vent covers 1991 Park Avenue?
- 91 PA battery drain
- Just got '89 Park Avenue..Radio Problem
- fuel gauge funny
- is there some sort of brake selector valve?
- Acceleration problem
- Cranks, then dies
- I'm creating FrankenBuick!
- How good is the 95 PA?
- where is an oil pump on a 92 buick park avenue supercharge
- Parts & manual???
- Error code 42 (EST circuit)
- 91 Park Ave not starting
- 1990 Park Ave ECM Port
- Brake Caliper Removal
- Starter problem???? 1995 Pk. Ave.
- 4T60-E Automatic Trans Problem
- PA Runs fine some time and then dies others
- whats wrong?
- 97 PA starter motor replacement
- add a supercharger?
- windshield wipers won't shut off
- 98 Buick LaSabre
- Is it possible...?
- UFO's?97 PA DASH LIGHTS GO CRAZY
- ECM location
- Speed Limiter
- Master cylinder w/ power booster
- 94 park avenue ultra no power 3000rpm
- A/C blowing cold air on left side and Hot air on the right side
- climate control flash
- Sticking Gas Pedal at Idle
- 94 to 97 Ultra Info
- Power Steering Pump Bolts
- GM Code 56
- 96 transmission
- Failed Emissions Test
- cant get to start
- hood release problem
- Look at what I did this week! (1 picture)
- Oil Light on with good oil pressure
- Setting Remote For Buick Park Ave.
- PA won't slow down
- bad ass rice
- 92 PA won't idle
- 93 PA Headlights
- Interior Change/Large Center Console
- 99 Park Avenue - Blower Motor ANNOYING Noise !
- Clearcoat paint repair?
- 1999 Park Avenue Climate Control Display Problem
- 92 PA Error Codes, need help
- Console light idea
- Newbie has tuneup questions
- Plenum repair kit
- 90 PA rear doors wont open
- 92 Buick PA won't start
- Brake Repair and a couple other questions
- Major interior change desired
- 01 PA Power seat, climate control
- trailer towing
- tail lampfuse blows when ignition engadged
- ever tryed a 5.7 HEMI ?
- How do I change fuel filters on 3800 engine cars?
- Would like some info on 1998-2000 ParkAve
- How do I change spark plugs?
- HELP! Supension is shot!
- security alarm
- 4T65E Troubles
- Theftlock
- PA 91-96 description and security
- found a 1999 PA service manual. I need some advice..
- erratic oil pressure pressure
- drive lights fuse
- 91 PA a/c fahrenheit and celsius
- Difference between Grand Touring Suspension and Dynaride??
- I think I have a kaput ingition switch ...
- bleed hole in thermostat
- 95 Buick engine cuts off NEW INFORMATION
- Cruise control jump out
- R.P.M Technical Question
- low beams won't shut off on 97 PA
- supercharger lacking power?
- 95' Pa Ultra.. Problems
- Driver side door doen't open from outside.
- Steering Column Questions
- has Security fix caused another problem?
- 2002 Prk Ave Aux Pwr
- Sludge in coolant tank
- What to know when purchasing a 2002 PA Ultra
- Idle air control valve & O2 Sensor
- i have a problem with defogger
- fuse
- Front Drive Axle(right-hand side)
- 91 park ave 112,000 miles...couple problems
- 89 park avenue problems
- 97 PA computer, how do you reset it???
- Heater Problem 1995 Park Avenue Ultra
- Dynaride Mod
- illuminated entry system doesn't work
- Fuel Filter
- Sharing my experience pulling a 91 steering wheel
- Ultra with Slow Front Windows 2001
- 94 Park Avenue wont start
- 92 PA Dies out frequently.
- 91 PA Alternator?
- How to disconnect the self-leveling motor on my 93 PA Ultra?
- Blower on 97 Buick Ultra
- Tire noise or Wheel Bearing Noise
- 94 park avenue power window problem
- RPM fluctuates while revving engine in "park" position...why?
- Power Windows Non-Functional 1996 Park Avenue
- cheap gas in a ultra
- Discontinue Park Ave?
- 1989 Buick Park Avenue Alarm / Car wont start
- Can the air conditioning compressor leak?
- 87 trans slips out
- 91 PA,Who knows how to remove instrument cluster??
- 97 PA water pump
- Toeverybody out there with:Rough idle,no start,or fuel pump problems,and fuelprobs
- car rumbles, didn't shift, doesn't start
- Headlight plastic Fogging Up
- Fuel pump relay?
- 91 pa fuel pump where is it and why is it not working?
- Changing battery on a 95
- 1995 Park Avenue DLC
- 91 park avenue need help
- Coolant temperature
- park avenue rough idle
- wheel bearings
- 91 PA remote question
- 95 PA codes.
- changing ignition coil
- Climate Control Beebing
- 92 Ultra has some probs
- Cruise control speed oscillating
- security system
- compass in rearview mirror question!?
- Where is Directional Signal flasher 92 PA?
- Keyless remote help
- wrong pins connected
- Buick now has more problems than me!
- Park Avenue
- Tape Player Problem
- 1991 Buick Park Ave Control Module Failure
- rough ride
- 91 Buick PA Dynaride draining battery?
- wheres the brakes?
- heater blower on 93 PA wouldn,t shut off
- 99 Park Ave Hard Shift
- peeling paint
- fix this one and your the PA master
- another MPG issue
- 94 Buick Park Avenue Blower Won't Shut Off
- bad transmission
- Low Coolant Warning Light
- Wireless Remote Programming Instructions
- I need your help (remote entry)
- Heating Codes Help Needed
- Heating Problems-Help!
- No Selling Allowed!!!!!!
- 96' park avenue engine dies while driving
- '91 PA - PCV valve,where is it?
- 1995 park ave w/ dual e.t.c.
- Twilight sentinel
- 97 Ultra DIC resets on its own
- 90 Park Avenue heater fan problems
- knock sensor question,99 park ave
- ABS separate computer under dash?
- HELP!! <-security system
- PA93 remote entry & heating problems
- Brake problems on a 92 PA
- Heater Comes On When I Hit The Brakes
- 93's have audible alarm ?
- 1991 Park Avenue Keyless Remote Problem
- bipolar climate control
- 1987 engine problems
- Transmission problems
- fuse panel diagram
- 93 PA interior light bulbs can't find any????
- No Heatwater from engine
- Checking Power Steering Fluid / Is there an easier way?
- 1993 Turn signals
- HELP!! Harmonic balancer pulley removal
- 1993 Park Ave driver Power seat
- Heater blows slightly warm air
- 2002 Park Ave heated seats not working
- 95 PA Blower Issues
- Transmission problem - hesitation
- harmonic balancer
- 1996 Park Avenue Grille
