View Full Version : Park Avenue
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14
  1. 92 PAU Power Locks
  2. 1992 PA - Harmonic Balancer Question
  3. 92 PAU Suspension???
  4. Interior Lights - New twist to the problem
  5. Possible Supercharger Air Leak
  6. TSP Adjustment
  7. New Owner of a 1992 PAU SC ~ Great Forum!
  8. 91 PAU alarm
  9. Interior Lights
  10. 1998 PA - Low Tire Pressure Message
  11. Outside Temp Sensor
  12. 98 Pa
  13. Super Charging a L27
  14. The dam thing is fixed...almost
  15. Interesting Find
  16. Water pump gasket leak
  17. 91 park ave vent removal
  18. abs light will not go out
  19. 1997 Buick Park AVenue Ultra- Coolant low / leak
  20. '91 PA Driver's Door Panel
  21. 1991 pa radio upgrade
  22. park avenue interior lights
  23. just for fun
  24. Anyone have a Park Avenue in the 13s?
  25. brakes
  26. '91 PA Acceleration
  27. A question to PA Ultra owners and enthusiasts
  28. Re: 92 PAU engine probs???
  29. Where do I shop online for GM parts for less money?
  30. 94 Ultra - Paint color code for touch-up
  31. How much supercharger oil?
  32. Starter / Ignition Issue Please Help
  33. 91 PA can't shift out of park
  34. 99 Park Ave rear defrost...
  35. 94 Ultra - Idle is misbehaving
  36. 1998 Buick Park Ultra needs spicing up
  37. 92 Buick Park Ave- ABS Light
  38. 91 PA speedometer crazy
  39. new member with 91 PA troublecodes
  40. 94 Ultra Fuel pressure regulator replacement
  41. car wont go past 35mph !!!
  42. Gm 3800 3.8l Upper Intake And Plenum 3.8 Repair Kit
  43. 89 P/A - Where is the fuse box located?
  44. popping when put in or out of park
  45. Levelers + engine dying
  46. 94 Ultra exhaust smoke
  47. 94 Ultra exhaust question
  48. Power antenna adapters finally available!
  49. 94 PAU Compressor question
  50. RPM increase when braking.
  51. Brake warning light issue
  52. 1997 Park Avenue issues
  53. 94 PAU rack and pinion and pump testing
  54. A/C resetting
  55. A few things for my 94 parkave
  56. 95 PA disable air bag
  57. Pulling codes on a 97 pa
  58. 93 P/A Strut bearing plate
  59. New and Old Members Please Read
  60. the pics (finally!)
  61. pics
  62. 01 PA rear window defogger & power seats
  63. coolant loss with no drips?????
  64. Ashtray wont close?
  65. 91 PAU Starting Issue
  66. vibrate
  67. Trans Mount
  68. power widow switch
  69. 94 PAU SC Bypass solenoid question
  70. 94 PAU running HOT but not overheating w/ ac on
  71. tires park aveneu
  72. 92 PA Tranny
  73. hesitation 89 park avenue
  74. 93 starter selonoid
  75. 1999 service engine soon
  76. '92 PAU Alternator
  77. help park ave 94
  78. ABS Light 02 Park Avenue
  79. Sway bar extender
  80. transmission mount 99 park ave.
  81. 1997 buick pa shutting off when going slow
  82. 97 Ultra, leaky rear struts
  83. Delco Radio Volume Control
  84. 89 Park Avenue with some missin parts
  85. Acceptable voltage
  86. Electrical Gremlins
  87. 93 P/Ave. Service Engine Soon Light
  88. 94 Ultra driveaxle swap
  89. rattling or clanking sound under 1500 rpm
  90. Sometimes: rough starting, then all is fine?
  91. abs light and traction control light...
  92. Driver Side Seat Belt
  93. 94 Park Avenue Bumper
  94. 99 Park Ave master key won't start....
  95. Airflow and gas pedal
  96. Engine treatment
  97. 94 PA chirping from steering column
  98. 94 Park ave. alternator question
  99. 94 park ave. ultra power steering?
  100. 91 buick park avenue ultra
  101. ABS Light on. HELP!!
  102. Delco CASSETTE MECHANISM 16256794
  103. Installing bypass filter on '96 Park Avenue?
  104. 1988 Park Avenue trouble spots
  105. 1997 PA Coolant leak, by-pass fitting
  106. For an 85 Park Avenue
  107. 91 Park Avenue Ball joint trouble
  108. 1991 Park Avenue Keyless entry programming question
  109. Harmonic Balancer Question
  110. 96 park ave won't start. Battery good.
  111. 1997 Park Ave tachometer problem
  112. 1997 Park Ave wheel cover problem
  113. Rear toe in on 1996 Park Avenue
  114. Seeking 97-05 Park Ave owners in Socal~
  115. Brake lines. Bubble flare. Help me!
  116. '97 PA Hesitation When Cold and Delayed Shift
  117. 92er PA eats ignition coils
  118. 95 buick park avenue battery dead
  119. Trouble with touch up spray
  120. Keyless Programming 92-95 HOW TO
  121. Amount of oil in a 3.8 (1997 PA)
  122. 1997 PA Window Problem Revisited
  123. Question about the vin number
  124. Help Low Oil Pressure
  125. 94 PAU Bug Deflector w/ screen question
  126. 94 Ultra Tire question
  127. RPO Codes
  128. 94 Ultra Hesitation/Alt
  129. change fuel injector
  130. on star
  131. 1997 PA Ultra
  132. Transmission Problems?
  133. my 1995 buick park ave drivers power seat will not work
  134. 1997 Park Avenue A/C only BLOWS on ONE SIDE???
  135. Is Bosch to blame?
  136. Transmission pan gasket sealing
  137. Bearing noise on 91 PA
  138. Park Ave. ABS control Module
  139. Getting to VATS connector
  140. Radiator cap pressures. 7 lbs ok?
  141. 88 PA fusebox location?
  142. ECM for Buick Park Avenue
  143. 94 PA Trunk Motor
  144. 1988 Park Ave Air Ride
  145. Stabilizer bar/control arm linkage
  146. 94 Regal dies without warning and does not start/95 LeSabre dies without warning II
  147. Cupping of tires? tie rods or just bad tires?
  148. Front strut ?
  149. JaxJag
  150. tensioner replacement
  151. power steering pump question
  152. Recharging AC for 92 PA
  153. Latest year radiator possible for 92 PA
  154. Window alignment tips
  155. '91 Fuel line problem?
  156. Oil pan exposes connecting rods?
  157. 98 PA dash removal Gas hand jumped peg
  158. needs performance\style assistance
  159. Dash shaking when fan is on
  160. PCM schematics
  161. 1998 Park Avenue A/C quit
  162. Automatic won't use 4th gear. =[
  163. Vacuum reservoir leaks on 95 park ave causes vacuum leaks
  164. Transmission mount 97 PA
  165. AIR CONDITIONING LbEAKS INSIDE CAR
  166. AC Question
  167. Alternate Oil Filter for 1996 PA
  168. Draining Fuel tank on '89
  169. Voltage problem - Belt tension?
  170. Oil changing tip
  171. 94 Ultra's gotta shake at 50 to 60 mph
  172. Pic of Datalink on 1996 PA. Terminal #s??
  173. 1997 Park Avenue traction control and Anti locks brakes
  174. Aftermarket Stereo's
  175. 1994 Ultra catalytic converter question
  176. Steering wheel control wire question
  177. Remote Entry/Security ?
  178. Flushing Brake Fluid in 1996 PA
  179. AC Compressor is bad...
  180. 1996 Park Ave - Problem w/ Power Seat, Interior lights
  181. Owners Manual for 1996 Park Avenue?
  182. Fan motor
  183. Using factory and custom remotes?
  184. 97 PA Brake Job Help
  185. Circuit Breaker 3 Seat power 94'Ultra FIX
  186. 99 Park Ave. coolant in No.1 cyl
  187. Where to find a new ELC sensor?
  188. '97 Ultra no tach revisted
  189. 92 climate control
  190. Rear bumper crome on Ultra
  191. 1997 Park Avenue Radio
  192. Steps in changing A/C compressor clutch Help!!
  193. Park Avenue does 220mph??
  194. Will not run correctly
  195. Oil leak on my 97 pa
  196. 98 tune up ?
  197. 95 Park Ave herky-Jerky solved?
  198. 94' Park Ultra Water PUMP
  199. Supercharger question
  200. Engine Sludge
  201. 1997 Park Avenue Starting Hard
  202. Supercharger pulley replacement
  203. 87 Park Avenue...what can i do with this?
  204. Headlights/dashlights flicker
  205. '89 Electra T-Type Synthetic oil?
  206. 96 Park Ave-Alarm keeps going off
  207. 93 trans drain plug
  208. Installing new turn signal cam
  209. Rpm idle is to low
  210. 1986 window regulator guide
  211. Aftermarket keyless entry questions
  212. Programming Instructions for Remote
  213. 85' Park Avenue...opinion needed
  214. Installin door Speakers
  215. 91 PAU mixed gas in oil pan
  216. 92 PAU Trouble Codes
  217. Need help pulling codes please...
  218. oil filter
  219. help on installing 6x9 speakers in 83 electra park avenue
  220. 93 PA.. Won't start
  221. 1988 Cruise Control
  222. 92 Park Avenue Ultra Struts
  223. Just bought a 92 PA Ultra
  224. 1997 PA Regular Stock Radio
  225. 2001 parkave turn signal switch problem.help
  226. Can u guys HELP supercharge my Lesabre?
  227. 94 PA Dash Lights
  228. Reving engine
  229. 91 PAU not starting
  230. No mix control and drivers side.
  231. 1978 Buick Park Avenue - charging/wiring problem
  232. 1994 Buick Park Ave
  233. change oil soon
  234. 95 park ave no start
  235. Starting problems
  236. 98 PA windshield blade won't back to home position
  237. Radiator
  238. Fuel sending unit/ pump question
  239. 99 PA ULTRA Supercharger
  240. National Quick Start Iceberg Alternator?
  241. Is the HVAC programmer sold outside the dealer? 95 PA
  242. 91 PA check engine but no codes
  243. Security light stays on 95 PA
  244. Brake line
  245. Exhaust leak the culprit?
  246. 1988 buick p[ark avenue problems
  247. 91 Buick Electrical -Schematic/ESM
  248. Advice on s*lling my problematical PA Ultra
  249. Review mirror ready to fall off?
  250. Climate Control
