View Full Version : Park Avenue
Pages :
1 2 3 4 5 6 7 [ 8]
9 10 11 12
- 2000 PA oil pan removal
- Tape deck vs. CD deck question
- PDL - very strange symptoms
- 1992 Park Avenue strut recommendation!
- Belt Tensioner
- 95 Buick Park Ave Climate control module
- Alternator keeps failing!
- hard to start 89
- HELP! 97 Park Ave wont start!
- Stearing is 'Clucking'- now ABS/Traction Control is Lit
- Spark Plug Replacement
- Buick PA Water pump replacement
- 1998 PA Coolant problem
- 89 park ave running rough
- chime for lights
- 91 PA failed emissions
- Driver and Pas door lock swicth
- Early 90's Park Avenues?
- programming A1994 Buick Park ave Keyless remote please help
- Lousy Gas mileage
- Take apart outside mirror
- 95 park climate control blinking -help please
- Washer Pump Motor
- 97 park -pass side interior light
- Changing a fuse
- 92 park avenue sentental headlight control
- 92 park avenue security door locks
- 96 park avenue....runs rough...code was for #4 cylinder
- Water Pump
- oil pressure
- 92 PA - Ran out of gas, now won't start
- 98 rear window defogger not working?
- 91 Buick Park Ave.
- Need Help-with 86 Park Avenue
- Kick Panel
- Turn signal flasher/relay/module?
- Traction Control
- engine gurgling sound
- won't start
- 99 park ave. no turn signal
- I'm Freezing! 94 Park Avenue W/ No Heat
- 91 PA won't start. intermitant
- 96 Ultra door locks u/s when placed in park
- 94 park ave fuel problem
- 92 Buick Park Avenue-No Gear
- 97 Park Ave power loss when above 60 degrees
- suspension overhaul
- Tail Light leaks
- 91 Ultra leak
- park avenue
- tape player warm inside
- Starting problem 91 Buick PA
- BCM location
- 91 buick ave possessed - ECM??
- 94 Buick Park Avenue - alternator problems?
- 94 ultra climate control/blower clutch relay
- new vent window price OMFG!?!?!?!?!?!
- brake, mc or abs
- what's that?
- 1988 Buick Park Ave.
- Park Ave dies while riding down the road
- 1997 fuel pump
- 94 ParkAvenue wheel radio controls
- starter repaired now make funny sound
- 1997 pa
- Code 31 Park/Neutral Safety
- 88 PA stalls out when headlkights are turned on
- Noisy supercharger is repairable parts found
- Rpm's High
- Parking lights
- 96 Ultra Noisey Supercharger
- 93 PA quit while driving, no spark, no pulse "CURED"
- 1997 pa
- Special Information for the VATS bypass
- 1992 PA right side of instrument cluster fuse keeps blowing.
- Dash Speakers
- serpentine belt
- 1997 pa cut off
- Blower still going when car is off.
- Trans Side Pan Removal 1997 Pa
- Intermittent - Rough Running
- 1997 User Manual - Please Help
- fuel injector
- 1997 PA door panels
- 2002 PA Driver Door PWR Lock
- 97 pa remote
- 1997 remote
- 1992 PA quits running
- Door Panel removal
- rear tie rod replacement on 93 pa.????
- injector cleaning
- Just replaced my 91's rear air struts
- 1997 Park Ave 4T65E Trans Problem
- keyless entry programing
- '91 Pau - Extreme Hesitation
- 94 ultra no power
- 91 PA Gas Tank
- traction control
- 1991 Buick PA fuel guage
- 1992 Buick Park Avenue
- 91 park ave. brake problem
- Cylinder 5 Misfire code 98' Park Ave.
- 91 PA stereo removal
- overheated PA
- 1991 and hesitation and some strange vibration
- 92 Park Ave Head Lights
- Rough idle
- Grille Question
- cruise/wiper lever
- Help with 91 PA not turning over..then it does...
- 92 Park Avenue, Blower problem
- 1997 park avenue
- 97 PA Turn signal flasher change
- 89 pa cuts off while driving
- fuel pressure relief 93 park avenue ultra
- 91 Buick PA running hot
- 98 park ave
- 91 Park Ave outside temp sensor
- 94 buick PA electrical problems
- Your Advice on PA 1997
- steering collum replacement
- Changing rear rotors on 97 PA
- Electrical Problems 1996 Park Ave
- Moron successfully changes blower module. Thanks HotZ...
- Traction & Cruise Control Problems
- 1997 Keyless Entry Programming
- 95 AC compressor replacement
- Please help moron change control module..
- Stalling problem
- How to reconnect broke off mirror assembly to door of '93 PAU?
- 92 P.A. Relay Location (Fuel Pump)
- Engine swap?
- 91 pa, can't get damper off
- Programming Keyless Entry
- 94 Pa
- horn help... and firewall access!
- 1992 Buick starter enable relay
- 91 PA lights are out
- 94 PA Ultra Hesitates when stepping on gas pedal
- Electrical/Wire Problem to the Starter on '93 PA Ultra
- 92 P.A. Stalls after Warm-up
- Code red!
- Looking for 92PA Ultra rear bumper (chrome pieces only)
- 94 Park Avenue Blower Motor---CRIPES!
- Stereo Change out
- Door Panel
- Can a bad blower motor module cause...
- Timing Set
- 95 Park Avenue w/short somewhere??
- 2000 Park Av power steering
- 91-96 PA Tire question
- Power Locks
- Please help with 89 park ave 3800 V6 running rough
- PA Power Seat problem
- 91 PA code 41 cam sensor question
- Stumped on 86 Buick idle!
- I have a sqealing sound from the rear of '93 Ultra
- Brakes nd TCS
- 97-99ark ave
- Horn Relay Location ?
- Can Anyone Figure this out???please...
- '92 Buick PAU, dies while driving.
- 94 PA Problem
- 92 P.A. Quits after a few miles. Circuit Breaker??
- trunk lid motor... help!!!
- Correction: 94 PA 3.8 Supercharged Engine Sputtering
- 94 PA 3.8 Supercharge Engine Sputtering
- is it the starter?
- Starts....doesn't start...starts
- 91 PA won't run
- Replace horn switch assembly
- Seats
- Head light problem
- The Trunk is a freak
- Mid 89' Electra Limited will not start!
- Park Avenue lights
- 97 Park Avenue ultra ,lights flashing
- 95 Buick PA engine will not crank
- Starting Issue
- 96 PA Ultra - Falling out of gear?
- hot wire Dyna ride air compressor?
- back door & window locked PA 1992
- 89 starts once a day
- The disappointing 92 PA A/C
- 1993 radio
- 91 PA air ride shocks
- A/C and speedometer quit at same time?
- 92 Park Ave jusr "Quits"
- 91 camaro rs, pass key decoder module? vats? will start but, give it gas dies immedia
- A/C Fan/Blower
- Test for intake leak?
- Online PA Parts
- 1999 park ave keyless entry
- water pump broke - engine got hot- what to watch for?
- 1992 Buick Park Avenue Keyless Remote
- sometimes it starts sometimes it won't
- simple question?
- PA questions
- 1994 Ultra fuel pump relay
- Search Parts For Buick Park Avenue 1992
- wont start
- Lopey idle and voltage gauge reading low - 92 PA
- 92 Park Avenue Popping sound and maybe misfire?
- 97-99 PA Questions
- Noisy Fuel Pump
- Runs then as driving it dies.
- Motor Mounts for 1998 PA Ultra
- 94 PA high idle after 'overheat'
- 91 Pa Rear Shocks -how much?
- Weird left power mirror problem- Intermittent
- Speaker Installation
- 1991 PA Ultra A/C goes into Econ mode
- number of splines on a 91 PA
- A/C blower pressure
- automatic climate control 138 code 91 pa
- Gas -> alcohol conversion experiences?
- 2007 Park Avenue Returns!
- i have a no start also
- no start ....but it turns
- 89 Park Avenue cough and stalls
- '92 PA Ultra Won't Start via Ignition/Key
- remote wont work and car dont start
- In Need of A part Number
- it wont start and remote dont work
- 95 PAU - moonroof malfunction
- 1991 PA ignition coils ...
- 91 PA turns but won't start ....
- 91 pa security lockout
- 96' Park Avenue - Climate Control System - Actuator $$$$
- A Myriad of Issues on a 1993 Park Avenue...
- boost gauge installation?
- 94 PA Ultra Overdrive problem
- Starter failures
- Need Stock Radio W/ CD Player
- 92 PA Ultra A/C Compressor Change
- 91 PA Fan Won't Turn Off (Question about Relays)
- Engine dies immediately when starting
- a/c compressor
- Daynaride rear air strut trick.
- 91 park ave 115,500 miles oil pressure issues
- ride control
- radiator replacement w/ oil cooler
- 91 p/a code 138 pcm failuer
- Does This Park Ave Look Like a Good Deal?
- 1992 PAU Fuel filter???
- dies, hard starting
- Overheating when car not moving
- A/C blowing hot air
- Low idle problem
