View Full Version : Park Avenue
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14
  1. Heater core problem?
  2. 1991 P-A Sporadic No-Crank
  3. 97 P/a Hard Up Shifts
  4. Fuel Pump???
  5. 2001 PA DIC programming
  6. Front Strut Recommendation
  7. 97 park ave vacumn build up in motor
  8. 2001 Park Avenue IAC screw
  9. 1989 Buick Park Avenue Service Engine Soon Light
  10. Holden's WM goes to China as a Buick
  11. 1989 Buick Park Avenue Memory Seats
  12. 1989 Buick Park Avenue Opera or Coach Lamps
  13. 1989 Buick Park Avenue Twilight Sentinel
  14. 1989 Buick Park Avenue Remote Keyless Entry
  15. 1996 Buick ParkAvenue Exhuast Question
  16. Wheel Locking Up (ABS Light ON)
  17. Drivers Side, Outside Door Handle
  18. 1995 Buick PA key in ignition chime
  19. Voltage drop issues on a 94 Ultra when stopping
  20. 2002 PA Squeaky dash
  21. 91 pau spearkers no sound
  22. 1999 PA Ultra Tire Pressure and Oil Condition
  23. Vacuum pressure and fuel pressure questions
  24. 95 Park Ave + Mercedes Supercharger?
  25. New PA Ultra 2000 Owner
  26. turning signal
  27. tired tachometer
  28. 2001 Park Avenue Front Seats
  29. 1997 park ave ultra jerks
  30. Climate Control -Acctuator Question
  31. 94 PA Tranny Replacement
  32. 98 Programming Disaster -- Trunk Problems
  33. 01 park right front strut noise,
  34. New 94 PA Owner- need help with Dynaride
  35. Cabin Filter Recommendation Needed
  36. erratic misfire?
  37. How does this work?
  38. Passenger Climate Control 95 Park Ave
  39. 98 Programming Remotes
  40. cannot program new transimitter for my PA
  41. 1998 Check Engine Light
  42. PA 1994 - ODB, ODB 1.5 or ODB-2?
  43. Crankshaft Position Sensor
  44. mount diagnosis?
  45. Spark Plug Consensus
  46. 99 park avenue keyless entry key fob
  47. 1997 Park Ave Noise from Strut Tower (solution)
  48. Setting Memory Seats
  49. park avenue tranny question
  50. Speed Sensor
  51. 1996 Buick Park Avenue question
  52. 97 park avenue ultra service engine liter came on
  53. 91 Prk Ave Abs Lite On Continually
  54. Belt tensioner...97 PA
  55. 92 PA ultra
  56. Spongy Brakes in '95 PA
  57. Cigarette Lighter Fuse Location
  58. Front break rotors warping
  59. Questions about rear suspension (air mainly)
  60. Gremlins messing with the horn...
  61. engine vibrations
  62. ABS ! and traction off stay on
  63. Park Ave Power Steering LOOSE
  64. Interior Lights Stay On.... 2000 PA
  65. PA electrical problem
  66. 95 Park Ave No a/c on passenger side, no heat on driver side
  67. 97 PA - New trans Installed now Steering Wheel off center
  68. Spark Plug Change Tools
  69. 2001 Pa
  70. 2000 PA Presidential
  71. 97 PA driver's side seat
  72. Buick Park Avenue 1992 Auto Dimming Mirror Wiring Information
  73. PA 92 doens't fire all cylinders
  74. 93 parkave driving by itself
  75. 1999 PA Base Upgrade to Concert Sound III
  76. Park Ave Info please
  77. Park avenue questions
  78. Gone!
  79. '93 PA won't start after I "fixed" it...help b4 wife kills me!
  80. 93 PA upper intake manifold question
  81. What problems? 2000 Ultra
  82. No brake lights or turn signals
  83. 03 Ultra Needs 22s
  84. Fuel Door Switch Wont Work!!!
  85. Trunk problem
  86. AC clutch continously cycling on/off 95 Park Ave.?
  87. 91 PA Climate Control Display ?
  88. Lock ring in the way!
  89. 97 Park Ave. Tranny Mount Help.
  90. Bad Computer?
  91. 1991 park avenue dies at red light / low idle
  92. 1993 parkave ultra no heat through vents
  93. Reset tire pressure error ULTRA 2000 TIP.
  94. Ultra 2000 Seat floor trim removal?
  95. Oil pick-up tube/ screen cleaning or replacement?
  96. 97 park avenue power seat problems HELP!!
  97. 1988 Park Avenue Won't Start
  98. Plenum & Lower Intake Replacement tips 3800 V6
  99. Picture of old Lower Intake Gasket 3800 Series II
  100. No power on drivers seat...
  101. 86 Park 3.8L Service Engine Soon Light Flicks
  102. 92 PA Heater/Floor/Windshield Control???
  103. Installing a aftermarket radio in 91 PA...
  104. 94 PAU checking engine codes question
  105. Intake Plenum Replacement Question
  106. Problem with speakers
  107. 97' PA fuel pump or fuel pump relay????
  108. wich green wire
  109. Oil pressure... falling off
  110. 91 PAU back doors won't open
  111. After market stereo
  112. Struts and shocks changed.....
  113. Is repair estimate reasonable? (to fix pcs solenoid)
  114. 1997 Park Ave - Noise from Vents
  115. 92 Park Avenue ultra
  116. 89 Park Avenue Electronic Dashboard Problems
  117. 91PA hard miss on acceleration
  118. 1997 Park Ave Fuel Gauge gone nuts
  119. Duplicate Window Sticker
  120. 1999 PA GM/Delco Radio Swap
  121. 1999 PA New Owner Mission of Discovery
  122. Headlight Sensor 1999 PA Base Model
  123. Power Steering Cooler (and other problems)
  124. 1997 pa both front windows go down slow
  125. Another climate control question
  126. 1996 Buick Park Avenue 3.8L * Non Ultra *
  127. Fuel line leaking. How do I replace it?
  128. Fuel-Door Spring?
  129. MY PA has several issues
  130. RADIOs FAILED Need Replacement
  131. 99 Park Ave rear defogger stopped working...
  132. What's the difference between 41-902 plugs & ...
  133. one more rear shock question...
  134. 94 Buick PAU Not Starting, Cranks and Then Does Not.
  135. Problems in '95 PA after installation of CD player
  136. New Struts (read the old posts, still have questions)
  137. Alternator Belt loose on Park Avenue
  138. Changing struts:
  139. 1999 PA Heads Up Display
  140. Engine loping
  141. Turn signals dont work
  142. 92 Buick PA- Light Monitor Flashes
  143. climate control display
  144. Trouble with my Park Ave.
  145. 93 PA PCV Valve
  146. Starts but let go of gas pedal and shuts off.
  147. 90 park ave cam sensor magnet
  148. Window Washer issue on 92 Park Ave
  149. Power window problem on a 92 park avenue
  150. Huge Problem... Moronic Solution
  151. Interior Cracks and Krinkles.
  152. 95 Park Avenue Cruise Control Problems
  153. Radiator Cap
  154. Engine mount bolts
  155. 1996 Park Avenue Power Steering
  156. '92 PA "Service Engine" Goes On Briefly
  157. 91 park ave. no start..
  158. 1999 Park Avenue driver's seat motor
  159. 1997 Park Avenue Driver's side seat
  160. HELP! lossing all my water!
  161. coolant temp sensor
  162. 97 PA driver's side window
  163. 99 PA sunroof problem
  164. code 41
  165. Regular Unleaded OK in 1999 PA Ultra?
  166. 92 PAU stalls while driving
  167. Larger wheels and tires...
  168. 89 Buick Park Ave
  169. considering buying a 1997 park ave. ultra
  170. 92 PAU Water Leak
  171. Gauge reading questions...
  172. 97 PA PO507 Code
  173. Park Ave Lower intake gasket problem ?
  174. Monroe quickstrut?
  175. remote transmitter
  176. 1992 PA car alarm question
  177. 94 park ave dying
  178. Recent Improvements... Need help.
  179. Exhaust dent: affecting power?
  180. Transmission Fluid Additive
  181. Problem with the digital cluster PA 1987
  182. 97 PA Front Wheel Groan
  183. 95 Park Ave wet floor
  184. exhaust tips and tricks??
  185. 93 PAU surges
  186. new wheels
  187. 1999 Park Avenue Ultra Radio
  188. Installing Aftermarket Steering Wheel
  189. Just got a 95' Park Ave. Have a few questions.
  190. Passenger side-view mirror
  191. this car is a pain in the a*#
  192. 94 pa rough idle
  193. bad brakes
  194. Two Questions
  195. the pics
  196. 91 Park Ave won't even try to start
  197. Loose Steering
  198. Bad wheel bearing or CV joint?
  199. electirc front struts
  200. 97 PA...Winter Snow=No TCS/ABS
  201. 1993 PA Steering Woes
  202. 2001 Park Avenue: Screwed
  203. 1997 Park Avenue Gas Filler Door / dash lights
  204. Question on stock radio
  205. 1989 Electra Park Avenue tranny issues?
  206. Where is the heater core in a 92 PA
  207. 91 PA Climate Control Trouble
  208. Head-up Display
  209. 96 Park Avenue Weird Heater Problem!
  210. Help install rear deck speakers - 99 PA
  211. Weird noise too
  212. New Member: 2001 Park Avenue
  213. Drilling Strut Tower: Normal or Not?
  214. 3.8 buick exhaust manifolds
  215. 96 PA misfire problems
  216. 1996 Buick Park Avenue question
  217. '85 Park Avenue, Drum Wheel Cylinder
  218. 1997 PA--Cellular Phone Readiness Pkg.
  219. 97 pa strut/shock replacement
  220. Help the newbie pls.
  221. '94 PA Battery Discharge
  222. Idle issues at start up on a 94 Ultra
  223. '99 PAU Sound System
  224. 95 Park Avenue stalls when windows or doors are activated
  225. 02 PA-Dual Digital Heat/Air Blower
  226. Crank position sensor
  227. 1998 Park Avenue trunk leak solved
  228. Looking 4 a shop manual for my 98 park avenue ultra
  229. please help hood cable broke
  230. Please help with my annoying sqeal
  231. Intake manifold reversable
  232. Shop Manual
  233. 98 Buick Park Ave Ultra
  234. '92 PA no heat thru vents
  235. 1995 Buick Park Ave - No Start - Electrical? HELP
  236. Code 49
  237. New struts - horrible ride
  238. Wrecking yard/salvage yard
  239. air bag cover
  240. Weird noise
  241. Rear suspension problem on 92 park avenue, urgent help needed.
  242. 94 PA is dead
  243. 97 PA speakers,tranny,and a/c, intake tube.
  244. What is this???? Please Help!
  245. 99 PA side mirror no heat/driver seat not raising
  246. 98 PA Front Passenger Side Seat Belt
  247. My 99 PAU needs help. Can you help us please?
  248. 2000 Park Ave. rear defrost
  249. Buick Park Avenue 1993 rear window defogger
  250. 91' Code 41 - Cam Sensor
