View Full Version : Park Avenue
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11 12
- Door locks and radio antenna stopped working on PAU '93
- 1998 Park Ave ticking when accelerating
- Weird tach problem on 97 ultra
- Sun-Moon roof glass removal
- 92 PA engine upgrade
- Sometimes my car does start
- Indicator Light
- Highbeam, turn signal switch replacement
- Door lock delay redux
- 93 pa won't turn over
- Heads Up Display
- Supercharger Oil Level Check
- Temp to high
- Headlights
- 1998 Park Avenue Driver Side window problem
- OBS II Question for '96 Buick PA
- 92 PA starting difficulty ?
- ELC problem
- 95 pa jerking
- 93 pa 3.8 --easy question
- 1995 transmission slipping
- 99 Park ave power seat problem
- 91'-96' part numbers and identification
- Where can I find new armrest for '93 PAU
- Remote stopped working on '93 Ultra
- No cruise control on PAU '93
- Suspension Parts
- Possible alternator porblem. Advice please?
- How hard is it to replace the heater
- Window Trouble Update
- 3.8L Throttle Body help
- 1990 Park Avenue Heating Problem
- How to decrease noise from PAU93?
- 92 Buick PA Starting problem
- Dash lights up like a christmas tree?
- Park Avenue pictures
- Transmission?
- 91 Pa fuse pannel
- Helpppp No Power - 92'pa!!!
- lltension pulley
- What a Dork, I overfilled my power steering..now what??
- Are those lights?
- 91 Park Ave Parking lights won't shut off
- 89 Electra T-Type Error codes 22 and 41
- Sub-frame alignment help!!!
- 1997 Drivers Side Window Motor
- Body control module
- 91 pa service manual needed
- need some advice on 89 Park Avenue
- '85 Park Ave. dash noise
- 1991 PA -> Need tranny interchange info ...
- 93' 3.8 stalling
- 2002 Park Avenue Ultra Dual Zone Climate Issue
- 1996 Prk Avenue Transmission Shudder
- Custom aftermarket grille?
- HUGE Security Problem
- 91 PA, won't start if it's too soon after shutting it off
- Multi Function Switch?
- Fuse for Blower Motor
- 1991 Park Ave.. removing the rear deck/seat
- 1991- upper intake plenum- no gasket??
- Tensioner assembly removal help- 91 PA
- Adding cornering lamps
- 91 PA Starting Problem
- 94 PA Weird No Start Problem
- 91 PA fuel leaking sending unit/hose connection
- Door locks and trunk release doesn't work
- Lock Up Torque converter problems& Programable Steering?
- 92 pa dies
- '91 PA Hard to start when warm
- 92 buick park ave runs when it wants
- Delco platinum or standard plugs?
- Will a 96 PA hood release cable fit a 91 PA?
- 92 PAU Suspension (Dynaride)
- 98 PA Ultra Trouble Codes
- Possessed 89 PA
- 89 pa transmission modulator
- bad strut?
- Just bought 94 PA Ultra.
- 95 PA windshield wipers went belly up
- 94 PA Auto door locks not working!
- Over $2,000 for a windshield!?
- Why Flatrater, Why??
- 92 park ave. hesitatates after stopping
- keys locked in car
- Newbie....lookin For Mods..........
- Unknown electrical component..??
- Rough Idle, no codes
- No Start 86 Buick Electra
- Scanning an 89 Park Avenue, will this work?
- 89 pa
- Black box
- 92 Park Avenue Ultra
- 89 PA, bad starter?
- 93 park ave headlites
- Need A Trans Shop In Nj
- Park AVe information
- Just bought it some questions - please
- 97 pa trunk pull down
- Fuel Pump Fuse Location
- did i make a booboo???
- 92 PA, poor air flow
- Will Not Start
- HELP PLEASE. Need Advice!
- euro lights
- 89 Park Avenue
- automatic climate control - dual zone
- 97 pa headlights
- 1995 PA Oil Pan removal
- 92 PAU rear defroster
- 1997 PA door lock delay
- No spark 91PAU
- 2000 Park ave programing new key?
- 2001 Park Avenue ride
- 92 Park Avenue tension pulley
- engine oil
- Changing Plugs on 1996 park ave
- metal gas tanks
- supercharger for 94
- 98 PA air struts
- Change wipers on '94 Park Avenue
- 97 pk ave supercharger
- Engine rocking and Motormounts question.
- Engine Movement?
- Engine stalls and dies, security light is always on.
- Surge, skipping under load
- The 1988 Holden Commodore VN
- Car Dies Right after Starting It
- 94 dual heating climate control problems
- 92 Park Avenue
- 91 Park Avenue EGR Valve
- 97 PA Paint Flaking Off
- Checking the IAC for operation
- WARNING! Automatic Carwash!
- 97 Park Ave - Supercharger Oil
- loud clunk when turning right
- 93 PA no airflow but the fan running fullspeed
- 97 Park Ave, no heat, drivers side only
- PA 93 0-62mph time
- Stalls: Suggestions Please!
- Circuit Breakers/Windows
- "Gurgle" noise in 98 PASC under load.
- Reports External Temperature 140F.
- Battery draining/Alternator good
- turn signal problem - 97 park avenue
- 1998 Park Avenue door handle replacment
- 1992 PA Water Pump
- Help help Help help
- Water leak '92 Ultra
- Adapter for aftermarket power antenna...
- Cigarette Lighter blowing fuses
- blower motor issues
- timing on a 91 PA
- Rear Park Assist
- 1991 PA headlights
- How long Oxygen Sensors last?
- engine fire prevention
- 91 PA idles rough
- 94 Park Avenue : Heat/Fan issue
- removing steering column panels-98 PA
- Any ABS out there?
- 1997 Park IP Fuse Box Location
- Hood Latch Cable
- 91 Park Ave Supercharger?
- GPS/DVD in-dash on late model PA?
- 91 Park Avenue Dies
- Voltage meter reading high
- BRAKE (!) Light comes on with hard acceleration
- Security problem?
- `97 engine squealing problem
- Wiper malfunction
- Service Engine Light 94 PA
- Starting Problems
- electric windows malfunction
- Recall - INTERIOR SYSTEMS:SHOULDER BELTS
- can't defog PA
- 93 PA keyless entry
- Replacing EGR Valve
- No spark when starting (?)electronic ignition~ (1994)
- Headlights "Blink" with Brake light
- 1994 park ave, dies every 2-3 days
- concert sound II
- cold tranny won't shift from Park until warm-up happens
- no heat in cabin, 93 pa. engine running hot
- 98 PA 120K, suddanly stalled
- 2001 Ultra just stops and shuts off while driving
- Compatible seats?
- getting car out of park
- need help removing climate control
- All new tranny problem!
- replaceing 91 PA level control struts
- Good Bye 91PA
- everythings just shuts off
- HELP.....PLEASE! 91 Buick Park Ave
- what's the difference?
- Thanks
- steering wander problem - HELP!
- Dynaride pump 91 park ave
- '95 PA - Climate Control No Readout...Blown?
- Headliner fabric has fallin and won't stick up
- '88 Park Ave stalls while driving
- 92 pa into 1986 olds 88
- 89 p.a. dies whenever it feels like it
- HELP!! 85-89 park avenue pic request
- Tire Pressure
- (Uneven) Brakes & ABS-problem on '94 Ultra
- Poor mileage on 95 PA
- Static in radio with headlights on
- A couple questions...
- Several Small Problems
- Sway bar 92 Question!
- 91 PA Ultra PCV Location?
- 1992 Sub-frame bushings concern
- Alternator Question!
- 92 Motor Mounts
- 1991 Buick Park Avenue Ultra Problems
- Need help - Compass calibration for rearview mirror off a 94
- 91 Park Ave rain leaking into sides of trunk
- 98 Ultra Gas Gauge
- 93 PA radio problems
- Electronic Level Control Relay...
- dual outlet muffler
- Changing Oil Pressure Sensor
- No Heat on passenger side
- Sputter when acclerating too fast.
- pass key has starter locked out
- 92' shows a code 16 and 31
- 91 Park Ave running rough
- Any different from an olds 88?
- Help with 94 Park AVE
- What is that side vent thingy?
- 1994 buick pa ultra supercharged - no heat
- transmitter
- Headlight Chime?
- Power Door Locks Relay?
- Battery Light!!!!
- running rough only in low idle
- Rear Defroster help
- need help
- Heater Woes
- I'd like leather heated seats for my 95 PA
- 92 Park Avenue Concert Sound Radio Amplifier
- starter help
- Heater problem
- Service Stability System
