View Full Version : Park Avenue
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14
  1. 91 pa starts then dies codes 31,34,62
  2. 1994 Buick PA- Security light stays on
  3. Lamp Monitor - how does it work?
  4. 2003 Ultra Electrical Problem
  5. 95 PA Alarm problem
  6. Exterior finish on a '94 Park Avenue.
  7. the sometime non-starter
  8. Car accident (Q about cost to fix)
  9. Engine revs to 2000 rpm in park at start-up
  10. PA 1999 -Incorrect temperature Display
  11. where is the headlight module
  12. 94 park ave ultra obd codes?????
  13. 1992 Park Avenue door locks
  14. 91 PA Poor acceleration
  15. newbe
  16. tcc always commanded on
  17. '98 pa window regulator?
  18. 94 pa ultra horrible gas mileage help!! 8mpg
  19. 94 pa ultra tried everything i am competant to
  20. 1997 PA a/c-heat changes hot/cold
  21. Ultra 2000 Supercharger
  22. installing monroe sensatrak shocks
  23. 94 park ave ultra light show...
  24. 1997 PA Headlamp Lens Restoration/Replacement
  25. 94 buick park ave ultra wont start just clicks help
  26. 96 PA Climate Control Flashes
  27. lowering park ave.
  28. engine swap for 95 park ave.
  29. 1991 PA rear shock replacement. - air hose
  30. 95 park avenue water pump removal
  31. Rod Knock on Park '96 Avenue.
  32. 1998 Buick Park Ave Trans problem
  33. Used rear seat, where ?
  34. 1995 PA -A/C Programmer Questions.
  35. Guage Cluster - very dim
  36. Who has this beauty? OBD1 Computer with a OBD2 Interface?
  37. Security Chip
  38. 2001 Park Avenue Driver's Side Air Bag Removal
  39. 1995 - Climate Control Problems
  40. Lowest Miles for 91-95?
  41. Horn won't stop!!!
  42. 93 pa solenoid switch
  43. Heating Issue-Winter Coming-Please Help!
  44. 1999 P/A Ultra Air Conditioning Pulley
  45. 94 PA: Hesitation when accelerating
  46. Crappy headlights
  47. off track window
  48. Left side turn signals out on 97 Park Avenue
  49. 1995 Buick Park Avenue heat issues
  50. '97 Buick Park Avenue fuel sender wrench
  51. 1991 Buick Park Avenue - HVAC Controls Dead
  52. 94 Ignition Coil problems
  53. fuel filter location and repair
  54. KYB Struts
  55. Tires
  56. 1992 PA Will not start when hot DTC 17
  57. not starting
  58. 1989 buick. door switch
  59. 93 PA ABS Brake bleeding
  60. 1997 PA Quandry help please
  61. 1995 Just Dies
  62. 1999 Base - Play in Front Wheel
  63. 95 PA ultra a/c fan don't work
  64. Partial power failure
  65. Timing Chain
  66. Checking for vacuum leaks!
  67. 1995 Park Avenue Fuel problem.
  68. 94 Pa Help Needed!
  69. 1997 park ave ultra driver door module
  70. 1988 HVAC Air Vent Problem - HotZ28 or Anyone?
  71. 1998 Buick PA Ultra Smooth Idler Removal Help Needed
  72. 99 PA 3.8L crankshaft removal...
  73. Leather map pocket
  74. 1995 Park Avenue Battery light
  75. Noisy Bearing - Supercharged
  76. Help - '89 Park Avenue HVAC
  77. whats up with my buick? SOLVE THIS ONE!
  78. Excessive idle speed '92 PA
  79. 98 PA trunk/key ?'s
  80. MPG increase
  81. 1996 Buick Park Avenue Question
  82. 2000 Park Avenue Driver Seat Back Removal
  83. Rear shocks for 1998 with touring suspension
  84. Park Avenue AC Control Issue
  85. 98 Buick PA - 3.8L Series II - Driveablility Issue
  86. 92 P/A Ultra
  87. supercharger removal 94 ultra
  88. 94 pa high idle,lack of power.
  89. Help with Keyless entry programming
  90. Low Coolant light question:
  91. 94 PA climate Control problems
  92. 91 PA Ext Temp
  93. 2001 OEM Rear Strut Part Numbers
  94. Half shaft to transmission leak
  95. Leather argument
  96. dies after 15 min
  97. Starting Problem with 1996 Park Avenue
  98. 98 park ave ultra heater problems
  99. Gear shift indicator
  100. 91 Buick Park Ave info on fuses and relays
  101. 97 park avenue doos dont open from outside
  102. Torque damper
  103. Help program new transmitter 05 Ultra
  104. Transmission will not engage in any gear
  105. upgraded to heated seat
  106. 1987 Buick Park Ave Flickering Lights?
  107. 1991 Buick Park Avenue Heater A/C Control Problem
  108. a/c problem
  109. Bypassing the heater core
  110. 3.8 lesabre motor in a 1985 pa
  111. 1990 park
  112. 94 buick pa remote help
  113. 91 PA - Several questions
  114. 98PA AC Hot drive side cold pass side
  115. Misfire/rough idle
  116. 95 Buick Park Ave
  117. 1996 front "mini-radiator", engine or transmission oil cooler?
  118. 1998 Park Ave no start
  119. Missing sensor connector harness
  120. 98PA unknown driver code and car will not start
  121. 1996 Buick Park Avenue Question
  122. spark plugs
  123. 92PAve/Ultra/3800/Super/150k-stalls and won' start
  124. 97 PA windshield washer motor/pump
  125. 97 PA Driver's side air conditioning
  126. 98PA airstrut or gas shock
  127. Power Steering Pump Pulley 97 Park Ave
  128. 91 PA not charging, urgent!
  129. 1996 Park avenue Ultra airbag interchange
  130. 96 park avenue fuel pump relay location
  131. 91 PA keeps dieing
  132. 93 supercharged timing chain cover
  133. Help! 94 PA Electrical problems?
  134. 1996 Park ave water pump
  135. 91 Park Avenue Trunk Pulldown
  136. 92 PA - low on AC Refrigerant
  137. Climate control back lights. Accessible?
  138. 96 Parkavenue Rough Idle
  139. 96 Parkavenue questions
  140. HELP 91 p.a. codes 16,23,21,43,68.etc.
  141. 95 Park Ave Power Antenna
  142. 94 Buick Pa "motor Boat Sound"
  143. radio will not turn off
  144. Air intake
  145. Identifying ECM in 91 PA
  146. 04 power seat control problem
  147. 1996 Park Ave. front fender question
  148. Interior-Parts-Swap
  149. 92 Buick died at idle
  150. Park Avenue Forums?
  151. Tensioner pulley bracket gone bad?
  152. 92 Park Headlights won't come on
  153. 91 stalls...
  154. series 1 PAU module/computer question
  155. 1996 Buick Park Avenue Question
  156. 1995 buick park avenue
  157. 98 ultra a/c glitch/problem
  158. TOWING Question 1998 Park Avenue ULTRA
  159. 92 PA Engine dies on highway
  160. 99 Ultra tire question
  161. 98 PA ULTRA Weird Sound Trans or Supercharger?
  162. Still Starting Problem 90 Pa
  163. DIC Messages 1997 PA
  164. 97 PA-Driver Power Window and Window Lock
  165. Map Sensor for 1996 Park Avenue
  166. 91 PA loose power with hot temperature
  167. 97 Park Avenue 3800 oil leak
  168. Code 22/34 PA 1993
  169. Class Action Lawsuit- Gm 3600 Leaking Coolant
  170. Mysterious Warning Bells 98 PA - ???
  171. 93 PA "change oil soon" light
  172. Scanner Recommendations?
  173. 1997 PA Frustrating Issue, bad timing on this
  174. 99 Ultra Dash question
  175. bad engine rattle series 1 S/C
  176. Please help me how to replace the 1997 Park Ave outside Drivers Side Door Handle
  177. 96 park avenue radio help
  178. 1987 Park Ave 3.8 V6 FI Trouble starting & Check engine
  179. The 55mph stall?
  180. Help! 1991 Buick PA with nonfireing number 3 cylender.
  181. 1997 Park Ave Drivers Side Door Handle
  182. 1996 Park Avenue Loses Power While Running
  183. PA-PAU Tranny Swap?
  184. park aveue 1994
  185. DTC Codes Message Interpretation?
  186. 94 PA Climate Control Sys.
  187. Help! Water Pump 93 Park Ave Ultra w/SC
  188. Door locks and power antenna not working??
  189. Looking for 1999 Park Avenue Driver's Seat Motor
  190. whats the best way to wire subs in a 96'?
  191. 94 PA starts and dies
  192. Hot Rod Buick
  193. Engine swap- is there an ECU change too?
  194. Loud Roaring
  195. Service engine soon light
  196. Another 90 PA Starting Prob?
  197. 1996 Buick Park Avenue Question
  198. Fuse or breader for Power door locks??
  199. Fuel Gauge Faults When Battery Disconnected
  200. 99 Ultra Struts
  201. 99 Ultra Drivers Door
  202. Rear suspension problem
  203. Pop Pop Pop
  204. A/c
  205. When the AC clutch engages, hear and feel a shudder for a second or two?
  206. park ave 93
  207. 91 PAU starting problem
  208. Help with keyless entry (96)
  209. 91 PA Ultra Rack and Pinion Replacement
  210. 93 PAU Won't Start - What Else Can I Try?
  211. '93 PAU cradle bolt washers rusted out
  212. Manually Adjust dead power seat?
  213. Quad Driver module and suspension
  214. Water leak/Paint Code
  215. '90 PA error code 13, runs very rich!!
  216. Starting Problems in a 90 PA
  217. My OnStar is going away...any remedies?
  218. Rear Shocks for a 99 Park Avenue
  219. Computer swap
  220. Overcharged?
  221. Water every were!!
  222. Rear Shocks on a 91 PA
  223. Need Advice
  224. 99 PA radiator install...
  225. 98 PA Starter Woes
  226. O2 Sensor / service light
  227. My Park Avenue thinks it's a diesel ???
  228. Airbag Interchangeability?
  229. CV Nut size
  230. When shifts into OD hear/feel a shudder or clunk, 95 PA
  231. Service Engine Light is Evil!
  232. 97 PA - Cassette tape stuck in radio
  233. Crankshaft Position Sensor 1997 PA
  234. Will our 96 PA Ultra go to 250k miles ?? (130k now)
  235. Buick Transmission Swap
  236. More TPS on 91 PA
  237. Programming Instructions for Remote
  238. Buying 98 PA Ultra
  239. 02 Buick Park Ave - A/C Water on Floor
  240. Stuck Accelerator(Idle)
  241. Driver Seat Repair Estimate-Ripoff?
  242. P/A tie rod end replacement
  243. 88 park ave.
  244. 86 pa ..wont stay running
  245. TPS on a 91 Park Avenue
  246. 1988 Power Seat Wiring Diagram
  247. How do I remove the crank pulley/balancer? (1992)
  248. 94 PA A/C vent problem
  249. 94 PA radio problem
  250. Starter problem?
