Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Buick
> Park Avenue |
View Full Version :
Park Avenue
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
Power antenna adapters finally available!
94 PAU Compressor question
RPM increase when braking.
Brake warning light issue
1997 Park Avenue issues
94 PAU rack and pinion and pump testing
A/C resetting
A few things for my 94 parkave
95 PA disable air bag
Pulling codes on a 97 pa
93 P/A Strut bearing plate
New and Old Members Please Read
the pics (finally!)
pics
01 PA rear window defogger & power seats
coolant loss with no drips?????
Ashtray wont close?
91 PAU Starting Issue
vibrate
Trans Mount
power widow switch
94 PAU SC Bypass solenoid question
94 PAU running HOT but not overheating w/ ac on
tires park aveneu
92 PA Tranny
hesitation 89 park avenue
93 starter selonoid
1999 service engine soon
'92 PAU Alternator
help park ave 94
ABS Light 02 Park Avenue
Sway bar extender
transmission mount 99 park ave.
1997 buick pa shutting off when going slow
97 Ultra, leaky rear struts
Delco Radio Volume Control
89 Park Avenue with some missin parts
Acceptable voltage
Electrical Gremlins
93 P/Ave. Service Engine Soon Light
94 Ultra driveaxle swap
rattling or clanking sound under 1500 rpm
Sometimes: rough starting, then all is fine?
abs light and traction control light...
Driver Side Seat Belt
94 Park Avenue Bumper
99 Park Ave master key won't start....
Airflow and gas pedal
Engine treatment
94 PA chirping from steering column
94 Park ave. alternator question
94 park ave. ultra power steering?
91 buick park avenue ultra
ABS Light on. HELP!!
Delco CASSETTE MECHANISM 16256794
Installing bypass filter on '96 Park Avenue?
1988 Park Avenue trouble spots
1997 PA Coolant leak, by-pass fitting
For an 85 Park Avenue
91 Park Avenue Ball joint trouble
1991 Park Avenue Keyless entry programming question
Harmonic Balancer Question
96 park ave won't start. Battery good.
1997 Park Ave tachometer problem
1997 Park Ave wheel cover problem
Rear toe in on 1996 Park Avenue
Seeking 97-05 Park Ave owners in Socal~
Brake lines. Bubble flare. Help me!
'97 PA Hesitation When Cold and Delayed Shift
92er PA eats ignition coils
95 buick park avenue battery dead
Trouble with touch up spray
Keyless Programming 92-95 HOW TO
Amount of oil in a 3.8 (1997 PA)
1997 PA Window Problem Revisited
Question about the vin number
Help Low Oil Pressure
94 PAU Bug Deflector w/ screen question
94 Ultra Tire question
RPO Codes
94 Ultra Hesitation/Alt
change fuel injector
on star
1997 PA Ultra
Transmission Problems?
my 1995 buick park ave drivers power seat will not work
1997 Park Avenue A/C only BLOWS on ONE SIDE???
Is Bosch to blame?
Transmission pan gasket sealing
Bearing noise on 91 PA
Park Ave. ABS control Module
Getting to VATS connector
Radiator cap pressures. 7 lbs ok?
88 PA fusebox location?
ECM for Buick Park Avenue
94 PA Trunk Motor
1988 Park Ave Air Ride
Stabilizer bar/control arm linkage
94 Regal dies without warning and does not start/95 LeSabre dies without warning II
Cupping of tires? tie rods or just bad tires?
Front strut ?
JaxJag
tensioner replacement
power steering pump question
Recharging AC for 92 PA
Latest year radiator possible for 92 PA
Window alignment tips
'91 Fuel line problem?
Oil pan exposes connecting rods?
98 PA dash removal Gas hand jumped peg
needs performance\style assistance
Dash shaking when fan is on
PCM schematics
1998 Park Avenue A/C quit
Automatic won't use 4th gear. =[
Vacuum reservoir leaks on 95 park ave causes vacuum leaks
Transmission mount 97 PA
AIR CONDITIONING LbEAKS INSIDE CAR
AC Question
Alternate Oil Filter for 1996 PA
Draining Fuel tank on '89
Voltage problem - Belt tension?
Oil changing tip
94 Ultra's gotta shake at 50 to 60 mph
Pic of Datalink on 1996 PA. Terminal #s??
1997 Park Avenue traction control and Anti locks brakes
Aftermarket Stereo's
1994 Ultra catalytic converter question
Steering wheel control wire question
Remote Entry/Security ?
Flushing Brake Fluid in 1996 PA
AC Compressor is bad...
1996 Park Ave - Problem w/ Power Seat, Interior lights
Owners Manual for 1996 Park Avenue?
Fan motor
Using factory and custom remotes?
97 PA Brake Job Help
Circuit Breaker 3 Seat power 94'Ultra FIX
99 Park Ave. coolant in No.1 cyl
Where to find a new ELC sensor?
'97 Ultra no tach revisted
92 climate control
Rear bumper crome on Ultra
1997 Park Avenue Radio
Steps in changing A/C compressor clutch Help!!
Park Avenue does 220mph??
Will not run correctly
Oil leak on my 97 pa
98 tune up ?
95 Park Ave herky-Jerky solved?
94' Park Ultra Water PUMP
Supercharger question
Engine Sludge
1997 Park Avenue Starting Hard
Supercharger pulley replacement
87 Park Avenue...what can i do with this?
Headlights/dashlights flicker
'89 Electra T-Type Synthetic oil?
96 Park Ave-Alarm keeps going off
93 trans drain plug
Installing new turn signal cam
Rpm idle is to low
1986 window regulator guide
Aftermarket keyless entry questions
Programming Instructions for Remote
85' Park Avenue...opinion needed
Installin door Speakers
91 PAU mixed gas in oil pan
92 PAU Trouble Codes
Need help pulling codes please...
oil filter
help on installing 6x9 speakers in 83 electra park avenue
93 PA.. Won't start
1988 Cruise Control
92 Park Avenue Ultra Struts
Just bought a 92 PA Ultra
1997 PA Regular Stock Radio
2001 parkave turn signal switch problem.help
Can u guys HELP supercharge my Lesabre?
94 PA Dash Lights
Reving engine
91 PAU not starting
No mix control and drivers side.
1978 Buick Park Avenue - charging/wiring problem
1994 Buick Park Ave
change oil soon
95 park ave no start
Starting problems
98 PA windshield blade won't back to home position
Radiator
Fuel sending unit/ pump question
99 PA ULTRA Supercharger
National Quick Start Iceberg Alternator?
Is the HVAC programmer sold outside the dealer? 95 PA
91 PA check engine but no codes
Security light stays on 95 PA
Brake line
Exhaust leak the culprit?
1988 buick p[ark avenue problems
91 Buick Electrical -Schematic/ESM
Advice on s*lling my problematical PA Ultra
Review mirror ready to fall off?
Climate Control
What all have you done to your Park Avenue?
fuel cap door '86 park ave
95 PA check engine light
2000PA Intermittent power loss/warning messages
Transmisson Shifting Problem
lesabre - seats
Diagnosing herky jerky problem with NemiSys scan tool
91 Buick Park Ave Shuts off and comes back on while driving
What an awesome site!
Vehicle speed sensor?
Factors affecting FI pulse width, 95 PA Ultra
92 Park Avenue tranny issues.
Doesn't seem like I have power brakes any more
Ye Old Dreaded Upper Manifold Plenum (3800 Series II)
1989 Electra T-Type Trouble Codes 22 & 41
1999 PA - Not hearing the supercharger "Whine"
92 Park runs rough when hot
1995 Buick Park Ave. Ultra...cannot Find Starter!!!
92 Park Avenue rough idle/popping through exhaust
Voltage problem
99 Park Ave Ultra stalling and cutting off....What's wrong??
remote transmitter diagram
Ignition coil questions
Regular Gas OK in an Ultra?
Help.. Power loss to fuel pump!
GM Canada being sued over engine gaskets
1994 PASC 60,000 miles
97PA - TCC Lockup Converter
99 Park ave ultra.......odor?
Series II swap into a 92 Park Avenue
Vacuum tank question
Will new alarm system allow me to remote open my doors.
92 PA Ultra Running Very Rich
confused with 2 things 91 PA
91 PA Rear Bearings
95 PA and stalling
1997 PA Rain Sensing Wipers
97 pa ultra bad motor mounts which one
89 Vin C DS halfshaft removal problems :(
1993 PA-Buick trunk wont fully close.
Trunk will not fully close.
vibration on 94 park avenue
Park Ave Wont Go Into Pak
1997 Park Avenue AC Compressor
97 pa trans fluid change...
Can not open hood on 91 PA!
1989 PA 3.8L misfire : ignition coil pin-out schematic?
Web
AF
