View Full Version : Park Avenue
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. Speed Sensor
  2. 1996 Buick Park Avenue question
  3. 97 park avenue ultra service engine liter came on
  4. 91 Prk Ave Abs Lite On Continually
  5. Belt tensioner...97 PA
  6. 92 PA ultra
  7. Spongy Brakes in '95 PA
  8. Cigarette Lighter Fuse Location
  9. Front break rotors warping
  10. Questions about rear suspension (air mainly)
  11. Gremlins messing with the horn...
  12. engine vibrations
  13. ABS ! and traction off stay on
  14. Park Ave Power Steering LOOSE
  15. Interior Lights Stay On.... 2000 PA
  16. PA electrical problem
  17. 95 Park Ave No a/c on passenger side, no heat on driver side
  18. 97 PA - New trans Installed now Steering Wheel off center
  19. Spark Plug Change Tools
  20. 2001 Pa
  21. 2000 PA Presidential
  22. 97 PA driver's side seat
  23. Buick Park Avenue 1992 Auto Dimming Mirror Wiring Information
  24. PA 92 doens't fire all cylinders
  25. 93 parkave driving by itself
  26. 1999 PA Base Upgrade to Concert Sound III
  27. Park Ave Info please
  28. Park avenue questions
  29. Gone!
  30. '93 PA won't start after I "fixed" it...help b4 wife kills me!
  31. 93 PA upper intake manifold question
  32. What problems? 2000 Ultra
  33. No brake lights or turn signals
  34. 03 Ultra Needs 22s
  35. Fuel Door Switch Wont Work!!!
  36. Trunk problem
  37. AC clutch continously cycling on/off 95 Park Ave.?
  38. 91 PA Climate Control Display ?
  39. Lock ring in the way!
  40. 97 Park Ave. Tranny Mount Help.
  41. Bad Computer?
  42. 1991 park avenue dies at red light / low idle
  43. 1993 parkave ultra no heat through vents
  44. Reset tire pressure error ULTRA 2000 TIP.
  45. Ultra 2000 Seat floor trim removal?
  46. Oil pick-up tube/ screen cleaning or replacement?
  47. 97 park avenue power seat problems HELP!!
  48. 1988 Park Avenue Won't Start
  49. Plenum & Lower Intake Replacement tips 3800 V6
  50. Picture of old Lower Intake Gasket 3800 Series II
  51. No power on drivers seat...
  52. 86 Park 3.8L Service Engine Soon Light Flicks
  53. 92 PA Heater/Floor/Windshield Control???
  54. Installing a aftermarket radio in 91 PA...
  55. 94 PAU checking engine codes question
  56. Intake Plenum Replacement Question
  57. Problem with speakers
  58. 97' PA fuel pump or fuel pump relay????
  59. wich green wire
  60. Oil pressure... falling off
  61. 91 PAU back doors won't open
  62. After market stereo
  63. Struts and shocks changed.....
  64. Is repair estimate reasonable? (to fix pcs solenoid)
  65. 1997 Park Ave - Noise from Vents
  66. 92 Park Avenue ultra
  67. 89 Park Avenue Electronic Dashboard Problems
  68. 91PA hard miss on acceleration
  69. 1997 Park Ave Fuel Gauge gone nuts
  70. Duplicate Window Sticker
  71. 1999 PA GM/Delco Radio Swap
  72. 1999 PA New Owner Mission of Discovery
  73. Headlight Sensor 1999 PA Base Model
  74. Power Steering Cooler (and other problems)
  75. 1997 pa both front windows go down slow
  76. Another climate control question
  77. 1996 Buick Park Avenue 3.8L * Non Ultra *
  78. Fuel line leaking. How do I replace it?
  79. Fuel-Door Spring?
  80. MY PA has several issues
  81. RADIOs FAILED Need Replacement
  82. 99 Park Ave rear defogger stopped working...
  83. What's the difference between 41-902 plugs & ...
  84. one more rear shock question...
  85. 94 Buick PAU Not Starting, Cranks and Then Does Not.
  86. Problems in '95 PA after installation of CD player
  87. New Struts (read the old posts, still have questions)
  88. Alternator Belt loose on Park Avenue
  89. Changing struts:
  90. 1999 PA Heads Up Display
  91. Engine loping
  92. Turn signals dont work
  93. 92 Buick PA- Light Monitor Flashes
  94. climate control display
  95. Trouble with my Park Ave.
  96. 93 PA PCV Valve
  97. Starts but let go of gas pedal and shuts off.
  98. 90 park ave cam sensor magnet
  99. Window Washer issue on 92 Park Ave
  100. Power window problem on a 92 park avenue
  101. Huge Problem... Moronic Solution
  102. Interior Cracks and Krinkles.
  103. 95 Park Avenue Cruise Control Problems
  104. Radiator Cap
  105. Engine mount bolts
  106. 1996 Park Avenue Power Steering
  107. '92 PA "Service Engine" Goes On Briefly
  108. 91 park ave. no start..
  109. 1999 Park Avenue driver's seat motor
  110. 1997 Park Avenue Driver's side seat
  111. HELP! lossing all my water!
  112. coolant temp sensor
  113. 97 PA driver's side window
  114. 99 PA sunroof problem
  115. code 41
  116. Regular Unleaded OK in 1999 PA Ultra?
  117. 92 PAU stalls while driving
  118. Larger wheels and tires...
  119. 89 Buick Park Ave
  120. considering buying a 1997 park ave. ultra
  121. 92 PAU Water Leak
  122. Gauge reading questions...
  123. 97 PA PO507 Code
  124. Park Ave Lower intake gasket problem ?
  125. Monroe quickstrut?
  126. remote transmitter
  127. 1992 PA car alarm question
  128. 94 park ave dying
  129. Recent Improvements... Need help.
  130. Exhaust dent: affecting power?
  131. Transmission Fluid Additive
  132. Problem with the digital cluster PA 1987
  133. 97 PA Front Wheel Groan
  134. 95 Park Ave wet floor
  135. exhaust tips and tricks??
  136. 93 PAU surges
  137. new wheels
  138. 1999 Park Avenue Ultra Radio
  139. Installing Aftermarket Steering Wheel
  140. Just got a 95' Park Ave. Have a few questions.
  141. Passenger side-view mirror
  142. this car is a pain in the a*#
  143. 94 pa rough idle
  144. bad brakes
  145. Two Questions
  146. the pics
  147. 91 Park Ave won't even try to start
  148. Loose Steering
  149. Bad wheel bearing or CV joint?
  150. electirc front struts
  151. 97 PA...Winter Snow=No TCS/ABS
  152. 1993 PA Steering Woes
  153. 2001 Park Avenue: Screwed
  154. 1997 Park Avenue Gas Filler Door / dash lights
  155. Question on stock radio
  156. 1989 Electra Park Avenue tranny issues?
  157. Where is the heater core in a 92 PA
  158. 91 PA Climate Control Trouble
  159. Head-up Display
  160. 96 Park Avenue Weird Heater Problem!
  161. Help install rear deck speakers - 99 PA
  162. Weird noise too
  163. New Member: 2001 Park Avenue
  164. Drilling Strut Tower: Normal or Not?
  165. 3.8 buick exhaust manifolds
  166. 96 PA misfire problems
  167. 1996 Buick Park Avenue question
  168. '85 Park Avenue, Drum Wheel Cylinder
  169. 1997 PA--Cellular Phone Readiness Pkg.
  170. 97 pa strut/shock replacement
  171. Help the newbie pls.
  172. '94 PA Battery Discharge
  173. Idle issues at start up on a 94 Ultra
  174. '99 PAU Sound System
  175. 95 Park Avenue stalls when windows or doors are activated
  176. 02 PA-Dual Digital Heat/Air Blower
  177. Crank position sensor
  178. 1998 Park Avenue trunk leak solved
  179. Looking 4 a shop manual for my 98 park avenue ultra
  180. please help hood cable broke
  181. Please help with my annoying sqeal
  182. Intake manifold reversable
  183. Shop Manual
  184. 98 Buick Park Ave Ultra
  185. '92 PA no heat thru vents
  186. 1995 Buick Park Ave - No Start - Electrical? HELP
  187. Code 49
  188. New struts - horrible ride
  189. Wrecking yard/salvage yard
  190. air bag cover
  191. Weird noise
  192. Rear suspension problem on 92 park avenue, urgent help needed.
  193. 94 PA is dead
  194. 97 PA speakers,tranny,and a/c, intake tube.
  195. What is this???? Please Help!
  196. 99 PA side mirror no heat/driver seat not raising
  197. 98 PA Front Passenger Side Seat Belt
  198. My 99 PAU needs help. Can you help us please?
  199. 2000 Park Ave. rear defrost
  200. Buick Park Avenue 1993 rear window defogger
  201. 91' Code 41 - Cam Sensor
  202. 92 PAU Power Locks
  203. 1992 PA - Harmonic Balancer Question
  204. 92 PAU Suspension???
  205. Interior Lights - New twist to the problem
  206. Possible Supercharger Air Leak
  207. TSP Adjustment
  208. New Owner of a 1992 PAU SC ~ Great Forum!
  209. 91 PAU alarm
  210. Interior Lights
  211. 1998 PA - Low Tire Pressure Message
  212. Outside Temp Sensor
  213. 98 Pa
  214. Super Charging a L27
  215. The dam thing is fixed...almost
  216. Interesting Find
  217. Water pump gasket leak
  218. 91 park ave vent removal
  219. abs light will not go out
  220. 1997 Buick Park AVenue Ultra- Coolant low / leak
  221. '91 PA Driver's Door Panel
  222. 1991 pa radio upgrade
  223. park avenue interior lights
  224. just for fun
  225. Anyone have a Park Avenue in the 13s?
  226. brakes
  227. '91 PA Acceleration
  228. A question to PA Ultra owners and enthusiasts
  229. Posting in Closed or Outdated Threads
  230. Re: 92 PAU engine probs???
  231. Where do I shop online for GM parts for less money?
  232. 94 Ultra - Paint color code for touch-up
  233. How much supercharger oil?
  234. Starter / Ignition Issue Please Help
  235. 91 PA can't shift out of park
  236. 99 Park Ave rear defrost...
  237. 94 Ultra - Idle is misbehaving
  238. 1998 Buick Park Ultra needs spicing up
  239. 92 Buick Park Ave- ABS Light
  240. 91 PA speedometer crazy
  241. new member with 91 PA troublecodes
  242. 94 Ultra Fuel pressure regulator replacement
  243. car wont go past 35mph !!!
  244. Gm 3800 3.8l Upper Intake And Plenum 3.8 Repair Kit
  245. 89 P/A - Where is the fuse box located?
  246. popping when put in or out of park
  247. Levelers + engine dying
  248. 94 Ultra exhaust smoke
  249. 94 Ultra exhaust question
  250. Power antenna adapters finally available!
