View Full Version : Park Avenue
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12
  1. 1995 Buick Park Avenue heat issues
  2. '97 Buick Park Avenue fuel sender wrench
  3. 1991 Buick Park Avenue - HVAC Controls Dead
  4. 94 Ignition Coil problems
  5. fuel filter location and repair
  6. KYB Struts
  7. Tires
  8. 1992 PA Will not start when hot DTC 17
  9. not starting
  10. 1989 buick. door switch
  11. 93 PA ABS Brake bleeding
  12. 1997 PA Quandry help please
  13. 1995 Just Dies
  14. 1999 Base - Play in Front Wheel
  15. 95 PA ultra a/c fan don't work
  16. Partial power failure
  17. Timing Chain
  18. Checking for vacuum leaks!
  19. 1995 Park Avenue Fuel problem.
  20. 94 Pa Help Needed!
  21. 1997 park ave ultra driver door module
  22. 1988 HVAC Air Vent Problem - HotZ28 or Anyone?
  23. 1998 Buick PA Ultra Smooth Idler Removal Help Needed
  24. 99 PA 3.8L crankshaft removal...
  25. Leather map pocket
  26. 1995 Park Avenue Battery light
  27. Noisy Bearing - Supercharged
  28. Help - '89 Park Avenue HVAC
  29. whats up with my buick? SOLVE THIS ONE!
  30. Excessive idle speed '92 PA
  31. 98 PA trunk/key ?'s
  32. MPG increase
  33. 1996 Buick Park Avenue Question
  34. 2000 Park Avenue Driver Seat Back Removal
  35. Rear shocks for 1998 with touring suspension
  36. Park Avenue AC Control Issue
  37. 98 Buick PA - 3.8L Series II - Driveablility Issue
  38. 92 P/A Ultra
  39. supercharger removal 94 ultra
  40. 94 pa high idle,lack of power.
  41. Help with Keyless entry programming
  42. Low Coolant light question:
  43. 94 PA climate Control problems
  44. 91 PA Ext Temp
  45. 2001 OEM Rear Strut Part Numbers
  46. Half shaft to transmission leak
  47. Leather argument
  48. dies after 15 min
  49. Starting Problem with 1996 Park Avenue
  50. 98 park ave ultra heater problems
  51. Gear shift indicator
  52. 91 Buick Park Ave info on fuses and relays
  53. 97 park avenue doos dont open from outside
  54. Torque damper
  55. Help program new transmitter 05 Ultra
  56. Transmission will not engage in any gear
  57. upgraded to heated seat
  58. 1987 Buick Park Ave Flickering Lights?
  59. 1991 Buick Park Avenue Heater A/C Control Problem
  60. a/c problem
  61. Bypassing the heater core
  62. 3.8 lesabre motor in a 1985 pa
  63. 1990 park
  64. 94 buick pa remote help
  65. 91 PA - Several questions
  66. 98PA AC Hot drive side cold pass side
  67. Misfire/rough idle
  68. 95 Buick Park Ave
  69. 1996 front "mini-radiator", engine or transmission oil cooler?
  70. 1998 Park Ave no start
  71. Missing sensor connector harness
  72. 98PA unknown driver code and car will not start
  73. 1996 Buick Park Avenue Question
  74. spark plugs
  75. 92PAve/Ultra/3800/Super/150k-stalls and won' start
  76. 97 PA windshield washer motor/pump
  77. 97 PA Driver's side air conditioning
  78. 98PA airstrut or gas shock
  79. Power Steering Pump Pulley 97 Park Ave
  80. 91 PA not charging, urgent!
  81. 1996 Park avenue Ultra airbag interchange
  82. 96 park avenue fuel pump relay location
  83. 91 PA keeps dieing
  84. 93 supercharged timing chain cover
  85. Help! 94 PA Electrical problems?
  86. 1996 Park ave water pump
  87. 91 Park Avenue Trunk Pulldown
  88. 92 PA - low on AC Refrigerant
  89. Climate control back lights. Accessible?
  90. 96 Parkavenue Rough Idle
  91. 96 Parkavenue questions
  92. HELP 91 p.a. codes 16,23,21,43,68.etc.
  93. 95 Park Ave Power Antenna
  94. 94 Buick Pa "motor Boat Sound"
  95. radio will not turn off
  96. Air intake
  97. Identifying ECM in 91 PA
  98. 04 power seat control problem
  99. 1996 Park Ave. front fender question
  100. Interior-Parts-Swap
  101. 92 Buick died at idle
  102. Park Avenue Forums?
  103. Tensioner pulley bracket gone bad?
  104. 92 Park Headlights won't come on
  105. 91 stalls...
  106. series 1 PAU module/computer question
  107. 1996 Buick Park Avenue Question
  108. 1995 buick park avenue
  109. 98 ultra a/c glitch/problem
  110. TOWING Question 1998 Park Avenue ULTRA
  111. 92 PA Engine dies on highway
  112. 99 Ultra tire question
  113. 98 PA ULTRA Weird Sound Trans or Supercharger?
  114. Still Starting Problem 90 Pa
  115. DIC Messages 1997 PA
  116. 97 PA-Driver Power Window and Window Lock
  117. Map Sensor for 1996 Park Avenue
  118. 91 PA loose power with hot temperature
  119. 97 Park Avenue 3800 oil leak
  120. Code 22/34 PA 1993
  121. Class Action Lawsuit- Gm 3600 Leaking Coolant
  122. Mysterious Warning Bells 98 PA - ???
  123. 93 PA "change oil soon" light
  124. Scanner Recommendations?
  125. 1997 PA Frustrating Issue, bad timing on this
  126. 99 Ultra Dash question
  127. bad engine rattle series 1 S/C
  128. Please help me how to replace the 1997 Park Ave outside Drivers Side Door Handle
  129. 96 park avenue radio help
  130. 1987 Park Ave 3.8 V6 FI Trouble starting & Check engine
  131. The 55mph stall?
  132. Help! 1991 Buick PA with nonfireing number 3 cylender.
  133. 1997 Park Ave Drivers Side Door Handle
  134. 1996 Park Avenue Loses Power While Running
  135. PA-PAU Tranny Swap?
  136. park aveue 1994
  137. DTC Codes Message Interpretation?
  138. 94 PA Climate Control Sys.
  139. Help! Water Pump 93 Park Ave Ultra w/SC
  140. Door locks and power antenna not working??
  141. Looking for 1999 Park Avenue Driver's Seat Motor
  142. whats the best way to wire subs in a 96'?
  143. 94 PA starts and dies
  144. Hot Rod Buick
  145. Engine swap- is there an ECU change too?
  146. Loud Roaring
  147. Service engine soon light
  148. Another 90 PA Starting Prob?
  149. 1996 Buick Park Avenue Question
  150. Fuse or breader for Power door locks??
  151. Fuel Gauge Faults When Battery Disconnected
  152. 99 Ultra Struts
  153. 99 Ultra Drivers Door
  154. Rear suspension problem
  155. Pop Pop Pop
  156. A/c
  157. When the AC clutch engages, hear and feel a shudder for a second or two?
  158. park ave 93
  159. 91 PAU starting problem
  160. Help with keyless entry (96)
  161. 91 PA Ultra Rack and Pinion Replacement
  162. 93 PAU Won't Start - What Else Can I Try?
  163. '93 PAU cradle bolt washers rusted out
  164. Manually Adjust dead power seat?
  165. Quad Driver module and suspension
  166. Water leak/Paint Code
  167. '90 PA error code 13, runs very rich!!
  168. Starting Problems in a 90 PA
  169. My OnStar is going away...any remedies?
  170. Rear Shocks for a 99 Park Avenue
  171. Computer swap
  172. Overcharged?
  173. Water every were!!
  174. Rear Shocks on a 91 PA
  175. Need Advice
  176. 99 PA radiator install...
  177. 98 PA Starter Woes
  178. O2 Sensor / service light
  179. My Park Avenue thinks it's a diesel ???
  180. Airbag Interchangeability?
  181. CV Nut size
  182. When shifts into OD hear/feel a shudder or clunk, 95 PA
  183. Service Engine Light is Evil!
  184. 97 PA - Cassette tape stuck in radio
  185. Crankshaft Position Sensor 1997 PA
  186. Will our 96 PA Ultra go to 250k miles ?? (130k now)
  187. Buick Transmission Swap
  188. More TPS on 91 PA
  189. Programming Instructions for Remote
  190. Buying 98 PA Ultra
  191. 02 Buick Park Ave - A/C Water on Floor
  192. Stuck Accelerator(Idle)
  193. Driver Seat Repair Estimate-Ripoff?
  194. P/A tie rod end replacement
  195. 88 park ave.
  196. 86 pa ..wont stay running
  197. TPS on a 91 Park Avenue
  198. 1988 Power Seat Wiring Diagram
  199. How do I remove the crank pulley/balancer? (1992)
  200. 94 PA A/C vent problem
  201. 94 PA radio problem
  202. Starter problem?
  203. Heater core problem?
  204. 1991 P-A Sporadic No-Crank
  205. 97 P/a Hard Up Shifts
  206. Fuel Pump???
  207. 2001 PA DIC programming
  208. Front Strut Recommendation
  209. 97 park ave vacumn build up in motor
  210. 2001 Park Avenue IAC screw
  211. 1989 Buick Park Avenue Service Engine Soon Light
  212. Holden's WM goes to China as a Buick
  213. 1989 Buick Park Avenue Memory Seats
  214. 1989 Buick Park Avenue Opera or Coach Lamps
  215. 1989 Buick Park Avenue Twilight Sentinel
  216. 1989 Buick Park Avenue Remote Keyless Entry
  217. 1996 Buick ParkAvenue Exhuast Question
  218. Wheel Locking Up (ABS Light ON)
  219. Drivers Side, Outside Door Handle
  220. 1995 Buick PA key in ignition chime
  221. Voltage drop issues on a 94 Ultra when stopping
  222. 2002 PA Squeaky dash
  223. 91 pau spearkers no sound
  224. 1999 PA Ultra Tire Pressure and Oil Condition
  225. Vacuum pressure and fuel pressure questions
  226. 95 Park Ave + Mercedes Supercharger?
  227. New PA Ultra 2000 Owner
  228. turning signal
  229. tired tachometer
  230. 2001 Park Avenue Front Seats
  231. 1997 park ave ultra jerks
  232. Climate Control -Acctuator Question
  233. 94 PA Tranny Replacement
  234. 98 Programming Disaster -- Trunk Problems
  235. 01 park right front strut noise,
  236. New 94 PA Owner- need help with Dynaride
  237. Cabin Filter Recommendation Needed
  238. erratic misfire?
  239. How does this work?
  240. Passenger Climate Control 95 Park Ave
  241. 98 Programming Remotes
  242. cannot program new transimitter for my PA
  243. 1998 Check Engine Light
  244. PA 1994 - ODB, ODB 1.5 or ODB-2?
  245. Crankshaft Position Sensor
  246. mount diagnosis?
  247. Spark Plug Consensus
  248. 99 park avenue keyless entry key fob
  249. 1997 Park Ave Noise from Strut Tower (solution)
  250. Setting Memory Seats
