View Full Version : Park Avenue
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12
  1. PCV valve problem-96 Park Avenue
  2. 92 PA miss when cold under 1500 RPM
  3. 96 P.A. repair maual and parts list non supercharger
  4. PCV Valve location on 96 P.A.
  5. Re: 1988 P.A. Tune-up & A/C problem
  6. brake help
  7. 94 Sputtering Problems over 50MPH Runs Rough, Hot
  8. Beautiful 96 Buick Park Ave P0102 Code plus few other problems
  9. 93 Buick PA Ultra glove box lock cylinder removal
  10. Buick Park Avenue /Electrical
  11. whats the differance between supercharged 3800 and a NA
  12. 94 Buick P.A. tune up
  13. Pictures
  14. 01 park ave keyless entry
  15. Squeaky Alternator
  16. 1997 Park Avenue Fuel Gauge
  17. quick tech questions 01 buick pa
  18. 95 PA starting & sputtering problem
  19. 1996 Park Avenue Climate Control
  20. 94 Park Avenue dying
  21. 91 PA Crank Position Sensor gap
  22. 1994 Park Ave Ultra Keyless/dome light problem
  23. Keyless entry ?
  24. Rear Passenger seat vanity mirrors
  25. Replacing my 96 PA heater core
  26. 95 Base Transmission noise when shifts to 3rd?
  27. 1995 Buick Park Ave Electrical - Engine cutting off
  28. 88 park ave
  29. rotor?
  30. sluggish turn signals
  31. Climate Control Display
  32. abs light help needed
  33. Change Oil Soon Light
  34. 89 buick park avenue/ Starter fuseable link?
  35. 91 Park Ave Question
  36. 91 PA a/c driving me nuts
  37. Oil change question
  38. 91 PA A/C compressor seal leak - PW driver side inop
  39. 1999 park avenue supercharger idler pully
  40. 92 Park Avenue Blower Fan & No Start
  41. 88 buick park ave.
  42. 96 fuel pump control module
  43. radiator fan
  44. PA Vacuum Question
  45. 93 Buick Ultra dash trim
  46. Where can I get these parts?
  47. 97 A/C problem
  48. 97 PA electrical problems SOLVED
  49. A/C on the Fritz, Please help
  50. Best Gas
  51. Shaking while Braking
  52. 91 Park Ave Hard Start
  53. 1990 Buick Park Ave Keyless Entry Programming
  54. 97 PA idle problem
  55. Park avenue climate control flashing
  56. 94 park ave stalls while driving
  57. Seeking Eaton Supercharger M62 (or OEM/aftermarket)/rebuild
  58. little light by the alt guage 94 PA
  59. 99 PA Ultra Daytime Running Lights/High Beams
  60. 92 Park Ave
  61. 89 Park Avenue Rear Shock Replacement- Yikes
  62. 1998 park ave. rear suspension 2 full
  63. Oil pressure 97 PA
  64. 97 PA tire pressure warning
  65. 97 PA starting Issues
  66. 97 Park Avenue Driver Power Window Motor Replacement
  67. License plate lights removal...
  68. 1995 PA Seat Control/Window Lights
  69. 97 PA Trans kickdown
  70. 97PA voltage drop
  71. 94 PAU Intake Manifold Bolts
  72. 92 Buick Park Ave
  73. Alternator question
  74. 2003 Ultra Stability Question
  75. Repair/replace heated seats
  76. Mystery Radio Code
  77. 1996 Park Avenue air mix actuator
  78. Fuel rail removal
  79. 1995 PA Electrical Problems
  80. 97 PA What Changes?
  81. 1989 Buick Park Avenue starting problem?
  82. 97 PA Hums and Buzzes
  83. 95 park avenue starts but wont run.
  84. 1989 Buick Electra Park Ave T-Type Timing Chain Cover
  85. A/C question
  86. keyless remote fob programming
  87. 96 PA stalling problem
  88. 95 PA base radio swap
  89. Help with power seat
  90. 94 PA Turns Off When Hot Outside
  91. Vatts bypass
  92. Fuel injector question
  93. Engine infreq stalls code p0102 and p0300
  94. Engine light and infrequent stalling
  95. Engine stalls
  96. 91 PA starts when cold
  97. Lower Intake gasket Torque specs.
  98. 96 PA - Noise from the passenger side
  99. 1999 Park Ave homelink wiring questions
  100. Buick Fuel and temp gauge fix
  101. 1997 Buick park avenue - windows and door locks will not work
  102. Transmission issues - 2001 PA
  103. Weird lighting issue on '97 Park Avenue
  104. '97 Park Avenue - passenger heat goes cold then hot then cold, etc.
  105. 96 Park Avenue transmission filter seal
  106. what is this?
  107. 92 PA intermittent starting problem
  108. Intake manifold hose connector snapped
  109. 1993 park avenue horn
  110. 2003 Park Ave Ultra Grill
  111. 91 buick Starter Enable Relay
  112. 91 Buick Scanner Codes
  113. '92 Park Avenue Ultra with SES Code 57
  114. 91 Buick Park Ave Wont turn Over
  115. Got the new front struts on the 01' PA
  116. 99 Park Ave engine is racing
  117. 97 buick park avenue no radio, door locks, sunroof, or daytime running lights
  118. 94 PA, Dash Brake Light on, feels like no power assist
  119. left turn signal steady on
  120. Darn ABS/Traction control light intermittent...
  121. Buick Park Avenue Lights Keep coming on
  122. 1991 Buick Parkave Lugnut Size
  123. 97 Park Ave electrical problems- FRUSTRATED
  124. HELP! Intrument Cluster Lights Went Out!
  125. Trans Fluid Question - Dextron VI
  126. The '92 Park Avenue Ultra Acceleration Blues
  127. 97' PA Oxygen sensor/s location/s
  128. Water noise when it rains
  129. 1999 Park Ave Ultra Door Panel Removal
  130. 1991 park ave
  131. help with water pump
  132. 95 Buick PA falls off at higher speeds
  133. 1995 Park Ave early upshift, poor mileage?
  134. 97 PA Cooling Issue
  135. PAU '94 loses idle at times
  136. Any specialized tools needed
  137. 97 Park Ave Ultra - shf
  138. 1995 PA Stall/No start & repair?
  139. 92 Park Avenue won't start & security light flashes
  140. No Heat 97 Park Ave
  141. It just died!
  142. 92 park ave / heater
  143. 98 PA low oil pressure
  144. Removing Shift Knob?
  145. 89 Buick Electra/Park Avenue Valve Cover Bolts
  146. 1997 Park Avenue Belt Change
  147. 93 Park Avenue power seat, power mirror, and power lock
  148. coolant loss=head gasket?? and more q's
  149. 94 PA: Battery being drained by Lighting Monitor Module?
  150. Need some advice...
  151. Humming noise from the front end
  152. 91 Buick PA Ultra - Parts questions
  153. 91 PA Backfiring and No Power
  154. '91 Buick Park Avenue - Blower Motor?
  155. Temp gauge shows 0 all times
  156. 1998 park avenue ultra
  157. Flickering lights, battery dead
  158. Help needed on 91 PA: Service Engine Soon, Error Code 41
  159. Help needed on a 91 PA: central locking system & remote control
  160. Help needed on a 91 PA: Safety Light
  161. New to Buick and this Forum, some help please..
  162. '03 ultra, coolant loss, ticking, and ping?
  163. Intake Manifold destroyed-replacing it
  164. 95 Park Avenue Horn
  165. 98 PA flickering headlights with clicking sound in dashboard
  166. 90 PA emissions problem? Maybe?
  167. 95 buick park avenue need diredtion to program keyless remote
  168. Help with 91 PA
  169. 1989 Buick Electra/Park Avenue Hard to start/runs funny initially.
  170. 97 P/A a/c ?
  171. 2001 Buick Park Avenue Rear Defrost Issue
  172. 1997 traction, ABS lights, Accident Pics
  173. Blower module
  174. Broken Instrument Panel. 91 Buick PA
  175. Replacing starter on 1994 park avenue
  176. 97P/A a/c stop blowing cold air
  177. Noise after installing the new transmission, PA Ultra '99
  178. A/C & inside lamps STOP WORKING
  179. Hi i'm new. I have a 92 buick PA that will turn over but not start.
  180. 96 parky power steering pump help
  181. No Lowbeam Headlights?????
  182. Park Avenue 92, Water through the sunroof
  183. Key with Diode? '91 Park Ave.
  184. 94 PA Cutting Out
  185. 97 Park Avenue oil pressure
  186. Brake groan
  187. 1988 park ave. engine light on
  188. Headlight flicker
  189. PA cutting out when driving
  190. Alternator?
  191. 1995 3.8l v6 wont run
  192. No Heat Out Of The Drivers Vents
  193. 94 PA Blower Control Module & fan speed
  194. Horn sometimes works on 93 PA
  195. oem key fob part number
  196. 2002 Park Avenue front end vibration
  197. ELC-3 year mystery finally solved!
  198. 2000 Pa Climate Contol On Steering Wheel
  199. park avenue door ajar light
  200. SOMEBODY HELP!!!!!!!! Park Avenue won't start
  201. After market radio installation
  202. 91 pa starts then dies codes 31,34,62
  203. 1994 Buick PA- Security light stays on
  204. Lamp Monitor - how does it work?
  205. 2003 Ultra Electrical Problem
  206. 95 PA Alarm problem
  207. Exterior finish on a '94 Park Avenue.
  208. the sometime non-starter
  209. Car accident (Q about cost to fix)
  210. Engine revs to 2000 rpm in park at start-up
  211. PA 1999 -Incorrect temperature Display
  212. where is the headlight module
  213. 94 park ave ultra obd codes?????
  214. 1992 Park Avenue door locks
  215. 91 PA Poor acceleration
  216. newbe
  217. tcc always commanded on
  218. '98 pa window regulator?
  219. 94 pa ultra horrible gas mileage help!! 8mpg
  220. 94 pa ultra tried everything i am competant to
  221. 1997 PA a/c-heat changes hot/cold
  222. Ultra 2000 Supercharger
  223. installing monroe sensatrak shocks
  224. 94 park ave ultra light show...
  225. 1997 PA Headlamp Lens Restoration/Replacement
  226. 94 buick park ave ultra wont start just clicks help
  227. 96 PA Climate Control Flashes
  228. lowering park ave.
  229. engine swap for 95 park ave.
  230. 1991 PA rear shock replacement. - air hose
  231. 95 park avenue water pump removal
  232. Rod Knock on Park '96 Avenue.
  233. 1998 Buick Park Ave Trans problem
  234. Used rear seat, where ?
  235. 1995 PA -A/C Programmer Questions.
  236. Guage Cluster - very dim
  237. Who has this beauty? OBD1 Computer with a OBD2 Interface?
  238. Security Chip
  239. 2001 Park Avenue Driver's Side Air Bag Removal
  240. 1995 - Climate Control Problems
  241. Lowest Miles for 91-95?
  242. Horn won't stop!!!
  243. 93 pa solenoid switch
  244. Heating Issue-Winter Coming-Please Help!
  245. 1999 P/A Ultra Air Conditioning Pulley
  246. 94 PA: Hesitation when accelerating
  247. Crappy headlights
  248. off track window
  249. Left side turn signals out on 97 Park Avenue
  250. 1995 Buick Park Avenue heat issues
