Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Buick
> Park Avenue |
View Full Version :
Park Avenue
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
Interior color/code?
'89 vin C code 21 and 22 and 26
Water standing in rear floor board
Re: Displaying HVAC diagnostic '97
98 park ave coolant bypass elbow
Grinding noise in my 96' PA
1996 PA power steering issues and endlink question
external temperature
Tie Rod replacement?
Re: 1997 Park Ave Drivers Side Door Handle II
1991 park avenue electric motor keeps running
horsepower
wiper blade inserts
98 PA Ultra transmission issue
97 PA soft ride suspension?
lower door seals
2000 Buick Park Avenue Leaking from Oil Level Sensor
oil plug washer.
ways to check codes on older cars.
Turn/Stop wiring
96 park ave climate control flashing
96 buick park ave ... driving me up the wall... dies when put in gear
98 PAU Multi function switch removal?
Time to replace my tires
How to program keyless entry for 1998 Buick Park Ave
1990 Park Avenue Turn Signals Not Flashing
rear window defogger
Stalling when I let up on gas pedal
93 Park Ave Ultra no heat
00 Park Avenue 6x9's Removing
Park Avenue Problems
Buick Park Avenue or a Cadillac DTS
96 Ultra Rear air struts
2001 PA Turn Signal problem
crankshaft position sensor
Disconnect Theft Alarm ? Can I do it?
RPMs Studder in 1800-2500 Range
1997 Park Avenue - Oil pressure at 129psi - sending unit
car battery terminals.
Radiator - Hairline Crack
horn pad replacement
Supercharged vs Non-Supercharged
Molded carpet for 97-04 PA's?
01..replacing license plate bulbs...
How big is my tank?
1986 Buick Park Ave Wont Start
electrical problem?
1991 PAU (non-SC) LIM Heater Core Pipe Question
a few concerns.
Replacing timing chain assembly
DC 12v power source
Remote Programming For 1995/96 Park Avenue
1992 PA - headlights and warning dash
Car won't go into gear until it warms up
99 PA Ultra misfire at acceleration
Automatic Locks when you put car in gear - wiring question
Temp control issues
93' Buick Park Ave Ultra Injector problem
Water leaking onto carpet - solution
97 PA Lights/Electrical Problem
oil cap
96 PA climate control issue
97 Park Ave Ultra power surge on ignition
totally removing vats on a 91 park ave
what to look out for
94 Buick park ave Trans Problem
Noisy Fuel Pump
Front wheel bearing assembly
heater air from front air ducts
95 PA ride leveling system??
Ultra conversion?
Fluctuating gas gage
Brakes - Dealer Vs. Muffler and Brake Stores
Bosch O2 Sensor
HELLLP! Need your Advice!
Heater Hose Routing
91 Park Ave Brake Headache
Air Pockets In Cooling System??
Re: 2000 Park Avenue Ultra - Rear Defogger
1997 PA Power Steering
Cold Air Intake and MPG???
95 won't start
Re: 1992 PA Theft Deterrent Problems - Trunk
Battery Condition, Cold Crank Amps vs Drain Test
O2 Sensors - 1999 Park Avenue Ultra
1999 Park Avenue Ultra - Magnasteer
Just picked up a 96 PA
95 Park Ave Rear Air Strut Replacement
98 Park Ave. Procedure for Changing Alternator
Gas Mileage 02 Sensors and Spark Plugs - Once Again
98 PA valve cover gaskets
power seats
94 buick pa radio and climate control
Rear spring compatibility
crazy automatic climate control problems (1992 PA)
Re: park avenue interior lights
1991 Performance
90 PA heater stuck on hot and in foot mode
88 PA opera lamps
1990 fails to shift out of first gear. Fuse Issue?
Gas Mileage O2 Sensors and Spark Plugs
warning lights
93 buick park ave passkey bypass
power locks.
1991 Buick P.A. ignition coil assembly! How to Check?
Fusible Link?
97 Park Avenue check vehicle soon light
Is this from the trunk pull down?
strut and shock recomendations?
95 park avenue engine or tranny
Bad ignition sw. ? 99 PA Ultra
98PA water pump
rumbling noise from speakers
Look to buy a 96' base model PA
And the cause of my hard start / low speed stall condition was.....
light bulb under the hood
Re: Water noise when it rains 11
button under the hood
overdrive problems
oil under plenum
95 Buick Park ave brake line blow out
grand touring suspension and valve adjustment
cruise control problem
Transmission going out???
91 PA won't start
Sunroof not closing properly
98 PA Noisy water pump
1999 Park Avenue Ultra Transmission Screech
1995 Park Ave Belt tensioner
supercharger oil
having some electical issues, I think my bcm might be going out?
hard idle, no power on acc. 1992 PA
airfilter question
1995 will crank but not start
Engine Hesitation after quick stop
Car jolts into gear, from park
98 ultra passenger door will not unlock
Rusted brake line replacement
94 Park Avenue transmission issues
odd radio time reset
95 Park ave a few different problems
Where is purge canister solenoid - 97 Park Ave ultra?
1998 Buick Park Avenue Ultra shudder under hard acceleration
Can a crank sensor be replaced on a '92 without the special alignment tool?
Brake ?
99 Park Avenue Ultra SC belt replacement
Live data scan tool for '92 or '93 PA's
HELP! Buick Park Avenue Bushings...
Harmonic Balancer
Best Oil?
Would anyone recommend a 2002 Park Ave?
ignition??
1999 Park Avenue Ultra Security Indicator
PAU can't idle below 950 rpm
2001 Not Starting
95 PA water Pump
Am I Dreaming?
PA Door Drain Holes?
Fuse Diagram for 1995 Buick Park Avenue?
1999 Park Avenue Ultra Difficult and Gritty Steering
1999 Park Avenue Ultra Steering/Starting/Stopping Noise (Metal to Metal)
92 Park A Ult. No Overdrive...
95 BUICK PARK AVE not running HELP symptoms inside
2002 self-leveling
'92 PAU Charcoal Canister
1995 Buick Park Avenue Just Dies - No Warning
94 Park Avenue door lock problem
Oil Leak Question
1992 Buick Park Avenue won't start - funny noise
Harmonic Balance 1993 Park Ave
No Start!!!
Wheel Covers?
Fuel related problems...
High mount brake light socket
'92 PAU with EGR valve issues
wobbly steering wheel
Problems Valve job
Knock/rattle at idle in my '93 PA
95 P.A. traction light, no overdrive
New PA owner with transmission shudder
oil pressure/ cabin air filter
engine replacement for 97 PA
External Temp Sensor vs A/C - 1999 Buick Park Avenue Ultra
code 45
1995 buick parkavenue ultra supercharged runs rough
95 buick color
my 95 buick park ave
The Great Debate
1998 buick park avenue ultra.... stalls
1988 Park Avenue Power Steering Issue
Fuel Trim ?
96 pa strut knocking
Pissed!!!Rear shocks
1997 PA Dash & Instrument lights
Help with cut off riding along
Lower Intake Manifold Replacement Questions
1989 Electra/PA Front Cover Gasket Leak after Timing set change.
Can a stock PA have the ultra supercharger installed?
trade off?
has anyone experienced this???
Buick Horn is so damn loud!!!!!!
Hard start / dies when hot.
95 Buick PA park/turn signal Lights
92 buick park ave, turn signal flasher
r-134 potential problems
2001 PA Ultra Brake Problem
A/C blows warm on Drivers side-1999 Buick Park Ave Ultra :-(
Park Avenue vs. Lumina
Electrical Problem to Fuel Pump PAU 97
Adding bass to stock system
1992 electrical issue??
89 park avenue automatic climate control dead
1992 Park Ave. Ultra unsteady idle
91 Park Ave. Won't Start After Reverse Jump Connection
Another 1988 PA A/C Problem
2003 Ultra ed. - Air conditioner problem - no air
96 park avenue low coolant warning light
rotors
'98 PA seat adjuster panel
Cassette Player error
92 PA oil issue
need help 94 pack ave
Re: Gas mileage & A/c ?
1995 Park Ave shift issue
97 PA A/C problem/noise?
92 PA, Engine Mount/Water Pump
1991 Idle/Over Drive Problems
'91 Park Ave Half shaft
Code 41? on a 91 PA
Transmission ?
92 rocker panel replacement
coil pack maintenace
1997 PAU Serpentine Belt Replacement
Blows Fuses Shortly After Installing It
A/c ?
93 park avenue charging trouble
Rocker arm pedestal bolts
1992 cam sensor error question
Park Avenue 1999 transmission bucking.
1999 buick park ave engine problems
help for a stripped bolt
Lowest Miles for 91-95? Continued.
97 PA Ultra problems!
92 parking brake light problem
Replacing mirror
Sunroof Problem
96 PA passenger door lock
96 P.A. Belt Replacement HELP, Is There A Trick To It???
tag light?
Web
AF
