View Full Version : Park Avenue
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14
  1. Quickest way to add cd changer to 1997 PA?
  2. need advice with my 91 pa
  3. Problem on my 91 PA
  4. Loss of power when hot (more problems)
  5. '94 Ultra gas gauge dips up and down, up and down...
  6. Brake Problems
  7. 95 park ave. front door speakers
  8. 91 Park Avenue TPS codes 21 and 22
  9. Door arm rest clip broken
  10. 1978 Park Avenue
  11. 0 to 60
  12. '92 Park Avenue
  13. 92 Park Avenue - smoke coming from steering column! and other tales of woe
  14. Bcm ???
  15. 1996 Buick Service
  16. Lost power while driving
  17. 1991 PA turn signals
  18. 1999 park avenue "service engine soon"
  19. Might need new engine. Whats the diffs?
  20. 00 Park Avenue performance tweeks?
  21. Tensioner Pullley
  22. 1996 Park Ave Spark plugs
  23. Radio Code
  24. Lamp Monitors
  25. Idles too high
  26. Starting problems
  27. diagnostic codes 93 prak ave.
  28. weird electrical problem
  29. Air intake housing
  30. Performance air filters...YAY or NAY
  31. Gas Grade
  32. '95 P.A. suspension
  33. Cranks but wont start!
  34. axle problem?
  35. help '89 Ultra has big problem
  36. Remote on '93 Park Ave Ultra not working
  37. 1991 PA flasher module?
  38. 92 PA will not start
  39. Keyless Entry Question
  40. BCM? PA acts like Christine!
  41. vibrations
  42. Mass Air Sensor
  43. Transmission issues?
  44. placard in trunk
  45. Trouble shifting into Park
  46. Best place to buy brake pads & rotors for 97 PA
  47. AC air flow problem
  48. Park Ave Power Mirrors/Seats
  49. Not so Dynamite a ride with Dyna Ride Suspension
  50. Need help locating keyless remote module in 1992 Park Ave.
  51. Climate Control
  52. 91 Park Ave startup issues
  53. Sooo many problems
  54. Low vacuum to vents on acceleration
  55. ignition switch
  56. power windows
  57. 89 Park Avenue
  58. trunk leak '92 PA
  59. 94 PA brake troubles
  60. '92, ticking / marble rolling sound?
  61. rough ridin PA
  62. 1994 Park Avenue - various problems
  63. 1994 park ave rear shocks
  64. Power Windows
  65. 92 Park Av Ultra alarm goes off unexpectedly
  66. Air condition trouble code..
  67. 92 Trunk Pull Down Motor
  68. 1990 Park Ave Blower Problem
  69. 94 Rear side windows
  70. Blower fan/front speakers
  71. Cant Find Code Meaning
  72. What size tools do I need?
  73. 1995 Park Ave Fuse Location
  74. 97 Ultra Brake Noise
  75. code 41 1992 park avenue
  76. 98 Park Ave Air Shocks won't go Down
  77. 2 Problems with 96 Park Ave
  78. 91 PA interior lights won't shut off
  79. 95 Park Avenue Still Won't Start Or Run HELP!!
  80. vibration caused by acceleration
  81. Transmission
  82. '89 PA door issues
  83. 95 Buick Park Avenue
  84. 95 park avenue cranks but won't run/start
  85. Coolant Leak
  86. 1993 Buick Park Ave Brake Warning Light Coming On
  87. 1997 Buick Park Eletrical Problem
  88. 92 Park Avenue Stereo wiring harness and trim kit questions
  89. Alternator removal
  90. 88 Park ave goes to high idle-wont restart
  91. 88 Park Ave goes to high idle-shut it off-wont restart
  92. love power options on '89 park
  93. My 91 PA
  94. 89 park avenue ultra with abs
  95. 91 - Check Oil light
  96. 1989 - 2 questions
  97. 93 Park Avenue-no kickdown
  98. Keyless remote problem...
  99. start problems of 89.
  100. 1991 pa keyless remote
  101. 93 Park Ave High Idle
  102. 1991 PA Help
  103. '93 PA electrical gremlins
  104. help with poor starting
  105. 98" Cruise Control Issues
  106. Help -- Electrical puzzle!?
  107. 91 A/C!!!! Help!, I'm burning up!
  108. '96 buick park avenue starting problems
  109. 3800 Park Ave Intake Plenum Repair Kit
  110. Yet another keyless entry remote question 1991
  111. blown coil pack
  112. Everything works, but won't start
  113. Body panel question
  114. E-Brake Light
  115. abs/ need help
  116. 91 buick pa
  117. 01 buick
  118. wiring diagram
  119. 93 PA air conditioning problem
  120. OBD Scanner
  121. 1991 buick park ave ultra's a/c
  122. starter relay 91 PA
  123. Leak in trunk
  124. Location of 98 OA Ultra Coolant sensor
  125. Park Avenue Radio
  126. 92 Park Ave AC blinking temperature light
  127. 96 Park Avenue Cabin Air directional control
  128. Cornering Lights 92 PA
  129. 91 Park Avenue Timing Chain Cover Removal
  130. Changing a 98 Park Avenue Coolant level sensor
  131. window tinting
  132. Engine Dies After 15 minute and Won't Start
  133. lowering
  134. Jumping Idle on 91 P/A
  135. 91 park ave ultra
  136. Fixing an old PA
  137. MP3 player -> Radio schematic needed
  138. 93 Park Ave: when a/c on, cold driver side, heat from dual zone
  139. Air Conditioning Question
  140. 95 PA Stereo removal question
  141. 1991 Park Avenue idle is to high!
  142. Smoking Behind Engine
  143. 1991 Park Avenue
  144. Jed Rule's 1995 Park Avenue Pictures
  145. Transmission???
  146. 91 Park Ave. - Brake Light Coming On
  147. Lookin for a owners and shop manual for a 1997 park ave
  148. 1993 Park Avenue Starting Problem
  149. Collant Capacity, 97 Ultra
  150. fuse locations
  151. Park Ave Blower
  152. 93 Park Ave security system, "wont start!!!"
  153. '89 Park Ave. a/c clutch not engaging
  154. ?location of ECM for 89 Park Ave
  155. Metal Clanking Sound, Coming from Starter or Tranny-Flywheel/Plate, what could it be?
  156. AC Evaperator Core
  157. Help Ac not holding Freon
  158. replacing water pump
  159. How to remove stock DIN radio
  160. right front brake locking up
  161. Engine Specifications
  162. PROM Burn
  163. Finding rims that fit
  164. 1996 Owners, A question for you!
  165. Concert Sound III Amp
  166. no low beam head lights
  167. 1893 buick park avenue have a question
  168. Engine runs bad when A/C is on
  169. 98 V6 into a 90?
  170. Diagram of steering column/wheel needed
  171. Horn Relay Location
  172. Coolant Temperature
  173. Looking for advice
  174. How much oil, really?
  175. 97 Park Ave. Fuel Gauge
  176. chevy motor swap into 85 parkavenue
  177. Do the dashboard blowers blow when heat is on?
  178. Power Window Motor
  179. Help Please Code 42
  180. tips for replacing fuel pump
  181. ???fuel pump
  182. 90 Park Ave - Neither Inside or Outside Door Handle Works
  183. Car sometimes does not start
  184. 1985 Park Avenue Fuel Pump Issue?
  185. Power Moonroof
  186. '91 Park Ave. - Blower Won't Work on HI Speed Setting
  187. NEEDED: circuit diagram ABS 91 Park Ave
  188. HELP: Shocks/Struts for 91 Park Ave
  189. locked front right wheel
  190. 93 Park Aveune 'intermittently' turn signal
  191. RPM drops while accelerating
  192. Hole in firewall
  193. Back on the roads...
  194. 91er: WHICH relay does WHAT...?!
  195. FYI: Plastic Part in Cooling System
  196. Suspension parts - Numbers?
  197. 98 Ultra Shock replacement
  198. Buick letters on the trunk of '93 Park Ave.
  199. Supercharging a 95 park
  200. radio buttons on steering wheel hot?
  201. Park Avenue Dreams
  202. Black coolant / PCM location
  203. 95 Park Ave Ultra, rough coughing idle
  204. 91-96 spoiler
  205. Sensor Fault
  206. Turn signal fuse keeps blowing.
  207. Window question
  208. Automatic headlights not working
  209. '92 Buick cuts out while driving - baldness imminent
  210. internal coolant leak....again!
  211. Displaying HVAC diagnostic '99
  212. '99 6-way seat & climate control problems
  213. Park Ave Charging Light Problem.
  214. Sequential turn lights
  215. 94 Park Avenue Transmission Goofy
  216. 91 PA no spark on #2
  217. Pcode 1870 Manufacture Control Transmission
  218. Winshield wiper stop in the middle
  219. 1999 Buick Ultra Low Oil Pressure Problem
  220. 93 Park Ave. Problem
  221. Magnasteer
  222. 97 PA will not start bad (?)
  223. 92 Park Ave with a performance problem
  224. 89 ultra vs. 2000 accord?
  225. 95 park avenue ultra passenger climate control problem
  226. BCM Body control Module
  227. Need Help Removing Alternator Bracket
  228. Mileage per gallon
  229. 1994 Suspension from GTS to Dynaride?
  230. CD/Radio works intermittently
  231. 94 Buick Park Ave won't start
  232. 91 Park Ave Trunk Pull Down
  233. Concert Sound III stereo
  234. Interiour Lights stay on! 96 PA
  235. Tech Manual 94 ultra
  236. 3800 SC Series II faulty?
  237. 1995 Park Ave Ultra climate control problem
  238. 1994 park ave
  239. What am I doing wrong???
  240. Axing the Park Ave
  241. 97 Park Ave Suspension
  242. '95 P.A. OBD I or II?
  243. Car Dead after fixing fuel guage Needle issue
  244. Ghost in the machine?
  245. 87" Buick Park Ave 4 $$$Sale$$$$$
  246. 99 Ultra front shocks?
  247. 97 traction control
  248. Where is the data link connector terminal
  249. Sun-roof closing slower on 93 Park Ave Ultra
  250. Why there's no hot air from the front air vents?
