View Full Version : Park Avenue
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14
  1. cheap gas in a ultra
  2. Discontinue Park Ave?
  3. 1989 Buick Park Avenue Alarm / Car wont start
  4. Can the air conditioning compressor leak?
  5. 87 trans slips out
  6. 91 PA,Who knows how to remove instrument cluster??
  7. 97 PA water pump
  8. Toeverybody out there with:Rough idle,no start,or fuel pump problems,and fuelprobs
  9. car rumbles, didn't shift, doesn't start
  10. Headlight plastic Fogging Up
  11. Fuel pump relay?
  12. 91 pa fuel pump where is it and why is it not working?
  13. Changing battery on a 95
  14. 1995 Park Avenue DLC
  15. 91 park avenue need help
  16. Coolant temperature
  17. park avenue rough idle
  18. wheel bearings
  19. 91 PA remote question
  20. 95 PA codes.
  21. changing ignition coil
  22. Climate Control Beebing
  23. 92 Ultra has some probs
  24. Cruise control speed oscillating
  25. security system
  26. compass in rearview mirror question!?
  27. Where is Directional Signal flasher 92 PA?
  28. Keyless remote help
  29. wrong pins connected
  30. Buick now has more problems than me!
  31. Park Avenue
  32. Tape Player Problem
  33. 1991 Buick Park Ave Control Module Failure
  34. rough ride
  35. 91 Buick PA Dynaride draining battery?
  36. wheres the brakes?
  37. heater blower on 93 PA wouldn,t shut off
  38. 99 Park Ave Hard Shift
  39. peeling paint
  40. fix this one and your the PA master
  41. another MPG issue
  42. 94 Buick Park Avenue Blower Won't Shut Off
  43. bad transmission
  44. Low Coolant Warning Light
  45. Wireless Remote Programming Instructions
  46. I need your help (remote entry)
  47. Heating Codes Help Needed
  48. Heating Problems-Help!
  49. 96' park avenue engine dies while driving
  50. '91 PA - PCV valve,where is it?
  51. 1995 park ave w/ dual e.t.c.
  52. Twilight sentinel
  53. 97 Ultra DIC resets on its own
  54. 90 Park Avenue heater fan problems
  55. knock sensor question,99 park ave
  56. ABS separate computer under dash?
  57. HELP!! <-security system
  58. PA93 remote entry & heating problems
  59. Brake problems on a 92 PA
  60. Heater Comes On When I Hit The Brakes
  61. 93's have audible alarm ?
  62. 1991 Park Avenue Keyless Remote Problem
  63. bipolar climate control
  64. 1987 engine problems
  65. Transmission problems
  66. fuse panel diagram
  67. 93 PA interior light bulbs can't find any????
  68. No Heatwater from engine
  69. Checking Power Steering Fluid / Is there an easier way?
  70. 1993 Turn signals
  71. HELP!! Harmonic balancer pulley removal
  72. 1993 Park Ave driver Power seat
  73. Heater blows slightly warm air
  74. 2002 Park Ave heated seats not working
  75. 95 PA Blower Issues
  76. Transmission problem - hesitation
  77. harmonic balancer
  78. 1996 Park Avenue Grille
  79. 1999 ultra transmission
  80. 1995 Park Avenue cuts off
  81. 91 PA still stalls
  82. 96 Ultra Won't Start
  83. slight hesitation
  84. 92 PA Disarm Alarm Wire-Tach Wire
  85. 3.8 supercharge park ave 95 changed many parts
  86. 1994 buick park ave fuel filter location
  87. Changing Tail/Headlight Bulbs?
  88. Underhood light problem
  89. bad fuel gauge
  90. rear window defogger 97 Park Avenue
  91. 4T60E shift problem
  92. 99 Ultra Problems
  93. Temporarily disable Left Frton Brake??
  94. I need your advive.
  95. 93 Park ave won't start also
  96. ECM location 91 PA Ultra
  97. 97 PA, DIC=????, ENG Lite/Air Bag Lite on, no gearshift indicator
  98. crank sensor
  99. Chime Module Location ?
  100. Struts
  101. 1993 Park Ave Ultra won't go in reverse
  102. Engine swap in '92 Ultra???
  103. 98 buick park ave no right turn signal
  104. Defrosting rear window
  105. gas guzler
  106. 97 Buick Park Ave Ultra
  107. 97 buick PA power steering unit
  108. obd 2 scanner not working on 94 Park ave
  109. Buick Park Avenue Climate Control
  110. 91 PA coil burn out problem
  111. The Old Tape / CD Player Swap
  112. Don't know if I should just give up!
  113. Charging light
  114. Climate control, a bug or normal?
  115. 95 PA stalling problem
  116. 91 PA Service Engine Light
  117. 95 Buick Park Avenue Coolant In Oil
  118. Will not Accellerate properly
  119. 95 Park Ave Blower Control Malfunction
  120. remote keyless system
  121. Passenger side door lock actuator
  122. Replacing center pad with horns / airbag
  123. 91 buick park avenue
  124. 1992 fuel tank capacity
  125. oil light reset
  126. gran touring suspension
  127. series1 3800 1992 VS. 1993
  128. Cabin Air Filter
  129. 92 Park Ave. No Start
  130. Timing Belt
  131. 88 PA lock actuators
  132. PA coil replacement.
  133. 1991 Park Avenue Ultra
  134. Power Seat Issues -- '91 PAU
  135. 86 Park Ave.
  136. heated seats?
  137. 92 PA Blower Motor for Heater works intermittently
  138. Raw Gas Smell
  139. 95 Park Ave Climate Control - Celcius / F
  140. Auto climate control / headlight problem
  141. hesitation on acceleration hard
  142. Fuel Filter and Clearing Out the Fuel Line
  143. 91 ultra transmission mounts keep breaking
  144. P/A fuel leak
  145. drop a '92 engine in a '93?
  146. GM Techs- Need Part number for trunk lid stopper
  147. 98 Belt Replacement HOW?
  148. ABS & TRAC Problem..also gas gage
  149. '99 Park Avenue Ultra Power Window Switch
  150. 1991 Park Avenue Power Window Problem
  151. Headlights stay On
  152. Broken Gas Guage
  153. I think heater core
  154. Should i shop it?
  155. error codes for ABS/Traction control
  156. Driver's Seat Upholstery
  157. sparks at the ignition wires
  158. trunk pull down and alarm
  159. Inner Tie-Rod replacement on a '92 PA
  160. Leather Car Seats
  161. 97 PA Door Panel Removal - Door Lock SW went into door!
  162. water pump or tensionner pulley?
  163. Supercharger Vacuum Actuator
  164. noisy lifter and what?
  165. 97 Drivers Information COmputer - buttons/lights
  166. 95 Park Ave HVAC Blend Door Location
  167. 93 PA tps problems
  168. no more AC ??
  169. 1985 PA Steering Column
  170. Any '92 PA balljoint replacement ponters?
  171. need PA bumper part
  172. ultra front shock help
  173. 97 Ultra Fuel Filter Location
  174. Fuel Door Problems
  175. Oil Pressure / Normal / 129psi ??????
  176. 92' Factory CD problems
  177. 95 PAU Supercharger replacement
  178. keyless not working:transmitter or receiver?
  179. Lamp Monitor Module
  180. ABS light & low coolant light on
  181. Blinking Service Engine Soon
  182. Engine noise in 92 Park Ave. Ultra w/SC - HELP!!
  183. 92 park avenue dyna?
  184. 91' PA Rocker panel rot @ 60k
  185. Replacing the dimmer switch?
  186. Bulldog Security T-Harness For 1989 Park Avenue
  187. disable alarm/security system?
  188. remove speed limiter?
  189. Should I give up on my 92 PA?
  190. 91 PA Headlights
  191. wheel bearing sound, which side?
  192. 91 pa climate control
  193. PA cranks will not start
  194. Headlights missing after the GM dealer fixed the.. brakes!?
  195. "98 Park Avenue Front Mount
  196. 95 Buick PKA door panel removal
  197. Trunk slams open now
  198. inside lights have a mind of their own???
  199. Any known trunk leak problems? 99
  200. Winter Storage of the 91 PA Ultra
  201. Band "hunting" radio, driver going crazy!
  202. Transmission diagnosis help wanted
  203. 95 Park Avenue won't start
  204. '86 PA Roadster info wanted - New Guy
  205. voltage indications
  206. Park Avenue VS Roadmaster
  207. Swedish Buick PA owner here needs some help
  208. 95 PAU traction control light
  209. voltage variations
  210. Gas mileage
  211. 92 PAU engine probs???
  212. climate control system
  213. Cigarette Lighter Fuse
  214. 99 Park avenue ultra brake rotor
  215. Park Ave 97 error codes
  216. Code P0301 misfire cyl #1 Help!
  217. 92 Buick PAU
  218. shop manual for PA SC 92
  219. 89 park ave: cruise, trans, heater problems
  220. '91 Park Avenue
  221. Park Ave Questions
  222. Catalitic converter
  223. 94 PAU - rear disk brakes
  224. 94 PAU - brake alarm
  225. tranny issue
  226. Snow Tires
  227. 1985 buick park ave won't start
  228. 91 Park Ave - Replacing Driver's Seat Belt
  229. are PA's speed limited??
  230. 1990 PA Electra and My mechanic
  231. Buick for a buck ???
  232. Speedometer dies and Trany slips (at same time)
  233. 1990 Pa Electra
  234. 1990 Park Avenue/Electra stall problem
  235. Brakes
  236. Proper fuse for Blower Motor Control Module and Blower Fan
  237. adding boost
  238. Traction Control on the 99 park avanue
  239. Doorlocks fail when cold
  240. 91 Park Blower Motor Control Module
  241. 99 Park avenue
  242. Replacement for supercharger - 98 Ultra
  243. Twilight Sentinel on PA Ultra
  244. 0-60 92 Pa Sc
  245. 89 PA won't start sometimes
  246. supercharger lubrification
  247. Where is the IAC On a 91 PA
  248. 1989 PA won't start sometimes
  249. Torque Converter Shudder?
  250. 89 PA, IAC pulses with ignition off!
