View Full Version : Park Avenue
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14
  1. PA questions
  2. 1994 Ultra fuel pump relay
  3. Search Parts For Buick Park Avenue 1992
  4. wont start
  5. Lopey idle and voltage gauge reading low - 92 PA
  6. 92 Park Avenue Popping sound and maybe misfire?
  7. 97-99 PA Questions
  8. Noisy Fuel Pump
  9. Runs then as driving it dies.
  10. Motor Mounts for 1998 PA Ultra
  11. 94 PA high idle after 'overheat'
  12. 91 Pa Rear Shocks -how much?
  13. Weird left power mirror problem- Intermittent
  14. Speaker Installation
  15. 1991 PA Ultra A/C goes into Econ mode
  16. number of splines on a 91 PA
  17. A/C blower pressure
  18. automatic climate control 138 code 91 pa
  19. Gas -> alcohol conversion experiences?
  20. 2007 Park Avenue Returns!
  21. i have a no start also
  22. no start ....but it turns
  23. 89 Park Avenue cough and stalls
  24. '92 PA Ultra Won't Start via Ignition/Key
  25. remote wont work and car dont start
  26. In Need of A part Number
  27. it wont start and remote dont work
  28. 95 PAU - moonroof malfunction
  29. 1991 PA ignition coils ...
  30. 91 PA turns but won't start ....
  31. 91 pa security lockout
  32. 96' Park Avenue - Climate Control System - Actuator $$$$
  33. A Myriad of Issues on a 1993 Park Avenue...
  34. boost gauge installation?
  35. 94 PA Ultra Overdrive problem
  36. Starter failures
  37. Need Stock Radio W/ CD Player
  38. 92 PA Ultra A/C Compressor Change
  39. 91 PA Fan Won't Turn Off (Question about Relays)
  40. Engine dies immediately when starting
  41. a/c compressor
  42. Daynaride rear air strut trick.
  43. 91 park ave 115,500 miles oil pressure issues
  44. ride control
  45. radiator replacement w/ oil cooler
  46. 91 p/a code 138 pcm failuer
  47. Does This Park Ave Look Like a Good Deal?
  48. 1992 PAU Fuel filter???
  49. dies, hard starting
  50. Overheating when car not moving
  51. A/C blowing hot air
  52. Low idle problem
  53. Could A/C Work Have Caused Coolant Loss?
  54. instrument lights and radio lights
  55. Rear windows do not open entirely
  56. 1996 Park Avenue - No Air Blowing Out Of Vents
  57. Car runs like POO especially when HOT outside
  58. Temp sensor location for 1992 Park Ave.
  59. gas prices and an ultra... bummer..
  60. Hot Temp
  61. 1991 park avenue
  62. 1992 park avenue climate control error codes
  63. O2 Sensor - Bank 1 Sensor 2
  64. 92 Park Ave fuel filter removal...HELP!
  65. 1991 Park Ave Engine keeps dying
  66. It wont start
  67. Buick vs. Mazda?
  68. Air induction for the early Ultras
  69. front end
  70. Life expectancy of 4T60?
  71. 91 Park Avenue A/C Code 152
  72. security light stays on in dash
  73. Power trunk release motor
  74. Turn Signal problem for 1998 buick park avenue
  75. price for a rebuilt transmission?
  76. 88 Type T Electra, the horn this time.
  77. 97 Park Ave spark plug change
  78. 1987 PA with rattling/hammering sound
  79. Instrument Panel lights wont work
  80. Help! 92 Park Avenue died, won't start!
  81. Coolant Change
  82. Park Avenue Exhaust Diagram
  83. What is this Part?
  84. 91 Park Ave Electrical Problem
  85. A/C Cold on pass. side
  86. 95 PA replacement antenna mast
  87. Dropping Buick?....no good
  88. Oil Pressure Blues
  89. Rear Strut Replacement on 98 PA
  90. Desperately Need Help - 1995 Pa Ultra
  91. PA mods
  92. TPS - damaged again
  93. Electrical Problems - No accessory power: gauges, windows, radio, heat/ac
  94. Plastic interior cover
  95. radiator replacement
  96. wheres the fuel regulator?
  97. hesitation under load = fuel presure regulator
  98. Park Ave. radios
  99. noise when turning right FIX
  100. Scan Tool / DLC question
  101. PA Trouble Code 26- On Board Diagnostics
  102. 1990 PA blower fan ont shut off
  103. 1997 Pa
  104. Help! Vibration problem even while in Park
  105. SE light (Service engine)
  106. 93 Park Avenue Ultra Constant Low Battery / Drain
  107. buick park avenue
  108. Relay part #
  109. '97 Park Ave Pass. Power Seat
  110. 97 p/a lumbar or bust?
  111. 97' park ave drivers window defunct
  112. Removing Vent covers 1991 Park Avenue?
  113. 91 PA battery drain
  114. Just got '89 Park Avenue..Radio Problem
  115. fuel gauge funny
  116. is there some sort of brake selector valve?
  117. Acceleration problem
  118. Cranks, then dies
  119. I'm creating FrankenBuick!
  120. How good is the 95 PA?
  121. where is an oil pump on a 92 buick park avenue supercharge
  122. Parts & manual???
  123. noise when turning right
  124. Error code 42 (EST circuit)
  125. 91 Park Ave not starting
  126. 1990 Park Ave ECM Port
  127. Brake Caliper Removal
  128. Starter problem???? 1995 Pk. Ave.
  129. 4T60-E Automatic Trans Problem
  130. PA Runs fine some time and then dies others
  131. whats wrong?
  132. 97 PA starter motor replacement
  133. add a supercharger?
  134. windshield wipers won't shut off
  135. 98 Buick LaSabre
  136. Is it possible...?
  137. UFO's?97 PA DASH LIGHTS GO CRAZY
  138. ECM location
  139. Speed Limiter
  140. Master cylinder w/ power booster
  141. 94 park avenue ultra no power 3000rpm
  142. A/C blowing cold air on left side and Hot air on the right side
  143. A/C blowing cold air on left side and Hot air on the right side
  144. climate control flash
  145. Sticking Gas Pedal at Idle
  146. 94 to 97 Ultra Info
  147. Power Steering Pump Bolts
  148. GM Code 56
  149. 96 transmission
  150. Failed Emissions Test
  151. cant get to start
  152. hood release problem
  153. Look at what I did this week! (1 picture)
  154. Oil Light on with good oil pressure
  155. Setting Remote For Buick Park Ave.
  156. PA won't slow down
  157. bad ass rice
  158. 92 PA won't idle
  159. 93 PA Headlights
  160. Interior Change/Large Center Console
  161. 99 Park Avenue - Blower Motor ANNOYING Noise !
  162. Clearcoat paint repair?
  163. 1999 Park Avenue Climate Control Display Problem
  164. 92 PA Error Codes, need help
  165. Console light idea
  166. Newbie has tuneup questions
  167. Plenum repair kit
  168. 90 PA rear doors wont open
  169. 92 Buick PA won't start
  170. Brake Repair and a couple other questions
  171. Major interior change desired
  172. 01 PA Power seat, climate control
  173. trailer towing
  174. tail lampfuse blows when ignition engadged
  175. ever tryed a 5.7 HEMI ?
  176. How do I change fuel filters on 3800 engine cars?
  177. Would like some info on 1998-2000 ParkAve
  178. How do I change spark plugs?
  179. HELP! Supension is shot!
  180. security alarm
  181. 4T65E Troubles
  182. Theftlock
  183. PA 91-96 description and security
  184. found a 1999 PA service manual. I need some advice..
  185. erratic oil pressure pressure
  186. drive lights fuse
  187. 91 PA a/c fahrenheit and celsius
  188. Difference between Grand Touring Suspension and Dynaride??
  189. I think I have a kaput ingition switch ...
  190. bleed hole in thermostat
  191. 95 Buick engine cuts off NEW INFORMATION
  192. Cruise control jump out
  193. R.P.M Technical Question
  194. low beams won't shut off on 97 PA
  195. supercharger lacking power?
  196. 95' Pa Ultra.. Problems
  197. Driver side door doen't open from outside.
  198. Steering Column Questions
  199. has Security fix caused another problem?
  200. 2002 Prk Ave Aux Pwr
  201. Sludge in coolant tank
  202. What to know when purchasing a 2002 PA Ultra
  203. Idle air control valve & O2 Sensor
  204. i have a problem with defogger
  205. fuse
  206. Front Drive Axle(right-hand side)
  207. 91 park ave 112,000 miles...couple problems
  208. 89 park avenue problems
  209. 97 PA computer, how do you reset it???
  210. Heater Problem 1995 Park Avenue Ultra
  211. Dynaride Mod
  212. illuminated entry system doesn't work
  213. Fuel Filter
  214. Sharing my experience pulling a 91 steering wheel
  215. Ultra with Slow Front Windows 2001
  216. 94 Park Avenue wont start
  217. 92 PA Dies out frequently.
  218. 91 PA Alternator?
  219. How to disconnect the self-leveling motor on my 93 PA Ultra?
  220. Blower on 97 Buick Ultra
  221. Tire noise or Wheel Bearing Noise
  222. 94 park avenue power window problem
  223. RPM fluctuates while revving engine in "park" position...why?
  224. Power Windows Non-Functional 1996 Park Avenue
  225. cheap gas in a ultra
  226. Discontinue Park Ave?
  227. 1989 Buick Park Avenue Alarm / Car wont start
  228. Can the air conditioning compressor leak?
  229. 87 trans slips out
  230. 91 PA,Who knows how to remove instrument cluster??
  231. 97 PA water pump
  232. Toeverybody out there with:Rough idle,no start,or fuel pump problems,and fuelprobs
  233. car rumbles, didn't shift, doesn't start
  234. Headlight plastic Fogging Up
  235. Fuel pump relay?
  236. 91 pa fuel pump where is it and why is it not working?
  237. Changing battery on a 95
  238. 1995 Park Avenue DLC
  239. 91 park avenue need help
  240. Coolant temperature
  241. park avenue rough idle
  242. wheel bearings
  243. 91 PA remote question
  244. 95 PA codes.
  245. changing ignition coil
  246. Climate Control Beebing
  247. 92 Ultra has some probs
  248. Cruise control speed oscillating
  249. security system
  250. compass in rearview mirror question!?
