View Full Version : Park Avenue
Pages :
1 2 3 4 5 6 7 8 9 10 [ 11]
12
- placard in trunk
- Trouble shifting into Park
- Best place to buy brake pads & rotors for 97 PA
- AC air flow problem
- Park Ave Power Mirrors/Seats
- Not so Dynamite a ride with Dyna Ride Suspension
- Need help locating keyless remote module in 1992 Park Ave.
- Climate Control
- 91 Park Ave startup issues
- Sooo many problems
- Low vacuum to vents on acceleration
- ignition switch
- power windows
- 89 Park Avenue
- trunk leak '92 PA
- 94 PA brake troubles
- '92, ticking / marble rolling sound?
- rough ridin PA
- 1994 Park Avenue - various problems
- 1994 park ave rear shocks
- Power Windows
- 92 Park Av Ultra alarm goes off unexpectedly
- Air condition trouble code..
- 92 Trunk Pull Down Motor
- 1990 Park Ave Blower Problem
- 94 Rear side windows
- Blower fan/front speakers
- Cant Find Code Meaning
- What size tools do I need?
- 1995 Park Ave Fuse Location
- 97 Ultra Brake Noise
- code 41 1992 park avenue
- 98 Park Ave Air Shocks won't go Down
- 2 Problems with 96 Park Ave
- 91 PA interior lights won't shut off
- 95 Park Avenue Still Won't Start Or Run HELP!!
- vibration caused by acceleration
- Transmission
- '89 PA door issues
- 95 Buick Park Avenue
- 95 park avenue cranks but won't run/start
- Coolant Leak
- 1993 Buick Park Ave Brake Warning Light Coming On
- 1997 Buick Park Eletrical Problem
- 92 Park Avenue Stereo wiring harness and trim kit questions
- Alternator removal
- 88 Park ave goes to high idle-wont restart
- 88 Park Ave goes to high idle-shut it off-wont restart
- love power options on '89 park
- My 91 PA
- 89 park avenue ultra with abs
- 91 - Check Oil light
- 1989 - 2 questions
- 93 Park Avenue-no kickdown
- Keyless remote problem...
- start problems of 89.
- 1991 pa keyless remote
- 93 Park Ave High Idle
- 1991 PA Help
- '93 PA electrical gremlins
- help with poor starting
- 98" Cruise Control Issues
- Help -- Electrical puzzle!?
- 91 A/C!!!! Help!, I'm burning up!
- '96 buick park avenue starting problems
- 3800 Park Ave Intake Plenum Repair Kit
- Yet another keyless entry remote question 1991
- blown coil pack
- Everything works, but won't start
- Body panel question
- E-Brake Light
- abs/ need help
- 91 buick pa
- 01 buick
- wiring diagram
- 93 PA air conditioning problem
- OBD Scanner
- 1991 buick park ave ultra's a/c
- starter relay 91 PA
- Leak in trunk
- Location of 98 OA Ultra Coolant sensor
- Park Avenue Radio
- 92 Park Ave AC blinking temperature light
- 96 Park Avenue Cabin Air directional control
- Cornering Lights 92 PA
- 91 Park Avenue Timing Chain Cover Removal
- Changing a 98 Park Avenue Coolant level sensor
- window tinting
- Engine Dies After 15 minute and Won't Start
- lowering
- Jumping Idle on 91 P/A
- 91 park ave ultra
- Fixing an old PA
- MP3 player -> Radio schematic needed
- 93 Park Ave: when a/c on, cold driver side, heat from dual zone
- Air Conditioning Question
- 95 PA Stereo removal question
- 1991 Park Avenue idle is to high!
- Smoking Behind Engine
- 1991 Park Avenue
- Jed Rule's 1995 Park Avenue Pictures
- Transmission???
- 91 Park Ave. - Brake Light Coming On
- Lookin for a owners and shop manual for a 1997 park ave
- 1993 Park Avenue Starting Problem
- Collant Capacity, 97 Ultra
- fuse locations
- Park Ave Blower
- 93 Park Ave security system, "wont start!!!"
- '89 Park Ave. a/c clutch not engaging
- ?location of ECM for 89 Park Ave
- Metal Clanking Sound, Coming from Starter or Tranny-Flywheel/Plate, what could it be?
- AC Evaperator Core
- Help Ac not holding Freon
- replacing water pump
- How to remove stock DIN radio
- right front brake locking up
- Engine Specifications
- PROM Burn
- Finding rims that fit
- 1996 Owners, A question for you!
- Concert Sound III Amp
- no low beam head lights
- 1893 buick park avenue have a question
- Engine runs bad when A/C is on
- 98 V6 into a 90?
- Diagram of steering column/wheel needed
- Horn Relay Location
- Coolant Temperature
- Looking for advice
- How much oil, really?
- 97 Park Ave. Fuel Gauge
- chevy motor swap into 85 parkavenue
- Do the dashboard blowers blow when heat is on?
- Power Window Motor
- Help Please Code 42
- tips for replacing fuel pump
- ???fuel pump
- 90 Park Ave - Neither Inside or Outside Door Handle Works
- Car sometimes does not start
- 1985 Park Avenue Fuel Pump Issue?
- Power Moonroof
- '91 Park Ave. - Blower Won't Work on HI Speed Setting
- NEEDED: circuit diagram ABS 91 Park Ave
- HELP: Shocks/Struts for 91 Park Ave
- locked front right wheel
- 93 Park Aveune 'intermittently' turn signal
- RPM drops while accelerating
- Hole in firewall
- Back on the roads...
- 91er: WHICH relay does WHAT...?!
- FYI: Plastic Part in Cooling System
- Suspension parts - Numbers?
- 98 Ultra Shock replacement
- Buick letters on the trunk of '93 Park Ave.
- Supercharging a 95 park
- radio buttons on steering wheel hot?
- Park Avenue Dreams
- Black coolant / PCM location
- 95 Park Ave Ultra, rough coughing idle
- 91-96 spoiler
- Sensor Fault
- Turn signal fuse keeps blowing.
- Window question
- Automatic headlights not working
- '92 Buick cuts out while driving - baldness imminent
- internal coolant leak....again!
- Displaying HVAC diagnostic '99
- '99 6-way seat & climate control problems
- Park Ave Charging Light Problem.
- Sequential turn lights
- 94 Park Avenue Transmission Goofy
- 91 PA no spark on #2
- Pcode 1870 Manufacture Control Transmission
- Winshield wiper stop in the middle
- 1999 Buick Ultra Low Oil Pressure Problem
- 93 Park Ave. Problem
- Magnasteer
- 97 PA will not start bad (?)
- 92 Park Ave with a performance problem
- 89 ultra vs. 2000 accord?
- 95 park avenue ultra passenger climate control problem
- BCM Body control Module
- Need Help Removing Alternator Bracket
- Mileage per gallon
- 1994 Suspension from GTS to Dynaride?
- CD/Radio works intermittently
- 94 Buick Park Ave won't start
- 91 Park Ave Trunk Pull Down
- Concert Sound III stereo
- Interiour Lights stay on! 96 PA
- Tech Manual 94 ultra
- 3800 SC Series II faulty?
- 1995 Park Ave Ultra climate control problem
- 1994 park ave
- What am I doing wrong???
- Axing the Park Ave
- 97 Park Ave Suspension
- '95 P.A. OBD I or II?
- Car Dead after fixing fuel guage Needle issue
- Ghost in the machine?
- 87" Buick Park Ave 4 $$$Sale$$$$$
- 99 Ultra front shocks?
- 97 traction control
- Where is the data link connector terminal
- Sun-roof closing slower on 93 Park Ave Ultra
- Why there's no hot air from the front air vents?
- Upgrading the suspension system on '93 Ultra
- 1997 Park Ave Ultra -No Brake Lights
- Programming Remote for 97 Park Avenue
- Lateral G ratings
- 1994 park ave exceleration missing
- Performance parts 86 electra park ave?
- Missing amd Loping.
- 86 Electra park avenue dead after carwash
- 1993 Park/AVE Over heating problem.
- 1991 Buick Park Avenue door panel removal
- on board diagnostics system?
- '97 Park Ave shifting problem
- 97 Park Av. Ultra noise when turning.
- Oxygen sensor replacement?
- Rocking driver's seat on my '87 Park Ave
- Slow motion power windows on my '87 Park Ave
- Rear brake issue on my '87 Park Ave
- Head gasket issue with my '87 Park Ave ?
- Serverl Electrical Problems 1991 Park Ave 98,000miles
- 3.8L engine
- 1991 Park Avenue Starting Problem
- 93 park avenue ulta
- 1997 value of '92 Park Ave
- 91 Buick Park Avenue rough run up hill
- autonix car alarm
- Park Avenue Wheels 03
- 92 Ulta Supercharger
- will a motor from a 94 park ave fit in a 96 park ave?
- Wow Wow sound synched with wheel speed
- 1992 BUICK PARK AVE, Wont' Start
- Fuse box on 89 Park Avenue?
- 1997 Buik Park Ave ABS/Traction problem
- 1994 Park Ave Dies
- Belt replacement on 99 Park Ave Ultra SC
- 94 ParkAve not starting--factory alarm?
- '92 Park Avenue Ultra
- Shift Indicator
- Heated seats are HOT!!!
- Premium Fuel In Ultra?
- 96 Park Avenue battery drain
- supercharger oil??
- Miles
- To Rebuild an 89' Park Ave
