View Full Version : Park Avenue
Pages :
1 2 3 4 5 6 7 8 9 [ 10]
11 12
- 1996 Park Avenue Grille
- 1999 ultra transmission
- 1995 Park Avenue cuts off
- 91 PA still stalls
- 96 Ultra Won't Start
- slight hesitation
- 92 PA Disarm Alarm Wire-Tach Wire
- 3.8 supercharge park ave 95 changed many parts
- 1994 buick park ave fuel filter location
- Changing Tail/Headlight Bulbs?
- Underhood light problem
- bad fuel gauge
- rear window defogger 97 Park Avenue
- 4T60E shift problem
- 99 Ultra Problems
- Temporarily disable Left Frton Brake??
- I need your advive.
- 93 Park ave won't start also
- ECM location 91 PA Ultra
- 97 PA, DIC=????, ENG Lite/Air Bag Lite on, no gearshift indicator
- crank sensor
- Chime Module Location ?
- Struts
- 1993 Park Ave Ultra won't go in reverse
- Engine swap in '92 Ultra???
- 98 buick park ave no right turn signal
- Defrosting rear window
- gas guzler
- 97 Buick Park Ave Ultra
- 97 buick PA power steering unit
- obd 2 scanner not working on 94 Park ave
- Buick Park Avenue Climate Control
- 91 PA coil burn out problem
- The Old Tape / CD Player Swap
- Don't know if I should just give up!
- Charging light
- Climate control, a bug or normal?
- 95 PA stalling problem
- 91 PA Service Engine Light
- 95 Buick Park Avenue Coolant In Oil
- Will not Accellerate properly
- 95 Park Ave Blower Control Malfunction
- remote keyless system
- Passenger side door lock actuator
- Replacing center pad with horns / airbag
- 91 buick park avenue
- 1992 fuel tank capacity
- oil light reset
- gran touring suspension
- series1 3800 1992 VS. 1993
- Cabin Air Filter
- 92 Park Ave. No Start
- Timing Belt
- 88 PA lock actuators
- PA coil replacement.
- 1991 Park Avenue Ultra
- Power Seat Issues -- '91 PAU
- 86 Park Ave.
- heated seats?
- 92 PA Blower Motor for Heater works intermittently
- Raw Gas Smell
- 95 Park Ave Climate Control - Celcius / F
- Auto climate control / headlight problem
- hesitation on acceleration hard
- Fuel Filter and Clearing Out the Fuel Line
- 91 ultra transmission mounts keep breaking
- P/A fuel leak
- drop a '92 engine in a '93?
- GM Techs- Need Part number for trunk lid stopper
- 98 Belt Replacement HOW?
- ABS & TRAC Problem..also gas gage
- '99 Park Avenue Ultra Power Window Switch
- 1991 Park Avenue Power Window Problem
- Headlights stay On
- Broken Gas Guage
- I think heater core
- Should i shop it?
- error codes for ABS/Traction control
- Driver's Seat Upholstery
- sparks at the ignition wires
- trunk pull down and alarm
- Inner Tie-Rod replacement on a '92 PA
- Leather Car Seats
- 97 PA Door Panel Removal - Door Lock SW went into door!
- water pump or tensionner pulley?
- Supercharger Vacuum Actuator
- noisy lifter and what?
- 97 Drivers Information COmputer - buttons/lights
- 95 Park Ave HVAC Blend Door Location
- 93 PA tps problems
- no more AC ??
- 1985 PA Steering Column
- Any '92 PA balljoint replacement ponters?
- need PA bumper part
- ultra front shock help
- 97 Ultra Fuel Filter Location
- Fuel Door Problems
- Oil Pressure / Normal / 129psi ??????
- 92' Factory CD problems
- 95 PAU Supercharger replacement
- keyless not working:transmitter or receiver?
- Lamp Monitor Module
- ABS light & low coolant light on
- Blinking Service Engine Soon
- Engine noise in 92 Park Ave. Ultra w/SC - HELP!!
- 92 park avenue dyna?
- 91' PA Rocker panel rot @ 60k
- Replacing the dimmer switch?
- Bulldog Security T-Harness For 1989 Park Avenue
- disable alarm/security system?
- remove speed limiter?
- Should I give up on my 92 PA?
- 91 PA Headlights
- wheel bearing sound, which side?
- 91 pa climate control
- PA cranks will not start
- Headlights missing after the GM dealer fixed the.. brakes!?
- "98 Park Avenue Front Mount
- 95 Buick PKA door panel removal
- Trunk slams open now
- inside lights have a mind of their own???
- Any known trunk leak problems? 99
- Winter Storage of the 91 PA Ultra
- Band "hunting" radio, driver going crazy!
- Transmission diagnosis help wanted
- 95 Park Avenue won't start
- '86 PA Roadster info wanted - New Guy
- voltage indications
- Park Avenue VS Roadmaster
- Swedish Buick PA owner here needs some help
- 95 PAU traction control light
- voltage variations
- Gas mileage
- 92 PAU engine probs???
- climate control system
- Cigarette Lighter Fuse
- 99 Park avenue ultra brake rotor
- Park Ave 97 error codes
- Code P0301 misfire cyl #1 Help!
- 92 Buick PAU
- shop manual for PA SC 92
- 89 park ave: cruise, trans, heater problems
- '91 Park Avenue
- Park Ave Questions
- Catalitic converter
- 94 PAU - rear disk brakes
- 94 PAU - brake alarm
- tranny issue
- Snow Tires
- 1985 buick park ave won't start
- 91 Park Ave - Replacing Driver's Seat Belt
- are PA's speed limited??
- 1990 PA Electra and My mechanic
- Buick for a buck ???
- Speedometer dies and Trany slips (at same time)
- 1990 Pa Electra
- 1990 Park Avenue/Electra stall problem
- Brakes
- Proper fuse for Blower Motor Control Module and Blower Fan
- adding boost
- Traction Control on the 99 park avanue
- Doorlocks fail when cold
- 91 Park Blower Motor Control Module
- 99 Park avenue
- Replacement for supercharger - 98 Ultra
- Twilight Sentinel on PA Ultra
- 0-60 92 Pa Sc
- 89 PA won't start sometimes
- supercharger lubrification
- Where is the IAC On a 91 PA
- 1989 PA won't start sometimes
- Torque Converter Shudder?
- 89 PA, IAC pulses with ignition off!
- 1991 PA wont start
- 2001 speaker sizes/locations
- idiot lights
- Wiring Diagram for VSS-150
- AC codes
- tranny acting funny..
- spark plugs on PA SC
- Question About ClearCoat Paint
- coolant low light
- noisy lifter... a cure?
- MPG on a 92 PA
- 1992 p.a. danaride suspension
- Park Avenue 91 lost overdrive
- IAC powered with ignition off, 89 PA
- ****1989 Park Avenue Being Parted Out*****
- Help Please I Dont Want To Buy Another Car!! Ignition Fuse Keeps Blowing!!!!
- Body Control Module on a 1993 Ultra
- 93 Park Ave. wont start "factory alarm"
- cone filter, good or bad?
- 1989 PA Complete Electrical Failure
- abs light
- 90 PA will not idle
- How do I remove door panel on 1990 Park Ave.
- Battery Warning light
- stuff for the leather?
- Questions on 95 Park Avenue
- Won't start
- PA 92 questions
- PA 92 questions
- coolant low ???
- Sun Visor Problem
- parking lights stay on
- water pump on 91 PA 3.8 lt.
- 1991 pa dynaride
- Quickest way to add cd changer to 1997 PA?
- need advice with my 91 pa
- Problem on my 91 PA
- Loss of power when hot (more problems)
- '94 Ultra gas gauge dips up and down, up and down...
- Brake Problems
- 95 park ave. front door speakers
- 91 Park Avenue TPS codes 21 and 22
- Door arm rest clip broken
- 1978 Park Avenue
- 0 to 60
- '92 Park Avenue
- 92 Park Avenue - smoke coming from steering column! and other tales of woe
- Bcm ???
- 1996 Buick Service
- Lost power while driving
- 1991 PA turn signals
- 1999 park avenue "service engine soon"
- Might need new engine. Whats the diffs?
- 00 Park Avenue performance tweeks?
- Tensioner Pullley
- 1996 Park Ave Spark plugs
- Radio Code
- Lamp Monitors
- Idles too high
- Starting problems
- diagnostic codes 93 prak ave.
- weird electrical problem
- Air intake housing
- Performance air filters...YAY or NAY
- Gas Grade
- '95 P.A. suspension
- Cranks but wont start!
- axle problem?
- help '89 Ultra has big problem
- Remote on '93 Park Ave Ultra not working
- 1991 PA flasher module?
- 92 PA will not start
- Keyless Entry Question
- BCM? PA acts like Christine!
- vibrations
- Mass Air Sensor
- Transmission issues?
