Our Community is 705,000 Strong. Join Us.
Honda
> Let's get Technical!
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
Forward in reverse.. very bad?
D15Z1 swap into 91 civic
This Sux
Looking for a d16y8
Accord F22 turbo How-to
cat or no cat?
PGM-FI Manifold
b18a1 swap
Fuel flow meter/gauge kits?
Help on '89 626 LX
that dam oil.....
ITB's
what's this hole for ???
need expert help b4 dishing out cash
rubbing sound accelerating from stop
Incomplete grounding upgrade
P&P
So Confusing
B18c1 engine trouble HELP!!!
b18b/gsr tranny probs....
Cams
New ACT stage 2 clutch
b18b questions
APexi VAFC
tranny question
d16 possiblity?
guages installation
best product?
what bearing is making that noise in tranny?
si pistons in ex
how to install CAI cold air intake
self bore
What is an LS's safe redline with GSR tranny?
TURBO LS integra ?
'03 civic headlight trouble
How do you Convert PS to HP?
after installing air filter
prelude
Water pump and Flywheel Help
b16a into 92 4 door
nitrous question
D15B7 torque specs???
01 accord V-6 ignition system without a distributor??
clutch question
engine swap
exhaust help
exhaust help
alternators
what are the stock specs for a 96 integra rs
How to Take of Need Maintanenece light of? on 98 civic dx
burning gas
BOV in WAI pipe?
DIY colored emblems
Torque specs cam caps
Prob After Prob Please help!!!!!
putt putt puttin
what should i do now
1990 5 speed Honda Accord EX Error codes
Starting Problems 98' accord
Shifting
Turbocharging LS...gsr or ls tranny?
240 hp d15b is it possible
flames
b16a1 swap question
no pressure in clutch after bleed!!!
Accord H22a Swap
engine swap advice
b16a vtec ??
1986 crx to ls b18a1 help
b18 vs h22
B18 swap help
Stuck Lug Nuts HELP!
abs not working
dose anyone have a 93 legend LS? if so.....
what is needed for ls/vtec?
96_gsr_into_96_civic_help!?!?!
K20?
civic obd2 vs integra obd2
Probs With Speedo
jdm b16a distributor HELP!!!!
95 ls questions
More motor problems!!!
crx with h22a4 and turbo?
1994 Civic EX window rolled down and won't go up!!!
94 Vigor Oil Leak
2.0 LS Vtec Motor
need help with motor swap (civic)
Prelude Specs
'88 Civic hatch high/unsteady idle problem once warmed up...
1990 civic wont start
F20b --versus-- H22a
stroked b20?
Starting troubles
click in B16a
illegal smog in san diego...?
my broken honda...
is there a govenor on a 99 civic
vtec lights, cruise control, & random questions
Auto School?
got some questions on what to do? 96 civic hatch.
just rebuilt my motor now won't start and I have no juice
Racing Seats & Engine
NEED HELP ON MY B16a2 tuning
Horsepower ?'s
Golden Eagle vtec dowel pins!
car wont start?
swap help !!!!!!!!!!!!!
STuck Cv Joint 92 Prelude
msd problems need spark fast
Motor Wont Start
93 Accord Cooling Fan Issues
VTec or no Vtec, that is the question
vtec wont engage after vafc install
What is power shifting?
Fuel injector problem
turbo+nitrous
Help! o2 sensor problem
B16a leaking oil help needed
LS/VTEC Conversion
runnin ls/vtec oil supply line off of the oil pump?
Lost Power!! Where Is It?!?!
help. valve spring install
drag help
b16a/b vs b18b/c vs h22/23 vs b20 FAQ
removal the dashboard 1990 acura integra
intake manifold mount
b18b1 swap in 95 civic help!!!
Drag Racing Question
Air Intake Question
skunk2 exhaust
My B16 was running like shit
Motor swap problems
Accord tuneup specs pls
wideband o2 sensor ivtec k24 engines
Civic dashboard and tail lights out
valve tick? but only under vaccum
Quicc Question
Rumor about 4dr exhaust
I need help on a swap
$$$ dohc zc header
question about breaks
adjusting points for a b16a
90 Prelude 2.05 liter DOHC is loosing power.
Racing Harness??
LS tranny swap?
R) headB18c5(Type on a F20c bloc(S2000).
this is a hard one for you guys
!!.. Apexi ..!!
Dual Vtec, 3-stage vtec "ECu HElp) d15b obd2
would this be a good set-up?
Ignition Wires
92 ls motor in 91 civic hatch
!!... Apexi N1 ...!!
1.6 ZC DOHC - igniter or coil problem!
Civic 2000 swap?
OBX-R cams ????
which wire harness?
Cold air into Ram Air intake for the winter
89 accord tranny removal and install
how good is the 2.5 I5 in the vigors/TL?
cost 4 h22 swap
D15b Dual Vtec
3rd Gen Integra LS and 4th Gen prelude si
98 civic problems please help
is this a good price
prelude head swaps
94 lx coup speedo on/off
mini-me d16y8 head
supercharging gsr
autometer oil pressure gauge help
d15 head
I Need help with my 91 accord
How much does a 1993 Honda Prelude weigh?
Interga axles question for SWAP
Overheating problems - HElp
Sad Story...
My ZC
Port and Polish Intake Manifold
b16 problems
retarded tranny ?
reccomended engine swap?
EF8 front end.
Need help for '88 Integra LS SE
ZC [DOHC] Seaching for Cam gears set...........
in search of itr tranny
White/Greyish smoke only in VTEC..
How To Bleed Hydraulic Clutch for 1990 Honda Accord
need a new clutch!!
Clutch - *56k Warning*
B20/VTEC first start hangs with fast flashing CEL
At the stage of buying an accord... 94-97
looping idle with a knock then......
SOHC to DOHC
heads on a d16 engine
Need help for a 1982 Accord
B16 civic and h23 prelude
prelude 4th gen h23 and h22
Lsd ?
98 honda civic A/C engage/disengage frequently during Idle.
how do i set timing
Need 03 Civic Radio Code
Boosted VTEC
6 grand for a motor build let me get some of wut ur smokin'
Frankenstein
90 Integra Fuel Pump
rough idle problem - need help
Car Will Not start just put motor in...
Integra-R Intake manifold into LS head???
Fluidyne Radiator Installed
got new skunk2 harness and computer
2000 Civic SI check engine light
gsr cam swap
Civic Si not running right
h22 auto vs manual swap
tranny ques: gsr to a type r
radiator help needed
Radiator cracked, need help!
need help adjusting valves
B16 in N.S
exhaust: quiet with hp gain
rods and pistons?
where will they go?
H22A HorsePoWa
86, 87 integra ecu in a 87 crx si
Sub-harness venders for 91 Accord EX
O2 sensor
90'Acura Integra rear end into 98 Civic EX
possible european civic engine swaps
Clutch and Flywheel
b16a flywheel
the tranny Tranny
[Need Help] Problemes after ZC Swap
motor mounts b18c
auto to manual conversion?
DOHC ZC stock tb/intake to 74mm, fuel issues?
Engine Swap
underdrive lightweight pulley
OBX power pulley kit
Head Gasket Replaced, but still losing coolant??
my freinds car will not stay running
question about exhaust!!
Swap F20B into Honda Civic EX
b18c1
exhaust header installation on 94 accord ex
Guage Install...Help Needed
diffrence betwen the D16y Vtec and the D16z Vtec
exhaust decibels
Engine & Trans. Swap
how much boost?
Stock Civic EX to JDM-B18c5 swap questions....
Automotive Network, Inc., Copyright ©2013
