Our Community is 705,000 Strong. Join Us.
View Full Version : Let's get Technical!
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12
  1. Need help wont spark
  2. Do I Need A Tranny For A Swap?
  3. Technical swap advice needed
  4. 98 Prelude OBSII to OBDI conversion
  5. Short Ram Intakes
  6. distributor compatability on b-series engines
  7. 96 civic ex with what SWAP???
  8. oil question.
  9. funny sound?
  10. some old school flavor for you guys
  11. VTEC Engagement/Oil Problem
  12. b16 head gasket
  13. Coverting Obd Ii Motor
  14. d16a1 valves in a zc head
  15. vss location
  16. What do I need for a Mini-Me swap?
  17. water pump leaking, need help!
  18. OBDII GS-R motor in 5th gen Civic, Injectors?
  19. 94 Honda Civic DX/throwout bearing/headgasket/mechanic lying??
  20. 94 Civic won't start in cold weather
  21. ammeter gauge?
  22. f20b accord?
  23. Turbo h22a, please take a look.
  24. Making a B20 CRVTec
  25. zc rod bearings
  26. My car is overcooling
  27. H22A swap in a 96 civic hatch, can i use prelude axles?
  28. compression test??help
  29. engine swap question
  30. honda lovers. warning this may piss some people off lol
  31. New water/oil pump?
  32. Cylinder Chamber Design Faq
  33. Skunk 2 vs. Toda
  34. Wheel Stud Removal/Replacement
  35. Too Much Torque for my clutch?
  36. Ricy Concept?
  37. engine swap ideas
  38. CTR Pistons & GSR Rods?
  39. B20 Crank ?
  40. 1990 accord tranny conversion possible?
  41. VTEC Head Rebuild Faq (Please Help)
  42. how to give my civic more power??
  43. Erratic Idle....????
  44. beefing up an H22A...
  45. changing gears in tranny
  46. What the hell?!?!
  47. rpm's running high?
  48. Valve Lash!!!!
  49. Question? connecting rods
  50. in need of help bad swap complete car wont start
  51. 96 accord ex vtec overheat/massive blowby
  52. Type R Block/GSR Head
  53. slick sizes
  54. need help to build up civic
  55. ECU Question!!!
  56. CRX Check Engine Light & Unmanned Revving
  57. need help with 91 civic hatch
  58. Hondata k100 Vs. Reflash
  59. Power To Weight Ratio
  60. Rev ups, and drops. Please Help!!
  61. Plz Help Me Guys Noise Prob!
  62. running straight pipes
  63. Need ECu, ABS, Cruise Control, and stability control help
  64. Exhaust
  65. Please Help - Valve Lifters Bad?
  66. Change Engine Head Good Idea?
  67. REPLACING A d15b7 ENGINE NEED HELP
  68. Tuning Cams
  69. Carby To E.f.i.possible??
  70. Clutch Question
  71. 2003 Civic Si exhaust.
  72. Looking For Engine Swap In Melb!
  73. honda door lock noise/paint issues
  74. 95 Integra ABS light comes on
  75. civic idle (NEED HELP)
  76. 8lb. fly wheel?
  77. d15b vtec for a b15 in a 92 civic hatch possible?help
  78. 91 integra shift linkage in 91 civic??
  79. Voltage issues
  80. VTEC conversion?!
  81. need help
  82. Shifting
  83. need help after installing air filter
  84. cr-v drivetrain into a civic
  85. integra service manual, anyone?
  86. exhaust sound question
  87. built h23 without balance shafts???
  88. What's A Good Nitrous Set Up ???
  89. tune-up help.
  90. comp cam any good?
  91. h22 tranny
  92. how to check injectors?
  93. Race Gas / NOS
  94. Help with 91 Accord?
  95. prelude conversions
  96. issues
  97. VTEC system malfunction CEL
  98. ls/vtec will not start without me priming it.
  99. h22 swap question
  100. Critical swap problem
  101. dimensions~need help!!!
  102. Honda Head Work
  103. low beam headlights
  104. Check engine light after intake install
  105. ? about ohms to injectors.
  106. Broke a wheel stud...
  107. h23 non-VTEC mods
  108. B20B + Type R Head = Good Combo?
  109. spark plug wiring diagram
  110. decyphering the engine codes
  111. need help with my d15 v-tec swap
  112. K20 to an F20C tranny?
  113. h22 head on h23 block
  114. Wiring?? Help!!
  115. any comments?
  116. auto to manual conversion ?
  117. Castrol 10 W-40 to Quaker State 10W-30
  118. Yes, It's probably been answered a thousand times...
  119. 00 si head work any ideas
  120. Help, OBDII-OBDI CEL
  121. Mount ? for B20B swap into 00 civic
  122. Rod and Main bearings
  123. Car goin crazy...Scan says misfire in cylinder 1 & 3...help
  124. low idle when car is warm
  125. b18 tranny
  126. Blown b18 block
  127. Idle Problems No Check Engine Or Vacume Leaks.
  128. will this setup haul ass???
  129. Rough idle on 2000 Civic
  130. Transmission flushes - yea or nay?
  131. Noise from my 93 civic
  132. im reading a lot of idle probs, heres mine
  133. 1999 honda passport probs
  134. head swap in 96 dx hatchback
  135. need info about puttin a 03-04 cr-v motor in my 91 si hatch
  136. Shift rod trouble
  137. 4th slips on new swap?
  138. Axle Removal?
  139. Blueprinted?
  140. wouold doing this help me get rid of the rice sound
  141. LS Tranny Vs. GSR Tranny
  142. My car idle's hard WHY???>>.....
  143. Rod/Main Bearings
  144. Steering creak in Accord
  145. Ob2-ob1 Cel
  146. Help! oil leak
  147. weld/bore cylinder?? possible?? also B17 valvetrain/CTR cams??
  148. parts for B20B block
  149. Obx Camshafts????
  150. 1993 honda civic dx hatchk for sale
  151. steering rack
  152. wont go into gears at all
  153. Which One?
  154. All Motor D16 vs Turbo D16...???
  155. B20B in an 00 Civic Help!!!
  156. Trans swap
  157. cheapest route to 225-250 hp?
  158. how to lube chassis?
  159. engine problems ><
  160. light flywheel with FI
  161. Got a spark plug problem!!!
  162. my h22 wont go in reverse
  163. no spark on piston #3 !!!!
  164. crane cams
  165. 1989 Honda accornd engine shutting down
  166. CD player overheating
  167. Valve springs compresor
  168. Odyssey ABS trouble
  169. need some help pls
  170. Converting 96+ LS to OBD1
  171. ls tb on sohc
  172. Am I on th Right Track?
  173. Please Please Help
  174. All The Basics!!!!!
  175. mini me build
  176. b16b swap
  177. Check Engine Light and ABS Light!?!?!
  178. car wont rev past 4k rpms???? help
  179. axle problem
  180. how to change oil
  181. Ls Vtec timing belt
  182. need someone whos good with calculating CR, 11:1 B20 w/ B17 crank/head?
  183. chipped ecu vs stock
  184. Car shakes when floored
  185. vacuum lines help!
  186. Jdm D15B2 MPFI VTEC swap on a 88 crx D15b2 DPFI...HELP!!
  187. installing camshafts QUESTION
  188. Turbo list of doom
  189. What Am i doing Wrong ??????
  190. Ls/ Vtec problem can you guys help me!
  191. How bad is it doctor?
  192. What to do next????
  193. B18A1 in '89 Civic
  194. d16y8 compression good or bad?
  195. THROW OUT BEARING or Clutch???
  196. rev limiter on auto LS?
  197. d16y8 vtec SOUND!!!
  198. Power With These Mods!!!????
  199. 91 honda accord help
  200. whats that noise
  201. what camshaft to get
  202. How much can I Deck A b16 head
  203. Setting 88 prelude Si Timing?
  204. 95 timeing belt
  205. 'teg type R and ls exhaust systems...
  206. integra transmission
  207. H22A4 USDM Best Performance RPM Limit, Secondary Kick in, Vtec Kick in levels
  208. Accord King
  209. D16z6 Pinout (need help to look this over please)
  210. system too rich...
  211. Low RPM Vibrations
  212. Best Engine for 93 Accord EX
  213. starter relay switch
  214. A/C Help
  215. b16 head on b20??? or k20a4
  216. Non performance tranny swap, need advice.
  217. ARP HEAD BOLTS AND STUDS>> WHATEVER THEY ARE
  218. crx idel
  219. 1989 nissan pathfinder
  220. gsr interior into civic
  221. Running rich possibly?
  222. SO MUCH SMOKE coming from my 94 Prelude Si. Help? Eh?
  223. How can i improve my current stock tranny?
  224. 93 civic problem overheating,
  225. injectors not squirting. :(
  226. Smog Problems
  227. need help with a tranny swap
  228. What does 4-2-1 mean for a header?
  229. 88 Prelude Si Timing Question
  230. Catalytic Converter 02 Sensor Wiring
  231. Roller wave pistons
  232. V-afc
  233. 90 Prelude Si Leaking coolant
  234. type r b18c engine swap
  235. hydraulic to cable
  236. Has anybody turboed a d15b7
  237. RWD Civic
  238. Best Turbo for a 95 civic dx (d15b7)
  239. what is the difference between b16 and stock
  240. looking for a B16 93 civic hatchback
  241. 93 civic dx hatchback probs need help please
  242. 3.2L vs. 3.5L Connecting rod Lengths?
  243. Need Help!!!!
  244. H22 swap help
  245. SOHC Gear d15b2
  246. Please help me build a Honda powered gokart/sandrail/dune buggy
  247. should i drop a v-tech in my 85 lude? i got 6k
  248. Can i Hook a Pocket Pc up to my engine?
  249. o2 sensor and ecu
  250. B16A2 160 HP or 170 HP?
