Our Community is 705,000 Strong. Join Us.
View Full Version : Let's get Technical!
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. a little help from some people with some experience
  2. need help got ?'s
  3. Piston rings or is it something eles messed up wit my oil...
  4. Fuel/ HP Q's
  5. b20a5 head swap
  6. whats better
  7. what is the biggest engine i can fit in a 92 acura integra rs b18
  8. 1997 Honda Accord IAT sensor
  9. code 20 on ecu and starting problems
  10. tranny problems or clutch problems?
  11. Hhheeelllpppp
  12. No compression on #2 cylinder, need a little help?
  13. B20 block B17 help...
  14. itr lsd, ls tranny
  15. ls vtec questions !!!!!!!!!!
  16. Where is speed sensor on 1994 Honda accord?
  17. which clutch?
  18. 1989 Accord Oil Pan leaking...help
  19. Question about Cat Converter on my car?
  20. Dry auxiliary jet...primary working fine.
  21. crx engine wiring NIGHTMARE!
  22. no fuel help
  23. ef9 clip conversion
  24. 1992 Honda Accord Transmission?
  25. A20a Swap
  26. LSD Tranny
  27. Rotors & brake pads for 2002 Honda Accord
  28. h22 runs like $!#*
  29. 90' Honda Accord Trans help
  30. 89 integra problem...please help ASAP!
  31. Honda Accord ECM codes
  32. Serious Issue, Need Info Asap
  33. How do i check the compression on my 90 accord?!
  34. help car over heating
  35. Ancient Chinese Secret????
  36. need help with crx, weird problem
  37. dim check engine light
  38. f22 intake manifold question
  39. smog legality in california
  40. ecu question
  41. Tuning Question
  42. Shifting Problems...
  43. sohc vtec
  44. 87 crx
  45. 94 Accord Lx 2.2 oil issue
  46. throwing codes
  47. what head gasket do i use???
  48. LS-VTEC problems
  49. Code 43 or 45 on a 98 GS teg
  50. Leak????
  51. Coolant leak
  52. I Need Hewlp Fast Plz
  53. H22 needs a little help...
  54. need a honda mechanic
  55. O2 sensor secondary
  56. can this be done
  57. 90 Accord serious starting problem...please help!
  58. Swapping B18B into 89 civic HB
  59. ls vtec questions please help
  60. 1998 Civic Sparkplug Misfire
  61. Help!!!!!!!!!!!!
  62. Apexi v-afc
  63. Need Timing Belt Walkthrough
  64. Going broke throwing parts at it!
  65. 9lb flywheel with my set up????
  66. b18a1 swap into 91 crx dx manual trans.
  67. 5th gear popping out
  68. HELP! b16a. gsr head???
  69. Civic Acceleration stuck
  70. crx smoke?
  71. ls vtec questions???
  72. will a z6 head bolt up to a y5 block?
  73. B18c5 vs B18c1 turbo
  74. coilovers
  75. Hardcore Automotive Opens Soon!!
  76. 93 honda civic front end
  77. Windshield Chip
  78. Which engine for turbo??
  79. I NEED TRANNY HELP!!!! think its my syncros
  80. 96 civic to be lowered
  81. What does it mean?!
  82. redline,stalling?
  83. h22 EAGLE sleeved block
  84. ls all motor ?
  85. B16 complete swap
  86. B16a2 complete swap
  87. 02 problems after adding header
  88. annoying problem
  89. Power window regulator cable
  90. Hydro lock
  91. kinda confuzd
  92. O2 Sensor out for the 2nd time.
  93. Acceleration Problem
  94. Trans. rattle
  95. Are ground wire kits easy to install?
  96. installing ac
  97. car wont turn over
  98. crx/civic si tb & im lines were do they go??
  99. pics of a d16a6 ghetto dizzy on vtec head???
  100. bolt sequence
  101. how do i run vtec?
  102. dont laugh
  103. installing skunk2 im
  104. Fuel rail direct conect!!
  105. Some Questions?
  106. ?
  107. b16a jdm rpm worry's....
  108. O2 sensor or new engine?
  109. SOHC ZC + Vtec Head combo? HELP
  110. too much r-134a???
  111. Installing lowering springs?
  112. S2000 Head Bolts
  113. Best High Pressure Assembly Lube
  114. high rpm idle
  115. Gsr to Type R head
  116. Engine Build Up - GSR vs. LS/VTEC
  117. b18a 92 ls motor swap into a 97 civic ex WILL IT WORK???
  118. shift point
  119. Check Engine After BBk Throttle body install
  120. 93 Honda Accord overheat question
  121. Recharged AC and now the compressor turns on and off constantly
  122. Accident....NOooooo!!!! Please help Map sensor?
  123. b16a or b18a??
  124. 92 civic hb no spark
  125. Civic Problem, Need Help.
  126. Compression Too High Overheat?
  127. Brakes are stuck on 94 civic
  128. Clutch Thing
  129. lsd
  130. failing emisions in oregon
  131. need help with LSD
  132. wideband o2 sensors
  133. d16z6 and b16
  134. gsr intake mani and throttlebody on b18b
  135. Knock sensor question
  136. handbrake does not work.
  137. Check engine with vtec controller?
  138. problem installing an alternator
  139. Bigger injectors?
  140. when should i feel the Vtec kick in?
  141. 96 civic ex clutch question
  142. timing marks
  143. GSR fuel pump
  144. can i put a d15b7 in my civic
  145. car wont rev
  146. im almost ready to give up some one help plz
  147. cel check
  148. 2005 civic rims ?
  149. new motor!! suspension first...
  150. Need Help With SOHC ZC Vtec!!
  151. B18C1 Stalls after warm up.
  152. 91 integra ls b16a vtec issues
  153. Massive Wheel Hopping
  154. jdm d15b vtec MAP sensor
  155. car keeps dying. need help!
  156. overheating problems....sometimes
  157. how to wire in vtec
  158. How Bad???
  159. h22 in hatch
  160. Valve Knocking
  161. i got a quick ?
  162. 95 civic wont start
  163. lights dim
  164. Clunking while accelerating
  165. JDM B18c engine swap to 95 USDM gsr
  166. car wont start
  167. is this normal
  168. exhaust
  169. b18c1 VS b18c5
  170. chec engine light???
  171. b18ac1 1995 civic 1.8 gsr idleing weird
  172. timing jumped!!! help
  173. dots on rear windshield?
  174. Electric Supercharger???????????????
  175. dont know whats wrong
  176. Trany Leak?
  177. clanking/taping(metal on metal) noise...
  178. Engine...Weirding out, Help please
  179. 2.5 or 2.25 exhaust
  180. smellyyyyy~~~~~~
  181. clutch adjustment
  182. vtec spool solenoid
  183. Quiefe vs Honda LSD
  184. good headers????
  185. all motor d16y8
  186. Oxygen Sensor, which one?
  187. tps sensor
  188. 1984 icvic DX 1500 aux. valve removal
  189. hey! Hey!! HEY!!!
  190. B18c (jdm) Vs B18c Itr
  191. 2005 honda civic windshield problem
  192. Why does a neutral-drive launch hurt your car worse than a manual launch?
  193. A/C Questions
  194. heating problem again!!!!!
  195. D16y7 Mini-me
  196. Vtech Problems
  197. 94 integra Ls boggs please help
  198. 2nd gear pops neutral-Honda Civic 1.6
  199. What Is Best?????
  200. What Is Best?????
  201. Ls/vtec?????
  202. passenger window wont move
  203. what swap for tubo app in eg hatch?
  204. 420 in my new 05 civic
  205. GSR Trany on a B16A
  206. tail lights wierd problem
  207. ITR internals
  208. ls/vtec wiring
  209. b16 rings
  210. How to identify what heads I have
  211. Cant keep caliper sliders from freezing
  212. my 91 integra with a hesitation
  213. Need Clutch Help
  214. Story of the First LS VTEC
  215. p28? ECU codes
  216. CEL on and what seems to be vacumm leak
  217. auto to 5 speed
  218. Replacing clutch, 1987 CRX-SI ??
  219. intake pipe substitution, what to use?
  220. B18b1
  221. b18c crank in b16a?????
  222. Chipped ECU *(56K: should be ok)*
  223. How Much Oil Exact
  224. What to swap into my 96 hatch, your opinions please.
  225. ECU quesiton
  226. Air Bag Light On
  227. honda 2000 automatic trans problem. HELP!!!!!
  228. Car making wierd noises
  229. Wiring Harness Help
  230. H22 SwaP!. actin Funny!
  231. will the oil pressure gauge work without hooking it up to the 12v
  232. 91 hatch obd0 obd1 question cars is sittin HELP!!!!!
  233. Help !!!Turbo M35
  234. rotten egg smell
  235. my piece of shit dont start
  236. Sudden oil burning
  237. N/A or Turbo ?
  238. sqweeking from clutch
  239. Where's my PCV Valve? uh oh...
  240. Horrible Engine Knock
  241. Ticking sound could be lifter or cam???
  242. Flamethrower
  243. obd2 harness
  244. how do i test a TPS?
  245. Del Sol Si, Z6 problem..
  246. 89 accord lxi surges and dies and hard to start afterward
  247. hole in my muffler
  248. Internals question
  249. Sleeve the block on a B18C1
  250. piston problem
