Our Community is 705,000 Strong. Join Us.
Honda
> Let's get Technical!
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
tranny issues HELP PLEASE
87 si civic timing
ok checked compression now what?
what tranny do i have?
budget help
d16z6 head on d15z1 block? possible YES or NO
whats the most power i can get from a d-series engine in a 1,700 budget
92 prelude engine swap
oxygen sensor oops
im sick of honda's!!!!! please ReAd!!
help identifying ysk2 tranny
Swap Time
V-tec
Fluidyne radiator
Head Swap
oil pan
Worst Gas Burner
f22a block h22a head
92 civic fuel tank
Overheating, no heat in interior and now not starting
Next upgrade?
Coolant on intake valve
Fuel Tank
Aftermarket rod and chakshaft bearings
White smoke+good compression???
d16y8 build questions
Its Cold Up Here!
Type R
motor SWAP HELP GUYS ASAP!!!!!1
drinking it up
Heat/AC fan in dash
Strangest Problem I've come across
90 prelude si auto tranny issuses
Identifying a D16?
JDM b18c cams
B16a integra da
engine build
LS/Vtec
shift linkage PIN
Needs help b18c itr
Fuse Box
re:turbo
Headers or Intake ??
type r questions
turbo
Knock Under Car
How to destroy a cylinder
failing OBD II smog test
where to start?!?!
how will this set up PERFORM????!!!!!
b16 tranny lever is stuck up!!!
pics of my build
98 Accord Rebuild
cylinder head ports
Need Info On B20 Vtec Crank Case Breather
Cheap all-season tires that are good in snow?
Gear shift locking
Turn signal / headlight
clutch
will intake pass smog test?
1992 Accord tranny
Shifter/Trans question
car problems...
apexi
Some Civic Si Coupe Questions.
What problems can come about...
is it possible
b20 vtec set up info
shortram intake/smog test
removing power steering
What's wrong ?
96 accord enigine prob
Some One please help or send me in the right direction
Crank hitting piston head
Ls/vtec info
shrapnel Pics after hyrdoloc (pics)????
A/C compressor
@#$#'n Cold Starts
Speedometer and Final Drive
`88 1.5L still smokin'...
lots of codes
Distributor question ??
Boring the cylinders
A resistor on the IAT sensor?
Civic headlight problem
clutch / tranny question...
Stuck clutch pedal
1989 1.5 won't fire
Whant to cut out....
Hey
Honda To Buy List!!
Major Problems Help!!!!!
Making a Piston fit
need help badely
b18 antifreeze leak from block?
Clicking after hydrolock
Front Suspension Problem
Hydrolock - clicking sound..
torque specs... help
D17 Swap
alcohol injection
Leaking from oil filter housing
Timing belt cover removel?
B16b HELP
1984 CRX engine swap
96 accord-APEXi Super AFC II for more power and boost?
b18c5 building
Flywheel Installation
need some help
91 integra brake issues!!! HELP
K&N Filter revisited..
header ???
starting problem
spark plug wires
need some help
What SET UP IS BEST!!!!!!!!!
fuel pump not on
91 LS OBD0 swap to 95 OBD1 civic
Can i run a pr4 ecu on a b16a motor swap for now?
Transmission mount
Fuel injectors
2005 civic
pistons
D17A1-A2 Engine Dimensions
I Need Massive Information!!!!!!!!!
Why NA??
Greddy vs. Apexi
Messed up doing simple coolant change!!! got a question...
fuel upgrades?
swap question
timing
What can I expect>?
Series Help
95 integra clutch problem!
is my 95 civic ex obd1?
any good sites
D16Y8 head port...how much??
O2 sensor gone bad??
need some advice about check engine light
del sol innercooler
93accord-F20A-torque settings
Honda Turboz....
this is wierd....
Question???
something is cutting spark on my 92 accord ? any ideas
d16y8 valve spring suggestions anyone??
Technical question h22a swap
d16z6 turbo...
Piston , Rod, and Crankshaft set
installing vafc on obd0 pr3 b16a
Building LS/Vtec
D16Y8 intake manifold on a D16Z6 and b series throttle body
2002 Accord 4 CYL New Owner Needs Help with Engine Problem (Stalling and Maint. Light
Timing issues
AEM EMS engine management system
pulley vs. harmonic balancer?
headers
ls tranny upgrade
LS Tranny upgrade
Air Conditioning Issues
Crv Transmission
96 Civic Dx Crowder Camshaft
A Good Engine
D16y6
Vtec
b18c1 GSR
96 civic dx engine rebuild suggestions????
Sudden noise from motor. Help!
Turbo Engine
ground wires 95 civic
92 accord doesn't start ! D4 light blinking!!!any ideas ??
clutch slave help!
Are 91 and 93 Accord distributor housings interchangeable?
Does anyone know of a good motorcycle forum?
pedals sticking...
Sleeving?
any 1 in nc
I tried searching, cant find it, TCM codes...
95' Civic Dx ignition tore up from thief ... HELP PLEASE !!
Lowered - - - No Cambers
h22 alternetor problem
at intake manifold/mt manifold
a
what is a ricer..?
need the tech names of d series motors
95 Civic Ex Next Upgrade
Junk Headers on ebay
O2 sensor by pass?
what tranny is the toughest d series
94 civic starting problem
worst weekend of my life...
JDM P73 ecu
H22 Problem
Any Suggestions
Integra motor
Auto to Manural Transmission photos
Integra Side Skirts???/
95 LS need some info ???
venom intake manifold
Headlights Wont Work
what is better
obx lsd
ecu for 95 civic ex
Tried this?
Connecting rods for turbo H22a
1/4 mile question #2
rocker adjustment problems
FITV? how far to screw the plastic thing in? ASAP
Brake insanity
engine light;h22 tdc sensor problem
oil entering coolant sytem
Ok... Im stumped...
Brake Booster replacement causes brake lights to stay on, and brake power is VERY low
94 accord
running rich?
running rich?
leak under dash
Shimmy/front end vibration above 60
coolant temp. sending unit
need help with drivetrain noise on GSR
H22 not starting no engine lights?
tail light problem
Help wiring a B16A1 in my 89 CRX Si
Parts needed for a Y8 intake mani on Y7 block/head?
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1976&prmenbr=361
problem with 00 ex
Parts from 97 sedan to 96-00 hatch
Clutch slipping on my 89 crx si!! Please help
downstream turbo
gsr smokin
Need intake manifold help badly!!
SMOG question:hydrocarbons in my car
d16 swap
B-20 in 1991 Integra HELP
oil problem
need help i have high vibration at 4k
Honda Overheat Problem Need Help!
Vehicle immobiliser problem
1992 civic lx 1.5 lit engine non-vtec....need help
timing on 1991 honda accord
Crankshaft position sensor
B16A Gen2 OBD1 ?
Is jdm p72 ecu pinout different from the usd p72?
d15b7 to d16y8 questions
cr-vtec and also del sol b16 swap guids and...
slotted vs drilled rotors
Air Idle Control Valve problem??
a little help from some people with some experience
Automotive Network, Inc., Copyright ©2013
