View Full Version : Let's get Technical!
Pages :
1 2 [ 3]
4 5 6 7 8 9 10 11 12
- My Car Wont Start
- B18a swap
- 91 Civic Timing belt?
- stupid header :P
- injector problems
- What intake should i buy for 98 civic???
- B20 engine swap
- south florida import scene
- what is my zc
- Accord Tranny Question
- tranny swap questions
- newbie with a crx hf
- choking problem...where do i start?
- Oil Leak
- 1998 Honda Civic Si???
- Build up on pistons and head
- post CAI problem
- problem after CAI
- radiator
- Diagrams
- it all starts with a sound...
- Clutch Problem
- speed sensor
- question about d16y7 motor
- Problems with the shocks
- Help!!! Spark Plug!!
- Cooling fan Situation
- ysk 1 tranny
- Computer link on '99 Honda Civic DX hatchback
- confusedd..
- oil in sparkplug wires
- d17 question
- d15a3 Project
- REVVING problem
- b16a2 swap, half of del sol cluster not working
- Need to get my car refed
- Car won't start but no pgm error codes
- Pgm Fi?
- Leaky oil pan....
- Adding cruise to a Civic
- zc pistons in an a6
- Hypathetically saying!!!
- lightweight!!
- question
- Radiator Swap Walkthrough
- Info on b16a1 swap to 92 body
- b18a1 driveshaft problem
- b18a1 into a 90 hatch help .
- Brake upgrade for GSR.
- 1992 civic dx wont start!!!!
- 97 Accord FR power Window is slow or gets stuck??
- What does it mean...
- My speedometer is going nuts!
- Possibly getting an h22a Accord what do you think
- Del Sol no start problem
- cams
- civic engine noise - what is it?
- Service Manuals
- i need you guys more then ever!!!
- f1 racing clutch
- need info on 89 civic std compatibility with dx head
- Overheating
- Oil control orifice
- 97 accord is blowing hot air. Help! Freon didnt work.
- MAP sensor question...
- Needing Help Fixing The Problem
- Valve Chatter or knocking?
- Block A/C & radiator w/ tranny cooler - how much?
- XS Power Cams
- No Clutch!!!
- Oil in spark plug recess
- Car Wont start after gas put in it?
- I Need The Help!?
- FOrks??
- skunk2 manifold install
- adjustable cam gears
- OBD2 vs. OBD1
- intake ????
- engine runs like crap
- lsd for b18b
- Oil is gone.....Help!
- need numbers
- Losing Break Fluid???
- WTF is this on my block? (pics)
- To anyone who works on his/her own car...
- which oil???
- Racing Cam Help! PLZ doing now
- junk yard engines
- wiring for my swap
- does vtec work when cold
- carburetor diagrams needed
- car overheating help
- Hondata or Apexi vtec controller
- Skunk 2 manifold
- B18b & B18c
- EGR valves
- EGR valves
- 75 shot
- cant tell a differance gsr /type-r
- tps problems
- no spark, help!
- starting issues
- D16Z6 to D16y8 Swap homework
- LS/VTEC wont start, was running fine
- Rear Diffusers
- 95 honda accord keeps cutting out and backfiring..
- need help quick!
- ATTS 2001 prelude sh
- tranny noises, someone please reply
- Obx Lsd
- wiring diagram for a 2000 type R
- Cylinder head weight?
- question about h22 manifold
- vtec h22 head fit a h23 block
- Degreeing The Stock Cam on a SOHC ZC
- Gasket sealant
- 85 crx fuel issues
- Mod/hybrid my f20b
- 1993 honda civic shuts off when started!!!
- can fmu replace ecu in upgrade
- 94 Honda SI redline problems
- need help with my accord
- exhaust
- GS-R Burning too much oil
- Valve adjustment
- Skunk2 manifold for turbo?
- New Civic SI beats a TransAM!?
- Need Help
- fuel injector help?
- I think...
- 93 Accord Vibration after belt replacement
- Fuel Starvation Problem Please Help!
- I need help bad...
- Speedo Not Reading Right
- help-ls vtec swap in progress-help
- d16a6 pistons in a d16y7
- Dark LSD Fluid
- yo, do my chrome rims help wit downforce?
- Valve clearance
- custom-built vs DC exhaust?
- b series comparison
- D16 pistons...any suggestions or websites?
- 98civic d16 cam?
- ????? about Valve timing
- Lengthening O2 sensor wire?
- how the engine cut off
- TOTALLED MY LEGEND GS.... need info!!!!!!!
- Skunk2 Intake Manifold and Throttle Body
- auto ecu in manual tranny
- D16/b16
- Fuel Pressure Regualtor
- AEM V2 Intake
- Cold Air Intake
- Accord Parts
- 92' Honda Civic BEST ENGINE!
- rebuild or upgrade whats easier
- 93 Integra only starts in reverse
- help!!!!
- Valve Adjustments
- Problems Help!!!
- Problems Help!!!
- d16 mini me swap timing belt...
- Acura TL 2005 6 sp manual -synchronization
- vtec+turbo=no good????
- VAFC 2 Intial Setup
- Misfire
- vtec wiring
- 96 civic dx mini me swap?
- What kind of Exhaust is the right exhaust?
- skunk2 stage 3 cams
- ex/si cluster in a dx
- 1989 Prelude fuel filter 6mm bolt
- Headlight Relay?
- ignition/spark plug wires for prelude
- Going N/A until new Turbo comes, Fuel question
- what rebuild kit
- Steel Seal and others.....
- valve cover gasket
- is a boost controller necessary
- help choosing a car please!
- 1993 ls-vtec teg fluttering and bucking-just purchased
- 01+ Civic "Manufacturer" Steering DEFECT
- Location Of Egr Valve
- Test Pipe and O2 simulator
- Sleeves for a B20
- ls/vtec...few extra questions
- Prelude Type S Cams
- vtec conversion kit
- engine lift fluid
- bypass valve
- a ????????????? please!
- power lost on new headers
- OVERHEATING over with???
- can u chip pm6 for ls swap?
- lol read this
- Rebuilt engine shuts off after running 2 minutes
- is obx a good brand name?
- b18c1 won't start
- crx problemo
- how do i install a apexi vafc(old school version) in my 93 civic ex?
- d15 to a d16, what to do?
- Help with Brake caliper seal kit
- rethinkin the project...???
- K20a
- Ls/Vtech integra
- building the internal kit
- '98 Honda Passport/Isuzu Rodeo timing belt
- 96 civic w/98 engine wont start
- 96 civic fuel pressure reg. question
- Parking Brake indicator on 97 civic - controller issue?
- voltage spike 2000 LX Accord need ICU info
- is this possible n realistic
- i want to turbo stock d16z6 engine?
- Master cylinder help.
- AWD Civic Hatch
- 98 Rl
- False o2 code?
- apexi vafc intall HELP!!!!!!!!!!!!!!
- spark plug
- grinding noise
- tranny fluid LEAKING.... HELP
- 94 Honda Accord safety ???
- Gauge pod swap, help please
- type r fuel & timing settings.... help
- Spark plug gap
- oil on spark plugs?
- OVERHEATING, OVERHEATINg
- Manual Remote Start Override
- 02 civic dx cat problem
- Throttle body spacer
- just need someone to tell me how to turn eng light off
- engine build
- a/c problem
- About Oxygen Sensors (narrow and wideband)
- 96 civic auto to man tranny swap
- D15b7/D16z6 need assistance
- D series
- 96 Passport Wont Start !!! Ecm????
- oil LIGHT
- Testing alternator voltage regulator??
- 1993 civic vx engine(d15z1) in crx??
- 2 Intermittent codes
- plugs soaked, 1.5 vtech won't start
- is a d15z1 a jdm engine??EVER??
- how do i bore from a 1.6 to a 1.8??
- Honda motors in Saturns???
- Knock sensor.
- Gas, oil and engine problems
Automotive Network, Inc., Copyright ©2013
