View Full Version : Let's get Technical!
Pages :
1 [ 2]
3 4 5 6 7 8 9 10 11 12
- 1988 Honda Accord DX Door Ajar Chime!!!
- exaust
- CAI -or- SRI, worth risk of hydrolocking???
- Fuse panel diagrams, wiring info for 95 Integra
- extra pipes on bottom of radiator
- CRX wont start every time
- superchargers
- Civic hybrid code??
- Renting vs Own for long drives
- Is it right or wrong?
- Weak car? Big problem
- D15 With 400+hp
- 1998 Honda Civic - Erratic Stalling
- Loud roar after timing belt replacement
- 91 Accord: Noise/Vibration
- obd 1 map sensor on obd 0?
- 2005 Honda Civic Air Filter ?
- HELP!! Car won't start, HAD oil in cylinder, RINGS?
- where to find engine specs
- misfire...
- weird noise :(
- advice needed
- anyone installed an afc neo onto a 1997 civic hx
- Need help 1994 D15 leaking oil onto exhaust
- 91 dx hatch
- Help, Help, Help, Coilovers
- b18b1 no start??
- Transmission Problems? Please help
- Quick Question Please Help
- vtec not hitting
- The Truth About The Zc Series!!
- Honda Crv Wont run
- 1990 legend 3.2L engine swap
- 8 or 12 Valve Head on D16B6...HELP
- manual transmission replacement ????
- Lighting troubles.
- Smoke from tailpipe (exhaust and...
- 89 crx white smoke...but not head gasket
- 94 Honda Accord TRANSMISSION HELP
- Electrical Problems 98 Accord EX
- Need help asap with alternator wiring!
- coolant system problem?????
- Auto tranny clutch problems
- Need Opinions & Suggestions with my FI setup (CRX
- C32b With C32a FWD tranny?
- 98 Civic EX Tranny issue
- System Too Lean
- 97 Passport Leaking Antifreeze from Under Glove Box
- R18
- ac leak
- A20 Question
- Thought this was funny
- Alternator problems!!!
- Engine dead @ 100K
- B16A2 head on a D16Y7 block?
- Trannie
- 1998 Civic head gasket change
- Rear Disc Brake Caliper Piston Not Retracting
- Help Needed
- Is this a fuel filter or pump problem?
- turboing a B16A2
- Struts Vs. Shocks?
- Hellllllllllp
- Transmission Question
- CX/B18B1 swap
- Battery keeps dying
- Burning coolant... how long does it take to burn out all of it?
- obx throttle body spacer
- 91 EF civic dirt track help?!!?
- My passport is leaking spraying antifreeze
- Oil leaked into spark plug chamber?!?
- Del Sol Boot dimensions
- 91 Honda dies when hot, starts fine when cold
- 2000 acord v6 missfire code
- simple newbie qu about auto-trannies
- Water pump reliability
- Unortodox Racing Crank Pulley Help
- need ecu info!!!
- high compression turbo zc
- Did I blow the ignition?!
- check engine light code
- da16a7 engine management light on ??
- h23 head on a f22 block
- high compression???????
- stuped question
- wiring problem
- Water leak side window
- what does 4 cylinder mean?
- 95 Odyssey Temp Gauge
- insufficient EGR flow code
- cel code 4 help
- b16 head on a b18 block??
- 1990 Honda Accord Trany Issue
- LS/VTEC turbo or B18C1 turbo
- power fc or aem ems
- Civic HB modding questions
- Engine project
- compresion
- Lsd?
- rough idle
- More power for 98 Civic DX a/t
- 2002 Accord SE
- Oil in Cylinder!! What can cause this/how to fix??
- im an idiot
- Engine swap????
- Haynes or Chilton???
- Quick question !
- Vtec
- So little money, so many things...help!
- my journey in mth war
- d16y8 into 95 civic wiring questions
- 1990 Accord EXR tranny fluid type?
- Acura/ Motor
- prelude vtec not operating
- cylinder head
- I got a Big Race In a few days!!
- ha might be a stupid question but..
- Smog Problem.
- aem cai, last station power box, t1r b-max carbon intake
- What turbo is this?
- LS/VTEC Turbo
- turbo b20?
- New Q & A Forum Concepts
- Honda Civic SIR=II and VTi Specs?
- msd ????
- 94 Accord, problem with idle
- Honda Odyssey "choke" problem
- Exhuast it TOO LOUD
- Safc install help 97 integra ls
- Honda Civic 89 Misfiring - Where to begin??
- 01 civic shifting DIFFICULT and SQUEEKY
- Shifter problems
- B18C head + B16a = Good set-up?
- Smaller Battery?
- greddy e-manage ?
- Silicone aids rusting on metal?
- help with build?
- LS/VTEC Problems need help
- 93 civic stalling and tach and speedo going crazy
- HELP! In desperate need of ideas, My Accord Died!!
- Having an electrical problem and need help
- Hard starting after Timing Belt Change - Runs Fine when started?
- Ek 96 CAm Gears
- This should be simple, but...
- ??oil in radiator fluid...
- B-series Lower T-Belt Cover Interchangable?
- help!!!!!!!!!!
- 99 3.0 CL Won't start in Park
- limited $$$ rebuild? fuel management? ignition?
- 2000 accord with P0401 EGR code
- old school ek1 cvcc carb fuel tuning
- Need opinions on this buy!!!!!
- f20c refit
- trouble codes...
- burning/frying smell
- speedometer cable
- Rev Problems
- 91 CRX Dizzy trouble
- 1991 Honda Crx Problem!!
- I have gas in 1 cylinder
- d15b7 with 91 civic si head?????
- interesting conversion i found
- '00 Civic auto transmission swap
- Maintenance light
- 97 honda civic DX O2 Sensor
- having problems with my d15 vtec
- oil pump
- Rear intermittent wiper mod?
- d16a6 engine rebuild
- Help! 90 crx smells like gas inside!!
- Ouch! Grinding gears!
- usdm b16 swap with d16 ecu/mounts?!?!
- Need advice lower end D15B 91
- electrical problem
- digital dash gauges
- oil squirter?
- 98 CR-V Rear grinding?
- Tranny Talk
- Freaking Weird
- Trying to my Honda to quit smoking..Need Help
- overheating
- thermostat gauge
- Oil Leak after replacing head 91 Honda Civic 1.5 SOHC
- Difference between tuning and diagnostic tools
- Brake System
- Diagnostic Tools
- please tell me how to adjust a TPS sensor
- does anyone no how to really adjust TPS sensor
- Recent H22 swap PROBLEMS
- shock rebuild?
- Honda vs. Scion
- Replacing the O rings on the Thermostat housing
- Help with motor
- Power and MPG Increase
- HELP: RPM hesitations
- 91 integra reliability=
- JDM H22a Issues
- 88 accord starting problem
- Tranny Bearing
- 2000 integra i need help!
- 1992 Accord brake issue
- Accord Idles @ 3k!! Help!!
- water in b18a head
- Cam shaft upgrade, will it kill the Auto tranny?
- No vtec! please help!
- B16a2 IN a 89 si Crx
- woohoo fuel injectors!!!
- Civic half shafts
- CRV Rear Diff fluid change
- General Questions on Honda Engines
- Engine swap- civic sohc v-tec into 16 valve accord
- Civic door adjust??
- 94 Acura is not passing alot of gas
- B20B Super/Turbo Charger
- Soch Vtec 93' on a Coupe 96'
- what kind of exaust on 96' civic?
- Acura Engine Questions
- question
- weak breaks in the traffic hit
- overheating?
- 91 Honda Civic Sedan Air Conditioner
- ac not working
- modification questions
- 1991 Honda Parking Brake Problems
- civic idles but wont rev
- Need Help with my Integra - Starting prroblem Vti-R (GSR)
- Brake Lamp
- Cooling Fans
- 1993 accord service manual
- accord power
- B16a starting/dizzy probs
- Engine goes off from time to time?
- Radiator Fan Not Coming On 98 Civic
- I need a lot of help!
- Cracked Header - Big problem or let it go???
- 95 Honda Civic EX 1.6L automatic/check engine light/no air
- Input for new car purchase
- help me figure out problem please
- Timing belt
- Carburetor question
- Lower Ball Joint Nut
- Vtec worth tuning
- Installing EBAY ECU
- i have a question...
- D13b1 Rocker arm play?
- something weird about my vee tak!
- b16 wont rev past 3k ??
Automotive Network, Inc., Copyright ©2013
