Our Community is 705,000 Strong. Join Us.
Honda
> Let's get Technical!
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
Is there any difference in the B18A and B18B blocks?
JDM/USDM parts compatibility........
Fourth Mod ?
quad throttle bodies
b16 w/ integra ls/gsr 5th gear?
Motor ? 89 Lude ? My Motor ?
true or false
F20B in my accord?
b16b swap
RSX shifter
'88 Civic, no reverse lights?
ecu for sohc zc vtec
200ft skidpad
integra
Someone wants to trade a b18b1 for my 97 ex should i??????help
automatic manual transmision conversion?
best suspension?
blow off valve
LS Integra
sohc zc vtec
somethings wrong with my ls vetc
Location of VIN on Ls motor?????
Port and Polish?
teg vs civic
header
f20a engine swap
rsr vs skunk2
Problem With My Radio And Turning Signal
How To Install Solenoid (to Open Door) For A 95 Civic
radiator problem in hybrid
is it possible
Can I do it myself
h22a into an 88 prelude
Flywheels??
94 honda hatch. with B16a2 vtec engine
MSD rev limit help
need help with b16a1 vss wireing plz
Where to Buy ECU Connector Pins
92 Civic DX Performance Tweaks
need help wiring up vss for my JDM b16a1 in my 89 civic
has anyone actually done this??
1/4 mile times with the B18C1 engine
engine codes site
Anyone know of a website to buy K20a/2 motors?
transmission noise
2003 Civic LX Coupe AirBags???
H22A into 1991 CRX
B16A wiring for a 94 civic
1998 integra GSR swap for sale $2000.00
How to install Reverse Glow Gauges? (overlaps)
V-Afc issues...
What would i have to do, to get a prelude (4th gen) into 14's?
right hand drive 96-00 civic hatch?
CEL light
H22A stutter and jumping.
Anyone know where I can buy newer Acura/Honda engines?
MSD digital 6 problems
Vtec Help
clutch Question
Pacesetter exhaust
H23 Vtec
hondata?
vtec controller
All motor H22 vs H22 turbo?
95 Honda Civic Main Relay
repair fiberglass
what problems come with Ls V-tech
H22A to a civic swap
B16A or B18C?
what would be the best engine swap for a 90 integra....
Problem with COLD start..
B series project need opinions/advice
ITR head & camshafts for civic si 99'
Is this a good deal(B18B Motor +)?
H23 Auto Lsd
need some B series swap advice
TRANNY: B18 vs B16
D16y7 Question?????
Aluminum Flywheels
ECU code 6 - circuit testing
Piping my accord 1992
B18B Anyone?
Need Help On Si Engine
b18b block
b18b block
How to hook up Apexi V-tec controller to 98 prelude?
H22: Type S Pistons And Eagle Rods
no heat when stopped?
b18b electrical problem
87 honda accord lx has crazy or sometimes no idle
2" collector on my DC Sports header...WUUUT??
Mount for my CX to put in B16?
Where to buy my b16a
92 zc dizzy
lsd for ff?
B series motor questions
Trouble Code P1486 2000 accord lx coupe
how to swap 92-95 ex with JDM B16 engine...
Mounts
help please
check engine light after swap!!!?
What do you think?
2 Piece 4-2-1 Header Question
85 Accord
Vtec Not Working, Need Help Please!!!!
b16 runnin mid 13's??
b21a1 vtech
question aboput intake manifold
1994 Honda Civic Check Engine Light
which clutch for turbo ls?
f22b swap
86 crx motor
H22A Boring or Re-sleeving
B16 swap problem please help!
twin turbo on honda?
ls rod in d16a6 how too. please help!!!
B16 Or Zc Engine Is It Hard To Put A Engine In A 1990 Crx --dx-- How Hard
Help..Need Competent Mechanic
SOHC non VTEC ZC
f20b for an accord?
h22a into 5th gen civic ex
K20A2 vs 3SGTE
Welding cracks in a Header
increase RPM and high revving?
engine buildng please suggestions?
engine building please help
Hondabond and valve cover gasket
help deciding on how to spend $$$$
shaved door kit
b18c1 swap in civic help????
cheapest place to buy a dohc B Series head?
hatch vs. coupe at the wheels
rb26 able to fit v6accord?
V-tch kicks in @ 4600...
b20
The Ideal Motor
Need help my ZC Head
engine problems
90-93 accord mesh grill
ECU OBD0 or OBD1?
ECU Swapping?
b16a factory valve lash clearance specs
sohc zc help!!
B16A swap wiring
4th gen prelude guage install
Will my motor fall out?
Field SFC Hyper R - Install Help
i need help
Need1986 prelude ground kit
What to do with a b16
where is a Idle Air Control valve located?
Need help don't know what engine i have?
EGR valve anyone!!??
euro r conv. for 98-02 accords?
some suggestions for an intake
95 honda civic lx idle problem
Mis-shifted
1996 Civic DX
need help on ls/vtec
B18C1 SWAP QUESTION>??
OBX Type R exhaust
Reconnecting Internal Coil Help
H22 closed deck
h22a mount question
DC header
Swap to Vtec
suggestions for ls interals build up
idle issues w/ 95 civic si
nitrous on b16a motor...
CoBRa KiLLa???
VTECing It
Emissions Question
Loss of power for short times
Jdm K20a
fuel pump wont prime motor after swap help!
E300 2.8 cold start problem
1999 Honda Accord Moonroof
SKUNK2 ECU...opinions????
Aem Cai
A ? for B20 or LS
Engine Years
LS/VTEC ecu question
huper ground system
NA vs Turbo
ECU Location
b16 question
1988 Honda accord-ignition off-car still running?? HELP
Underbody Kit on a Body Kit for the Civic Coupe...
b16a Error Codes, Need help desperately
OBD question
i want to build up my d16z6, how should i do it
Automotive Network, Inc., Copyright ©2013
