View Full Version : Let's get Technical!
Pages :
1 2 3 4 5 6 7 8 9 10 [ 11]
12
- Failed Emissions...NOx & HC...any ideas?
- idle problem please help!
- Front windshield in my 95 Civic
- A/C belt on my 95 Civic
- B16A vs. JDM B16B
- B18B Longblock???
- boosting hp on 92 accord lx
- P75 vs P28 diffences?
- b16a crx question
- B16A1 Tuning
- 97 HOnda Civic Ex D16Y8 SOHC
- Check Engine Code 9
- b18c swap/tranny/clutch question
- chipped ecu with piggyback vafc
- headers or intake manifold ??
- 91 accord dies when hot
- D16 parts on B16?
- H22a question need help!!
- Difference: LsD SiR & Non LsD SiR...
- wanted : knowledge of stock air intake
- low brake pressure
- zc 1.6 16v DOHC
- USDM parts for a B16B?!?!
- red indiglo gauges?
- DOHC ZC problems......
- Factory LSD Cable Transmissions
- LS/VTEC's for sale
- H22 redline
- anyone have any info on a f22a non-vtec head swap to a f22b sohc vtec head
- Hybrid Transmission: Anything I'm missing before I start?
- H22a - what's next for it
- thermostat location
- head swapping
- Thinking of doing a h22 swap
- Better IM: skunk2 itr or stock b16
- how do i put in a newer radiator
- 6 spd civic?
- vtec questions
- Bad smoking problem..Need help?
- Valve clearance -> power loss: who can figure this out?
- Dropped screws in AC vents! Help!
- h22 into accord
- dose any one know the valve clearance on a ZC DOHC
- Will S2000 / RSX TypeR motor fit in a hatchback?
- B16 with Vortech?
- Problems to get to TDC (99 Accord)
- V6 swap into a 1990 honda accord
- Wil Anyone Respond To My Skunk Cam Question??
- What Ecu To Use With Gsr Swap???
- B18C and Turbo
- Hondata Tuning
- 01' Civic EX Exhaust
- JDM B16 needs turbo
- valve specs
- 1997 honda accord transmission problem
- DSM Injector questions
- h22's - does anyone know?
- Failed Emissions...NOx & HC...EGR Valve?
- 01 accord w/ wheel noise from front passenger side
- ET/mph for 93 dx coupe w/ B18C5 and 5spd LSD tranny
- B18C5 swap into a 93 DX......info
- EK9 or EK6 LSD
- oil change....snythic
- B Series question
- Stroked B16 questions
- need walkthrough on installing a/c compressor in 93 teg
- Any Help?? Engine Removal Question
- Need some serious help with my Skunk cams!!!
- f22b dohc
- Rsx type s- disadvantages with low torque
- is it possible?
- what should i do?
- Honda Civic Questions
- coolan temp. sensor problem???????
- Another Civic Q
- best intake filter
- 84 CRX transmission work with an 83 Civic?
- Field VTEC Controller
- CRX Engine Swap
- Help wit my civic
- Newbie...H22 swap help.
- 99 B20Z2 (CRV) Ported & Polished Head For Sale
- Daily driving w/ a light weight flywheel
- crx engine swap..what will fit?
- URGENT HELP! B18b Stuff
- Quick B20A5 Question
- Prelude OBD1 conversion for auto trans
- 1990 civic motor swap or head and porting ?
- 91 accord questions
- failed smog
- Cams for B16B
- how do I know if this is an EX tranny?
- Good Shop to Swap engine in Atlanta, GA
- What is better? GSR or LS Vtech?
- Just swap for a brand new b18c5 engine
- GSR swap for a 99 civic ex/ d16 turbo
- Vtec Soleniods?
- gsr swap
- h22 with f23 tranny?
- Manual Tranny filler/check bolt stuck
- DSM Injector install questions
- help me half-assed get my indiglo's to work.
- Question about VTEC
- B20 swap, crankcase breather? PLEASE HELP QUICK
- 1985 Honda Accord
- Light Flywheel on Stock Clutch?
- 94 Del Sol w/B16a JDM swap California ?s
- sohc zc clutch help?
- ZC vs. D16a1
- Will the stroker kit lover my redline????
- Building A Crx
- Clutch Problems?
- possible distributor problems
- B18B into my 97 civic
- B20 VTEC vs. B20 Turbo
- Climate Conrol
- In reply to jrcx, sooool eveyone can see a FOOL.
- Crx?
- anyone have a B series trans they didnt use that is for sale? even just the case??
- 87 CRXsi electrical problem
- bye bye accord....
- compression question
- cams and valvetrain
- ls vtec
- b16a2 with performance cams.........
- B16A ECU codes...
- noise at high RPM
- weird metallicy noise most of the time
- how much hp D16zc has?
- IYO...Best oil? Turbo or SC?
- Type-S tranny?
- Is a vtec controller need for skunk cams?
- Is there a high performance tranny for b16 A2
- You People don't know what your talking about!!!!
- B16 Turbo, what shot of NOS to use???
- abs light
- Oil pressure sender
- 97 civic ex
- b18a engine compression
- 96' Accord - Need detailed info for H22 swap! PLEASE!!!
- D-series engines
- best swap 92 civic
- 98 Accord Brake help!!!
- 1997 integra ls looing to swap Motors!!
- B16a SiR2 Help!
- engine swap: E-TEC to VTEC
- Time to swap the motor yet again.
- B16 A2 what compression pistons for Turbo
- Prelude JDM H22A swap/manual conv. problems
- will my swap smog?
- Si or Vtec
- Distributor Runs Fine Cold but not when Warm
- Civic B16A2 VS Civic with B18C1
- obd0/1/2 confusion
- my ludes hurt
- B16A Fuel Pump
- Adjusting vtec
- engine swap
- 99 Si exhaust, will it fit?
- proformance parts for a 86 civic
- 90-93 cheap parts
- 86 civic with the EW1 need a bigger motor
- Problem with Honda CRV. Engine Stalls sometimes
- 95 block with 99 head possible??
- B16 install info
- V-tec problems
- Spoon Cams
- B16 Swap question
- B20a5
- Timing
- My B16 not running good HELP
- B20/vtec
- b18c rebuild
- Weight Reduction - more than basic, tips?
- Stock teg camshaft specs
- b16a problem on crx, engine problem
- How to wire vtec?
- help on an 88 Honda Civic DX
- Making Power out of D16z???
- Engine RPM drops when Headlights are turned on
- h22a to integra
- help civic LIGHT PROBLEM
- b18c block/b16 head or ls vtec
- Shifter rods and cv shafts
- 88 Accord problem, help appreciated
- how much $$ I can get for a electronic speed sensor for b16 jdm
- b18c turbo??
- shifter help
- INFORMATION on acura power chip
- LS/Vtec on LS teg questions
- Maintenance light on 2000 gsr! need help
- HELP ME:Motor Swap: 1991 civic real-time wgn. w/ gsr or will a h22a work...???
- D17A1 swap
- Swap Question
- LS VTEC+ECU+Turbo
- knock! knock!
- B16 series Swap Manual
- cams for turbo LS
- b16 wont start
- B18C5--can she handle performance TB, IM, CAI, h/e???
- B16A2 cable or hydro trans?
- What is double clutching?
- Is B18c1 Good On A 2000 Civic Ex??
- Quick Question: Engine sawp or Mods
- Engine's for 88 civic dx hb
- Help with OBD research project
- 2000 si 91 teg
- zdyne gold SECU or hondata s200
- headlight removal
- Ls swap in hatch, which fan, linkage, etc???
- Hondata s200 or AEM EMS?? pls help..
- Greddy EVO for Integra
- upgrading my car.......
- B16A TPS Sensor
- Reprogramming Stock ECU?
- DX hope?
- Burn outs
- anti lag system
- b20 w/ b16 head
- Fuel Filter 87 CRX
- b17
- standard civic dx engine swap with b18c5
- 1.8L and 2.0L eng why can the 1.8 revs higher??
- B16 swap questions, wiht my B20 of course.
- ls b18b with type r crank ???
- 98-02 accord HELP
- B16 swap question I cant figure out
- Type R redline
- Floating RPMs
- spark plug wires on b16a1?
- 98 Accord - Stuck in Park & No Brake Lights
- 1990 Civic Sedan - Taillight problem
- 89 crx si ?
- ls Motor b18b
- cam question
- cam question
- Motor Swap?
- Speed govern
- 99 accord
- Motor Swap Completed :)
- 88-91 civic EX question
- civic 2002 180 kmh engine cut off
- CAI or short ram for good gsr top end
- THROTTLE BODIES effects??
- OBD1 Dohc Distributor
- Suspension brand
- spoon, mugen
- using timing light on '88 Civic 1.5L hatchback?
- dont laugh too much
