View Full Version : Let's get Technical!
Pages :
1 2 3 4 5 6 7 8 9 [ 10]
11 12
- 91 crx hf swap
- B16a needs help! Injectors,fuelrail,fuelpump
- ls/vtec step by step guide?
- 1993 honda accors ex
- air fuel gauge install and got a ????
- aem v2 on a swap
- crvtec vs. ls/vtec
- ls to gsr swap
- d16y8 to b16a
- Exhaust system question.
- Genie exhaust v Xforce
- want to get internals rebuilt ?????
- B18c1 swap into 99 civic ex
- Blew engine, need info d16 to b16
- Easy mods
- F20B from Accord SiR
- b16 vtec problems....
- H22a Camshaft?
- brake disc questions
- b16a, b18c
- Axle problem on 92 Civic Hatch w/ B16A
- Fuel indicator problem
- Can Launching cause problems
- Engine Swap question D16A6 to D16A3
- 93 b18 into 90 civic dx. Do i need obd-0 parts instead of obd-1?
- Clicking Noise?
- downpipe and up pipe
- price on B18c
- VTEC Controllers...
- top speed
- Which headers to go with?
- Accord motor number
- Gauge cluster if it matters?
- help with racing harness
- Parts/Distbtr Part number etc.
- clutch problems
- f20b (accord sir) swap in integra
- Ignition System upgrade
- Stroked LS Vtec (2.2) vs b20 vtec vs h22
- RSX-S motor into a Civic
- A/C question?
- "Check Engine Light"
- Swapping an engine
- SiRII Or not?
- Which distributor?
- H22 or K24 block/K20 head....
- CIVIC EX AUTO TO 5 SPEED SWAP ?'s!!
- Engine/Tranny Swap Question
- Safe to run 115+ leaded in my car
- cat 02 Q
- 12 second honda civic ex??
- injector noise
- 1/4 mile times on 93 dxhb h/i/e
- Oil Filter Relocation
- Help with my reverse gauges!!
- blown b20 with b18b tranny?
- A'Pexi AFC Vtec or any others
- Custom exhaust versus Greddy, Skunk2, etc.
- still confused about ZC
- B18c5 question need some input...
- compression test results good or bad??
- Out with the F20A4 in with the H22A
- wats the best engine for a honda
- how to ger euro car to america
- skunk 2 vs JG edlebrock
- b16a head for ls/vtec
- hasport not like 2nd gen?
- H23A DOHC VTEC - trans ratios?
- In need of wiring diagram for resistor
- Can A o2 Sensor go bad without CEL?
- Header Brands
- 95 HATCH SOHC ZC SWAP ???????'s
- 2nd gen zc distributor problem
- Shift light how to wire
- DIY Vtec controller
- zc info
- si engine?
- Converting '97 Accord LX engine to EX specs?
- what swap for 94 integra
- Car cut out at 95 mph?
- Honda prelude Torque specs
- Prelude doing crap .... help
- Est 1/4 time?
- port and polished head on a d16a6 how much gains?
- b16a3 engine, check engine light= knock sensor
- best moter for a 91 crx
- swap b16 for b18b
- b18b1 timeing
- LS/VTEC or B16A2 in CIVIC
- d series tranny
- h22a1 stroker kit?
- B18c Type R swap help!!
- b18b compession cylinder?
- Intercooler in a 91 integra
- Cheap Brand Make any differance?
- B16A Code 16 Failed Emissions Test
- AEM Bypass valve installing...
- Will a Type-R gear set fit in LS Tranny?
- Ls/Vtec----Experienced only please
- B16B vs B18C
- Blue Earth Gasoline vs Standard Unleaded
- h22a swap is done
- What brand and why for Exaust, Ignition wires, Spark plugs, Ecu, Headers, Intake
- What head package should I go with? Please respond cuz no one ever does!
- Fourth Gear Problem
- 92 zc map sensor
- best air induction
- Q's on b18 blocks.
- basic maintenence
- how do I identify my tranny? si or dx?
- A real Accord Type-R
- Honda Prelude wierd smell and steam/smoke
- d15b how hard can i push it...
- Hondata application info???
- Clutch pressure
- Tail light conversions
- Car blows fire out the exhaust?
- autotechnic vtec controller
- Integra GS-R Idling problems HELPP
- prelude swap
- B16 turbo
- Tranny or Motor ?
- Integra Idling??
- H23 Vtec Head Swap
- 95 Civic Swap Q
- Where is the tps wire on a 97 Integra?
- Getting the plastic instrument window off...
- 1982 civic question re:muffler
- 1991 Accord Supercahrger?
- weight of prelude
- Need help to remove 94 gsr dash
- wiring SWP gauges on a 95 civiv
- 98 Civic Malfunction Indicator Light fix needed
- Mounts for b18c1 into 93 Civic hatch
- brakes
- smokey?
- 98 Civic passanger fender
- Engine swap for a 97 civic ex
- double clutching.. what actually is it??
- H22A V.S LS/VTEC Please help.
- catch can?
- Accord Euro-R Intake Manifold
- anyone here on 11:1 daily, stock ecu also
- V-afc II H22A
- d16 engine problem?
- Car doesnt move after high psi blast?
- best swap
- Buy an Accord SiR CD6 for about $2000
- H23 head swap to H22 head
- Type R swap
- Integra engine max boost
- b16 questions
- what woudl a b16 tranny be like on a b20?
- which motor: h22a type s or b18c?
- tranny?
- b18c or b18c1?
- Need HELP on a 2001 CL
- Engine Swap Daytona area
- N/A D Series
- Making Type R horsepower
- No Fuel Pres. Riser if have S-AFC?
- H22 Swap
- will b18c5 bolt directly into my 91 teg
- b16a sec. gen. trans question!
- b18 in 88 civic hatch what do i need
- D16A6 question...
- Cont. Head Swap
- Choice of new motor mounts
- Hondata?
- engine compression
- Head Swap
- Engine Swap in the Bay Area
- B20b turbo ?
- AWD Honda conversions
- !!! K24 into 94+INTEGRA !!! *help need info*
- Low temp thermostat. Run Cooler better?
- Need help with regestering my Japan import civic in Washington
- B16 turbo questions
- High flow cat good/bad?
- Diagnose my distributor problem. With pict.
- Header Ques.
- zc info
- H22A horsepower
- 92-95 civic dx rear speaker installation
- My ZC Finally passed emmissions
- Integra GSR
- Q's on a b18 swap
- b20
- ...cRvTeC?...
- HELP..With next mod 4 RSX-S!?
- Engine Swap Question
- oem bumper
- Which Motor
- type r intake manifold idle problem please help!!
- B16a2 CRX Swap Exhaust Question
- VTEC v.s. VTEC-E
- K20 H22a B18c(type r)?
- B18C Question
- removal of catalytic converter
- Cheap ripoffs of the brand name
- h22, h23a, or f20b???
- ls/vtec ??
- removing 2000 civic dx rear dashboard
- BS A20A to a B20A5 swap?
- B18C1 Automatic ECU?
- URGENT: Help me ID my Tranny via Gear Ratio
- 200+ hp d16?/ b16 or b18 swap?
- Does higher viscosity oil raise oil pressure?
- motor swap in 88 crx
- gs-r running 13.0s on stock internals????..
- B16 fitting problem
- 90 Prelude H22 Swap
- Bore and Stroke (B18B1)
- Need suggestions for CivicHatchGSR
- tps install please help!
- please help with tps!
- boost
- CRX with Integra Type R hubs/axles???
- Name that Engine!
- sohc apexi vtec controller
- B16 cable final drive.. jcrx chim-in
- how much for LS engine?
- vtec on an LX civic?
- Questions about future project car...
- Boost a b16 will it fit?
- Dx 2 ex swap
- Boosting an H22A
- Intake for Honda Jazz/Fit
- Failed Emissions...NOx & HC...any ideas?
- idle problem please help!
- Front windshield in my 95 Civic
- A/C belt on my 95 Civic
- B16A vs. JDM B16B
- B18B Longblock???
- boosting hp on 92 accord lx
- P75 vs P28 diffences?
- b16a crx question
- B16A1 Tuning
- 97 HOnda Civic Ex D16Y8 SOHC
- Check Engine Code 9
- b18c swap/tranny/clutch question
- chipped ecu with piggyback vafc
- headers or intake manifold ??
- 91 accord dies when hot
- D16 parts on B16?
- H22a question need help!!
- Difference: LsD SiR & Non LsD SiR...
- wanted : knowledge of stock air intake
- low brake pressure
Automotive Network, Inc., Copyright ©2013
