View Full Version : Regal
Pages : [1] 2 3 4 5 6 7 8 9 10
  1. 98 regal starts then dies
  2. 02 Buick Regal won't turn over
  3. headlight help please
  4. 02 Regal GS Vibration
  5. Help for 96 Regal GS
  6. headlights what happened ?
  7. idler pulley
  8. 91 Buick Regal Problems
  9. 92 Regal 3.8L Starting Problem
  10. LSE power rack leaking again
  11. Headlight Woes
  12. 01 Regal wipers
  13. waterpump or gasket ?
  14. 2003 Regal tranny
  15. 1994 Regal Custom 2dr Fuse Diagram
  16. 1991 regal gs
  17. 2000 buick regal ls wont start
  18. Engine misses after TC lockup
  19. Vehicle Speed Sensor
  20. Door handle
  21. Oil pan gasket replacement
  22. Problems
  23. Doors won't unlock
  24. Electrical problems with my 96 regal
  25. help with coil packs
  26. Replace crank position sensor?
  27. Rear lighting issue on 99 Regal
  28. Where's the heater valve on a '93?
  29. Replacing turn signal switch 98 Regal
  30. Axle question...?
  31. 1991 regal
  32. 99 GSE heater/AC not working, 35-60mph major shuddering
  33. 93 Regal Custom 3.8L stalling when hot
  34. Fuel Pump, Resister, PCM...will it ever end?
  35. 99 Regal Pulls to right Bent Rear Spindle Adjusting Rod
  36. bogging at 55-60 mph
  37. 1993 3.8 will not stay running on own..
  38. Sway (stabilizer) bar replacement on 98 Regal
  39. My friends 98 Buick Regal all tricked out!!!
  40. timing chain
  41. Readiness monitors won't reset
  42. Clunking in steering wheel??
  43. 1992 Buick Regal Gran Sport 4Dr: Vibration
  44. Stiff gas pedal?
  45. '98 Regal LS Security Light On
  46. 02 regal 3.8 power window
  47. '99 regal power windows
  48. Abs/brakes acting up
  49. EGR valve
  50. Service engine light on
  51. 2001 regal has a hesitation (no power)
  52. Painting my Regal
  53. camshaft position sensor
  54. 440t4 '90 Regal with common "harsh downshift" looking for link on the rear spring
  55. 1999 Buick Regal Ignition Switch
  56. Service Engine Soon Light On
  57. parts That Never Go Bad?
  58. 99 Regal LS - Replaced Starter - cranks - no start
  59. heat air flow,2000 regal
  60. 91 Regal shuddering
  61. Coolant Level Sensor
  62. Replacing my '98 regal engine. Is this a good rate and engine price?
  63. everyday starting problems
  64. emergency brake on 98 Regal
  65. Reverse issue. Regal with problems.
  66. Changing fog light bulb on 1998 Buick Regal GS
  67. Soldering a Blower Motor Resistor?
  68. 97 LS Regal Stabilizer link question
  69. Regal 2001 Fuel Pressure Regulator
  70. Starting issues 91 3800 3.8L
  71. 1992 Regal 3.8 stalls
  72. 1996 REGAL Limited Still not Charging (?) !!
  73. 1999 buick regal LS ODOMETER DOESNT LIGHT
  74. Drive Train Vibration
  75. 2011 Buick Regal - Spied
  76. 94 buick regal no spark
  77. 93 Regal fuel pump replacement
  78. Axle Removal
  79. 95 regal - heater control is bad?
  80. Crank< but no spark!!
  81. dash lights
  82. 00 regal 3.8, turn signals cause car to die
  83. Best Brand to replace camshaft position sensor
  84. 91 regal 3.8L v6 vin "L" n00b question on o2 sensors
  85. What touch up paint to buy?
  86. Heater Hose...Dealer only part?
  87. 02 regal questions about keys
  88. stalled again!!
  89. Reverse lights don't work
  90. Intermittent starting problem
  91. 2011 Regal
  92. 1999 Buick Regal starting issues
  93. where is the rcdlr?
  94. Front wheelbearing nut size??
  95. 99' check engine light on
  96. Dual -air condition problem
  97. 98 Regal starter wiring please help
  98. u bend delete..good mod?
  99. 92 regal runs poorly
  100. Thank You Everyone!!!
  101. Need Vapor Lock Solutions
  102. 98 regal super charged??
  103. dog Bones whats the part #
  104. I give up -car just will not start
  105. 99 Buick Regal GS has a bad miss at random times.
  106. 1991 regal
  107. rear plugs and wires
  108. Change igintion switch 2000 regal?
  109. starter/removal on 93 3.1L
  110. Regal won't start by itself
  111. starter switch and starter for a 2000 regal
  112. i need help
  113. Engine stalls sometimes when I brake
  114. Mono spring????
  115. 93 Regal Misfire
  116. Clicking when I start car.
  117. No Power to Fuel Relay, 1997 Regal GS
  118. serpentine belt slipping / plus noise - 1998 GS
  119. 98 Regal GS power steering fluid resevoir???
  120. Can't get key out of ignition
  121. 93 regal 3.1 starting problem
  122. help..any would be great
  123. Starting/running probs....
  124. 93 regal no start
  125. 97 regal Starter issues
  126. Hard shift...Shift solenoid or torque conv?
  127. Engine stall Problem. Runs Fine then Dies.
  128. whats that noise
  129. 99 regal oil pan gasket
  130. AC Low Side Port, '96 Regal
  131. Car won't hold an idle/run, I'm stupid
  132. POSSESSED WIPERS!! 94 Regal Gran Sport
  133. Help
  134. Hanging hose under gas tank????
  135. Problem with '99 Regal GS 3.8 (Supercharged)
  136. wiper problems
  137. 95 buick regal grand sport starting problems
  138. motor and tranny fit
  139. Clunking? '98 Regal
  140. wipers
  141. 98 Regal Keyless Receiver Location
  142. A/C condenser replacement on a Regal '98
  143. 99 Regal Remote Entry Failure
  144. a little sluggish
  145. Trans leak
  146. Diagnosing transmission problems
  147. Having problem with car.
  148. anti brake light on ?
  149. One for the books. Schematic for IP & Digital Climate control.
  150. 2001 LS stalls every morning
  151. water leak
  152. Brake Light Problem
  153. Plenum question
  154. 98 buick regal GS supercharger. PROBLEM!!! HELP! PLEASE
  155. Exhaust help please!!!
  156. Inspection due. 00 Regal ls
  157. 96 Regal Speed-o-meter
  158. 4t65e-hd vs. 4t60e
  159. 2002 Regal Stalls - S/C - Lots of details - HELP
  160. 93 Regal AC question
  161. 93 regal 3.1L dies going down the road
  162. 94" Buick Regal won't start using the key ang sometimes shuts off
  163. transmission issues. 91 buick regal 3.8
  164. 93 rough upon acceleration
  165. Ignition harness
  166. P0171- Bank 1 lean on 96 Regal w/3800 NA
  167. Don't have #18 fuel pump speed control
  168. Cracked sway bar
  169. sputtering
  170. Cruise Control question
  171. 99 Regal LS Brake Repair
  172. 99 Regal LS Transmission Question
  173. 99 Regal LS "Low Coolant" Light
  174. Location of check engine light
  175. Transmission THUNK
  176. '01 VATS key
  177. 96 regal crankshaft sensor?
  178. how difficult?
  179. a/c why?
  180. P0113, P0440, P0440pd
  181. 1999 buick regal dash lights
  182. 02 buick regal supercharged
  183. 83 regal
  184. 1999 Buick Regal Airbag Module Dilema
  185. 0 to 5 oil pressure 93 regal 3.8
  186. Belt Issues
  187. Rear end sag - the car's not mine
  188. 1998 Regal LS won't start... totally dumbfounded..
  189. hood latch 1988 buick regal
  190. 94 Buick Regal Engine Code Help
  191. flush that bad stuff away
  192. car runs better after UIM and LIM gaskets done
  193. recall on regal
  194. want a supercharger
  195. low tire light
  196. Headlight cover question
  197. Drain plug confusion????
  198. shift solenoid 1996 buick
  199. Rear Window Defroster 92 Regal Limited
  200. Need help trying to find front end part numbers!!
  201. OBD 2 code
  202. 93 regal strut noise (clinking and knocking noise)
  203. Re: 97.5 Regal.:.Left Turn signal out / right brake lamp out -Redux
  204. Window regulator cable retainer clips
  205. car wont start
  206. '90 Buick Regal. Tech 1 scan tool question for the pros.
  207. Windshield washer nozzle replacement?
  208. Codes for tourque conv.?
  209. Synthetic oil question 97 Regal LS
  210. 2001 LS security lite
  211. 1991 Regal Ltm. Problem
  212. hub bearing easy or not
  213. buick is sluggish
  214. 92 Regal gauge cluster
  215. UIM/LIM Problems
  216. life span of Ignition wires?
  217. Name this motor mount?
  218. air bag light on ?
  219. 93 regal 3 windows work 1 doesnt
  220. 1999 Regal questions
  221. 98 Regal : side-view power mirrors not working
  222. 97 Regal Leaky intake manifold gaskets
  223. `03 Regal Low Oil Level Sensor
  224. Car will start but dies stalls after 3 or 4 seconds?
  225. 00 regal fuel level
  226. 95 regal tranny pawl
  227. dash lights
  228. 94 3.8L v6 Regal
  229. 01 regal foam in coolant reservoir
  230. 99 ls rear valve cover removal, tensioner assy?
  231. Coolant flush timing question
  232. taking trunk struts off?
  233. Starter Runs Continuously
  234. how to change the window regulator and get the door panel off
  235. 97 Buick Regal Left Fender re & re
  236. 2001 GS with heater problems
  237. 2001 Buick Regal LS - 143k mi. - Radio Volume Jumps
  238. 92 Buick Regal; Stop light not working
  239. Blower motor dosen't work in sub zero temps
  240. Tranny Troubles?
  241. 1996 Buick Regal Custom 3800 II No Start
  242. '92 Regal Custom turn signals not working
  243. 1999 Regal GS water pump question.
  244. 92 Regal fan motors
  245. Tensioner Pully
  246. 02 Regal Joseph Abboud, PO412 Trouble Code
  247. How do you remove the steering wheel?
  248. 2001 Buick Regal--Dash lights dim
  249. 2000 Buick Problem Starting
  250. 92 Regal trans fluid change
