View Full Version : Regal
Pages : 1 2 3 4 5 6 7 8 [9] 10
  1. 93 Regal 3.1 Stalls when warmed up
  2. sparkplug
  3. 2000 Buick Regal Transmission
  4. Rear Brake calipers on a 1996 Buick Regal
  5. low fuel light
  6. Transmission wont shift into second!!
  7. 1993 Buick Regal Remote
  8. '91 buick regal....No start?
  9. 1998 Buick Regal oil pan removal
  10. How to get to the battery - 93' Regal
  11. coolant level
  12. 1984 Buick Regal Grill
  13. no spark
  14. My wife doesn't know
  15. 81 Stereo Diagram
  16. Hood Release Cable
  17. 1996 GS supercharged won't run
  18. 1991 Regal 3.8 ran great-stalled, ran great-stalled, don't run
  19. sensor for anti lock brakes 93 buick regal
  20. '96 Buick Regal in an Accident!
  21. Chocolate milk in oil
  22. 78 Regal Reverse Lights
  23. 93 3.1 troubleshoot
  24. 96 Regal Head Unit w/ CD player
  25. 1983 regal 3.8 oil problem
  26. 1999 Buick Regal won't start...
  27. 97.5 Regal Interior Vent fan off
  28. 97.5 Regal.:.Left Turn signal out / right brake lamp out
  29. 96 regal stiff shift into gear when cold
  30. Newer GS rims for 1995 Regal??
  31. Runs when it is cold
  32. 94 GS won't idle
  33. 91 Regal brake lights on when cold
  34. 91 Regal 3.8 no spark
  35. Stabilizer Shaft Insulators Replacement
  36. 1995 Regal GS starting problems
  37. No Dash Lights
  38. use regular in superchaged MOTO
  39. 1992 Regal odometer stopped
  40. 1992 Regal Brake warning light.
  41. 1992 Regal ventilation air dampers
  42. 2004 Regal oil drain plug ?
  43. 96 Regal fuel pump relays
  44. 94 Regal Cruise Control & VSS
  45. 89 Regal probs
  46. 1978 Buick Regal Coupe Interested in Selling
  47. Buick Regal Blinker Problems
  48. Gas Gauge
  49. 1991 Regal Master Cylinder
  50. '94 Buick Regal GS trouble starting
  51. changed a fuse now it won't tunr over
  52. Engine trim cover removal
  53. 00 3800 - Hesitates between 15-2000rpm when driving?
  54. New recall info: 99 Regals/Century's
  55. easy questions about stock 93 regal 3.8 sc
  56. 1998 Regal abs problems
  57. remote starter
  58. 93 regal ign coils
  59. 2001 Regal Jerks when shifting
  60. 2001 Buick Regal - Grinding noise when turning
  61. 78 Regal where do I find rear rebar??
  62. cruse control drops out
  63. 93 Regal-turning off engine does not unlock power doors
  64. 95 RKE programing problem
  65. Programming directions for 1998 Regal
  66. 1995 Regal - Plug wires
  67. Remote Keyless Instructions for 98 Buick Regal
  68. 1995 Regal shuts down
  69. 94 Regal intermitant starting
  70. p106
  71. 1990 3.1L V6 Buick Regal
  72. Running Poorly.
  73. Regal 98 Intermittent problem
  74. 1992 Regal didn't pass emissions
  75. Pulling codes
  76. knock sensor location on 94 regal with 3.1???
  77. 1986 buick regal problem
  78. CEL after 50 mph
  79. 88 Buick Regal Passenger Door Handle
  80. fuel gauge for my 93 buick regal custom
  81. Passenger cab filter
  82. 2004 Regal Air Filter
  83. 99 Regal no instrument lights
  84. Busted odometer
  85. 2002 regal won't start
  86. :( big problem!!! HELP!!
  87. Rack & Pinion
  88. GS Supercharger breather plug
  89. Paint colors for 78 Regal
  90. 98 Regal fuel pump
  91. 1996 buick regal intermittant starting
  92. 92 buick regal being junked, need anything?
  93. 89 regal Won't start!
  94. door interchange
  95. 1992 Buick Regal struts
  96. Ignition will not turn
  97. Won't Start
  98. 85 Regal fuel leak
  99. 1992 leaking oil from distributor shaft
  100. tire pressure
  101. Dash light mutiny!!!
  102. 96 buick regal won't run
  103. 99 Regal Rear strut Noise
  104. brake lights on 89 regal
  105. '99 Regal GS New Tranny won't downshift
  106. Few problems w/Regal Custom 3800
  107. 96 Regal Custom E20 error code on radio/cd
  108. 350 swap in an '84 Regal
  109. why are there 2 different sets of lights ?
  110. 92 Buick Regal Headlights & Running Lights
  111. 96 Regal 3.1l overheating
  112. 98 LS completely locked up.
  113. lowering a 94 GS
  114. Where's the PCV valve on a `99 Regal?
  115. Texas Girl needs help!!
  116. difference between 3800 and stage II 3800??
  117. 1987 Regal 307
  118. Temp light problems
  119. 96 Regal start/dies
  120. too slow for money spent 14s?
  121. me too
  122. 94 regal electrical probs
  123. locked steering column
  124. 1993 Regal Blower Motor Removal
  125. 1990 Buick Regal
  126. Regal Parts
  127. Keyless entry system tempermental
  128. 1993 regal radio install problem
  129. turn signal/remove steering wheel 92 Regal
  130. '93 Regal rotor removal
  131. 95 buick regal oil pan removal
  132. '93 Regal GS Problem
  133. Fan Noise
  134. 94 Regal Electrical Problems
  135. Switching ABS systems
  136. Just Bought A 87 Regal Limited
  137. I smell gas
  138. ABS to non-ABS
  139. Left Blinker flash quick... Replace fuse?
  140. serpentine belt
  141. Larger rear brakes
  142. 94 regal GS (3.8) repair help
  143. battery replacement on 1992 Buick regal
  144. 1994 Regal Custom (L27 performance options?)
  145. 1997.5 Regal LS Starts!
  146. 99 Regal Windows, Radio, Door locks malfunctioning
  147. 85 Regal wont hold charge
  148. 1997.5 Regal LS Won't Start!
  149. boost on a regal gs 2001
  150. 96 Regal Console Arm Rest
  151. 1988 Buick Regal stalls when driving
  152. Sensor Location 93 Regal 3.8L
  153. need help customizing
  154. 92 Turn signal Problem
  155. Regal 99 P1360 P1361 - Ignition Coil C/Low Voltage...HELP!!!
  156. Oil is leaking badly..
  157. Wacky wipers -94 Regal custom
  158. anti lock brake, brake, traction control light and service vehicle soon lights all on
  159. 92 Regal keyless entry
  160. 99 Regal Doesn't start (Please Help)
  161. 3.1 Intake Gasket change?
  162. Master Cylinder ABS code #62
  163. velocity stack on 1986 GN?
  164. 02 Buick Regal 3.8 SuperCHG upgrade
  165. kill list
  166. light malfunction
  167. 1999 Buick Regal LS
  168. picture of me and my ride
  169. 1994 Buick Regal intermittent starting problems
  170. insurance?
  171. slight irradic idle
  172. Problems with coolant sensor
  173. 87 gn needs tuning, way slower than it should be
  174. 86 GN lacks power
  175. 3.1 high idle, runs rough
  176. 98 regal trans
  177. Help with Spark Plug Question
  178. My Radio is locked, help please
  179. '94 Regal Custom Trunk Latch Problem & Cruise Control
  180. Master Cylinder
  181. '99 BUICK REGAL GS Electrical Problem
  182. 99 Regal GS shutter
  183. it shuts off at will
  184. 89' Buick Regal Custom 2.8L - overheating problems
  185. 1998 Regal Stalls on Accel, won't restart
  186. Coolant Loss, then overheating
  187. 91 buick regal code 41 running rough
  188. Grand National Performance????
  189. help me please
  190. noob question.
  191. 1995 Regal Air Conditioning
  192. '98 Regal Blower Motor
  193. problems w/94 tran fluid/error light
  194. 1996 Custom Code ?
  195. Short in turn signals
  196. 81 Regal Doesn't Pass Emissions
  197. external temp display not working
  198. How to Remove Radio in 1995 Regal Sedan
  199. Oil life Monitor
  200. 98 buick limited wont start, please help
  201. Over Heating
  202. 97 Regal Turn Signal/Running Light Problem
  203. 1992 Regal Door handle removal
  204. 93 Regal troubleshooting
  205. 1999 Buick Regal - Add HP and Mileage
  206. 92 regal dying
  207. 92 engine code 34 MAF
  208. system for '89 Regal
  209. Rough idle when hot
  210. Keyless entry works....sometimes
  211. My 1989 Buick Regal
  212. '94 - turn signal problem
  213. Front End / Brakes?
  214. 98 Regal, trans prob. maybe?
  215. Haynes shop manual
  216. 92 Regal Limited AC not working
  217. Steering Wheel "Paint"
  218. Turbo buick FAQ's and Myths.
  219. 1992 Buick Regal Stalling
  220. 2000 Buick Regal A/c Control Problem
  221. 98 Buick Regal
  222. Safety Neutral Switch Location
  223. 1999 Regal persistant P0300 code driving us nuts .. help please
  224. drive axl's ????????HELP
  225. digital speedo going nuts
  226. Specs please?!?
  227. Can it be? 5 speed?
  228. Knocking sound under hood
  229. Sure these things are fast, but handling?
  230. speedometer/gauge swap...is this possible?
  231. overheating issues
  232. 88 Regal analog odometer stopped working
  233. Horn, Door Locks, and Keyless Entry problems
  234. 88 regal digital speedometer
  235. 2000 Regal Window Regulators
  236. intermittent starting problem
  237. 3800 does not start
  238. 1991 Buick Regal 3.1 fan/overheat problem
  239. Stalling, Bad Error Codes, Strange Error Lights
  240. Proper fuel pressure for GNX w/ mods?
  241. '99 Regal Dual Climate Control Driverside Hotter
  242. 1979 regal T-type turbo, what the hell is up with this thing?
  243. coolant blow out!!!
  244. 84 Regal lights don't work
  245. 91 Buick Regal
  246. window motor
  247. any 70's buicks ?
  248. 99 Regal LS power windows problem
  249. 97 Fuel Pump problem! HELP
  250. Premature parts replacement
