View Full Version : Regal
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12
  1. Does my car have a ubend too?? please read!
  2. Muffler for 91 Regal Custom 3.8
  3. 97 regal ignition switch
  4. 96 Regal trans locked in park!
  5. Intermittent 97 Regal Stalling!!
  6. 99 Regal Parking Lights...
  7. Headlights - High and Low Beams on
  8. 2001 Regal Fuel Gauge
  9. '81 BOP regal tranmission question??
  10. Buick Performance Chips
  11. Regal Fire Wall
  12. 2002 steering has slight bind
  13. 2000 Regal Ls Interior Door Panel Reflector
  14. 2000 Regal Ls Interior Door Panel Reflector
  15. 2000 Regal Ls Interior Door Panel Reflector
  16. Overheating Problems 96 Regal Custom
  17. High Flow Cat
  18. 98 Regal E22?
  19. 96 Regal GS Battery light back on
  20. a/c bearing noise
  21. Headlights relay?
  22. 96 Regal GS Battery light comes on after driving
  23. 1995 Regal GS....Brake/ABS warning light on
  24. Adding power to my 1996 Buick Regal 3.8
  25. micro switch location
  26. 98 regal gs just dying right after start
  27. cannot remove key from ignition !!
  28. exhaust questions for 3.8L 91 custom
  29. Sorensen sensor CSS7 (what is it?)
  30. 1996 Regal 3.8 code 106
  31. 2000 regal will not stay running
  32. Best Speakers to Buy??
  33. Cheapest Horsepower Upgrade?
  34. What do I need to Upgrade to Supercharger
  35. 1986 Regal Engine Swap??
  36. Where are the temp sensor located for 91 Regal?
  37. '96 Regal Radiator Change
  38. Question
  39. 98 GS whistles
  40. Code 41 Cam sensor, Is this a serious issue?
  41. Bleeding Master Cylinder - '92 Limited discs ABS
  42. Questions about a 91 Regal Custom
  43. 93 Regal Custom power lock question
  44. REGAL GS 97 or 97.5?
  45. CV-JOINT how to replace?
  46. 96 Regal GS Battery light comes on after driving
  47. does any one know how to fix oil problems
  48. engine
  49. 97 Regal no Start/Gagues gone nuts
  50. 98 Regal - Turn Signal problem, likely wiring
  51. 98 Regal GS vs 02 Grand Prix GT
  52. will this work?
  53. Regal 93 lost acceleration
  54. air conditioner compressor
  55. Broken hood release
  56. Turn signals stall 94 Regal Custom
  57. Need to change my distributor cap, can't find it!
  58. Buick Regal lifter collapsed
  59. Power Window Regulator
  60. 98 Buickgs
  61. Ways to make my 91 3.8l regal go faster.
  62. 2000 Buick Regal - no dash lights
  63. loud shifting of transmission
  64. 1996 Regal GS 3.8 stalls
  65. pick n pull
  66. what can i do to sup up my L27 3.8
  67. 01 Buick whining noise
  68. Oil Problem?--94 Buick Regal
  69. 88 Regal very hard to start when cold
  70. 2000 Buick Regal Headlights
  71. air bag light
  72. 99 Regal Check Engine/AC problem
  73. click click click...
  74. Let's Play Name This Part!
  75. 91 regal backfiring
  76. Headlamp and dash lights flickering/dimming
  77. 1991 Regal multiple issues
  78. car stalling while driving NEED HELP!
  79. 1992 Regal, 3.8 lit. stalled
  80. 3.1 to 3.8 engine swap
  81. start car w/engine rotated?
  82. 02-03 GS Supercharged
  83. 2000 Buick Regal Rims....
  84. 93 Buick Regal 3.8 liter Oil Pressure?
  85. 3800 engine swap
  86. 95 buick gs stalling
  87. 98 regal gs random stalling, from stop at idle.
  88. 2001 regal LS 3800
  89. any 81-87 regals for sale hear philly area?
  90. 92 Regal Transmission
  91. 99 regal ls
  92. No heat??
  93. changing spark plugs
  94. ball joint press instructions?
  95. crackshaft bot
  96. tail lights
  97. High Idle 1990 Regal Custom 3.1
  98. Window Motor compatability
  99. Pcv valve on 90 Regal w 3.1 engine
  100. Possible cat problem?
  101. steel timing gear
  102. HELP!!! 91 regal lights not working
  103. 92 regal door assembly
  104. 1991 Regal GS - How do I clear the SES light?
  105. 2001 buick regal v6 ls po420 code
  106. brakes/Supercharger question
  107. 96 regal, transmission problems
  108. oil pump ?
  109. 1999-2000 Buick Regal Keyless Entry Remote
  110. Ignition Key Stuck in Accessory Position
  111. 91 Buick Hard start
  112. How to change the spark plugs?
  113. Tranny on a 99 GS
  114. acceleration problem+sound
  115. Spark plug heat shields
  116. 94 Regal Won't turn over
  117. 93 Buick Regal Custom
  118. 3800 Regal owners
  119. Reprogram the keyless remote?
  120. 1999 Buick Regal Random Stalling????
  121. parting out 87 regal
  122. 1991 Buick Regal Radio Reciever question
  123. rough Idle when cold
  124. rough Idle when cold
  125. Car won't turn over
  126. Car won't start all of a sudden...
  127. 1993 regal intermitant starting problems
  128. 92 Regal gas tank
  129. 88' Regal Limited
  130. 95 Buick Regal 3.8
  131. 1988 buick regal starting problem
  132. Rust on ignition coil terminals - replace?
  133. VSS removal
  134. Camshaft sensor Help?
  135. 96 GS rear struts...easy job?
  136. brake lights. centre works, main don't
  137. '97 Regal dash lights fading
  138. 97.5 GS DIC lcd gone bad?//
  139. AC/HEATER FAN trouble
  140. CD player installation
  141. steering whining noise
  142. 99 Buick Regal
  143. reverse lights broken ?
  144. 97 regal gs idiot lights are going crazy
  145. cherry bomb on a 88 regal
  146. analog speedometer stop working
  147. question about panel lights from total newbie
  148. 95 suspension?
  149. What is this tube?
  150. 97 3800 engine squealing noise
  151. Can't find modulator in 92
  152. Shorted Fuse / 2000 Buick Regal GS
  153. ...Idea for a sticky?
  154. fried starter?
  155. '83 Buick Regal Lug pattern?
  156. 97.5 or 98 Regal GS any differences?
  157. gm/regal antenna extension
  158. 2002 door lock problem
  159. knock knock who's there?(88 Regal knocking)
  160. Horn FYI
  161. OIL LEAK... cooler pipes rusty?
  162. What causes uneven brake pad wear?
  163. 96 Regal Airbag light flashes at times
  164. Tie Rod Ends
  165. 1992 Buick Regal Custom with a car newbie
  166. 1998 regal ls, thoughts?
  167. Cornering Lamp Not Working on 97.5 GS
  168. 94 Buick Regal climate control lighting does not work
  169. 2.8 3.1 heads the same?
  170. Rear struts
  171. Break lights acting funny
  172. '94 Regal Humming noise
  173. '98 regal seat warmer repair
  174. Emission test failure 91 Regal
  175. Replacing a fuel pump
  176. Hub Assembly/ABS Sensor
  177. Oil Changes
  178. 93 regal cps
  179. 99 Regal LS Ocassional Dead Battery
  180. 1994 Buick Regal turn signals not working
  181. Airbag Light
  182. 1996 Buick Regal Custom 3800 Shutters
  183. Regal GS Tires
  184. brakes vibrates when applies before and after
  185. lss ac
  186. good price?
  187. 93' custom air condition lights
  188. Chronic Rim Leaks
  189. blower motor
  190. Hub Replacement. Do's and Dont's?
  191. where does one shop for buick parts?
  192. 98 regal door won't open
  193. 98 regal door won't open
  194. Ext Temp Sensor and Service Engine Soon
  195. RE: Programming Instruction ...
  196. 91 fuel pump
  197. 93 Buick Regal Electrical Problem
  198. Neutral the tranny @lights??
  199. 1994 buick regal ABS/Brake light on and harder than normal pedal
  200. 99 Stalled...
  201. 1994 buick regal ABS/Redbrake warning light on and brakes feel harder than normal
  202. 98 regal gs won't start when cold
  203. oil life monitor function
  204. Power Window Motor Repair
  205. design tech car starter
  206. Seat Cover Replacement?
  207. Passenger Side Airbag Cover
  208. Power steering reservoir 2000 regal
  209. getting code 33 but wont clear
  210. Regal dies, I mean dead
  211. Buick Regal 2000 Fuel Guage Problem
  212. Spark problem on 91 Regal
  213. 91 Regal - parasitic battery drain
  214. Trunk Lock does not work from button in glove compartment
  215. odd noise
  216. left turn signal on 99 Regal GS
  217. 1994 Buick Regal GS
  218. Buick Regals Hidden Power Steering Unit
  219. 98 regal gs supercharger life
  220. wheel bearing hub assembly
  221. regal LS Tires
  222. UPDATE:91 Regal spit sputter stall
  223. 94 3.8L GS "low coolant" light
  224. 94 Regal GS misses
  225. rear strut in trunk
  226. haveing a hard time tuneing up my buick ragal custom
  227. aftermarket speedo 91 regal
  228. Regal GS tires
  229. Still tranny problem
  230. speedo 91 regal need help!
  231. cooling system '92 3.1
  232. Regal GS 2000 suspension
  233. Tranny on 98 regal
  234. Power Door Locks,Click to lock while Driving
  235. Keyless entry horn sound not needed
  236. Gas Gage
  237. 1998 Buick Regal Belt Tensioner removal
  238. washer fluid leak??/97 LS Regal
  239. Lights in heater controls 94 Regal
  240. 92 regal(3.8) stalling/missing problems
  241. Cabin air filter
  242. Catalytic Converter Problem
  243. Replacing lower ball joint front hub in a 95 regal
  244. '98 3.8L oil in water??
  245. 98 Regal Supercharger whinning noise
  246. knocking in the steering
  247. 91 regal gs radio fuzz
  248. Shift Control Cable
  249. 1997-2004 Buick Regal GS Hard to find used?
  250. '95 regal will start most of the time, but not always.
