View Full Version : Regal
Pages : 1 2 3 4 5 6 7 [8] 9 10
  1. 97 Regal fan motor in/op- repaired
  2. Object behind glove box
  3. code 63 1988 2.8 Regal?????
  4. Loud noises when pressing gas 1991 Buick Regal
  5. 88 regal 2.8 engine making noise Help
  6. 91 Buick Regal ECM
  7. 98 Buick Regal GS won't start
  8. Need Help !!!!! Please
  9. A Big Thanks...specifically "malimag99"
  10. 98 Buick Regal Will Not Start
  11. '91 Regal Firewall Grommet
  12. Monsoon Rear Deck Speaker Options for 99 GS?
  13. Turbocharger or Supecharger
  14. Question about accessing fuel pump area
  15. 96 regal custom 3800 series ii
  16. 1995 Regal stalls intermittently when in drive/reverse; hard to restart
  17. Squeal/ squeak
  18. on my cluster ..what is it?
  19. How to make my Buick 78' 350 faster
  20. Remove Drivers Power Seat- 93 Regal
  21. 1998 Buick Regal GS ABS Control Module
  22. Knock Sensor?
  23. Making new dashboard
  24. 87 Buick Electra Park Ave
  25. How to move steering
  26. How many miles or kilometers on your Regal?
  27. Electrical Problem / Car Dies and Vent Turns on
  28. getting water under passenger side carpet
  29. 99 regal wont start
  30. Removing Starter
  31. Exaust leak in 87 Regal
  32. 1998 Regal GS Anti Lock Brake warning lights
  33. 1980 fuses
  34. 99 buick regal starting problems
  35. When heater is turned on!!!!!
  36. 94 Regal 3100 TCC solenoid location ??
  37. 1988 buick regal cooling fan relay location
  38. 1991 Regal 2-door
  39. changing rear struts on a 92
  40. Climate control knobs..Regal
  41. 1996 Regal 3.8 Fan Trouble
  42. 94Regal Problem Starting - BRAKES?
  43. No acceleration
  44. 1996 Regal Custom keyless Issue
  45. 89 Regal power steering problems
  46. Parked Regal
  47. Performance Recomendations For 97's
  48. Harsh Shifting???
  49. Turn Signal kills engine. aargh!
  50. Factory Radio
  51. Cannot open door from the outside. Inside works.
  52. Power locks won't work
  53. 99GS won't run help!!!!!
  54. how does DEX-COOL look towards the end of it's life?
  55. CD Changer For a '99 Regal GS to fit factory stereo
  56. what is this wire?
  57. WHat's that light called? (86 Regal)
  58. Regal - 1994 - Should I buy?
  59. 88 regal dead
  60. 2001 Tcs
  61. 91 Regal electrical panel
  62. Buick coolant recall
  63. dash questions
  64. Engine oil level
  65. remote door locks/trunk
  66. replacing cracked mirror glass only for side of 2000 regal
  67. Regal Question
  68. 88 Regal
  69. 2001 tranny input output sensor
  70. 96 regal bucks between 45-50 mph
  71. 91 Regal has been sitting for a year+
  72. 91 regal won't start
  73. My 86 regal wont burn out!!
  74. 86 regal with ticking engine
  75. 1991 Regal fuel filter?
  76. 88 regal keeps dieing
  77. 1991 buick regal won't start
  78. Anyone got a headlight wiring diagram?
  79. power window problem
  80. Buick 455 Regal
  81. 89 regal limited with grond effects
  82. Can't locate turn signal flasher in my 1994 Regal
  83. 01 trans, etc.
  84. 92 regal 3.8?
  85. 92 regal bouncy ball fallen into air vent
  86. Need help: Vent shuts down while driving (96 Regal)
  87. having problems with 1993 regal gran sport
  88. Sideview Mirror
  89. 91 Regal won't start. PLZ HELP!!!!!
  90. fuel pump won't cut off
  91. 95 Regal quit today - ADVICE??? SUGGESTIONS????
  92. car cuts out while driving!! HELP!!
  93. Bad torque converter???
  94. 96 regal knocking engine
  95. 1995 Regal GS Dead Battery
  96. How do I remove the dash????
  97. 1989 Regal LE 2.8 Crankshaft Sensor Troubles
  98. 87 Buick Regal T Type Exhaust Manifold
  99. Car repair Cost Canada
  100. P0336 code 99 GS
  101. MAP Sensor
  102. Stolen Car
  103. bolt pattern and size
  104. buick glow gauges
  105. 1996 Buick rides like a truck
  106. '99 OE struts
  107. 95 buick regal running rough Please help
  108. 92 Regal Problem with the radio volume
  109. Installing new head unit help?
  110. Help With Strange Headlight Switch Issue
  111. Transmission matching
  112. tires for a 98 Regal GS
  113. '99 450clicks per tank...something needs to get cleaned?
  114. Anyone else own a 86 Regal limited?
  115. ABS Warning Light
  116. 86 Regal Limited poor gas miliage
  117. 91' Won't Restart
  118. Anti-Lock brake knocking
  119. intro/headlight problem on 83 Regal
  120. 97 regal serious electrical!!!
  121. Rad Fans
  122. 98 Buick down and out!
  123. 93 Regal GS CD Player?
  124. help car wont stay runing
  125. 3800 Series I needs Alternator:
  126. Black Smoke, STalling, hard to start....
  127. Electrical Issues:
  128. 1996 regal service engine light
  129. Smoke under hood
  130. Ran Out Of Gas wont start now
  131. 1991 buick regal odometer malfunctioning
  132. 2000 Regal Trunk gas lift struts
  133. 1983 brakes dont work properly
  134. assuming transmission going out on 93'
  135. 92 Gran Sport -- Speedometer/Tach problem
  136. loosing coolant into the oil 1995 buick regal
  137. car dies when shifting between gears
  138. 98 GS - starts but won't run
  139. '91 buick regal 3.8 custom
  140. Brake Shimmy
  141. 2000 regal ABS codes
  142. 1993 Regal custom Tranny problem
  143. 92 Regal blower motor only works on the highest setting
  144. Regal Fuel pressure
  145. Paint chipping off 97 regal
  146. 98 Regal LS Shudder and jerking!
  147. 92 Buick Regal replacing power steering pump
  148. Supercharger Rattle
  149. 93 Regal Warning Lights
  150. Car Wont Start
  151. 2000 Buick Regal computer
  152. 1992 Buick Regal- No electrical!
  153. 1993-1995(?) Regal Limited
  154. 98 Regal Tensioner
  155. GS vs GSE?
  156. Dependable,mid-sized,4 door,RWD car
  157. Any significant differences between 3.1L engine and 3100cc engine
  158. 1994 regal oil pan removal
  159. 92 Regal 3880 oil filter
  160. 1988 regal odometer failure
  161. 99 Regal with 3800 Dies while in Park; Then won't start!
  162. 94 Regal Tail Light
  163. 98 Buick Regal Heater Control problem
  164. New manifold, new sound
  165. crankpositionsensor location
  166. Fuel Pump Resistor
  167. 99 110,000km service check
  168. 91 regal turns but doesnot start
  169. 1999 regal automatic transmission-overdrive problem
  170. location of oil sender switch
  171. 99 Regal HVAC problems
  172. Fuel pump stays on
  173. 98 regal gs
  174. Need Advice-'96 Regal
  175. catalytic
  176. 1995 Regal Tranny Problem
  177. 99 Regal Steering Problem
  178. 92 Regal Trans modulator
  179. Regal engine rotation & other questions
  180. Problems starting 90 Buick after car is warm
  181. Intercooling an 85 Grand National...
  182. Many Thanks
  183. No Selling Allowed!!!!!!
  184. Sick Buick Lover, Regal owner
  185. 2000 Buick Regal idles rough, 3rd cylinder misfires
  186. 89 regal heat problems
  187. 2 Door vs. 4 Door
  188. 95 Regal - Security Light Staying On
  189. 99-01 Buick Regal Wanted
  190. '88 regal cruise control
  191. Leaking water
  192. Mr. Freeze Locks
  193. 1978 regal wiring diagram
  194. 94 regal, Interior dash lights
  195. 4T60E Transmission
  196. 2000 Buick Regal Windshield Washer Pump
  197. New plugs, now car shudders
  198. 98 Rear wheel bearings
  199. 1996 Buick Regal
  200. Headrest removal
  201. 94 Regal "All the sudden" Problem
  202. 1988 Regal Suggestions??
  203. 88 Regal Idle Jump/Sputter/Jump/Sputter
  204. 95 leaking something yellow
  205. day time light
  206. 98 Regal engine runs fine; can't get into gear
  207. gas gauge
  208. A 17 year old girl driving a regal??????
  209. 94 Regal Custom power steering help
  210. electrical problems?
  211. new batteries die very quickly NOT ALTERNATOR
  212. '94 ball joints/wheel bearings
  213. whine noise 94 regal
  214. '93 Regal Keyless Program
  215. 1991 Buick Regal Limited 3.8litre Supercharge
  216. Lost Keys
  217. cd changer installation
  218. Neutral Switch
  219. '95 Regal Column Shift
  220. buick tranny problem
  221. 95 Regal GS
  222. Starts but shuts off within five seconds.
  223. 1995 regal warning light problem
  224. Dead battery & ABS light on
  225. Help Me
  226. FYI - Security blinking - No Start info
  227. Cold air intake
  228. Coolant IN Exhaust
  229. 96 Buick Regal Custom "low trac" warning light
  230. check engiine light
  231. Line going to carb, pinhole leak..
  232. 1998 buick regal GS (suprecharged) wont start
  233. 1982 buick regal need to get the heater working again in the car
  234. Aftermarket parts
  235. Qdm????
  236. 3800 coolent and ATF
  237. 95 Buick Regal
  238. 1992 Regal- Cd player install.
  239. 98 regal Intemittent runs rough and dies when warm
  240. 1990 Regal GS
  241. 1978 Regal
  242. Buick regal 1993 - no startup at all
  243. Heater fan making awfull noise
  244. 1986 Buick Regal For sale 6850 miles!!!
  245. 96 Regal heatless heater
  246. 2000 Regal - CD changer socket?!
  247. OIL FILTER/ Trac control 95 regal
  248. special keys
  249. 98 GS constant Stalling
  250. 1991 Regal Parking Brake
