View Full Version : Regal
Pages :
1 2 3 4 5 6 [ 7]
8 9 10
- 98 regal gs supercharger life
- wheel bearing hub assembly
- regal LS Tires
- UPDATE:91 Regal spit sputter stall
- 94 3.8L GS "low coolant" light
- 94 Regal GS misses
- rear strut in trunk
- haveing a hard time tuneing up my buick ragal custom
- aftermarket speedo 91 regal
- Regal GS tires
- Still tranny problem
- speedo 91 regal need help!
- cooling system '92 3.1
- Regal GS 2000 suspension
- Tranny on 98 regal
- Power Door Locks,Click to lock while Driving
- Keyless entry horn sound not needed
- Gas Gage
- 1998 Buick Regal Belt Tensioner removal
- washer fluid leak??/97 LS Regal
- Lights in heater controls 94 Regal
- 92 regal(3.8) stalling/missing problems
- Cabin air filter
- Catalytic Converter Problem
- Replacing lower ball joint front hub in a 95 regal
- '98 3.8L oil in water??
- 98 Regal Supercharger whinning noise
- knocking in the steering
- 91 regal gs radio fuzz
- Shift Control Cable
- 1997-2004 Buick Regal GS Hard to find used?
- '95 regal will start most of the time, but not always.
- HELP !!! No light on DASH BOARD Buick Regal 1999
- Hub replacement...New axle too?
- Is my 95 Buick Regal a "W" body?
- 89 Regal sounds like a lawn mower
- Detailed pics or specs 1992?
- Going to drive it off a CLIFF
- No Heat! on drivers side
- oil pressure sending unit
- 93 Regal Problem Starting
- 2000 regal radio removal
- Vaccum Problems On an 89 3.1L Gs
- Gas gauage is not working
- Helllllp!!!
- Ignition Switch Replacement Help
- 2000 Regal GS w/Supercharger Possible ABS Issue?
- 1991 regal problem
- 1996 buick regal occasionally will not turn over
- HELP me make a decision!!!
- 1991 Buick Regal Limited
- 92 Ragal GS Code 42
- 93 regal electrical and idle problems
- 99 Regal GS Struts
- Regal transmission question
- oil pressure gauge problem
- Shorty duals
- Electrical problems REPLY ASAP
- Wheel wells on an 86 REGAL
- 1996-2001 Regal's,Any chronic problems ?
- Regal 93 rear strut tool help!
- 1994 Buick Regal GS
- 3.1L v6 code 33 fast idle. any suggestions?
- 84 Buick T-type Electrical
- 2001 - 2002 Buick Regal Special Policy on Warranty Coverage of CAT Convertor
- small gas tank
- SKirts on an 86 REGAL
- Blown Speakers - New Ones?
- Rubber Rear Auxiliary Spring - '95 Grand Sport
- 1996- Radio/AC control lights burnt
- 2001 buick regal wire short between PCM and DIS
- 1994 buick regal brake light problem
- Hard turning and clunks
- ignition switch for 2000 regal
- regal monsoon speakers
- 2000 regal starter?
- what is this button?
- Fuel Gauge not registering correct level
- 81 Regal underhood wiring
- 1996 Buick Regal - both horns stuck on
- 95 Buick Regal GS
- Transmission fluid leaking through vent hole
- Replacing fuel injectors, plugs and wires
- 1999 Regal GS Transmission trouble
- 94 Regal 3.8 Stutters
- turn signal switch
- 1999 regal problems
- 97 Gs - Power Steering Leak???
- DUALS on a 84 regal
- Brake light troubleshooting
- air condition
- 91 regal custom missing?
- 94 Regal takes long to start, struggles when gassed
- 2000 Regal right rear caliper sticking
- 1995 regal, died need help.
- '92 buick regal keyless entry
- 2002 Regal fog light button
- 98 Buick Regel troubles with starting
- RIP 09/06/2005 My Buick Regal
- 2002 Regal "blowing out" oil
- Cooling fan Troubleshoot
- Re: 92 Regal Power Door Locks
- How the hell do i get to the rear spark plugs
- radiator drain plug location on 2000 Regal
- Hmmm...
- Buick 98 weird problems...
- where is external temperature sensor?
- code 43 Knock sensor or Mem-cal chip?
- need help
- 98 GS couple???'s
- 92 3.8 engine assembly question...
- 90 Buic Custom Chronic Tranny leak
- need help setting radio
- Help w/radio station settings
- Left turn on, car dies
- Driver Window Power Switch wont work
- Let's play "Name that part"
- Drivers window stuck down
- Car sometimes won't start, must wait 40 mins.
- gas gauge problem
- gas gauge problem
- I think i have a record?
- 93 GS top speed 3.8L?
- 1996 buick regal wont turn over
- '92 Regal GS Oil Pump Replacement
- Installing an aftermarket stereo in a 92 Regal
- 1993 Buick GS Motor Mounts
- 89 REGAL GS TEMP STUCK ON "WARMISH"
- 3800 Engine Removal - Tips/Comments?
- 3.8L Codes
- 2000 Regal climate control LED lights
- '92' stalling and speedometer reads 0
- keyless entry module for 1995 regal
- alternator??
- battery or alternator?
- 91 buick Regal Headlight indicator problem
- AC suddenly Blowing Hot air
- Only blowing out air on side vents
- 3800 Engine Problems
- keyless remote 1989 Buick Regal
- 94 regal chip needed
- Trip Odometer
- Replacing the column switch (91 Regal)
- how to switch out a pulley
- Low coolant light flashes
- Head or head gasket..anyway to preserve?
- Rear Brakes
- Rear end squeak
- 96 Buick - HELP!!!!!
- 2003 Buick Regal - shifter park brake interlock
- oil life
- codes ask for mass air flow sensor
- Need help with an OLD's Cutlass
- my 1990 3.1 lumina died on road
- Window Tracks, Is There A Better Way?
- 98 Buick Regal--Blower Motor Help!!!
- 1996 REGAL GS fuel filter?
- 1985 regal - rattling noise
- 92 Regal - idles - kills on throttle and when put in gear
- engine mount trouble
- What tires are best?
- 98 Regal GS Horn Relay Location
- Hard Staring when Hot (Buick Regal 1996)
- Buick Regal 78-84?
- 98 GS S/C perf.shift and trac control
- 2000 regal climate control display
- Car runs "heavy" when A/C is on
- Service Vehicle Soon/Anti-Lock/Trac Off
- (ABS) & Brake lights keep coming on... suggestions
- Figured out the part number, can't find part
- 1993 Buick Regal Custom help
- Antifreeze smell
- New to Buicks
- 92 regal 3.1 dies after 20 min
- 1992 regal custom dashlights
- Help... 96 Regal Dashboard Darkness! Grrrrrrr!
- 1992 buick regal custom...IN HELP BAD!
- 98 GS spoiler brake light
- Fuel pump resistor-do I need a new one?
- A/C Compressor Not Getting Power
- Help! Dash Light Blinking Crazy
- '98 Buick Regal Window motor
- Rear Brake Calipers, Why do they Suck? Still!!
- Pcv Valve 2000 Buick Regal Ls 3800 Series Ii
- 1987 buick somerset
- 2000 regal gse
- Doors unlocking in Park
- 1992 Regal Stalling out in heat
- 90 Buick Limited Runs Rough
- 98 Regal brake rotor warped?
- Struts for a 91 buick custom
- e--brake cable
- Power Window Problem
- 94 Regal Power Locks Short
- 99 Buick Regal Hard Shifting
- DIC or DID
- Replacing the Radio in a 1992 Regal
- Ignition Troubles!
- 1998 Regal Climate Control
- Water in passenger footwell
- Stall,spit,sputter,die,REPEAT
- Will a Monsoon head unit work w/out the trunk amp?
- 93 Buick Regal Custom keyless receiver
- Regal to a clone?
- Need to replace part, don't know what it is
- service engine light??
- 1994 Regal, Misses, getting worse
- 91 buick regal; check engine engine light?
- Programming Remote
- 94 regal horn switch
- 89' regal custom GS 3.1 rating and hints
- 98 Regal problems
- A/C fan only works on High
- Regal Repair RipOff
- wrong tranny installed?
- 92 Regal Cooling System Flush & Fill Procedures
- help i need a diagram
- EGR valve - do I have one??
- so called security chips
- proceedure to remove rear view mirrror
- 1991 Buick Regal Horn
- 1994 Regal - Getting to the 4" dash speakers
- Your Opinion of the 2.8L V6
- '92 Custom has a problem starting
- '96 Regal AC condensation drain
- location of EGR valve 1991 buick Regal
- Peice of Scheiss Stereo
- 96 regal stereo
- cant get signals to work right
- low pressure A/C port
- Problems with VENT setting.
- Ignition problems
- Brake Light Problem
- LOW TIRE pressure indicator?
- 97 Regal-radiator drain plug
- 1992 Gran Sport -- Driver's side window
- '91 Custom v6 3.8l Battery Drain?
- Poor milage in 01 buick regal LS
- Disconnecting automatic door locks
- 1994 Regal Tranny Shift Problem
- Dashboard
- check guages light
- 97 Regal AC HELP! Please!
- dash lights gone crazy
- low coolant light blinks on/off
- 1991 Regal stereo
- 95 stalling problems
- '91 buick regal radio question
- '98 buick regal a/c
- Torque Specs
