View Full Version : Regal
Pages : 1 2 3 4 5 [6] 7 8 9 10
  1. Car stero install helpp.....!!!!!!
  2. Regal 93 water pump / belt slipping
  3. 2000 Regal Ls - Performance Upgrades
  4. LOW TIRE light after Hub/Strut replacement
  5. ECM BAT fuse keeps burning out
  6. Low Oil Pressure Once Warmed Up
  7. 1990 Regal Custom 3.1 stalling
  8. Highbeam Issues
  9. 93 Regal Brake light
  10. Jumpy Tach on '97 regal 3800 series2
  11. 92 Regal 4t60 / 4t60e swap
  12. 90' Regal GS a/c compressor HELP!!! PLEASE
  13. How to remove ignition switch?
  14. Can failed knock sensor cause no spark?
  15. 94 Regal Custom Electrical?
  16. Misfiring Piston?
  17. New Cat and O2 sensors?
  18. Transmission louder shifting
  19. Can you remove windage tray next to oil pan?
  20. Obsessive Blow outs
  21. what is your gas mileage on ur buick?
  22. 91 Buick Regal Limited Cam Sensor Question!
  23. 1994 Buick Regal GS 3.8L
  24. 99 regal - changing front signal
  25. cant remove my ignition key
  26. Front Strut Bushings?
  27. 1996 Regal not start when it is hot
  28. New steering column...
  29. '98 Regal GS - glove box lock cylinder removal from latch body
  30. Newb (or not)car repair video
  31. 91 Regal Problems
  32. 2000 Regal GS - Dash Lights all flashing car won't start>>>
  33. Does my car have a ubend too?? please read!
  34. Muffler for 91 Regal Custom 3.8
  35. 97 regal ignition switch
  36. 96 Regal trans locked in park!
  37. Intermittent 97 Regal Stalling!!
  38. 99 Regal Parking Lights...
  39. Headlights - High and Low Beams on
  40. 2001 Regal Fuel Gauge
  41. '81 BOP regal tranmission question??
  42. Buick Performance Chips
  43. Regal Fire Wall
  44. 2002 steering has slight bind
  45. 2000 Regal Ls Interior Door Panel Reflector
  46. 2000 Regal Ls Interior Door Panel Reflector
  47. 2000 Regal Ls Interior Door Panel Reflector
  48. Overheating Problems 96 Regal Custom
  49. High Flow Cat
  50. 98 Regal E22?
  51. 96 Regal GS Battery light back on
  52. a/c bearing noise
  53. Headlights relay?
  54. 96 Regal GS Battery light comes on after driving
  55. 1995 Regal GS....Brake/ABS warning light on
  56. Adding power to my 1996 Buick Regal 3.8
  57. micro switch location
  58. 98 regal gs just dying right after start
  59. cannot remove key from ignition !!
  60. exhaust questions for 3.8L 91 custom
  61. Sorensen sensor CSS7 (what is it?)
  62. 1996 Regal 3.8 code 106
  63. 2000 regal will not stay running
  64. Best Speakers to Buy??
  65. Cheapest Horsepower Upgrade?
  66. What do I need to Upgrade to Supercharger
  67. 1986 Regal Engine Swap??
  68. Where are the temp sensor located for 91 Regal?
  69. '96 Regal Radiator Change
  70. Question
  71. 98 GS whistles
  72. Code 41 Cam sensor, Is this a serious issue?
  73. Bleeding Master Cylinder - '92 Limited discs ABS
  74. Questions about a 91 Regal Custom
  75. 93 Regal Custom power lock question
  76. REGAL GS 97 or 97.5?
  77. CV-JOINT how to replace?
  78. 96 Regal GS Battery light comes on after driving
  79. does any one know how to fix oil problems
  80. engine
  81. 97 Regal no Start/Gagues gone nuts
  82. 98 Regal - Turn Signal problem, likely wiring
  83. 98 Regal GS vs 02 Grand Prix GT
  84. will this work?
  85. Regal 93 lost acceleration
  86. air conditioner compressor
  87. Broken hood release
  88. Turn signals stall 94 Regal Custom
  89. Need to change my distributor cap, can't find it!
  90. Buick Regal lifter collapsed
  91. Power Window Regulator
  92. 98 Buickgs
  93. Ways to make my 91 3.8l regal go faster.
  94. 2000 Buick Regal - no dash lights
  95. loud shifting of transmission
  96. 1996 Regal GS 3.8 stalls
  97. pick n pull
  98. what can i do to sup up my L27 3.8
  99. 01 Buick whining noise
  100. Oil Problem?--94 Buick Regal
  101. 88 Regal very hard to start when cold
  102. 2000 Buick Regal Headlights
  103. air bag light
  104. 99 Regal Check Engine/AC problem
  105. click click click...
  106. Let's Play Name This Part!
  107. 91 regal backfiring
  108. Headlamp and dash lights flickering/dimming
  109. 1991 Regal multiple issues
  110. car stalling while driving NEED HELP!
  111. 1992 Regal, 3.8 lit. stalled
  112. 3.1 to 3.8 engine swap
  113. start car w/engine rotated?
  114. 02-03 GS Supercharged
  115. 2000 Buick Regal Rims....
  116. 93 Buick Regal 3.8 liter Oil Pressure?
  117. 3800 engine swap
  118. 95 buick gs stalling
  119. 98 regal gs random stalling, from stop at idle.
  120. 2001 regal LS 3800
  121. any 81-87 regals for sale hear philly area?
  122. 92 Regal Transmission
  123. 99 regal ls
  124. No heat??
  125. changing spark plugs
  126. ball joint press instructions?
  127. crackshaft bot
  128. tail lights
  129. High Idle 1990 Regal Custom 3.1
  130. Window Motor compatability
  131. Pcv valve on 90 Regal w 3.1 engine
  132. Possible cat problem?
  133. steel timing gear
  134. HELP!!! 91 regal lights not working
  135. 92 regal door assembly
  136. 1991 Regal GS - How do I clear the SES light?
  137. 2001 buick regal v6 ls po420 code
  138. brakes/Supercharger question
  139. 96 regal, transmission problems
  140. oil pump ?
  141. 1999-2000 Buick Regal Keyless Entry Remote
  142. Ignition Key Stuck in Accessory Position
  143. 91 Buick Hard start
  144. How to change the spark plugs?
  145. Tranny on a 99 GS
  146. acceleration problem+sound
  147. Spark plug heat shields
  148. 94 Regal Won't turn over
  149. 93 Buick Regal Custom
  150. 3800 Regal owners
  151. Reprogram the keyless remote?
  152. 1999 Buick Regal Random Stalling????
  153. parting out 87 regal
  154. 1991 Buick Regal Radio Reciever question
  155. rough Idle when cold
  156. rough Idle when cold
  157. Car won't turn over
  158. Car won't start all of a sudden...
  159. 1993 regal intermitant starting problems
  160. 92 Regal gas tank
  161. 88' Regal Limited
  162. 95 Buick Regal 3.8
  163. 1988 buick regal starting problem
  164. Rust on ignition coil terminals - replace?
  165. VSS removal
  166. Camshaft sensor Help?
  167. 96 GS rear struts...easy job?
  168. brake lights. centre works, main don't
  169. '97 Regal dash lights fading
  170. 97.5 GS DIC lcd gone bad?//
  171. AC/HEATER FAN trouble
  172. CD player installation
  173. steering whining noise
  174. 99 Buick Regal
  175. reverse lights broken ?
  176. 97 regal gs idiot lights are going crazy
  177. cherry bomb on a 88 regal
  178. analog speedometer stop working
  179. question about panel lights from total newbie
  180. 95 suspension?
  181. What is this tube?
  182. 97 3800 engine squealing noise
  183. Can't find modulator in 92
  184. Shorted Fuse / 2000 Buick Regal GS
  185. ...Idea for a sticky?
  186. fried starter?
  187. '83 Buick Regal Lug pattern?
  188. 97.5 or 98 Regal GS any differences?
  189. gm/regal antenna extension
  190. 2002 door lock problem
  191. knock knock who's there?(88 Regal knocking)
  192. Horn FYI
  193. OIL LEAK... cooler pipes rusty?
  194. What causes uneven brake pad wear?
  195. 96 Regal Airbag light flashes at times
  196. Tie Rod Ends
  197. 1992 Buick Regal Custom with a car newbie
  198. 1998 regal ls, thoughts?
  199. Cornering Lamp Not Working on 97.5 GS
  200. 94 Buick Regal climate control lighting does not work
  201. 2.8 3.1 heads the same?
  202. Rear struts
  203. Break lights acting funny
  204. '94 Regal Humming noise
  205. '98 regal seat warmer repair
  206. Emission test failure 91 Regal
  207. Replacing a fuel pump
  208. Hub Assembly/ABS Sensor
  209. Oil Changes
  210. 93 regal cps
  211. 99 Regal LS Ocassional Dead Battery
  212. 1994 Buick Regal turn signals not working
  213. Airbag Light
  214. 1996 Buick Regal Custom 3800 Shutters
  215. Regal GS Tires
  216. brakes vibrates when applies before and after
  217. lss ac
  218. good price?
  219. 93' custom air condition lights
  220. Chronic Rim Leaks
  221. blower motor
  222. Hub Replacement. Do's and Dont's?
  223. where does one shop for buick parts?
  224. 98 regal door won't open
  225. 98 regal door won't open
  226. Ext Temp Sensor and Service Engine Soon
  227. RE: Programming Instruction ...
  228. 91 fuel pump
  229. 93 Buick Regal Electrical Problem
  230. Neutral the tranny @lights??
  231. 1994 buick regal ABS/Brake light on and harder than normal pedal
  232. 99 Stalled...
  233. 1994 buick regal ABS/Redbrake warning light on and brakes feel harder than normal
  234. 98 regal gs won't start when cold
  235. oil life monitor function
  236. Power Window Motor Repair
  237. design tech car starter
  238. Seat Cover Replacement?
  239. Passenger Side Airbag Cover
  240. Power steering reservoir 2000 regal
  241. getting code 33 but wont clear
  242. Regal dies, I mean dead
  243. Buick Regal 2000 Fuel Guage Problem
  244. Spark problem on 91 Regal
  245. 91 Regal - parasitic battery drain
  246. Trunk Lock does not work from button in glove compartment
  247. odd noise
  248. left turn signal on 99 Regal GS
  249. 1994 Buick Regal GS
  250. Buick Regals Hidden Power Steering Unit
