View Full Version : Regal
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12
  1. 2000 instrument gauges acting up
  2. 2000 regal coolant leak, back left on engine
  3. code c1246
  4. 92 Regal Turn Signals
  5. 99 regal dash lights intermittent
  6. I have about given up
  7. will not start
  8. 1999 Regal GS ABS Light
  9. 2000 GS Fuel pump resistor/bypass???
  10. buick regal upper and lower intake
  11. 2000 regal no start, dash flashing
  12. Buying Advise Asap
  13. 91 Regal wont start
  14. How to change ignition switch?
  15. 00 regal starts sometime
  16. Buick Regal stalls when turn signal on and stopping
  17. 92 Buick Regal; Various Problems
  18. 93 Regal - Back Up Light Sensor
  19. '93 Buick Regal 3.8L - cranks but won't start
  20. Rear center brake light
  21. 90 Regal GS will not start
  22. key broke off in ignition switch
  23. 1999 Regal GS 3.8 Supercharged wont start - see details
  24. Coolant
  25. Power Locks/Mirrors
  26. buick regal 2000 radiator leak
  27. 94 regal won't start
  28. white smoke and water comeing out the tailpipe
  29. i dunno what to do next..
  30. 96 Buick Regal Custom- new battery worked for a day. Now car won't start.
  31. 2002 Buick regal LS steering problem
  32. 1993 Regal Strut/ Shock Replacement
  33. How do i reprogram the remote keyless entry of a 91 regal
  34. Which ABS sensor causing problems?
  35. 92 Regal- Goes to nuetral when stopped.
  36. sluggish acceleration when cold
  37. 1999 LSE "Low Coolant" light
  38. 1991 regal
  39. Rough Running
  40. Blend Door Actuator
  41. Low Oil Level Light
  42. 00 regal won't start
  43. unusual symptoms! Haunted 97 Regal LS
  44. 2002 Regal Tensioner
  45. 98 RegalGS won't start
  46. 92' Buick Regal just stopped working
  47. 2002 regal 3800 cranks a while before starting
  48. No spark
  49. delay in acceleration when stepping on the gas
  50. PCV valve on 3800 w/ SC
  51. 00 Buick Regal LSE will not start please help
  52. 2000 Buick Regal LSE - Shifts Hard
  53. 92 regal 3.1 power steerting line
  54. Headlight chime
  55. '00 Regal LS IP Cluster Question
  56. Running rough after seafoam
  57. 99 Buick Regal LS P1810 & P1811 Codes/ Tranny rebuild?
  58. Interior Lights Will Not Turn Off
  59. Can I put a KATS recirculating heater in my '93 Regal ?
  60. trackbar
  61. Driveline thump
  62. turn signal question 97 LS
  63. Typical Lifespan Of A 2000 Regal Ls
  64. P0480 2000 3.8l K
  65. Latest problem: Fuel pump humming?
  66. Coolant Loss
  67. 98 Regal brakes system gone hay-wirer
  68. Stalled on the highway
  69. smoke rising from steering column
  70. 1991 regal gs
  71. sensor
  72. Turn off Running Lights
  73. 2000 regal keyless entry problem
  74. Trunk Lock
  75. 94 regal issues
  76. Car making thump, thump, thump sound... what would it be?
  77. I'm car illiterate please help...
  78. '92 Regal A/C blows hot air
  79. 1991 regal shuts down after 15 mins of driving/warmup.
  80. Fuel Pump Resistor
  81. gauge light
  82. 92 Buick Regal Electrical Problems
  83. 92 Regal cam position sensor
  84. Cruise control
  85. 94 Regal 3.1 PASS-Key bypass instructions
  86. 1991 regal gs
  87. car start with remote but not with key
  88. 1996 Buick Regal wheel noise
  89. 92' Regal: 2 brake questions
  90. 02' Regal 3.8 engine
  91. Leaking Mirror
  92. New remote installation - Buick Regal
  93. Front-end vibrates in bumps
  94. 1991 regal gs 3800
  95. 1999 Regal, 3800II, electrical - wont start
  96. opinions please
  97. Keyless Remote Module Location
  98. Cluster Dashboard Light Problem
  99. 2001 Buick Regal LS electrical problem.
  100. 99 Regal GS Fuel Tank Pressure/Gas Coming Out When Filling Up!!
  101. 2001 regal LS poor fuel mileage
  102. Coolant Sensor cleaning/service
  103. brake light: 1998 Regal GS
  104. 1988 Regal squeeking in front please help.
  105. 89 regal 3.1 fuel prob.
  106. Buick Regal Aftermarket Stereo
  107. 93 regal 3.8 cruise control
  108. 1992 Buick Regal Water Pump Pulley gone bad need advice please!
  109. 94 regal custom horn wont turn off
  110. 89 regal 3.1 fuel pump
  111. Help with 98 buick electrical problem please
  112. 98 regal AC Electrical problem
  113. Intermittent high idle
  114. 1991 regal gs
  115. Buick Regal Trailer Hitch ??
  116. 94 Regal GS intermittent power after start up
  117. fuel pump resistor or O2 sensor
  118. 1991 regal gs
  119. 1994 buick regal GS head unit? anyone?@!$
  120. 1991 regal gs
  121. Rad Drain Plug??
  122. Rough Idle or Bad Miss Help.
  123. 99 regal needs new sparks plugs
  124. spark plugs
  125. 1980 Regal w/350 chevy...heating problem
  126. 2000 Buick ignition key stuck
  127. 99 regal needs new maf
  128. intermitant engine stall?
  129. 1993 Regal GS has rough IDLE
  130. 2001 Buick Regal moans
  131. my power locks dont work
  132. electrical problems with my 1996 buick regal custom
  133. No POWER
  134. review mirror - mounting button
  135. '99 LSE 3800 - won't start, but tries!!
  136. stolen catalytic converter
  137. 1992 buick regal brakes
  138. 93 Regal alternator (power) usage vs mpg
  139. 1991 buick regal
  140. 1995 Buick Regal A/C stopped
  141. 92 Buick regal Speedo work OD does not
  142. 99 Regal GS, starts, dies after 3 seconds
  143. passenger side door wont open
  144. smoke from steering column
  145. 97 Regal-Change Oil soon lights stays on
  146. 2000 Regal A/C
  147. Window Switches wont work (2000 Regal LS)
  148. older regal help! unknown noises!
  149. '02 Regal- Severe vacuum in cranckcase
  150. 93 regal misfires (tail pipe explosions and smell)
  151. 97 Regal LS-Passenger side window not working
  152. Regal LS key problems
  153. 2001 regal ls
  154. Window track lubricant- GTP Dad?
  155. burning oil after oil change
  156. 1996 Buick Regal 3.8L AC pressure cutoff
  157. Rear leaf spring pads on 1994 buick regal
  158. replacing the fuel pump
  159. external temp gage
  160. 93 regal battery discharges overnight (sometimes)
  161. 92 Regal runs like garbage now that I
  162. 98 rear window regulator
  163. 95 regal front end bouncy and high
  164. 1996 Regal front end shimmy/vibration?
  165. Regal LS is hesitating
  166. Fuel pump fuse
  167. 1997 buick regal LS 3800
  168. buick regal stalls when placed in reverse or drive
  169. Chime rings when nothing seems wrong
  170. 97 Regal Cigarette Light won't work
  171. window regulator
  172. 1996 Regal GS 3.8 cruise control not working & A/C sound
  173. Runs for seconds then stalls; please help
  174. Drivers door window don't work.
  175. A/C Not Cold - 94 Buick Regal 3.8
  176. 1994 Buick Regal... water issues
  177. 1991 buick regal
  178. Low voltage on gauge 94 Regal
  179. How dangerous is it to drive with cracked sway bar links?
  180. Resealing the Taillight Assembly
  181. Fuel line connector at fuel rail leaks
  182. Rear glass interchangability
  183. Rear sparkplugs `99 Regal?
  184. cold air intake
  185. 94 Regal 3.8 - Engine Shuts Off While Driving
  186. 1991 regal
  187. 99 regal blower control module location?
  188. help 92 regal wont run??? any tech here
  189. Gas Mileage
  190. what's causing the thud/clunk i'm hearing?
  191. 1991 regal gs
  192. if you ever wondered if Regals are safe....
  193. Engine running over 2000rpm while in park
  194. Busted Tail Light, Can't Find Part
  195. 92 Regal Transfer
  196. 98GS Driver information instrument failure
  197. 93 Regal-major hesitation
  198. replace wiper transmission or crank arm
  199. Turn signal bulb 02' buick regal
  200. 1989 Regal Door lock switch, lighter, mirror switch stopped working
  201. 92 Regal Need Help!!!
  202. Buick Regal - error code 41 - Car has slight Hesitation
  203. 87 Regal: re & re headliner???
  204. Error code P0141, 3.8 v6 Regal 2001
  205. Any experience with Actron CP 9449?
  206. Engine Dies When Turn Signal On
  207. 89 Buick Ignition replacement
  208. 2001 Regal LS oxygen sensor
  209. 2001 Regal fuel gauge issue....
  210. Door Wont open
  211. 99 Regal Keyless entry issues
  212. 2002 Buick Regal is it Supercharged?
  213. 1991 Regal fuel pump
  214. 1995 Regal intermittent miss while cruising down highway
  215. oil leak for 2000 regal
  216. 98 regal cannot turn ignition key
  217. Fuel pressure regulator
  218. 94 Buick Regal - Headlight & Ignition Issue
  219. 1991 regal 3800 245000 miles
  220. 1996 regal overheats at idle, but doesn't if the A.C. is on?
  221. 92 buick regal start problem 3.8L
  222. 91 regal stalling issues
  223. 1991egal
  224. P1071 Code: System mixture to lean (Bank 1)
  225. 92 Regal idle issues
  226. 1992 buick regal gs 3.8 TRANSAXLE DEAD?
  227. 2001 Series II 3.8 v6 blowing oil filters - fix
  228. 93 Regal: 1. Cruise control 2. Power door locks
  229. broken car door handle
  230. Need some help from the electrical guru's!!
  231. '94 Buick Regal - Problem Starting
  232. front end noise
  233. 24 inch rims , HELP
  234. 2002 Buick Regal LS Issues (after repairs)
  235. 1996 Buick Regal electrical issues
  236. 1982 Regal Crank No Start. Fuel Problem???
  237. 1992 Buick Regal Power Steering Leak!
  238. 95 Regal Gas Cap
  239. Hood won't pop.
  240. 99 Regal Front Struts
  241. Small Vibration
  242. 1995 Regal loud transmission noise in P or N
  243. 98 Regal - No Heat
  244. New safety Notice/Recall Buick regal
  245. 99 regal GS transmission problem?
  246. Sticky finish on instrument bezel I console
  247. 1985 Regal won't start. Possible wiring problem?
  248. 99 Regal GS - Couple minor questions
  249. 93 Regal wireless remote programming
  250. 2000 regal -odometer light
