View Full Version : Regal
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12
  1. 1991 regal
  2. 99 GSE heater/AC not working, 35-60mph major shuddering
  3. 93 Regal Custom 3.8L stalling when hot
  4. Fuel Pump, Resister, PCM...will it ever end?
  5. 99 Regal Pulls to right Bent Rear Spindle Adjusting Rod
  6. bogging at 55-60 mph
  7. 1993 3.8 will not stay running on own..
  8. Sway (stabilizer) bar replacement on 98 Regal
  9. My friends 98 Buick Regal all tricked out!!!
  10. timing chain
  11. Readiness monitors won't reset
  12. Clunking in steering wheel??
  13. 1992 Buick Regal Gran Sport 4Dr: Vibration
  14. Stiff gas pedal?
  15. '98 Regal LS Security Light On
  16. 02 regal 3.8 power window
  17. '99 regal power windows
  18. Abs/brakes acting up
  19. EGR valve
  20. Service engine light on
  21. 2001 regal has a hesitation (no power)
  22. Painting my Regal
  23. camshaft position sensor
  24. 440t4 '90 Regal with common "harsh downshift" looking for link on the rear spring
  25. 1999 Buick Regal Ignition Switch
  26. Service Engine Soon Light On
  27. parts That Never Go Bad?
  28. 99 Regal LS - Replaced Starter - cranks - no start
  29. heat air flow,2000 regal
  30. 91 Regal shuddering
  31. Coolant Level Sensor
  32. Replacing my '98 regal engine. Is this a good rate and engine price?
  33. everyday starting problems
  34. emergency brake on 98 Regal
  35. Reverse issue. Regal with problems.
  36. Changing fog light bulb on 1998 Buick Regal GS
  37. Soldering a Blower Motor Resistor?
  38. 97 LS Regal Stabilizer link question
  39. Regal 2001 Fuel Pressure Regulator
  40. Starting issues 91 3800 3.8L
  41. 1992 Regal 3.8 stalls
  42. 1996 REGAL Limited Still not Charging (?) !!
  43. 1999 buick regal LS ODOMETER DOESNT LIGHT
  44. Drive Train Vibration
  45. 2011 Buick Regal - Spied
  46. 94 buick regal no spark
  47. 93 Regal fuel pump replacement
  48. Axle Removal
  49. 95 regal - heater control is bad?
  50. Crank< but no spark!!
  51. dash lights
  52. 00 regal 3.8, turn signals cause car to die
  53. Best Brand to replace camshaft position sensor
  54. 91 regal 3.8L v6 vin "L" n00b question on o2 sensors
  55. What touch up paint to buy?
  56. Heater Hose...Dealer only part?
  57. 02 regal questions about keys
  58. stalled again!!
  59. Reverse lights don't work
  60. Intermittent starting problem
  61. 2011 Regal
  62. 1999 Buick Regal starting issues
  63. where is the rcdlr?
  64. Front wheelbearing nut size??
  65. 99' check engine light on
  66. Dual -air condition problem
  67. 98 Regal starter wiring please help
  68. u bend delete..good mod?
  69. 92 regal runs poorly
  70. Thank You Everyone!!!
  71. Need Vapor Lock Solutions
  72. 98 regal super charged??
  73. dog Bones whats the part #
  74. I give up -car just will not start
  75. 99 Buick Regal GS has a bad miss at random times.
  76. 1991 regal
  77. rear plugs and wires
  78. Change igintion switch 2000 regal?
  79. starter/removal on 93 3.1L
  80. Regal won't start by itself
  81. starter switch and starter for a 2000 regal
  82. i need help
  83. Engine stalls sometimes when I brake
  84. Mono spring????
  85. 93 Regal Misfire
  86. Clicking when I start car.
  87. No Power to Fuel Relay, 1997 Regal GS
  88. serpentine belt slipping / plus noise - 1998 GS
  89. 98 Regal GS power steering fluid resevoir???
  90. Can't get key out of ignition
  91. 93 regal 3.1 starting problem
  92. help..any would be great
  93. Starting/running probs....
  94. 93 regal no start
  95. 97 regal Starter issues
  96. Hard shift...Shift solenoid or torque conv?
  97. Engine stall Problem. Runs Fine then Dies.
  98. whats that noise
  99. 99 regal oil pan gasket
  100. AC Low Side Port, '96 Regal
  101. Car won't hold an idle/run, I'm stupid
  102. POSSESSED WIPERS!! 94 Regal Gran Sport
  103. Help
  104. Hanging hose under gas tank????
  105. Problem with '99 Regal GS 3.8 (Supercharged)
  106. wiper problems
  107. 95 buick regal grand sport starting problems
  108. motor and tranny fit
  109. Clunking? '98 Regal
  110. wipers
  111. 98 Regal Keyless Receiver Location
  112. A/C condenser replacement on a Regal '98
  113. 99 Regal Remote Entry Failure
  114. a little sluggish
  115. Trans leak
  116. Diagnosing transmission problems
  117. Having problem with car.
  118. anti brake light on ?
  119. One for the books. Schematic for IP & Digital Climate control.
  120. 2001 LS stalls every morning
  121. water leak
  122. Brake Light Problem
  123. Plenum question
  124. 98 buick regal GS supercharger. PROBLEM!!! HELP! PLEASE
  125. Exhaust help please!!!
  126. Inspection due. 00 Regal ls
  127. 96 Regal Speed-o-meter
  128. 4t65e-hd vs. 4t60e
  129. 2002 Regal Stalls - S/C - Lots of details - HELP
  130. 93 Regal AC question
  131. 93 regal 3.1L dies going down the road
  132. 94" Buick Regal won't start using the key ang sometimes shuts off
  133. transmission issues. 91 buick regal 3.8
  134. 93 rough upon acceleration
  135. Ignition harness
  136. P0171- Bank 1 lean on 96 Regal w/3800 NA
  137. Don't have #18 fuel pump speed control
  138. Cracked sway bar
  139. sputtering
  140. Cruise Control question
  141. 99 Regal LS Brake Repair
  142. 99 Regal LS Transmission Question
  143. 99 Regal LS "Low Coolant" Light
  144. Location of check engine light
  145. Transmission THUNK
  146. '01 VATS key
  147. 96 regal crankshaft sensor?
  148. how difficult?
  149. a/c why?
  150. P0113, P0440, P0440pd
  151. 1999 buick regal dash lights
  152. 02 buick regal supercharged
  153. 83 regal
  154. 1999 Buick Regal Airbag Module Dilema
  155. 0 to 5 oil pressure 93 regal 3.8
  156. Belt Issues
  157. Rear end sag - the car's not mine
  158. 1998 Regal LS won't start... totally dumbfounded..
  159. hood latch 1988 buick regal
  160. 94 Buick Regal Engine Code Help
  161. flush that bad stuff away
  162. car runs better after UIM and LIM gaskets done
  163. recall on regal
  164. want a supercharger
  165. low tire light
  166. Headlight cover question
  167. Drain plug confusion????
  168. shift solenoid 1996 buick
  169. Rear Window Defroster 92 Regal Limited
  170. Need help trying to find front end part numbers!!
  171. OBD 2 code
  172. 93 regal strut noise (clinking and knocking noise)
  173. Re: 97.5 Regal.:.Left Turn signal out / right brake lamp out -Redux
  174. Window regulator cable retainer clips
  175. car wont start
  176. '90 Buick Regal. Tech 1 scan tool question for the pros.
  177. Windshield washer nozzle replacement?
  178. Codes for tourque conv.?
  179. Synthetic oil question 97 Regal LS
  180. 2001 LS security lite
  181. 1991 Regal Ltm. Problem
  182. hub bearing easy or not
  183. buick is sluggish
  184. 92 Regal gauge cluster
  185. UIM/LIM Problems
  186. life span of Ignition wires?
  187. Name this motor mount?
  188. air bag light on ?
  189. 93 regal 3 windows work 1 doesnt
  190. 1999 Regal questions
  191. 98 Regal : side-view power mirrors not working
  192. 97 Regal Leaky intake manifold gaskets
  193. `03 Regal Low Oil Level Sensor
  194. Car will start but dies stalls after 3 or 4 seconds?
  195. 00 regal fuel level
  196. 95 regal tranny pawl
  197. dash lights
  198. 94 3.8L v6 Regal
  199. 01 regal foam in coolant reservoir
  200. 99 ls rear valve cover removal, tensioner assy?
  201. Coolant flush timing question
  202. taking trunk struts off?
  203. Starter Runs Continuously
  204. how to change the window regulator and get the door panel off
  205. 97 Buick Regal Left Fender re & re
  206. 2001 GS with heater problems
  207. 2001 Buick Regal LS - 143k mi. - Radio Volume Jumps
  208. 92 Buick Regal; Stop light not working
  209. Blower motor dosen't work in sub zero temps
  210. Tranny Troubles?
  211. 1996 Buick Regal Custom 3800 II No Start
  212. '92 Regal Custom turn signals not working
  213. 1999 Regal GS water pump question.
  214. 92 Regal fan motors
  215. Tensioner Pully
  216. 02 Regal Joseph Abboud, PO412 Trouble Code
  217. How do you remove the steering wheel?
  218. 2001 Buick Regal--Dash lights dim
  219. 2000 Buick Problem Starting
  220. 92 Regal trans fluid change
  221. Heater hose size 2002 Regal
  222. 93 3.8 swap for a s.c. 3.8... will it fit?
  223. 2001 - Won't idle, but will run at higher RPM
  224. 97 Regal GS - HVAC Climate Control
  225. plastic nipple for bypass water pump to intake broke pllzz help
  226. Newbie just bought a 2002 GS steering problem?
  227. 99 Regal GS Coolant leak
  228. HVAC Control Panel
  229. Turn signal question 97 LS Regal
  230. 3.8 supercharger and another question
  231. 99 regal both keyfobs not working
  232. auto tranny thumps into place
  233. 2001 gs whining when accelrating and some times moans when it turns
  234. 91 3800 speed sensor function?
  235. 1999 regal gs
  236. Low Coolant light on 97 LS Regal
  237. 1994 Buick Regal GS ALDL(DTC) not powering scan tool
  238. 2000 Regal LS - Interior lights
  239. Tight Caliper Bracket Bolts
  240. Universal Windshield Washer Nozzles?
  241. 92 Regal fuel lines
  242. 97 LS cranking, cranking but won't start!
  243. 92 Cruise Control
  244. 92 Regal Codes 13 and 44
  245. 91 regal starter wires?
  246. Tricky Question for the Gurus
  247. I Messed Up Bad
  248. 2002 Regal LS O2 sensor
  249. 97 Buick Regal GS - No Start - Intermittent
  250. 97 Regal Brake failure
