View Full Version : Regal
Pages : 1 2 [3] 4 5 6 7 8 9 10
  1. 1996 regal overheats at idle, but doesn't if the A.C. is on?
  2. 92 buick regal start problem 3.8L
  3. 91 regal stalling issues
  4. 1991egal
  5. P1071 Code: System mixture to lean (Bank 1)
  6. 92 Regal idle issues
  7. 1992 buick regal gs 3.8 TRANSAXLE DEAD?
  8. 2001 Series II 3.8 v6 blowing oil filters - fix
  9. 93 Regal: 1. Cruise control 2. Power door locks
  10. broken car door handle
  11. Need some help from the electrical guru's!!
  12. '94 Buick Regal - Problem Starting
  13. front end noise
  14. 24 inch rims , HELP
  15. 2002 Buick Regal LS Issues (after repairs)
  16. 1996 Buick Regal electrical issues
  17. 1982 Regal Crank No Start. Fuel Problem???
  18. 1992 Buick Regal Power Steering Leak!
  19. 95 Regal Gas Cap
  20. Hood won't pop.
  21. 99 Regal Front Struts
  22. Small Vibration
  23. 1995 Regal loud transmission noise in P or N
  24. 98 Regal - No Heat
  25. New safety Notice/Recall Buick regal
  26. 99 regal GS transmission problem?
  27. Sticky finish on instrument bezel I console
  28. 1985 Regal won't start. Possible wiring problem?
  29. 99 Regal GS - Couple minor questions
  30. 93 Regal wireless remote programming
  31. 2000 regal -odometer light
  32. Buick Regal 1998 stalls when turn signal on and stopping.
  33. cat converter want code 420 gone
  34. 94 Buick Regal
  35. Blinker bulbs melting near contacts?
  36. car burnt up aless than 150 miles trans rebuilt PLEASE HELP
  37. 91 Regal hood won't release
  38. Speedometer
  39. How To Fix Heated 02 Sensor Regal
  40. Need some real quick help please!
  41. 2002 Buick Regal LS question
  42. MiSsInG 3.8 GS
  43. To attempt or not to attempt.
  44. Hey can anyone help me please... '92 buick regal gs 3.8
  45. power steering reservoir fluid level
  46. 1990 Buick Regal Custom 3.1L shuts off after 5 min. warmup (won't restart until cold)
  47. L27 performance/modding
  48. IP Cluster 00 Regal LS
  49. Intermittent stall & no start- Fuel pump relay makes fast ticking sound?
  50. Radio Wiring Harness
  51. 3100 series upgrades
  52. 98 Buick Regal Tensioner replacement / No start
  53. 90 buick regal PLEASE HELP!!!
  54. Remote leyless entry, Very weird problem.
  55. 94 Regal GS 3.8, multiple starting issues
  56. 3.1 1993 Regal runs until it warms up then won't restart until it cools
  57. 1997 Regal GS - Starting problem
  58. '83 3.8L knocking after oil change??
  59. Need some help! 1996 Regal stalls while driving and then won't restart
  60. Battery dead in my 1994 Buick Regal Custom!!! Can I change it on my own?
  61. 98 Regal rear windows
  62. Installed another tranny, now...
  63. 1991 Buick Regal Custom- Lateral Stab Bar R&R
  64. 93 regal tensioner came off!
  65. 89 Regal Tail light issues need help please
  66. 94 Regal Custom electrical lights dim
  67. Basic Cold Air Intake
  68. installing new stereo in a 1992 buick regal gs
  69. 93 Buick Regal Lmt
  70. Battery Gauge
  71. Is there a section for standard repairs?
  72. 1991 Regal Custom - High Idle
  73. 1990 buick regal radiator
  74. 95 Regal won't start after sitting
  75. 2001 Regal, rough start, power steering rumble
  76. 92 regal 3.8
  77. 98 regal no start/code 1610,1626
  78. Strut Recommendations
  79. help me with 92' buick regal?
  80. '88 Buick Regal sputtering badly. Only has 34K miles on it! Please help
  81. 93 Regal 3800 door locks
  82. buick regal 94 custom stalling problem
  83. Installing Rack and Pinion in 2002 Buick Regal LS
  84. 99 Buick Regal blower motor problem
  85. 84 T-type "sneezing" out turbo
  86. 93 regal GS electric problem
  87. 92 Regal code 17
  88. Loud squeeling sound-97 Regal LS
  89. Headlignts and highbeams
  90. fuel pump or sensor??
  91. 92 Buick Regal
  92. water leak
  93. 1991 Buick Regal Won't Start!!!!!!!!!!!!!!!!!
  94. 93 engine swap?
  95. 92 Buick Regal
  96. GS vs GSX
  97. 1999 regal
  98. heater and a/c dont work
  99. 1999 regal gs
  100. Brake system gone haywire
  101. 84 t-type vacuum diagrams and firing order for coil pack?
  102. 94 GS - Zero Compression
  103. Auto lights turn off when blower motor turned on
  104. Power steering stiff when cold
  105. Shift Control Cable
  106. 01 regal seat warmer
  107. '98' Buick Regal
  108. trouble code dtc u1153
  109. Fog lights for older body style? - 1995
  110. 2000 regal GS ecm ?
  111. 93 regal ABS/BRAKE warning light + alternator "gauges" light
  112. 83 regal t-type compression limits
  113. Light electrical problem
  114. 94 Regal 3.8 Engine - How To Change TCC Solenoid
  115. battery change
  116. 94 Regal 3.8 Engine - Codes P0705 & 1406
  117. 96 buick regal 3800 type 2
  118. 90 buick regal transmission problems
  119. 97 regal gs radio
  120. 97 regal gs
  121. Broken Fuel Line
  122. 1993 regal gs power steering line
  123. Water Leak keeps coming back
  124. 98 Regal ls/P0507
  125. Check Engine Light doesn't work
  126. 1994 regal 3.8 problems starting and stalling
  127. Tensioner Pulley Remove/Install
  128. 94 Regal Shuts Off
  129. 97 regal low beams not working and drl
  130. 83 Buick Regal for $300.00, good deal??
  131. 1999 regal
  132. Basic Engine upgrades to get a little more
  133. wipers stop in upright position
  134. Climate Control Lights
  135. 4T60 no forward or reverse after sitting overnight
  136. supercharger
  137. 94 regal custom hard starting
  138. 1996 regal wont start
  139. '92 Regal won't start
  140. Supercharged 3800 maintainence
  141. 2001 Regal Backup/Reverse lights not working
  142. 92 Regal Turn Signals?
  143. 1988 Buick Regal Stalls and Won't Start
  144. Digital Dash broken, odometer?
  145. computer woes
  146. exhaust
  147. 99 Buick Regal GS Heater problems
  148. new or used struts
  149. how to get to a 1991 regal starter
  150. rims...
  151. 98 regal gs 3800 supercharged
  152. 1999 odometer light
  153. 1993 Regal windshield wiper switch
  154. '91 3.1 won't run with gas cap on...?
  155. Please Help
  156. 2001 Buick Regal LS shifting & digital gear display
  157. What oil to Use?
  158. 01 Buick Regal LS
  159. 94' Regal GS charging issues
  160. 2000 regal front headlight doesnt work
  161. A/C Compressor Noise
  162. 97 regal LS jumpy speedometer needle
  163. 1999 Regal LS Headlight Aiming Problem
  164. 98 Buick Regal only start w/lights on
  165. 92 Regal no start, no power, no headlights, possible bad ECM?
  166. 1990 battery cover issue
  167. '93 Regal Custom problem with a fuse
  168. Where is the window ground landed?
  169. 91 regal problems starting
  170. 99 regal GS not charging
  171. 91 regal stalling/wavering idle
  172. water leaks
  173. ignition cylinder won't come out
  174. 1999 buick regal
  175. 88 Buick Regal won't stay running
  176. 1986 carb tuning help???
  177. 2000 Regal GS supercharger whine
  178. I need a compatible models for a driver side bucket seat. (94 Buick Regal Custom)
  179. AC / Heater blower Motor always on
  180. 1991 buick regal 3800 died out wont start
  181. 2004 Regal Brakes and ABS Light
  182. Will Not Start
  183. electrical gremlins
  184. buick regal window regulator or motor?
  185. Climate Control and Cruise Control Problem
  186. 1999 regal gs
  187. 1993 Buick Regal Keyless Entry Receiver Module Location
  188. 99 Regal LS hesitation up hill?
  189. 1990 stalls when brakes are applied
  190. Whinning sound. Transmission going???
  191. 1996 Belt Tensioner
  192. Tire Pressure?
  193. Window regulator question...?
  194. rear struts
  195. hesitation/jerk 2001 Regal LS 10-15 mph
  196. What number tranny?
  197. whinning noise
  198. transmission problem?
  199. '95 Regal GS Intermitting problem - need help badly!
  200. sway in rear end?
  201. 1999 regal gs
  202. 2000 Regal - Backup and license plate lights not working
  203. Regal low shift points
  204. abs sensor for 2000 regal LS
  205. 01 Regal 3.8 intake manifold???
  206. right window will not work(need to take off panel)
  207. Regal '91 - brakes control solenoid
  208. anti-lock brake light
  209. overheated buick regal
  210. 1999 Regal Stereo Speaker Removal
  211. 96 Regal continual brake issues
  212. Sun Visors
  213. 1990 buick regal radiator drain plug
  214. 91 Regal GS 3.8 no spark
  215. Power Moonroof Switch
  216. 98 buick regal wont start
  217. Buick regal 2000 HVAC
  218. low coolant light
  219. Horns goes off when ever it feels like it!!!
  220. 99 Regal LS 3.8
  221. Ignition problem - 2001 Regal
  222. 93' Buick Regal "Low Oil" Light On.....
  223. 99 Regal Supercharge...starts but dies immediately
  224. new Regal Moderator
  225. 1993 regal idles rough
  226. 96 Regal ABS light on
  227. 2000 Buick Regal GSE Fuse Block problem
  228. '99 vent doors noise?
  229. please help me 97 buick regal!
  230. 93 Buick Regal shutsdown
  231. 2002 regal 3.8 loses power on hills
  232. 92 Regal blowing fuse pump fuse
  233. 2000 GS Stalling
  234. 80 buick regal oil in the air cleaner
  235. 1980 buick regal
  236. broken power window switch 97 Regal
  237. 98 Buick Regal GS list of problems all at once
  238. 1993 regal 3.8l starting problem
  239. Bleeding Brakes ABS '92 Regal
  240. How to disable just the auto door lock feature?
  241. low blower speeds
  242. 90 regal 3.1 autocross car
  243. 98 Buick Regal won't start
  244. Window Stuck 98 Regal GS
  245. glove box broken
  246. 98 regal a/c problems
  247. Hi, Problem starting after battery drained
  248. 99 regal ls dash HVAC door control
  249. Turn signal problem
  250. paint code
