View Full Version : Regal
Pages :
1 [ 2]
3 4 5 6 7 8 9 10
- Turn signal question 97 LS Regal
- 3.8 supercharger and another question
- 99 regal both keyfobs not working
- auto tranny thumps into place
- 2001 gs whining when accelrating and some times moans when it turns
- 91 3800 speed sensor function?
- 1999 regal gs
- Low Coolant light on 97 LS Regal
- 1994 Buick Regal GS ALDL(DTC) not powering scan tool
- 2000 Regal LS - Interior lights
- Tight Caliper Bracket Bolts
- Universal Windshield Washer Nozzles?
- 92 Regal fuel lines
- 97 LS cranking, cranking but won't start!
- 92 Cruise Control
- 92 Regal Codes 13 and 44
- 91 regal starter wires?
- Tricky Question for the Gurus
- I Messed Up Bad
- 2002 Regal LS O2 sensor
- 97 Buick Regal GS - No Start - Intermittent
- 97 Regal Brake failure
- 99 regal electrical gremlin
- 2000 instrument gauges acting up
- 2000 regal coolant leak, back left on engine
- code c1246
- 92 Regal Turn Signals
- 99 regal dash lights intermittent
- I have about given up
- will not start
- 1999 Regal GS ABS Light
- 2000 GS Fuel pump resistor/bypass???
- buick regal upper and lower intake
- 2000 regal no start, dash flashing
- Buying Advise Asap
- 91 Regal wont start
- How to change ignition switch?
- 00 regal starts sometime
- Buick Regal stalls when turn signal on and stopping
- 92 Buick Regal; Various Problems
- 93 Regal - Back Up Light Sensor
- '93 Buick Regal 3.8L - cranks but won't start
- Rear center brake light
- 90 Regal GS will not start
- key broke off in ignition switch
- 1999 Regal GS 3.8 Supercharged wont start - see details
- Coolant
- Power Locks/Mirrors
- buick regal 2000 radiator leak
- 94 regal won't start
- white smoke and water comeing out the tailpipe
- i dunno what to do next..
- 96 Buick Regal Custom- new battery worked for a day. Now car won't start.
- 2002 Buick regal LS steering problem
- 1993 Regal Strut/ Shock Replacement
- How do i reprogram the remote keyless entry of a 91 regal
- Which ABS sensor causing problems?
- 92 Regal- Goes to nuetral when stopped.
- sluggish acceleration when cold
- 1999 LSE "Low Coolant" light
- 1991 regal
- Rough Running
- Blend Door Actuator
- Low Oil Level Light
- 00 regal won't start
- unusual symptoms! Haunted 97 Regal LS
- 2002 Regal Tensioner
- 98 RegalGS won't start
- 92' Buick Regal just stopped working
- 2002 regal 3800 cranks a while before starting
- No spark
- delay in acceleration when stepping on the gas
- PCV valve on 3800 w/ SC
- 00 Buick Regal LSE will not start please help
- 2000 Buick Regal LSE - Shifts Hard
- 92 regal 3.1 power steerting line
- Headlight chime
- '00 Regal LS IP Cluster Question
- Running rough after seafoam
- 99 Buick Regal LS P1810 & P1811 Codes/ Tranny rebuild?
- Interior Lights Will Not Turn Off
- Can I put a KATS recirculating heater in my '93 Regal ?
- trackbar
- Driveline thump
- turn signal question 97 LS
- Typical Lifespan Of A 2000 Regal Ls
- P0480 2000 3.8l K
- Latest problem: Fuel pump humming?
- Coolant Loss
- 98 Regal brakes system gone hay-wirer
- Stalled on the highway
- smoke rising from steering column
- 1991 regal gs
- sensor
- Turn off Running Lights
- 2000 regal keyless entry problem
- Trunk Lock
- 94 regal issues
- Car making thump, thump, thump sound... what would it be?
- I'm car illiterate please help...
- '92 Regal A/C blows hot air
- 1991 regal shuts down after 15 mins of driving/warmup.
- Fuel Pump Resistor
- gauge light
- 92 Buick Regal Electrical Problems
- 92 Regal cam position sensor
- Cruise control
- 94 Regal 3.1 PASS-Key bypass instructions
- 1991 regal gs
- car start with remote but not with key
- 1996 Buick Regal wheel noise
- 92' Regal: 2 brake questions
- 02' Regal 3.8 engine
- Leaking Mirror
- New remote installation - Buick Regal
- Front-end vibrates in bumps
- 1991 regal gs 3800
- 1999 Regal, 3800II, electrical - wont start
- opinions please
- Keyless Remote Module Location
- Cluster Dashboard Light Problem
- 2001 Buick Regal LS electrical problem.
- 99 Regal GS Fuel Tank Pressure/Gas Coming Out When Filling Up!!
- 2001 regal LS poor fuel mileage
- Coolant Sensor cleaning/service
- brake light: 1998 Regal GS
- 1988 Regal squeeking in front please help.
- 89 regal 3.1 fuel prob.
- Buick Regal Aftermarket Stereo
- 93 regal 3.8 cruise control
- 1992 Buick Regal Water Pump Pulley gone bad need advice please!
- 94 regal custom horn wont turn off
- 89 regal 3.1 fuel pump
- Help with 98 buick electrical problem please
- 98 regal AC Electrical problem
- Intermittent high idle
- 1991 regal gs
- Buick Regal Trailer Hitch ??
- 94 Regal GS intermittent power after start up
- fuel pump resistor or O2 sensor
- 1991 regal gs
- 1994 buick regal GS head unit? anyone?@!$
- 1991 regal gs
- Rad Drain Plug??
- Rough Idle or Bad Miss Help.
- 99 regal needs new sparks plugs
- spark plugs
- 1980 Regal w/350 chevy...heating problem
- 2000 Buick ignition key stuck
- 99 regal needs new maf
- intermitant engine stall?
- 1993 Regal GS has rough IDLE
- 2001 Buick Regal moans
- my power locks dont work
- electrical problems with my 1996 buick regal custom
- No POWER
- review mirror - mounting button
- '99 LSE 3800 - won't start, but tries!!
- stolen catalytic converter
- 1992 buick regal brakes
- 93 Regal alternator (power) usage vs mpg
- 1991 buick regal
- 1995 Buick Regal A/C stopped
- 92 Buick regal Speedo work OD does not
- 99 Regal GS, starts, dies after 3 seconds
- passenger side door wont open
- smoke from steering column
- 97 Regal-Change Oil soon lights stays on
- 2000 Regal A/C
- Window Switches wont work (2000 Regal LS)
- older regal help! unknown noises!
- '02 Regal- Severe vacuum in cranckcase
- 93 regal misfires (tail pipe explosions and smell)
- 97 Regal LS-Passenger side window not working
- Regal LS key problems
- 2001 regal ls
- Window track lubricant- GTP Dad?
- burning oil after oil change
- 1996 Buick Regal 3.8L AC pressure cutoff
- Rear leaf spring pads on 1994 buick regal
- replacing the fuel pump
- external temp gage
- 93 regal battery discharges overnight (sometimes)
- 92 Regal runs like garbage now that I
- 98 rear window regulator
- 95 regal front end bouncy and high
- 1996 Regal front end shimmy/vibration?
- Regal LS is hesitating
- Fuel pump fuse
- 1997 buick regal LS 3800
- buick regal stalls when placed in reverse or drive
- Chime rings when nothing seems wrong
- 97 Regal Cigarette Light won't work
- window regulator
- 1996 Regal GS 3.8 cruise control not working & A/C sound
- Runs for seconds then stalls; please help
- Drivers door window don't work.
- A/C Not Cold - 94 Buick Regal 3.8
- 1994 Buick Regal... water issues
- 1991 buick regal
- Low voltage on gauge 94 Regal
- How dangerous is it to drive with cracked sway bar links?
- Resealing the Taillight Assembly
- Fuel line connector at fuel rail leaks
- Rear glass interchangability
- Rear sparkplugs `99 Regal?
- cold air intake
- 94 Regal 3.8 - Engine Shuts Off While Driving
- 1991 regal
- 99 regal blower control module location?
- help 92 regal wont run??? any tech here
- Gas Mileage
- what's causing the thud/clunk i'm hearing?
- 1991 regal gs
- if you ever wondered if Regals are safe....
- Engine running over 2000rpm while in park
- Busted Tail Light, Can't Find Part
- 92 Regal Transfer
- 98GS Driver information instrument failure
- 93 Regal-major hesitation
- replace wiper transmission or crank arm
- Turn signal bulb 02' buick regal
- 1989 Regal Door lock switch, lighter, mirror switch stopped working
- 92 Regal Need Help!!!
- Buick Regal - error code 41 - Car has slight Hesitation
- 87 Regal: re & re headliner???
- Error code P0141, 3.8 v6 Regal 2001
- Any experience with Actron CP 9449?
- Engine Dies When Turn Signal On
- 89 Buick Ignition replacement
- 2001 Regal LS oxygen sensor
- 2001 Regal fuel gauge issue....
- Door Wont open
- 99 Regal Keyless entry issues
- 2002 Buick Regal is it Supercharged?
- 1991 Regal fuel pump
- 1995 Regal intermittent miss while cruising down highway
- oil leak for 2000 regal
- 98 regal cannot turn ignition key
- Fuel pressure regulator
- 94 Buick Regal - Headlight & Ignition Issue
- 1991 regal 3800 245000 miles
- 1996 regal overheats at idle, but doesn't if the A.C. is on?
- 92 buick regal start problem 3.8L
- 91 regal stalling issues
- 1991egal
- P1071 Code: System mixture to lean (Bank 1)
- 92 Regal idle issues
- 1992 buick regal gs 3.8 TRANSAXLE DEAD?
- 2001 Series II 3.8 v6 blowing oil filters - fix
