View Full Version : Regal
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12
  1. 91 Regal 3.8 no spark
  2. Stabilizer Shaft Insulators Replacement
  3. 1995 Regal GS starting problems
  4. No Dash Lights
  5. use regular in superchaged MOTO
  6. 1992 Regal odometer stopped
  7. 1992 Regal Brake warning light.
  8. 1992 Regal ventilation air dampers
  9. 2004 Regal oil drain plug ?
  10. 96 Regal fuel pump relays
  11. 94 Regal Cruise Control & VSS
  12. 89 Regal probs
  13. 1978 Buick Regal Coupe Interested in Selling
  14. Buick Regal Blinker Problems
  15. Gas Gauge
  16. 1991 Regal Master Cylinder
  17. '94 Buick Regal GS trouble starting
  18. changed a fuse now it won't tunr over
  19. Engine trim cover removal
  20. 00 3800 - Hesitates between 15-2000rpm when driving?
  21. New recall info: 99 Regals/Century's
  22. easy questions about stock 93 regal 3.8 sc
  23. 1998 Regal abs problems
  24. remote starter
  25. 93 regal ign coils
  26. 2001 Regal Jerks when shifting
  27. 2001 Buick Regal - Grinding noise when turning
  28. 78 Regal where do I find rear rebar??
  29. cruse control drops out
  30. 93 Regal-turning off engine does not unlock power doors
  31. 95 RKE programing problem
  32. Programming directions for 1998 Regal
  33. 1995 Regal - Plug wires
  34. Remote Keyless Instructions for 98 Buick Regal
  35. 1995 Regal shuts down
  36. 94 Regal intermitant starting
  37. p106
  38. 1990 3.1L V6 Buick Regal
  39. Running Poorly.
  40. Regal 98 Intermittent problem
  41. 1992 Regal didn't pass emissions
  42. Pulling codes
  43. knock sensor location on 94 regal with 3.1???
  44. 1986 buick regal problem
  45. CEL after 50 mph
  46. 88 Buick Regal Passenger Door Handle
  47. fuel gauge for my 93 buick regal custom
  48. Passenger cab filter
  49. 2004 Regal Air Filter
  50. 99 Regal no instrument lights
  51. Busted odometer
  52. 2002 regal won't start
  53. :( big problem!!! HELP!!
  54. Rack & Pinion
  55. GS Supercharger breather plug
  56. Paint colors for 78 Regal
  57. 98 Regal fuel pump
  58. 1996 buick regal intermittant starting
  59. 92 buick regal being junked, need anything?
  60. 89 regal Won't start!
  61. door interchange
  62. 1992 Buick Regal struts
  63. Ignition will not turn
  64. Won't Start
  65. 85 Regal fuel leak
  66. 1992 leaking oil from distributor shaft
  67. tire pressure
  68. Dash light mutiny!!!
  69. 96 buick regal won't run
  70. 99 Regal Rear strut Noise
  71. brake lights on 89 regal
  72. '99 Regal GS New Tranny won't downshift
  73. Few problems w/Regal Custom 3800
  74. 96 Regal Custom E20 error code on radio/cd
  75. 350 swap in an '84 Regal
  76. why are there 2 different sets of lights ?
  77. 92 Buick Regal Headlights & Running Lights
  78. 96 Regal 3.1l overheating
  79. 98 LS completely locked up.
  80. lowering a 94 GS
  81. Where's the PCV valve on a `99 Regal?
  82. Texas Girl needs help!!
  83. difference between 3800 and stage II 3800??
  84. 1987 Regal 307
  85. Temp light problems
  86. 96 Regal start/dies
  87. too slow for money spent 14s?
  88. me too
  89. 94 regal electrical probs
  90. locked steering column
  91. 1993 Regal Blower Motor Removal
  92. 1990 Buick Regal
  93. Regal Parts
  94. Keyless entry system tempermental
  95. 1993 regal radio install problem
  96. turn signal/remove steering wheel 92 Regal
  97. '93 Regal rotor removal
  98. 95 buick regal oil pan removal
  99. '93 Regal GS Problem
  100. Fan Noise
  101. 94 Regal Electrical Problems
  102. Switching ABS systems
  103. Just Bought A 87 Regal Limited
  104. I smell gas
  105. ABS to non-ABS
  106. Left Blinker flash quick... Replace fuse?
  107. serpentine belt
  108. Larger rear brakes
  109. 94 regal GS (3.8) repair help
  110. battery replacement on 1992 Buick regal
  111. 1994 Regal Custom (L27 performance options?)
  112. 1997.5 Regal LS Starts!
  113. 99 Regal Windows, Radio, Door locks malfunctioning
  114. 85 Regal wont hold charge
  115. 1997.5 Regal LS Won't Start!
  116. boost on a regal gs 2001
  117. 96 Regal Console Arm Rest
  118. 1988 Buick Regal stalls when driving
  119. Sensor Location 93 Regal 3.8L
  120. need help customizing
  121. 92 Turn signal Problem
  122. Regal 99 P1360 P1361 - Ignition Coil C/Low Voltage...HELP!!!
  123. Oil is leaking badly..
  124. Wacky wipers -94 Regal custom
  125. anti lock brake, brake, traction control light and service vehicle soon lights all on
  126. 92 Regal keyless entry
  127. 99 Regal Doesn't start (Please Help)
  128. 3.1 Intake Gasket change?
  129. Master Cylinder ABS code #62
  130. velocity stack on 1986 GN?
  131. 02 Buick Regal 3.8 SuperCHG upgrade
  132. kill list
  133. light malfunction
  134. 1999 Buick Regal LS
  135. picture of me and my ride
  136. 1994 Buick Regal intermittent starting problems
  137. insurance?
  138. slight irradic idle
  139. Problems with coolant sensor
  140. 87 gn needs tuning, way slower than it should be
  141. 86 GN lacks power
  142. 3.1 high idle, runs rough
  143. 98 regal trans
  144. Help with Spark Plug Question
  145. My Radio is locked, help please
  146. '94 Regal Custom Trunk Latch Problem & Cruise Control
  147. Master Cylinder
  148. '99 BUICK REGAL GS Electrical Problem
  149. 99 Regal GS shutter
  150. it shuts off at will
  151. 89' Buick Regal Custom 2.8L - overheating problems
  152. 1998 Regal Stalls on Accel, won't restart
  153. Coolant Loss, then overheating
  154. 91 buick regal code 41 running rough
  155. Grand National Performance????
  156. help me please
  157. noob question.
  158. 1995 Regal Air Conditioning
  159. '98 Regal Blower Motor
  160. problems w/94 tran fluid/error light
  161. 1996 Custom Code ?
  162. Short in turn signals
  163. 81 Regal Doesn't Pass Emissions
  164. external temp display not working
  165. How to Remove Radio in 1995 Regal Sedan
  166. Oil life Monitor
  167. 98 buick limited wont start, please help
  168. Over Heating
  169. 97 Regal Turn Signal/Running Light Problem
  170. 1992 Regal Door handle removal
  171. 93 Regal troubleshooting
  172. 1999 Buick Regal - Add HP and Mileage
  173. 92 regal dying
  174. 92 engine code 34 MAF
  175. system for '89 Regal
  176. Rough idle when hot
  177. Keyless entry works....sometimes
  178. My 1989 Buick Regal
  179. '94 - turn signal problem
  180. Front End / Brakes?
  181. 98 Regal, trans prob. maybe?
  182. Haynes shop manual
  183. 92 Regal Limited AC not working
  184. Steering Wheel "Paint"
  185. Turbo buick FAQ's and Myths.
  186. 1992 Buick Regal Stalling
  187. 2000 Buick Regal A/c Control Problem
  188. 98 Buick Regal
  189. Safety Neutral Switch Location
  190. 1999 Regal persistant P0300 code driving us nuts .. help please
  191. drive axl's ????????HELP
  192. digital speedo going nuts
  193. Specs please?!?
  194. Can it be? 5 speed?
  195. Knocking sound under hood
  196. Sure these things are fast, but handling?
  197. speedometer/gauge swap...is this possible?
  198. overheating issues
  199. 88 Regal analog odometer stopped working
  200. Horn, Door Locks, and Keyless Entry problems
  201. 88 regal digital speedometer
  202. 2000 Regal Window Regulators
  203. intermittent starting problem
  204. 3800 does not start
  205. 1991 Buick Regal 3.1 fan/overheat problem
  206. Stalling, Bad Error Codes, Strange Error Lights
  207. Proper fuel pressure for GNX w/ mods?
  208. '99 Regal Dual Climate Control Driverside Hotter
  209. 1979 regal T-type turbo, what the hell is up with this thing?
  210. coolant blow out!!!
  211. 84 Regal lights don't work
  212. 91 Buick Regal
  213. window motor
  214. any 70's buicks ?
  215. 99 Regal LS power windows problem
  216. 97 Fuel Pump problem! HELP
  217. Premature parts replacement
  218. Grill On Grand National - 1987
  219. in need of passenger side rear quarter panel !
  220. 89 regal stalls when slowing or stopped
  221. 99 Regal Gas Gauge Problem
  222. 97+ regal gs.....how good are these cars?
  223. Regal to GN
  224. 81 Regal Vacuum Diagrams
  225. 97 Regal GS Starts then Stalls
  226. 93 regal ghost
  227. 1999 Regal spark plug access
  228. 93 Regal - Engine Stuck? Water in Oil?
  229. 87 Grand National Seat replacements?
  230. Chime problem
  231. 1996 buick regal remote programing
  232. 99 buick regal
  233. anyone have a grille for a 1992 regal?
  234. '89 Regal died - won't start
  235. 99 regal rough idle
  236. Coolant loss
  237. odometer inop
  238. 1993 regal 3.1 troubleshooting question
  239. Battery drain on 91 Coupe. need help badly.
  240. Stop Lights
  241. 1997 regal gs stalling
  242. 98 buick gs Transmission question
  243. Coolant Change
  244. is there any web sites out there that sell parts for 80-87 regals?
  245. 93 3.8L Regal Coolant Leak
  246. 86 GN Stumble
  247. 87 GN Parts
  248. i need help
  249. fuel pump relay
  250. 91 regal 3800
