Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
> JDM Motor & Parts info/chat |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
jdm vs usdm
1/4 mile times
Best Engine For Dd?
prep for install of ported head
b18c1 specs
H22 Vs K20 ?
what is better?
is turbo h22 a bad idea?
every engine place send me a 1.5L D15B engine for my 1.6L 1997 honda civic dx.
ecu question
H22 front clip
Changing the valve springs?
check engine light on 96 integra gsr
b20 help
b20 help
when you get a fix-it ticket?
List of some engines
Exhast Help?
Tell if VTEC's engaging
Honda Accord Sohc Efi 16v
k20a into a 94 dx coupe?
teal valve cover???
engine wieght comparison: SOHC vs. DOHC
H22A Engine serial Numbers
b16a2 into 97 dx
DOHC D16ZC in a 2000 DX?
Is N/A Power Really Reliable ?
best b series tranny?????
help out a noob
What a good next step?
help whit my civic
JDM Engines near Philly or Delaware? NY, NJ? HELP!
H22A4 to JDM H22A? OBDI to OBDII Help
what is the best site to buy engine for a 1997 civic dx.
b16a2 question
need help maken more power from a jdm h22a
will this trans work?
throttle body?
SwAP H22a to 93 civic 4d
No Spark Help!!
zc in 92 dx?
H22 Swap Exchange B16 (Help)
88'accord
Help?
just 1 qustions
head on a zc?
Vtec Head Swap?
b16a swap into 89 hatch
H22a powered Eg
B18C into civic or crx
ecu chip?
K20A2 in an 02 ex...
question
Distributor blues
About this DOHC ZC?
Apexi VAFC vs. SAFC?
Questions...
turbo /swap question
I got my B16a in!
Any idea's?..?..anybody....
D16 Motors
Engine Swap Question...
Clean B16 head
Older motor than car.......
zc motor and rack-opinion
Build b16 1/4mile
vtec help
Cam idea's?
Legal Issues
is this a good deal?
ORIFICE, OIL CONTROL question
very important ?
Help!!!!!!!!!!!!!!!!!!!
will this fit?
OBD2 to OBD1 conversion
Aem V2
questions about an hx
ok, more swap issues...
look at this!!!
Motor Mount ??
Please I need Help Read this Important
Atlanta Area Swap
b16 swap
Info needed on D15B three stage VTEC
B seriers Thermostats and Fan switch
Help
Ecu question For h22 swap
A am Building an AUTO X car
d15 problems
Crx DX B16a1 swap
????complete Change Over????
ls/vtec
HELP I can't decide !?!?!?!?!?!?!?!?!
I've got.. no gas
Easy HP
CTR Cams vs. Skunk2 Stage 1 Cams
Well, Swap Problems...
OBD1 to OBD2 swap?
just wondering
Swap Progress *56K No-No*
h22 swap
B16A won't start!PLEASE HELP!
confusion
help w/b18 swap
bizimoto
CTR Cams? how can i tell a legit one from another type
where to set camgears?
obd0 obd1 wiring question im stumped!!!!
doing my swap tomarrow
ls vtec knock sensor
Mahle pistons for H22
B18B1 DOHC nonvtec to vtec?
b18 wanted
Where do i add trans fluid in b16
Air conditioning
Where to find a good DOHC ZC
GSR Head on my B16
Just Another Silly 'What Parts will Work' Question
Another Engine Swap?
b16a starter
easy swap or not?
tranny switch
AC Bracket for my B16a SiR I swap in my Integra 95
engine
D16 Swaps
transmition
is this wat i need
96 auto integra swapping an h22a motor and 5 spd trans
Ait
zc cam gears
CAn u identify this Prob .. so it can be fiixed?
b16 firring order
jdm vs usdm
conrod bearing for Honda Domani
Civic EK engine upgrade
Need Help Asap Please!!!!!!
compression
More power for ZC DOHC
girl needs engine advice, PLEASE help
black smoke from b16a
gonna go with individual throttle bodies...but have a question
Zc Engine
93 integra parts????
Quick info on a the size of the BORE (mm)
i need a b16
swaps
dohc zc parts list
Quastion ABOUT FWD cARS*
Pic of my baby
Ls/vtec, Can't figure out how to stop idle from jumping.
Driving on the right.
Type R parts?
B16 dizzy
Looking for a place in Illinois that does turbo work
Headers for LS/VTEC???
Attention B16 Owners
correct parts?
Question about b20 vtec?
Motor model question
crx or hatch?
B16 clutch
Fully Built Ls Vtec
accord tranny w/ H23
b16a1 JDM computer diagram
Spoon stroker kit
JDM Map Lights In Door...Where can I get these?
h23 accord swap
k20 swap procedure for 92 hatch
b20b engine numbers, and clutch help!!
Anyone know the problem?
some one help!!!
need b series
JDM ITR front end on 92-95 civic coupe
best site to buy engines from
B-series turbo
b16 service manual
Different Brand Swaps
2000 civic swaps what do you think
Headers on a B serie motor
zc swap, good or bad??
f22 pulleys fit h22?
b18b1 distributor problems
B16A/S1 JDM Question
WTF is a Type R Civic??
H23 Help
whats your opinion?
someone help with motor swap!!!
What do you guys think??
will an H22 fit?
ls motor in civic ex
h22 auto to manual
B16A crx swap
d16/ZC what ECU to use?
F20B JDM Swap
a simple swap question...
b16 tranny q
Where to buy my Motor?
Jdm Ecu
Engine Question
B20B vs B20Z ~~ B20B/vtec vs B20Z/vtec
Question about JDM H23A
head swap
how to chip JDM ECU?
b18a1/b18b/b16a2/b20b
93 civic dx tach line???? help me find it
clutch???
P72 vs PR3
92-95 sirII EG or 96-00 sirII EK in 98 ex
B16A gen1 into a 95 civic
In your opinion..........
Please Help!!! Cracking CV Joints
grinding the crank
Is it possible?
j1 tranny capacity
Injectors for B16
need some input!
rear disks?
B16 turbo question
99-00 Si b16a vs sir II
valve cover
How long will it last?
b16a or ls vtec
94 gsr swap b18c5 or keep b18c1?
Alternators?
93 teg engine swap
90 civic engine
GSR motor swap
h22 in a 6gen accord
which location should I source oil form for the VTEC head?
B16A oil pump specs? suffiecient for CRVTEC
is me engine a vtec?
which engine
b18c1 vs h22a Choose??
2.5" pipe
Louisville swap
turboed LS motor
91 crx si swaping in d16z6??
Honda/Acura Vigor
What is the easiest swap for a 90ls?
v-tec engine & trany
vibration
Tranny info pls
GSR Transmission
need info on bulding a motor from scartch
PLEASE PLEASE HELP me start my B18C1
I need help passing foreign emission
ZC spark plug cover
obd1 motor question
Web
AF
