Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
> N2O/Turbo/Superchargers |
View Full Version :
Web
AF
Pages :
1
2
3
4
b16a turbo
Internals for a SOHC ZC VTEC
Gauge question
turbo
mao difusser
bigger injectors
turbo b18
!!!Need Help!!! $1500 to go fast
Is it worth it?
Need Opinion on TURBO B16
1991 Honda Accord Turbo
Need advice h22a4 bore + turbo question
Thats what i Thought
engine glue?
Need basic info on turbos.
No more Boost for a while.
wategate spring?
oil lines!
B18b Boosted
fmu causeing my civic to buck when boost is engaged
D16y7 turbo install HELP!!
Safe Supercharge Boosting
Edelbrock Turbo Kit vs Greddy Turbo Kit ?
external wastegate question
Retaining A/C
"""94 ex CIVIC idle surge""""
Turbo project! (almost giving up)
Blockguard???
IS this CO2 setup possible?
DSM 450 injectors
Turbo Kit For Sale!
Turbo F22?
Overlap sucks for turbo, right?
accord turbo question
smikin
Custom Turbo Adaptor - Need Opinions
May have found the problem
Integra LS Prob
k20 turbo
b18 pistons in my b16
integra Dyno Results
95 integra gsr turbo
Performance Upgrade Info
used turbo pistons??? Should I buy???
"nawzz"
turbo rebuild
I need help! best way to boost B18C
supra engine
1988 si 4ws honda prelude
turbo for 86 crx HF
Boost Spike
No boost!! What happened?
The right injectors
Engine swap
Boosting my D16Y7
First hand ECU knowledge needed?
quick question about releasing fuel pressure
what size injectors???
Upgrading my car
ex turbo on a lx..
FINALLY! i drive a turbo D :)
Drag turbo kits, What Else??
Urgent Question !!!
Roger McDaniels Rally Charger
Other types of turbos?
trying to pull 13's
Race gas on stock GSR???
upgrading
Turbo D vs B16a2 Which one !!!!!
Need More Power
turbo head gasket
Using vitara pistons for boost???
99 Prelude w/ FMAX Turbo Kit
losing weight
Need more power
Civcic turbo
H23 T3 Turbo
Supercharger brands?
LS/vtec with N20
any deal with city speed before?
Where to get AEM EMS Base Maps?
Turbo? Internals? Forged? Stock Internals?
How much is too much???
Xs Power????
h22 turbo???????
ZC & a T3/T4 Turbo, Whats safe psi?
best place for turbo rebuild
98 civic cx Jackson Racing Supercharger
gsr vs b16a2
need a little advice on current turbo
best engine for turbo setup?????
Smoke and Oil
how much boost safe on dohc zc motor
Need help with emanage wiring
career in turbochargers
got white smoke,need help
Trouble with my turbo
DSM 450s in GSR Integra-T
Turbo Fuel Management Question
Q? on speedchip
turbo stock manifold
Quick Q on Turbo
Is it possible to DOHC an d16y8
New to turbos and i have questions.
help water coming from exhaust
Cold Air Intake Question
hp question
SOHC D-series Fans!!!
Jsrc
E-Bay NOS
Check Engine Light With The Turbo
JRSC d16z6 idle problem
turbo question for my d16z6
ebay turbo kit
Anyone w/ a Jackson Racing Super charger on GSR
Interesting psi question
what could be the problem?
Another Turbo Question
Hondata s100 questions
b16 with 8psi turbo how much hp?
h22 question ?
5th injector
Noz For a ZC DOHC
feed & train
h22 turbo or all motor ?
eagle forged crank
compressor inlet size
Daily Driven 802FWHP Civic
Which is the best way to go for a D16Y7?
Who knows anything about map senor bleedings
turbo question
whats psi should i run on my stock rs
do i need a missing link for my turbo set up?
fmu install on b16
Exhaust w/supercharger
management
Replace Oil Pan on 92 Prelude
JRSC question
Turbo Building Books
turboing a b16a2 and have sum ????
H22A with a 65 shot of nitirous.
ZC turbo?
Cam gears
Opinions for n20 on H22A
Engine Swap Help
A20a3 Turbo??
not getting any oil return!!! help me out!
srp 8.8:1 pistons?
Hondata
200+ whp NA help
turbo b16a2
bad seal?
Building an D16 turbo !!!
Where to tap oil line?
bore to 2.0L or stick with 1.8L with turbo
Will it fit?
why are all Honda's so slow?
help! im leaking oil!
Turbocalculator Ripped Me Off
I'm finally boosted! Check it out!
gates
How do I get low end torque and turbocharge?
Need a power estimate
Custom supercharger setup
F20A or B16A5 and how???:(
What to do with tax return money?
compressor maps
turbo help
Turbo's w/o oil?
turbo ?
pistons for turbo and nitrous
AIT sensor resistor
TURBO question
Whats the quality of this kit?
civic h22 build-up for turbo
Blow off valve on an integra
afc hack not working for me need help?
wow, it's been a while
Turbochargin a lude
96 Turbo Questions
Chrysler T3 or T3c parts needed! ASAP!
Getting Turbo
turbo ls hatch ?'s
Adjustable cams...
What do I need for a d16 turbo to hold 250whp
Camshaft and Topend question
Nitrous Question
I'm getting an engine today...but which
Camshaft
underdrive pulley kit
Boosting a 94 Civic w/swapped B16A
D16Z6 best turbo
K20 turbo question
skunk2 ecu
Electric TurboCharger??
Are high flow cats street legal?
b16a question
please help..
Need help with my b16 build!! Please Read!!
What do U think of D.C. Sports Headers?
Noobie Helper- Must Read
JDM d15b turbo?
Wastegate
Turbonator V.S. Cold Air Intake
Sorry For the Problems
Supercharged Y8, or am I crazy?
Turbo questions
turbos for automatics?
b16 turbo????
greddy turbo?
help: im completley new to civics
96 ex stock
nitrous question.
About vacuum lines
2 more Q?s by me(dumb)
Pieces of crap
Import Racing Is A Joke!!!!!!
what is a pvc valve for?if you dont need it
which pistons for 350 hp
Will someone take a min to explain what turbo lag is 4 me
Newbie Question for people that know things
High Point Industries
bad turbo? crankcase pressure
Q: intake manifold
Which BOV is this? (pic inside)
Internal Wastegate spring problem
Need Turbo Advice
TURBO on a d16z6??
Turbo GSR HELP!!
98 Honda Accord w/h22, What Kind of turbo???
T28 Water Line Mixup Help
what do I need?
edelbrock turbo
integra`s transmition & engine on 93' civic
Reliable power
93 civic si
? on turbo car
b18a1 integra
check valves
MSD BTM on 97 turbo civic
engine code 43
Eletronic Boost Controlers !
99 Civic Turbo
field sfc
didi i blow it?
Questions!!!!
fuel settings on turbo prelude
Supercharge a motor with 156000 miles
strange blow off valve noise
boost control?
Web
AF
