View Full Version : Century
Pages : 1 2 3 4 5 6 7 [8] 9
  1. Trac Off light coming on
  2. 1993 Century Power Windows... overheated breaker?
  3. 1994 Century losing alot of oil
  4. 1990 Buick Century Serious Problem
  5. buick century
  6. turning autolock on or off 92 century
  7. parking lights stay on
  8. 1999 Century Acceleration Problems
  9. high beam "switch" - '91 century
  10. 1989 Century Custom Headliner woes
  11. check engine lite on new tranny
  12. remote keyless keypad
  13. 89 Ol Type
  14. Check battery light comes on
  15. Daytime running lights - 95 Century
  16. 2000 Buick Century Limited Speakers
  17. Any aftermarket 3.3 headers/swappable?
  18. Battery
  19. 1998 Buick Century Transmission?? Problem
  20. Losing Power overnight
  21. Broken interior door handle--drivers side
  22. 1999 Buick Century AC Not real Cold
  23. Major car issue, any ideas or info would really help.
  24. 96 century 3.1 cooloing help!!!
  25. 95 3.1 V6, Name of part with vacuum outlets under coil pack?
  26. 1995 century transmission
  27. 1995 Century Won't start in park
  28. Thermostat
  29. 97 century A/C coming on and off?
  30. Front suspension damage..
  31. 1993 Century 3.3L Problems
  32. Changing Spark Plugs and Fuel Filter
  33. cooling fan won't run
  34. starting & charging wiring schematics ('86)
  35. Speedometer troubles 93 century
  36. radio controls on steering wheel
  37. 1990 Buick Century Power Windows
  38. Service Engine Soon and now rough running when cold only
  39. A/C Clutch rattling
  40. rotor removal 99 century
  41. 90 century cooling fan runs continuously
  42. bad gas milage
  43. 96 buick century giving code p1361
  44. Stalls, no answers, and cutting across three lanes on the thruway, HELP
  45. Kill Switch
  46. 1990 lighter doesn't work
  47. 93 Century Tailights
  48. help needed, 94 buick century wagon
  49. Vibration and jerking when the accelerator/gas pedal is pushed
  50. 1999 Buick Century Horn
  51. 1997 buick century headlamp adjustment
  52. locating keyless module
  53. Driver seat replacement, what it involves?
  54. Trouble with fuel injectors???
  55. door replacement
  56. Help needed with my Century please
  57. noise
  58. 99 buick century emission controls
  59. Not able to change airflow, only works on high
  60. 1990 stereo removal
  61. Distributer cap replacement how often?
  62. 93 Centry Plug wires??????
  63. Dash Fan Speed Switch R&R ???
  64. Century 1991, A/C problem
  65. Cracking Instrument cluster plastic?
  66. Gas guage question
  67. 91 Century Horn(cant find it!)
  68. 1999 Century-Electric window Problem
  69. Help! Water in floorboard
  70. Trouble code, help Emmision controll system
  71. Vibrating After 65 MPH
  72. '89 Century station wagon
  73. Newbie in need of Suggestions/Resources....
  74. Question about temperature
  75. would you buy a regal or a lesaber????
  76. crankshaft damper removal
  77. 2000 Century 'Lo Trac" light when hot
  78. '86 Buick hard idle fix (took awhile)
  79. Want a bit more go outta my car..please gimme a hand
  80. Door/Trunk lite wont turn off?
  81. help I'm a girl - ticking noise
  82. hard noise on front of engine?
  83. WIERD 98 Buick window problem
  84. Dexcool contraversy
  85. engine and tranny?
  86. Low tire, Help!
  87. How to reset the change oil indicator
  88. tried everything and cant get it started
  89. 1996 Century seatbelt retractors
  90. outside temp indicator
  91. radio
  92. Dexcool coolant - junk
  93. 98 Buick Century Fuel Filter
  94. intermitent anti lock warning
  95. 1998 Century - Power Window Problem
  96. 1993 Buick Century Altenator?
  97. "Brakes" light, no brakes; '86
  98. EGR Valve
  99. Recharging A/C 1998 Buick Century
  100. interior lights stay on
  101. Trouble With Tranny When Hot?
  102. 1989 Century - SES Problems
  103. 86 Heater Core Location
  104. Dumb question 96 Buick century
  105. 2001 Century F Brake Pad replacement
  106. 1992 Buick Century V-6 blows gauge fuse Intermittently
  107. Engine light Blinks
  108. 1990 3300 MPI Hard Start, Rough Idle, then Dies.
  109. 1992 Buick Century stalls
  110. Air Filter
  111. 99 buick centry overheating
  112. Starter will not engage 2000 Buick Century
  113. 1994 Century, oxygen sensor
  114. Starting Problem Knowledgable help Needed Please!
  115. 1990-Splutters when shifting into Drive
  116. 1987 Century Starting Problem
  117. Climate 'Mode" control
  118. Headlights don't work, Help!
  119. Messed Up Wiring From Dsitributor
  120. broken selector knob
  121. 2000 Century oil in cooling system?????
  122. signal flasher
  123. Buick Century '93 brakes light will not go off
  124. 93 Century relay switchs
  125. 1990 Buick Century trans problems
  126. 85 - Noise & Service light - HELP
  127. 1990 Century Stalling and starting problems
  128. 1995 Buick Centry Torques
  129. 98 Buick Century, Everything quits
  130. 85 Century - periodic rattle with "Service Engine Soon" light
  131. 2003 century
  132. 88 engine problems
  133. 89 aftermarket probelms
  134. 89 Buick Century cooling fan relay
  135. 1992 Buick Century 3.3 will not start hot
  136. 93 Century door lock problem
  137. Century Trans Rough
  138. Turn signal problem
  139. Firing Order/tune up problems
  140. 'Premium' and 'Standard' rotors. What is the difference? ?
  141. 1987 Transmision lock solenoid
  142. Where do I...
  143. Brakes - FLatrater and Bignosey, Thank you! !
  144. Bignosey, I checked the brakes and...
  145. '00 Century Door lock problem
  146. 1998 century help
  147. 1987 check engine light
  148. Brakes problem on Century 2000
  149. I am parting out my 1992 Buick Century
  150. 1985 Buick Century Limited
  151. 02 Century trans problems
  152. 89 century stalling
  153. engine stops on idle
  154. 96 Century kills batteries, why?
  155. Vacuum Diagram
  156. Please Help Me 92 Century 3.3L Stalls
  157. 88 buick century Radio removal
  158. Knock Sensor problem and DEX-COOL!
  159. Tachometer? Where?
  160. 1987 Century with Issues..
  161. power windows
  162. Causes of misfiring?
  163. 1995 Century Check Engine Soon light
  164. checking engine codes - 96 century
  165. turn signal cam
  166. 91 Century, problems starting
  167. whining noise
  168. coolant leakage
  169. 3.3 thermostat replacement - follow up
  170. Car smoking when I stop at a light
  171. Acceleration problem - is it so tough?
  172. Interchangeable front ends for 91 Century?
  173. 2001 Century Cruise Control
  174. Fuel Injectors 91 3.3
  175. '91 rumbles at 120kmph or 75mph?
  176. Slight "Jerking " feeling while HWY driving
  177. 2003 Century Ticking noise from 5-40mph F.R. side
  178. low beam lights on 97' century
  179. Automatic Transmission
  180. Automatic Transmission
  181. Broken ignition...please help. It might be the security??
  182. '97-up buick century stereo issues.
  183. a few questions
  184. reverse/trunk opens
  185. 2003 Buick Century w/Radio interference within the car
  186. Keyless Entry Programming
  187. Century Stalls at Idle!!Need Help
  188. 2000 Buick Cent Radio TROUBLE
  189. I HATE this automatic Door Locking when you start your car! Help!
  190. l67 swap
  191. Head gasket or intake gasket?
  192. Don't buy a Century!!
  193. 98 Century Door speakers
  194. lots of dead electrical things!
  195. Problems with Dash lighting in 91 Century
  196. overheating problems
  197. BC 1995 airco problem
  198. HELP! Electrical puzzle of the Century (Buick)
  199. service engine soon light
  200. Automatic Tranny Question
  201. turn signal switch
  202. '87 Century 3.8L Stalling Problem
  203. Interesting use for Bar's Radiator Stop Leak
  204. 1991 Heating Problems
  205. '97 Century - wipers stuck in up position
  206. heater fan won't turn off!!
  207. 93 buick century elec.trunk latch
  208. High pitch noise from fuel tank area
  209. Turn Signal Flasher Location on a 1987 Buick Century
  210. steerign colum for 92 3.3L
  211. 2000 Century starting problem
  212. Service Engine Light
  213. Dash Lights/Tail Lights dead
  214. Changing Thermostat.. 2000 Century
  215. 2000 Century Harsh Shifting when warm
  216. flasher location on '86 century
  217. Mods done 2 the Century
  218. No air from heater/ac [93 Century]
  219. 'Onstar' 'spy program in GM Cars
  220. Read more about Black Box in your car on this address..
  221. 'Black Box' in your car is recording your driving fellows
  222. Grounding sound in transmission
  223. '92 Buick 3.3L
  224. 3.3 hidden power
  225. Engine Problems
  226. Dashboard Removal Help
  227. 1995 Century oil problem
  228. fwd buick 3.8 with turbo
  229. Century courtesy lamp wiring problems
  230. Service Engine Light - Problem fixed.. (note for Flatrater)
  231. Problem with instrument lamps fuse
  232. 90 Century Thermostat
  233. Thank you Flatrater!
  234. Radio Code Help What's a E14?
  235. 3.3
  236. 'Service Engine soon' Light - codes included here
  237. Service Engine Soon
  238. locating coolant leak
  239. 96 century coolant problem
  240. Need help locating the radiator drain screw
  241. Aldl?
  242. 1991 Stalling, shuddering, slipping, idleing high
  243. 86 century, electric radiater fan fails to operate
  244. Help!-low tire light stays on
  245. Window problem in 97 Century
  246. Service Engine light but NO codes
  247. No Trouble Codes, just flashing light
  248. Oil Additives - Are they what they claim to be? ?
  249. stall problem in 87 buick
  250. 1990 buick century problems help please
