View Full Version : Century
Pages : 1 2 3 4 5 6 [7] 8
  1. Front suspension damage..
  2. 1993 Century 3.3L Problems
  3. Changing Spark Plugs and Fuel Filter
  4. cooling fan won't run
  5. starting & charging wiring schematics ('86)
  6. Speedometer troubles 93 century
  7. radio controls on steering wheel
  8. 1990 Buick Century Power Windows
  9. Service Engine Soon and now rough running when cold only
  10. A/C Clutch rattling
  11. rotor removal 99 century
  12. 90 century cooling fan runs continuously
  13. bad gas milage
  14. 96 buick century giving code p1361
  15. Stalls, no answers, and cutting across three lanes on the thruway, HELP
  16. Kill Switch
  17. 1990 lighter doesn't work
  18. 93 Century Tailights
  19. help needed, 94 buick century wagon
  20. Vibration and jerking when the accelerator/gas pedal is pushed
  21. 1999 Buick Century Horn
  22. 1997 buick century headlamp adjustment
  23. locating keyless module
  24. Driver seat replacement, what it involves?
  25. Trouble with fuel injectors???
  26. door replacement
  27. Help needed with my Century please
  28. noise
  29. 99 buick century emission controls
  30. Not able to change airflow, only works on high
  31. 1990 stereo removal
  32. Distributer cap replacement how often?
  33. 93 Centry Plug wires??????
  34. Dash Fan Speed Switch R&R ???
  35. Century 1991, A/C problem
  36. Cracking Instrument cluster plastic?
  37. Gas guage question
  38. 91 Century Horn(cant find it!)
  39. 1999 Century-Electric window Problem
  40. Help! Water in floorboard
  41. Trouble code, help Emmision controll system
  42. Vibrating After 65 MPH
  43. '89 Century station wagon
  44. Newbie in need of Suggestions/Resources....
  45. Question about temperature
  46. would you buy a regal or a lesaber????
  47. crankshaft damper removal
  48. 2000 Century 'Lo Trac" light when hot
  49. '86 Buick hard idle fix (took awhile)
  50. Want a bit more go outta my car..please gimme a hand
  51. Door/Trunk lite wont turn off?
  52. help I'm a girl - ticking noise
  53. hard noise on front of engine?
  54. WIERD 98 Buick window problem
  55. Dexcool contraversy
  56. engine and tranny?
  57. Low tire, Help!
  58. How to reset the change oil indicator
  59. tried everything and cant get it started
  60. 1996 Century seatbelt retractors
  61. outside temp indicator
  62. radio
  63. Dexcool coolant - junk
  64. 98 Buick Century Fuel Filter
  65. intermitent anti lock warning
  66. 1998 Century - Power Window Problem
  67. 1993 Buick Century Altenator?
  68. "Brakes" light, no brakes; '86
  69. EGR Valve
  70. Recharging A/C 1998 Buick Century
  71. interior lights stay on
  72. Trouble With Tranny When Hot?
  73. 1989 Century - SES Problems
  74. 86 Heater Core Location
  75. Dumb question 96 Buick century
  76. 2001 Century F Brake Pad replacement
  77. 1992 Buick Century V-6 blows gauge fuse Intermittently
  78. Engine light Blinks
  79. 1990 3300 MPI Hard Start, Rough Idle, then Dies.
  80. 1992 Buick Century stalls
  81. Air Filter
  82. 99 buick centry overheating
  83. Starter will not engage 2000 Buick Century
  84. 1994 Century, oxygen sensor
  85. Starting Problem Knowledgable help Needed Please!
  86. 1990-Splutters when shifting into Drive
  87. 1987 Century Starting Problem
  88. Climate 'Mode" control
  89. Headlights don't work, Help!
  90. Messed Up Wiring From Dsitributor
  91. broken selector knob
  92. 2000 Century oil in cooling system?????
  93. signal flasher
  94. Buick Century '93 brakes light will not go off
  95. 93 Century relay switchs
  96. 1990 Buick Century trans problems
  97. 85 - Noise & Service light - HELP
  98. 1990 Century Stalling and starting problems
  99. 1995 Buick Centry Torques
  100. 98 Buick Century, Everything quits
  101. 85 Century - periodic rattle with "Service Engine Soon" light
  102. 2003 century
  103. 88 engine problems
  104. 89 aftermarket probelms
  105. 89 Buick Century cooling fan relay
  106. 1992 Buick Century 3.3 will not start hot
  107. 93 Century door lock problem
  108. Century Trans Rough
  109. Turn signal problem
  110. Firing Order/tune up problems
  111. 'Premium' and 'Standard' rotors. What is the difference? ?
  112. 1987 Transmision lock solenoid
  113. Where do I...
  114. Brakes - FLatrater and Bignosey, Thank you! !
  115. Bignosey, I checked the brakes and...
  116. '00 Century Door lock problem
  117. 1998 century help
  118. 1987 check engine light
  119. Brakes problem on Century 2000
  120. I am parting out my 1992 Buick Century
  121. 1985 Buick Century Limited
  122. 02 Century trans problems
  123. 89 century stalling
  124. engine stops on idle
  125. 96 Century kills batteries, why?
  126. Vacuum Diagram
  127. Please Help Me 92 Century 3.3L Stalls
  128. 88 buick century Radio removal
  129. Knock Sensor problem and DEX-COOL!
  130. Tachometer? Where?
  131. 1987 Century with Issues..
  132. power windows
  133. Causes of misfiring?
  134. 1995 Century Check Engine Soon light
  135. checking engine codes - 96 century
  136. turn signal cam
  137. 91 Century, problems starting
  138. whining noise
  139. coolant leakage
  140. 3.3 thermostat replacement - follow up
  141. Car smoking when I stop at a light
  142. Acceleration problem - is it so tough?
  143. Interchangeable front ends for 91 Century?
  144. 2001 Century Cruise Control
  145. Fuel Injectors 91 3.3
  146. '91 rumbles at 120kmph or 75mph?
  147. Slight "Jerking " feeling while HWY driving
  148. 2003 Century Ticking noise from 5-40mph F.R. side
  149. low beam lights on 97' century
  150. Automatic Transmission
  151. Automatic Transmission
  152. Broken ignition...please help. It might be the security??
  153. '97-up buick century stereo issues.
  154. a few questions
  155. reverse/trunk opens
  156. 2003 Buick Century w/Radio interference within the car
  157. Keyless Entry Programming
  158. Century Stalls at Idle!!Need Help
  159. 2000 Buick Cent Radio TROUBLE
  160. I HATE this automatic Door Locking when you start your car! Help!
  161. l67 swap
  162. Head gasket or intake gasket?
  163. Don't buy a Century!!
  164. 98 Century Door speakers
  165. lots of dead electrical things!
  166. Problems with Dash lighting in 91 Century
  167. overheating problems
  168. BC 1995 airco problem
  169. HELP! Electrical puzzle of the Century (Buick)
  170. service engine soon light
  171. Automatic Tranny Question
  172. turn signal switch
  173. '87 Century 3.8L Stalling Problem
  174. Interesting use for Bar's Radiator Stop Leak
  175. 1991 Heating Problems
  176. '97 Century - wipers stuck in up position
  177. heater fan won't turn off!!
  178. 93 buick century elec.trunk latch
  179. High pitch noise from fuel tank area
  180. Turn Signal Flasher Location on a 1987 Buick Century
  181. steerign colum for 92 3.3L
  182. 2000 Century starting problem
  183. Service Engine Light
  184. Dash Lights/Tail Lights dead
  185. Changing Thermostat.. 2000 Century
  186. 2000 Century Harsh Shifting when warm
  187. flasher location on '86 century
  188. Mods done 2 the Century
  189. No air from heater/ac [93 Century]
  190. 'Onstar' 'spy program in GM Cars
  191. Read more about Black Box in your car on this address..
  192. 'Black Box' in your car is recording your driving fellows
  193. Grounding sound in transmission
  194. '92 Buick 3.3L
  195. 3.3 hidden power
  196. Engine Problems
  197. Dashboard Removal Help
  198. 1995 Century oil problem
  199. fwd buick 3.8 with turbo
  200. Century courtesy lamp wiring problems
  201. Service Engine Light - Problem fixed.. (note for Flatrater)
  202. Problem with instrument lamps fuse
  203. 90 Century Thermostat
  204. Thank you Flatrater!
  205. Radio Code Help What's a E14?
  206. 3.3
  207. 'Service Engine soon' Light - codes included here
  208. Service Engine Soon
  209. locating coolant leak
  210. 96 century coolant problem
  211. Need help locating the radiator drain screw
  212. Aldl?
  213. 1991 Stalling, shuddering, slipping, idleing high
  214. 86 century, electric radiater fan fails to operate
  215. Help!-low tire light stays on
  216. Window problem in 97 Century
  217. Service Engine light but NO codes
  218. No Trouble Codes, just flashing light
  219. Oil Additives - Are they what they claim to be? ?
  220. stall problem in 87 buick
  221. 1990 buick century problems help please
  222. What make Starter Kit for Century 2000 is best?
  223. How to replace Tstat in 91 Century V6??
  224. Remote start kit for Century 2000
  225. need help with thermostat on '98 century
  226. 2000 century and wipers
  227. service engine soon light
  228. No air across heater core
  229. Hey
  230. 1993 Century Wiring Problems
  231. 1986 century T-type shifting problems
  232. 1995 Buick Century
  233. 1990 Buick Century wont start
  234. just got a 88 century, where to get info?
  235. Body Kits
  236. 86 buick century starting failure
  237. remote start in 97 century
  238. No air through heater core?
  239. 'Service Engine Soon' light..
  240. 'Service Engine soon' warning light
  241. Century 2000 coolant
  242. Car key question
  243. 96 Century Fuel Pump Noise
  244. buick 1990 parking brake
  245. Century transaxle
  246. transmission woes
  247. 1990 Century
  248. Head gasket woes?
  249. Missing thermostat??
  250. 1992 3.3L random stalls
