View Full Version : Century
Pages : 1 2 3 4 5 [6] 7 8 9
  1. 3.1 Intake Gasket problem?
  2. 1998 Buick Century Driver's Window switch
  3. Can't go over 50 mph
  4. Heat
  5. Gunk in Radiator
  6. Rattling/clunking noise when starting/turning left
  7. Please Help! My Driver's Side Power Window is Stuck DOWN
  8. How To Program a 2000 Buick Century Key Fob???
  9. 94 century 3.1 surging
  10. Question on turn signal and cruise control issue
  11. Navigation system install
  12. Speed limiter/governor
  13. No trunk light in 2003 Centry
  14. 2000 Century Starter Replacement
  15. oil mix-up
  16. rough running again
  17. 92 century alternator replacement
  18. 1990 centry custom fan help
  19. 2002 Buick Century low Coolant Sensor
  20. 1990 3.3 v6 stalls and does not shift at times
  21. Check engine light
  22. Brake light trouble on 99 century
  23. Misfire detected and injector circuit open
  24. Floor Heat
  25. Power antenna and after market CD players don't mix?
  26. Steering problem-update-new problem
  27. MAP Sensor
  28. Sideway free play in steering column
  29. 1998 Hood Release
  30. Relay cylinders??
  31. front of the car shaking when breaking
  32. 88 century tranny probs...need help
  33. 93 loses elec volts and tries to die
  34. 91 Wagon electric trunk latch no working.
  35. Buick Century Starting Problems
  36. Another dead 88 Century Limited
  37. What car for donor 94 2.2L engine?
  38. 00 BUICK CENTURY Wet Passenger Carpet????
  39. Steering problems
  40. Couple of questions
  41. 1999 Century Heater control Trouble
  42. 96 century coolant leak
  43. Backfiring & Smog - Please Help!
  44. Trouble Code 42
  45. 93 century stall, longish read
  46. Buick Century
  47. Fuel Gauge
  48. 1996 to 2001 Century's, Any Chronic Problems /
  49. 3.3l engine bogs down when it is put in drive
  50. Engine Dies
  51. Buick-
  52. replacement of kickdown cable
  53. 95 Century Transmission losing fluid
  54. 1994 3.1L, at 1st just rough idle, now NO temperature reading...
  55. 89 buick century 3.3L won't start
  56. 2003 Century wont start
  57. "Steering Sensor Bias Malfuntion"
  58. 98 century, rear turn signal doesn't work and bulb good
  59. Ignition switch has intermittant Acessory contacts
  60. Blinker light and brake light
  61. removal of stereo in 03 century
  62. cruise control
  63. Transmission pump 1993 Century
  64. 1993 century crankshaft sensor
  65. 93 buick transmission leak, and it stalls
  66. ABS Brake & Cruise Problem 94 Century
  67. mystery water leak
  68. Ignition resistor Buick 2000 Century????
  69. front turn signal
  70. Bottoming out Century
  71. 1999 Century Remote trunk Trouble
  72. 1990 Buick Century reading code 33
  73. 95 Century wont start
  74. 1999 century
  75. 1997 Buick Century a/c Problem
  76. 2001 Buick Century Transmission slipping
  77. 2005 Buick Century Advice
  78. 1992 Buick Century Stalling
  79. 1991 Buick Century stalling
  80. buick 3.1 a/c century 1998
  81. 1985 buick century-resetting the check engine light
  82. 1991 air conditioning problem
  83. Removing drivers door panel on 90'Century
  84. strange gas level readings
  85. 2001 Buick Century Cruise Control problem
  86. looking for wiring diagram for my buick 89
  87. 96 misfire and 2 error codes
  88. vacuum line diagram
  89. No Juice...
  90. Very odd Buick Century noise, everyone please read!!!
  91. Changing alternator belt on 2.5
  92. tail lights won't turn off
  93. 89 buick century scanning problem
  94. Lumina engine overheating
  95. 1994 Century hood cable
  96. 1994 Century quit running
  97. Pulley system
  98. 2003 Buick Century keyless programming
  99. 90' Century Service Engine Soon Light ON
  100. Hard steering and low tire indicator light
  101. Engine Dying at Idle
  102. 98 Century - - $600 for a condensor???
  103. Gasoline Prices, will this change your driving habits?
  104. 2 Centurys, same electrical problem
  105. 1992 century radio install
  106. not hitting on all cylinders
  107. Security, ABS light and Brake light on! Please help!
  108. Transmission Problem
  109. 1993 3.3L stalling at stop or light
  110. 89 century problem with the choke
  111. Looking at 1995 buick century
  112. Transmission Problems?
  113. 1999 Century-- air dam scrapes TOO much!
  114. 1993 Century 3.3 harmonic balancer.
  115. 1996 Buick Century Blower question??
  116. 1993 Buick Century won't start
  117. runs hot,idle dosen`t kick down,tranny
  118. Instrument lights fuse blown
  119. 3.8 firing order
  120. What rims fit 2000 Century?
  121. Car really over heating
  122. How to change A/C bearing?
  123. 2003 Buick Century help needed
  124. Anti-Lock light stays on
  125. 1998 Century Fuel Filter ??
  126. GM's 3.x v6 engines-opinions
  127. 93 century muffler prices
  128. Courtesy Circuit Blowing
  129. Battery Indicator Light
  130. 1999 Buick Century All Power windows stopped working
  131. 1998 starter replacement cost?
  132. Sea Foam fixed my stumbling 3.3 litre
  133. 1990 Century Stalls
  134. removing back seat in 91 century
  135. Engine power problem
  136. What caused the tranny to quit, further information..
  137. '90 Century Custom pass door won't open
  138. running lights blow out 98 buick century
  139. Lokking to buy a buick century what to look for?
  140. Lights Dimmer Switch controls Radio Volume
  141. 91 Century just dies
  142. Help!!
  143. Why does Starter turn engine when I try to connect the negative cable to battery.
  144. 99 Century Wiring Diagram for 02 sensor...
  145. Buick unreliable trans - afterthough..
  146. Buick unreliable transmission (Part 2) - verdict by trans shop..
  147. Electric seats shorting? need help
  148. Buick transmissions prone to failure
  149. Turn signals do not work
  150. GM email contact will not accept Canadians
  151. Major transmission failure (Buick Century 2000)
  152. ABS and Brake Light on 98 Century
  153. 93 Buick Century 3.3L, funny start
  154. new to the buick community...kindof!
  155. Air Conditioning (but only half)
  156. Exhaust
  157. 88 stock stereo question
  158. 1998 Buick Century
  159. 2000 window cable
  160. 1993 buick century 3.3 liter
  161. 99 Buick-O2 Sensor
  162. Two problems-engine related
  163. Please, need help guys!!!!
  164. Rough running
  165. 95 Century Daytime Running Lights Module
  166. does anyone have the wiring schematics for a1995 buick century custom v6 3.1litre eng
  167. transmission cooler
  168. Window switch
  169. 99 Century P0341 error code, newbie
  170. car wont start,And i left nothing on
  171. 1988 Brake Light/Turn Signal Problems
  172. oil leak
  173. Loud Sucking Sound At Brake Pedal-90 Buick Century
  174. changing water pump on 94 buick century
  175. AC blows out of the defrost vents
  176. ABS, SES, trac off on 2000 century
  177. 89 Buick century master cylynder problem
  178. Removing Pivot Pin 91 Century
  179. 2000 Century Vacuum Source for HVAC Dampers
  180. Should I buy a BUICK?
  181. 93 century tow question
  182. 2000 Century HVAC Problem
  183. And yet another question about the cooling system
  184. 1990 Buick Century stalling in drive
  185. Compressor replacement concerns
  186. 1996 Buick Century
  187. engine cooling fan relay 1995 century?
  188. Trouble Moving
  189. 1990 Century Brake Service & Bleeding - Pedal Sqooshy
  190. Overeating problem
  191. 1991 Century Headliner
  192. 1989 buick century 3.3 engine won't start
  193. engine fan and temp gauge dosen't work
  194. Banging noise at serpentine belt
  195. 93 Century-Intermitant Starting Problems
  196. bright/dim headlights??
  197. 1990 Century All 4 Driver Side Window Controls Dead
  198. stereo problem
  199. 1996 Air conditioning removal(sort of)
  200. A/C Fuse locations
  201. Serp belt replace 1988 century, tensioner stuck ?
  202. 89 Century MAP Sensor Location?
  203. 2002 Buick Century Custom
  204. Quad Headlight Setup?
  205. 94 century what size belt without A/C
  206. Lubricatin locations on Century 2000
  207. 99 Century - What To Watch For?
  208. Request advice 1998 Century - should I buy
  209. Locking Gas Cap Install
  210. Stalling when hot
  211. Push button starters (installation)
  212. Straight through glass pack designed mufflers!
  213. Springs
  214. 95 Buick Century Electrical Problems/Battery/Accessories
  215. swap standard radio with factory cd
  216. Took muffler off of 86 Century> Bad or Good? it sounds soooo good now!!!
  217. Power Window Problems
  218. 3800 supercharged engine swap
  219. 2001 century back up lights
  220. need help with aftermarket head unit
  221. tps 90 century
  222. How do I remove dash for stereo removal?
  223. ABS an option in 2004?
  224. Loses battery charge
  225. Flatrater - cracked covers pics - location info..
  226. Very High Octane
  227. Flatrate, I submited the covers pics (where did they go)?
  228. Pics of the GM trans PCS problem
  229. To Flatrater, Bnaylor and alll our advisers, (Hard shifting)
  230. a/c driver side hotter
  231. Ultimate cause and solution for Century hard shifting revealed..
  232. 1998 Century Cluster
  233. 1990 Buick Century 3.3 hard to start mornings
  234. Trying to help a friend.. Your Thoughts. (Misfires after tune up)
  235. Drive belt walking
  236. code 41
  237. '96 Buick Century - Ghost In The Machine
  238. 93 buick century O2 sensor
  239. Flowmaster
  240. Thank you 'Bnaylor 3400' ! Expert says why the shifting problems
  241. Jerky gears shifting and strange noise when warm..
  242. 1995 buick century v6 3.1 help
  243. spark plug wire order
  244. Coolant Sensor
  245. Slight Rust spot
  246. OK, now I am confused, and angry
  247. 98 century - oil change frequency
  248. My fan only blows on the highest setting
  249. 1990 Century Flasher?
  250. 2 questions about my new 93 century.
