View Full Version : Century
Pages : 1 2 3 4 5 [6] 7 8
  1. Recall
  2. abs light on, cruise & back dash brake lts inop
  3. Water on rear passenger floorboard
  4. 1989 Buick Century Won't start in the cold
  5. 93 Century V6 water pump pulley
  6. 95 Lesabre Missing Severly
  7. Need help with steering column dissasembly please
  8. weird clay / rust in radiator
  9. My engine refused working while i was driving
  10. 1994 Buick Century needs flasher fuses
  11. need help with a 1993 century stalling
  12. Changing fuel injectors
  13. 89 Buick Century won't start
  14. 1996-Century Programming remote entry
  15. Need speedometer cable for 1985
  16. service engine soon light (yellow)
  17. 90 century limited rear deck speakers
  18. ignition wire
  19. OEM radio replacement question
  20. On the road, But still more Problems
  21. Concert sound rear speakers don't work
  22. 2000 Century Auto Transmission
  23. I am currently looking at a 96 Buick Centery
  24. "e13" error messeage on tape player
  25. Sun visor needed
  26. Buick Century 2000 No low / High Beam lights
  27. online manual for a 86'er
  28. 2004 century stereo rumble
  29. 1989 Century hard shift on first shift only
  30. Man! this was STUPID!
  31. 96 Buick Century - "Anti Lock" light on Dash
  32. eratic downshift when at cruise speeds
  33. Back door windows
  34. Carpets (front - floor) carpets wet.
  35. 1993 Buick Century HELP ME
  36. front ends
  37. 1992 buick century 3.3, won't start
  38. 1998 Cam position sensor location?
  39. Check Engine Light...Please help
  40. Front Ashtray Needed, Century Custom 1998
  41. 1993 buick century problems starting
  42. Freaky warning lights!
  43. Brakes are crappy
  44. trany slips wen i accelerate, why?
  45. I Have A 1992 Buick Century And Won't Stay On
  46. Where's the fuel pump fuse/relay/killswitch for a 1993 Century
  47. How big of a job is replacing heater box on 98 Century
  48. Head Gasket redux?
  49. 2003 Buick Century Keyless Remote programming?? Anyone??
  50. 95 century stuttering
  51. Oil change question
  52. stupid wires!
  53. Replacing the Transmission Modulator Vavle
  54. 2002 Headlamp Short?
  55. Thermostat
  56. New Starter Question
  57. 1993 Buick Century Wagon 3.3L v6 Fuel pressure problems.
  58. 89 Century Rotors Stuck
  59. Good website
  60. 2nd Post
  61. 98 Century - Where is HVAC air intake?
  62. Help! Problem with warning lights on 2000 Century
  63. Lifters tapping 3.3 liter
  64. Performance Info
  65. 98 Buick Century Good, Bad, and Ugly
  66. Heater Core
  67. Need body color number for 1995
  68. 97 Buick Century surges while applying power
  69. No Selling Allowed!!!!!!
  70. Anti lock light on after changing plugs?
  71. Thermostat
  72. Replacing serpentine belt
  73. Damn vacuum system
  74. High NOx emission
  75. 91 Century 3.3 Mystery Leak
  76. 4T65E Transaxle Recall?
  77. 2000 Century Oxygen sensor(s)
  78. 1985 Century Blower motor & Speedo not working
  79. Code Questions
  80. Lack of power
  81. no spark from 3 plugs on 88 century
  82. 1989 buick century blower motor
  83. 98 heater only works on Med/Hi & Hi
  84. 97 century EGR flow insufficient code problem
  85. 1993 century transaxel problem
  86. problems on 91 3.3l with 273,000 miles....
  87. century keeps dying
  88. 90 century wont start!
  89. 91 2.8L celeb trans in 94 3.8L century
  90. 95 Century blazing through oil!!
  91. Tranny Service Flush
  92. 89 century wont start?????
  93. ABS Light
  94. keyless entry
  95. No ABS or Cruise. 95 Century,everything else works
  96. Removing door panel
  97. '94 Transmission Problems
  98. 91 clunking noise
  99. Check engine light
  100. 1993 3.3 stalling issue. Help needed badly
  101. A 1993 Buick Century
  102. Code 29
  103. Performance
  104. Very Wierd problem
  105. Tie Rod and plastic rear bumper
  106. 96buick runs rough and dies out
  107. 87 buick no spark
  108. 1990 Buick will crank but not start
  109. My Car Keeps Stalling
  110. 1995 Century Problems
  111. 1995 Buick Century Seat Question
  112. trunk leaks
  113. '91 Century starter motor removal
  114. 98 Buick Tranny
  115. Is THis Normal?
  116. Worn 'Tie Rod' at 49.000 km ?!
  117. Injector Control Cicuit
  118. Wire Hub Cap Lock Removal Tool
  119. WTF is this?
  120. driver side window electric
  121. 87century starts cold but not hot
  122. 97 Buick Century ..?Heater Core?
  123. Need part for 1998
  124. 1989 Century heater problem
  125. 75 Gran Sport
  126. PCV Location 3.3L Engine?
  127. Pimp Centuries
  128. Torque Settings?
  129. Buick Century 1995 Skips all the time
  130. 98 Century blower motor
  131. Duel Automatic Comfor Temp Climate Control. HELP
  132. newbie needs help.Please!
  133. HELP, 89CENTURY 3.3 STALLS intermittenly
  134. 95 Century-Engine Won't Shut Off
  135. update on the trunk lighting problem
  136. 2001 Buick Century Limited Radio Problem
  137. cold weather starting
  138. 92 Buick Century Having 2 Problems
  139. 86 century custom stalling problem
  140. Electrical Phantom!
  141. Automatic Headlights
  142. O.K. it's official. My car's annoying!
  143. 1987 Stalls, need help please
  144. Tail Light Assembly 2001 Century
  145. Raising Springs
  146. Need wiring schematics for 81 Buick Century
  147. 81 Buick Century coil pack problem,HELP!
  148. Where's the TCC plug?
  149. Water sloshing in dash
  150. Cruse Indicator Lamp
  151. Brake Drums off How? buick century 92
  152. Lots of Problems!!!88'Buick Century
  153. auto. trans prob
  154. 1998 3.1 missing-
  155. Shifting problems
  156. Need Some Help Please 1995 Buick Century
  157. I call it quits!
  158. driver side heater doesn't work
  159. buick century wagon brakes
  160. 97 Buick Century Driver Side Airbag Installation
  161. Need code discriptions
  162. driver window and driver seat issue
  163. 3.3L V6 QuEsTiOnS
  164. Cruise Control
  165. 95 Century transmission problem (?)
  166. Power window problem
  167. Where's my Heater Blower?
  168. Rack and Pinion Going
  169. 99 buick centry probs
  170. 92 century antenna?
  171. 2000 Century TCC issue
  172. defroster turning off after 3 minutes
  173. need help with starter
  174. My century interior
  175. 91 Century Head/Tail Lens
  176. 91 buick century jerking/overloading gas help!!
  177. Dual Exaust Possible?
  178. High Beams Shut off while driving
  179. Buick Century Lowering springs!!!!!
  180. front wheel bearings whine
  181. 89' 3.3 V6 Starter!!!!!!
  182. im new here and have a question
  183. Power Window dead, 96 Century
  184. 91 Century trunk
  185. 89 Century - Belts and Power Steering Fluid
  186. HELP check engine light!!!!
  187. Automatic HVAC Controls on Limited Edition
  188. Headlight relay for 93 Century (and other 1988 and newer GM)
  189. '93 Century 3.3 service engine soon light
  190. New recall info: 99 Regals/Century's
  191. BUick Century
  192. 93 buick centry exhost gasket insrtallaiton
  193. Check Engine Light and Clicking
  194. Brakes Screeeem
  195. 1989 century, a/c stuck in vent position
  196. 1995 century....rev limiter kicks in when passing
  197. 2004 Century knobs
  198. 1992 Century - Antenna issues
  199. '95 century transmission
  200. 1997 Buick Century security
  201. 1990 Century Sudden Death
  202. Hub-bearing and anti-lock brake light
  203. 97 century air flow problem in HEAT position
  204. Help want to do a manual swap into 1991 century custom 3.3
  205. need to disable
  206. Cheap ways to diagnose Sensors
  207. 2000 Buick Century hard start/stalling
  208. 1995 century 3.1, runs when it wants to
  209. how much fuel pressure is a 93 century.....
  210. 1994 cetnury 2.2 shut down
  211. Dimmer Switch actuator AC Delco #D844
  212. 2.2 Buick engine same as Chevy, Olds?
  213. 99 Buick - Code P0306 - Service Engine Soon
  214. 92 Buick Century - Front End Repair
  215. Whats the Timing setting for a 93 3.3 V6
  216. wont start when warmed up
  217. Trac Off light coming on
  218. 1993 Century Power Windows... overheated breaker?
  219. 1994 Century losing alot of oil
  220. 1990 Buick Century Serious Problem
  221. buick century
  222. turning autolock on or off 92 century
  223. parking lights stay on
  224. 1999 Century Acceleration Problems
  225. high beam "switch" - '91 century
  226. 1989 Century Custom Headliner woes
  227. check engine lite on new tranny
  228. remote keyless keypad
  229. 89 Ol Type
  230. Check battery light comes on
  231. Daytime running lights - 95 Century
  232. 2000 Buick Century Limited Speakers
  233. Any aftermarket 3.3 headers/swappable?
  234. Battery
  235. 1998 Buick Century Transmission?? Problem
  236. Losing Power overnight
  237. Broken interior door handle--drivers side
  238. 1999 Buick Century AC Not real Cold
  239. Major car issue, any ideas or info would really help.
  240. 96 century 3.1 cooloing help!!!
  241. 95 3.1 V6, Name of part with vacuum outlets under coil pack?
  242. 1995 century transmission
  243. 1995 Century Won't start in park
  244. Thermostat
  245. 97 century A/C coming on and off?
  246. Front suspension damage..
  247. 1993 Century 3.3L Problems
  248. Changing Spark Plugs and Fuel Filter
  249. cooling fan won't run
  250. starting & charging wiring schematics ('86)
