View Full Version : Century
Pages : 1 2 3 4 [5] 6 7 8 9
  1. Help Needed Please!!!
  2. Jumping instead of passing?
  3. I really need help.
  4. Passenger side lights out
  5. Left rear power window not going up.
  6. 94 Buick Transmission problems
  7. '92 Century clacking sound from front end at low speeds
  8. Changing oil pan
  9. engine turns gettin fuel thats all????????
  10. 92 century over heating
  11. Vibration during acceleration from dead stop
  12. very fast idle
  13. HELP on AC Compressor 93 Century!!!! It hot in here in Las Vegas
  14. still having starting problems.
  15. EGR insufficient flow code
  16. 2003 Buick starting problem
  17. PS pressure hose- how do you get it loose...
  18. Would Like Advice for Troubleshooting Wiring
  19. 96 Wheel and Trim Line Questions
  20. 89 Buick 3.3L engine won't start
  21. Blower motor won't turn off
  22. Possible Wiring Problems?
  23. 1988 Century AC compressor vibration?
  24. '94 Century ignition stuck in "on." Please help?
  25. problem shifting out of park mostly in a.m.
  26. 94 century sticks going into Park
  27. 92 Century overheating, but no smoke..?
  28. A Question for Buick Experts
  29. 94 century frying alternators
  30. AC control problem
  31. 91 lock problem
  32. 97 Century Cooling Fan
  33. 1994 2.2 century
  34. 92 Buick Century with no spark.
  35. 2003 Century w/ dead battery
  36. 91 century stalling and radiator problem
  37. 2001 Century surging and no power
  38. Bumper Replacement
  39. Tires
  40. 200 century oil light
  41. electric windows malfunction
  42. 99 Century - Climate Control Problems
  43. Information on 1990 "Starter Sensor."
  44. P1404 P0300 codes 2001 century custom
  45. New and Old Members Please Read
  46. fuel enable signal location on 03 buick century?
  47. 94 century 3.1 loses power when warmed up
  48. bucking then dies
  49. A/C Compressor Clutch
  50. Intake manifold gasket Q Help quick!
  51. Engine Dies
  52. 3.1 performance
  53. 99 century, always burn A/C fuse
  54. '01 Century rear window defrost
  55. starter replacement
  56. Spongy brakes=bad idle
  57. scanners........
  58. 1999 Century remote start bypass
  59. PO440 code
  60. replace A/C compressor idler bearings?
  61. New Wheels-2000 Century!
  62. Anti Freeze Change-2002 Century
  63. fuel pump
  64. Coolant Leak behind Water Pump '92, 3.3
  65. 90 Century emergency brake
  66. 92 century
  67. Overheating. Help its driving me crazy
  68. Wiring problem on 3.1 liter on 94 Century
  69. Good buy?
  70. Best sparkplugs for 98 Century 3.1L
  71. Dash on 98 Century
  72. Power window problem (stuck)
  73. 91 Buick Century stalls out
  74. 1997 turnsignals
  75. air conditioning
  76. Programming Remotes 2000-05
  77. Intake deffective gasket issue - petition on line (to sign)
  78. 1991 Century Electrical Problems
  79. Buick Century transmission
  80. Canadian GM Canada car owner(s) launch faulty gaskets class suit
  81. 92 Century No fire
  82. 2001 buick century
  83. just some issues
  84. new stereo too deep for dash?????????
  85. 98 century air conditioning
  86. Gas Leak?
  87. Help On Putting Code In Delco Unit
  88. Dexcool likely cause of leaking gaskets..
  89. 93 Century Speaker Help
  90. Rim Size
  91. What is the difference.....
  92. 84 century
  93. Please help need to replace turn signal indicator
  94. Update, 2000 Century w/ odometer not visable!
  95. '93 Century Speakers
  96. 93 Century rear spark plug removal
  97. Intake manifold deteoriating gaskets problem - GM Service Bulletins
  98. 98 century radio problem
  99. '93 Century 3.3 no start.
  100. Faulty design intake manifold plastic gaskets..
  101. Knock Sensor?
  102. Cant find filter
  103. Still looking for advice
  104. 98 buick century oil safety switch ????
  105. ? on cooling fans 2000 century
  106. Delco GPS Unit
  107. Century Pic's.
  108. 93 Century Code 26 problem ...Help!
  109. buick won't start after running out of gas
  110. 2000 buick century transmission jump
  111. 2000 Buick century transmission jump
  112. 2000 century odometer not visible
  113. ABS error code help
  114. 91 century interior light
  115. Help - My 1993 Buick Century just died!!!
  116. 99 Century 3.1L - Intermittent No Re-Start When Hot
  117. Blower motor
  118. Emissions test
  119. 1st fuel filter switch... i got some ?s
  120. NO START: no spark
  121. 1990 Buick Century 3.3 v6 - Won't Start
  122. Another EGR trouble code
  123. Another EGR trouble code
  124. A/C Heater Control lights: Yes or No???
  125. 98 buick century rear power window problem
  126. Century 92 Tach Install
  127. 2000 century hard shift pattern
  128. 98 Century won't shift
  129. low tire light
  130. ODD lights
  131. What is ECM?
  132. 2001 century tail lights
  133. temp sending unit
  134. Cooling fan relay
  135. o2 sensor code - 89 century
  136. water pump removal 3.3liter
  137. Cooling fan
  138. 2000 Century EGR Valve
  139. 91 century engine swap
  140. Needing a a/c compressor
  141. electrical problem
  142. Door Latch Problem
  143. How to install a 95 Century window lift motor?
  144. which year engine will fit a 96?
  145. Lights popping up all over the place on instrument panel
  146. 94 Century 3.1 Need help with battery removal
  147. Parts
  148. Parts
  149. Where is the ALDL connector - 94 Buick Century
  150. 01 Century Custom A/C problem
  151. 94 Buick Century showing high temperature on gauge
  152. Left turn signal broken
  153. New LIM gasket seepage?
  154. blower motor
  155. Removing Part of Dash
  156. buick ran without water...what damage?
  157. Low compression 3.3L V-6
  158. coil problem?
  159. 02 Century Windshield Wiper problem
  160. Ready for Super Sunday
  161. 1998 Buick Century,Please help me
  162. thud in drivetrain
  163. 99 Century windshield wiper problem
  164. 1988 Century Rough idle?
  165. 94 century custom fan relay
  166. 97 Century ABS and Power Steering Problem?
  167. power steering questions 98 buick century
  168. 87 Buick century overheating
  169. No start after replacing serpentine belt?
  170. 98 Century rattle on startup
  171. Replacing parts on a 93 ever 2 years
  172. 2000 Buick heater problem
  173. Need help with 95 Century and weird ALDL connector
  174. harmonic balancer and broken door hinges
  175. Firewall Access for Amplifier Power Cable?
  176. Trunk light
  177. Right Turn Engine Hesitations
  178. code 1404
  179. 95 century-no exterior/interior lights
  180. 02' Century Codes
  181. Need help finding parts
  182. Idle RPM Adjustment
  183. w/d buick century 1997
  184. 2000 century radio install
  185. 1992 Buick Century
  186. Brake noise
  187. problem with lights on dash and instrument panel
  188. 1993 Buick Century Transmission
  189. Removing stock stereo from 91 century
  190. 1994 electrical problems(heater,radiator and engine)
  191. 89 century 2 door?
  192. 89 Heater, Defrost, Radio Not Working
  193. 2001 Century Transmission problem
  194. Radio Wiring Harness - Big Mistake
  195. P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
  196. Heater Coil help?
  197. 1993 Century Stop Lights Not Working
  198. Thanks for your help! window switch
  199. new guy
  200. What engine to replace 94 2.2L
  201. 1998 Century Factory Radio Removal
  202. gas smell
  203. Can I use 94 chevy 3.1 to replace a Buick 2.2l ?
  204. crankshaft postion sensor
  205. Will a 96 3.1L replace a 94 2.2L ?
  206. Tranny may have just went instantly? Need some advice
  207. radio
  208. Blower works only on HI, again
  209. Service Engine Soon light on 2001 Century
  210. Lack of power
  211. Highbeam problems
  212. 90 Century codes 14, 22, 43
  213. Transmission Bolt Torque
  214. my car keeps stalling while im driving
  215. '84 Buick Century alternator/voltage regulator abnormality
  216. '84 Buick Century "chirpping" in belt area
  217. Buick century 1987 radio/lighter/interior light problems
  218. Pimp My Ride 86 Century
  219. wire hub cap lock nuts
  220. help! 89 century runs poor after warmup
  221. 88 Century Rough Idle?
  222. Clunk & Rattle in 1990 Buick Century Trans.
  223. One more thing....
  224. 91 Century Transmission Filter change....
  225. I need help on rotating an engine on 1990 Buick
  226. 88 Century rear spring Question
  227. Power Windows on 95 Century
  228. Trailer Wiring
  229. Programming remotes
  230. 1995 buick century tranny surges in overdrive
  231. 1996 century no heat and loosing coolant.
  232. 96 buick century
  233. Ignition switch
  234. fuel guage missread
  235. 1990 SW 3.3L V6 exhaust installation. NEED HELP!
  236. Dead Ignition
  237. 89 Transmission shift cable location
  238. Intake manifold leak - '99 Century
  239. 2000 Buick Century wipers
  240. Stereo Wattage in Buick Century 2000 ??
  241. 91 wont start
  242. missing on acceleration
  243. buick century shuts off after 15-20 minutes
  244. tachometer
  245. speedometer fluctuation
  246. Anyone replaced 98 Century front hub?
  247. Intermittent Won't Start when cold
  248. 92 century.
  249. no instrument lights in 1997 buick century limited.
  250. 3.1 Intake Gasket problem?
