View Full Version : Century
Pages :
1 2 3 4 [ 5]
6 7 8
- Relay cylinders??
- front of the car shaking when breaking
- 88 century tranny probs...need help
- 93 loses elec volts and tries to die
- 91 Wagon electric trunk latch no working.
- Buick Century Starting Problems
- Another dead 88 Century Limited
- What car for donor 94 2.2L engine?
- 00 BUICK CENTURY Wet Passenger Carpet????
- Steering problems
- Couple of questions
- 1999 Century Heater control Trouble
- 96 century coolant leak
- Backfiring & Smog - Please Help!
- Trouble Code 42
- 93 century stall, longish read
- Buick Century
- Fuel Gauge
- 1996 to 2001 Century's, Any Chronic Problems /
- 3.3l engine bogs down when it is put in drive
- Engine Dies
- Buick-
- replacement of kickdown cable
- 95 Century Transmission losing fluid
- 1994 3.1L, at 1st just rough idle, now NO temperature reading...
- 89 buick century 3.3L won't start
- 2003 Century wont start
- "Steering Sensor Bias Malfuntion"
- 98 century, rear turn signal doesn't work and bulb good
- Ignition switch has intermittant Acessory contacts
- Blinker light and brake light
- removal of stereo in 03 century
- cruise control
- Transmission pump 1993 Century
- 1993 century crankshaft sensor
- 93 buick transmission leak, and it stalls
- ABS Brake & Cruise Problem 94 Century
- mystery water leak
- Ignition resistor Buick 2000 Century????
- front turn signal
- Bottoming out Century
- 1999 Century Remote trunk Trouble
- 1990 Buick Century reading code 33
- 95 Century wont start
- 1999 century
- 1997 Buick Century a/c Problem
- 2001 Buick Century Transmission slipping
- 2005 Buick Century Advice
- 1992 Buick Century Stalling
- 1991 Buick Century stalling
- buick 3.1 a/c century 1998
- 1985 buick century-resetting the check engine light
- 1991 air conditioning problem
- Removing drivers door panel on 90'Century
- strange gas level readings
- 2001 Buick Century Cruise Control problem
- looking for wiring diagram for my buick 89
- 96 misfire and 2 error codes
- vacuum line diagram
- No Juice...
- Very odd Buick Century noise, everyone please read!!!
- Changing alternator belt on 2.5
- tail lights won't turn off
- 89 buick century scanning problem
- Lumina engine overheating
- 1994 Century hood cable
- 1994 Century quit running
- Pulley system
- 2003 Buick Century keyless programming
- 90' Century Service Engine Soon Light ON
- Hard steering and low tire indicator light
- Engine Dying at Idle
- 98 Century - - $600 for a condensor???
- Gasoline Prices, will this change your driving habits?
- 2 Centurys, same electrical problem
- 1992 century radio install
- not hitting on all cylinders
- Security, ABS light and Brake light on! Please help!
- Transmission Problem
- 1993 3.3L stalling at stop or light
- 89 century problem with the choke
- Looking at 1995 buick century
- Transmission Problems?
- 1999 Century-- air dam scrapes TOO much!
- 1993 Century 3.3 harmonic balancer.
- 1996 Buick Century Blower question??
- 1993 Buick Century won't start
- runs hot,idle dosen`t kick down,tranny
- Instrument lights fuse blown
- 3.8 firing order
- What rims fit 2000 Century?
- Car really over heating
- How to change A/C bearing?
- 2003 Buick Century help needed
- Anti-Lock light stays on
- 1998 Century Fuel Filter ??
- GM's 3.x v6 engines-opinions
- 93 century muffler prices
- Courtesy Circuit Blowing
- Battery Indicator Light
- 1999 Buick Century All Power windows stopped working
- 1998 starter replacement cost?
- Sea Foam fixed my stumbling 3.3 litre
- 1990 Century Stalls
- removing back seat in 91 century
- Engine power problem
- What caused the tranny to quit, further information..
- '90 Century Custom pass door won't open
- running lights blow out 98 buick century
- Lokking to buy a buick century what to look for?
- Lights Dimmer Switch controls Radio Volume
- 91 Century just dies
- Help!!
- Why does Starter turn engine when I try to connect the negative cable to battery.
- 99 Century Wiring Diagram for 02 sensor...
- Buick unreliable trans - afterthough..
- Buick unreliable transmission (Part 2) - verdict by trans shop..
- Electric seats shorting? need help
- Buick transmissions prone to failure
- Turn signals do not work
- GM email contact will not accept Canadians
- Major transmission failure (Buick Century 2000)
- ABS and Brake Light on 98 Century
- 93 Buick Century 3.3L, funny start
- new to the buick community...kindof!
- Air Conditioning (but only half)
- Exhaust
- 88 stock stereo question
- 1998 Buick Century
- 2000 window cable
- 1993 buick century 3.3 liter
- 99 Buick-O2 Sensor
- Two problems-engine related
- Please, need help guys!!!!
- Rough running
- 95 Century Daytime Running Lights Module
- does anyone have the wiring schematics for a1995 buick century custom v6 3.1litre eng
- transmission cooler
- Window switch
- 99 Century P0341 error code, newbie
- car wont start,And i left nothing on
- 1988 Brake Light/Turn Signal Problems
- oil leak
- Loud Sucking Sound At Brake Pedal-90 Buick Century
- changing water pump on 94 buick century
- AC blows out of the defrost vents
- ABS, SES, trac off on 2000 century
- 89 Buick century master cylynder problem
- Removing Pivot Pin 91 Century
- 2000 Century Vacuum Source for HVAC Dampers
- Should I buy a BUICK?
- 93 century tow question
- 2000 Century HVAC Problem
- And yet another question about the cooling system
- 1990 Buick Century stalling in drive
- Compressor replacement concerns
- engine cooling fan relay 1995 century?
- Trouble Moving
- 1990 Century Brake Service & Bleeding - Pedal Sqooshy
- Overeating problem
- 1991 Century Headliner
- 1989 buick century 3.3 engine won't start
- engine fan and temp gauge dosen't work
- Banging noise at serpentine belt
- 93 Century-Intermitant Starting Problems
- bright/dim headlights??
- 1990 Century All 4 Driver Side Window Controls Dead
- stereo problem
- 1996 Air conditioning removal(sort of)
- A/C Fuse locations
- Serp belt replace 1988 century, tensioner stuck ?
- 89 Century MAP Sensor Location?
- 2002 Buick Century Custom
- Quad Headlight Setup?
- 94 century what size belt without A/C
- Lubricatin locations on Century 2000
- 99 Century - What To Watch For?
- Request advice 1998 Century - should I buy
- Locking Gas Cap Install
- Stalling when hot
- Push button starters (installation)
- Straight through glass pack designed mufflers!
- Springs
- 95 Buick Century Electrical Problems/Battery/Accessories
- swap standard radio with factory cd
- Took muffler off of 86 Century> Bad or Good? it sounds soooo good now!!!
- Power Window Problems
- 3800 supercharged engine swap
- 2001 century back up lights
- need help with aftermarket head unit
- tps 90 century
- How do I remove dash for stereo removal?
- ABS an option in 2004?
- Loses battery charge
- Flatrater - cracked covers pics - location info..
- Very High Octane
- Flatrate, I submited the covers pics (where did they go)?
- Pics of the GM trans PCS problem
- To Flatrater, Bnaylor and alll our advisers, (Hard shifting)
- a/c driver side hotter
- Ultimate cause and solution for Century hard shifting revealed..
- 1998 Century Cluster
- 1990 Buick Century 3.3 hard to start mornings
- Trying to help a friend.. Your Thoughts. (Misfires after tune up)
- Drive belt walking
- code 41
- '96 Buick Century - Ghost In The Machine
- 93 buick century O2 sensor
- Flowmaster
- Thank you 'Bnaylor 3400' ! Expert says why the shifting problems
- Jerky gears shifting and strange noise when warm..
- 1995 buick century v6 3.1 help
- spark plug wire order
- Coolant Sensor
- Slight Rust spot
- OK, now I am confused, and angry
- 98 century - oil change frequency
- My fan only blows on the highest setting
- 1990 Century Flasher?
- 2 questions about my new 93 century.
- Turn Signals Quit
- 2001 Cent *cold* slips in R and thunks ONCE into 1st
- 2000 Century rough shift to 3rd and overdrive
- 94 Buick Century Electrical Problems
- Light help with century 3.3
- drive axle retaining clip
- Replacement belt for '89 Century with 3.3
- Engine Swap? 3.1V6 to a ??V8?
- 3.1 Ignition Coils
- no instrument panel lights
- 3.1 Help!!!
- OBD computer
- Dual Exhaust
- Tie rod lubrication
- wiper stuck in an upright postion
- chang oil on 98 Century
- No Heat
- 1996 Buick Lemon (Century)
- Oil leak
- How to check if my 93 Century has remote entry installed?
- 89 century, check engine light-loosing some power
- 1998 Century is a rough ride....
- Door Wiring
- 98 Century AC system
- body work buick century
- '85 century, can seem to get it right
- 1996 buick century
- How's it work--A/C condensor fan
