View Full Version : Century
Pages : 1 2 3 [4] 5 6 7 8
  1. AC control problem
  2. 91 lock problem
  3. 97 Century Cooling Fan
  4. 1994 2.2 century
  5. 92 Buick Century with no spark.
  6. 2003 Century w/ dead battery
  7. 91 century stalling and radiator problem
  8. 2001 Century surging and no power
  9. Bumper Replacement
  10. Tires
  11. 200 century oil light
  12. electric windows malfunction
  13. 99 Century - Climate Control Problems
  14. Information on 1990 "Starter Sensor."
  15. P1404 P0300 codes 2001 century custom
  16. New and Old Members Please Read
  17. fuel enable signal location on 03 buick century?
  18. 94 century 3.1 loses power when warmed up
  19. bucking then dies
  20. A/C Compressor Clutch
  21. Intake manifold gasket Q Help quick!
  22. Engine Dies
  23. 3.1 performance
  24. 99 century, always burn A/C fuse
  25. '01 Century rear window defrost
  26. starter replacement
  27. Spongy brakes=bad idle
  28. scanners........
  29. 1999 Century remote start bypass
  30. PO440 code
  31. replace A/C compressor idler bearings?
  32. New Wheels-2000 Century!
  33. Anti Freeze Change-2002 Century
  34. fuel pump
  35. Coolant Leak behind Water Pump '92, 3.3
  36. 90 Century emergency brake
  37. 92 century
  38. Overheating. Help its driving me crazy
  39. Wiring problem on 3.1 liter on 94 Century
  40. Good buy?
  41. Best sparkplugs for 98 Century 3.1L
  42. Dash on 98 Century
  43. Power window problem (stuck)
  44. 91 Buick Century stalls out
  45. 1997 turnsignals
  46. air conditioning
  47. Programming Remotes 2000-05
  48. Intake deffective gasket issue - petition on line (to sign)
  49. 1991 Century Electrical Problems
  50. Buick Century transmission
  51. Canadian GM Canada car owner(s) launch faulty gaskets class suit
  52. 92 Century No fire
  53. 2001 buick century
  54. just some issues
  55. new stereo too deep for dash?????????
  56. 98 century air conditioning
  57. Gas Leak?
  58. Help On Putting Code In Delco Unit
  59. Dexcool likely cause of leaking gaskets..
  60. 93 Century Speaker Help
  61. Rim Size
  62. What is the difference.....
  63. 84 century
  64. Please help need to replace turn signal indicator
  65. Update, 2000 Century w/ odometer not visable!
  66. '93 Century Speakers
  67. 93 Century rear spark plug removal
  68. Intake manifold deteoriating gaskets problem - GM Service Bulletins
  69. 98 century radio problem
  70. '93 Century 3.3 no start.
  71. Faulty design intake manifold plastic gaskets..
  72. Knock Sensor?
  73. Cant find filter
  74. Still looking for advice
  75. 98 buick century oil safety switch ????
  76. ? on cooling fans 2000 century
  77. Delco GPS Unit
  78. Century Pic's.
  79. 93 Century Code 26 problem ...Help!
  80. buick won't start after running out of gas
  81. 2000 buick century transmission jump
  82. 2000 Buick century transmission jump
  83. 2000 century odometer not visible
  84. ABS error code help
  85. 91 century interior light
  86. Help - My 1993 Buick Century just died!!!
  87. 99 Century 3.1L - Intermittent No Re-Start When Hot
  88. Blower motor
  89. Emissions test
  90. 1st fuel filter switch... i got some ?s
  91. NO START: no spark
  92. 1990 Buick Century 3.3 v6 - Won't Start
  93. Another EGR trouble code
  94. Another EGR trouble code
  95. A/C Heater Control lights: Yes or No???
  96. 98 buick century rear power window problem
  97. Century 92 Tach Install
  98. 2000 century hard shift pattern
  99. 98 Century won't shift
  100. low tire light
  101. ODD lights
  102. What is ECM?
  103. 2001 century tail lights
  104. temp sending unit
  105. Cooling fan relay
  106. o2 sensor code - 89 century
  107. water pump removal 3.3liter
  108. Cooling fan
  109. 2000 Century EGR Valve
  110. 91 century engine swap
  111. Needing a a/c compressor
  112. electrical problem
  113. Door Latch Problem
  114. How to install a 95 Century window lift motor?
  115. which year engine will fit a 96?
  116. Lights popping up all over the place on instrument panel
  117. 94 Century 3.1 Need help with battery removal
  118. Parts
  119. Parts
  120. Where is the ALDL connector - 94 Buick Century
  121. 01 Century Custom A/C problem
  122. 94 Buick Century showing high temperature on gauge
  123. Left turn signal broken
  124. New LIM gasket seepage?
  125. blower motor
  126. Removing Part of Dash
  127. buick ran without water...what damage?
  128. Low compression 3.3L V-6
  129. coil problem?
  130. 02 Century Windshield Wiper problem
  131. Ready for Super Sunday
  132. 1998 Buick Century,Please help me
  133. thud in drivetrain
  134. 99 Century windshield wiper problem
  135. 1988 Century Rough idle?
  136. 94 century custom fan relay
  137. 97 Century ABS and Power Steering Problem?
  138. power steering questions 98 buick century
  139. 87 Buick century overheating
  140. No start after replacing serpentine belt?
  141. 98 Century rattle on startup
  142. Replacing parts on a 93 ever 2 years
  143. 2000 Buick heater problem
  144. Need help with 95 Century and weird ALDL connector
  145. harmonic balancer and broken door hinges
  146. Firewall Access for Amplifier Power Cable?
  147. Trunk light
  148. Right Turn Engine Hesitations
  149. code 1404
  150. 95 century-no exterior/interior lights
  151. 02' Century Codes
  152. Need help finding parts
  153. Idle RPM Adjustment
  154. w/d buick century 1997
  155. 2000 century radio install
  156. 1992 Buick Century
  157. Brake noise
  158. problem with lights on dash and instrument panel
  159. 1993 Buick Century Transmission
  160. Removing stock stereo from 91 century
  161. 1994 electrical problems(heater,radiator and engine)
  162. 89 century 2 door?
  163. 89 Heater, Defrost, Radio Not Working
  164. 2001 Century Transmission problem
  165. Radio Wiring Harness - Big Mistake
  166. P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
  167. Heater Coil help?
  168. 1993 Century Stop Lights Not Working
  169. Thanks for your help! window switch
  170. new guy
  171. What engine to replace 94 2.2L
  172. 1998 Century Factory Radio Removal
  173. gas smell
  174. Can I use 94 chevy 3.1 to replace a Buick 2.2l ?
  175. crankshaft postion sensor
  176. Will a 96 3.1L replace a 94 2.2L ?
  177. Tranny may have just went instantly? Need some advice
  178. radio
  179. Blower works only on HI, again
  180. Service Engine Soon light on 2001 Century
  181. Lack of power
  182. Highbeam problems
  183. 90 Century codes 14, 22, 43
  184. Transmission Bolt Torque
  185. my car keeps stalling while im driving
  186. '84 Buick Century alternator/voltage regulator abnormality
  187. '84 Buick Century "chirpping" in belt area
  188. Buick century 1987 radio/lighter/interior light problems
  189. Pimp My Ride 86 Century
  190. wire hub cap lock nuts
  191. help! 89 century runs poor after warmup
  192. 88 Century Rough Idle?
  193. Clunk & Rattle in 1990 Buick Century Trans.
  194. One more thing....
  195. 91 Century Transmission Filter change....
  196. I need help on rotating an engine on 1990 Buick
  197. 88 Century rear spring Question
  198. Power Windows on 95 Century
  199. Trailer Wiring
  200. Programming remotes
  201. 1995 buick century tranny surges in overdrive
  202. 1996 century no heat and loosing coolant.
  203. 96 buick century
  204. Ignition switch
  205. fuel guage missread
  206. 1990 SW 3.3L V6 exhaust installation. NEED HELP!
  207. Dead Ignition
  208. 89 Transmission shift cable location
  209. Intake manifold leak - '99 Century
  210. 2000 Buick Century wipers
  211. Stereo Wattage in Buick Century 2000 ??
  212. 91 wont start
  213. missing on acceleration
  214. buick century shuts off after 15-20 minutes
  215. tachometer
  216. speedometer fluctuation
  217. Anyone replaced 98 Century front hub?
  218. Intermittent Won't Start when cold
  219. 92 century.
  220. no instrument lights in 1997 buick century limited.
  221. 3.1 Intake Gasket problem?
  222. 1998 Buick Century Driver's Window switch
  223. Can't go over 50 mph
  224. Heat
  225. Gunk in Radiator
  226. Rattling/clunking noise when starting/turning left
  227. Please Help! My Driver's Side Power Window is Stuck DOWN
  228. How To Program a 2000 Buick Century Key Fob???
  229. 94 century 3.1 surging
  230. Question on turn signal and cruise control issue
  231. Navigation system install
  232. Speed limiter/governor
  233. No trunk light in 2003 Centry
  234. 2000 Century Starter Replacement
  235. oil mix-up
  236. rough running again
  237. 92 century alternator replacement
  238. 1990 centry custom fan help
  239. 2002 Buick Century low Coolant Sensor
  240. 1990 3.3 v6 stalls and does not shift at times
  241. Check engine light
  242. Brake light trouble on 99 century
  243. Misfire detected and injector circuit open
  244. Floor Heat
  245. Power antenna and after market CD players don't mix?
  246. Steering problem-update-new problem
  247. MAP Sensor
  248. Sideway free play in steering column
  249. 1998 Hood Release
  250. Relay cylinders??
