View Full Version : Century
Pages :
1 [ 2]
3 4 5 6 7 8
- 99 Century hard to start
- 2000 Buick Century 3.1L - Steering Hard Left, Easy Right
- Dropping oil pan
- 1992 buick century
- car won't start after head gasket change
- Trunk opens when starting car at night once dark
- coolant and steering probs. w/ my 97 century custom 3.1
- 2002 Buick Century ABS light on all the time
- 92 buick century audio
- 91 century struts
- temp control/tire pressure sensor
- 00' Buick Century Transmission Hard Shifting
- Is DexCool bad?
- Low Coolant Light
- Turn Signal Flasher
- White Smoke, Rubber Smell
- 1997 Buick Century Radio Swap
- 2000 Century: Guage cluster compatibility?
- 99 Century Fuel Gauge Reading Empty
- firing order for buick 3100
- Anyone Know about the different fuel modes
- Performance VS Luxury?
- AC Problems, Also Transmission.
- Tapping noise while idling.
- GM Linerat where are you? Motor no crank
- broken sway bar
- 1993 century window problems
- Code PO131
- Spark Plug Wires
- 99 Century Problems,
- 91 Buick Century 3.3 Stalling
- Blower fan stopped working
- 1988 Buick Century 3.8
- Buicks :(
- 1994 buick spark plug wire dia gram needed!!!!
- stalling problem
- Starting Problems?????
- P0446 on 2001 Buick Century
- Break Light Not Turning OFF
- Help: Drifting out of the straight line when I steer in the middle
- Where to download the Owner Manual of 2000 Buick Century
- 2003 Buick Century Blower Motor Problems
- Hesitation problem 93 century 3.3
- Rocker Arm Torque Specs. For "M" Engine
- Help: 2000 Century shaking in idle/low speed
- My 89 century overheated,how to fix?
- 2000 Buick Century Re-programming Keyless entry fob
- Wiper Motor / pulse board
- 98 Buick Turn Signal
- Head Gasket Installation
- Gasket Surface How clean Is Clean?
- Using Torque Angle Gauge
- Knocking noise in rear and sometimes front
- Whirring/grinding noise under hood
- 90 century wagon 3.3 rough idle & shifting
- 89 century seats....
- '96 Cent. tcc prob.
- 89 buick can go faster?
- 1999 Buick Century Custom with Low beams problem
- 93 Century 3.3L Transmission Mount Replacment Questions
- Code P0480
- '89 Century Poor Fuel Mileage
- speedometer
- Dimmer light for mileage
- power windows
- woodruff key
- Fast shifting
- squeeling brakes
- '86 Buick Century, torque converter not locking up
- 89 Century 3.3 Cooling Fan Problems
- Grinding Noise Under By Air Filter
- How to disable automatic locking
- General A/C Questions
- 93 Buick Centruy A/c Clutch Bearing Replacement?
- 93 Century light switch
- 87' century cutting out
- Torque question
- 98 Buick Century Heat Problem
- No Heat with 2001 Century
- 97 abs problem
- 1989 Century complete tail light assembly question
- Misfire code P0302
- Door hinge pins
- Antifreeze leak 3.1, 94Century
- 89 Radio Suggestion
- Buick century 2000: remote entry not working
- Search Function Century Forum
- Window lift motors
- boxed vs carded inner door handles?
- '92 Century Radio Problems
- tranny problems
- 91 century 3.3 trouble
- removing dash on 98 century for blower motor
- R/r Ignition Switch And Cable
- 96 Buick Century Stalling Problem
- heater issues with my buick centruy 1999
- Collapsed!
- 1998 Century - Broken Stabilizer Bar
- 99 buick century problem with power?
- 92 century fuel leak
- 93 Century Rear Axle/Carrier Replacment
- intake manifold gasket - leaking antifreeze
- 88 buick century radio removal
- 98 Buick Century digital temp control
- 2.5 head gasket
- 2002 century dash light question
- '92 Century starter removal
- 96 Buick Century No Forward Gears
- 94 Century blowing cold air
- 1991 Century 3.3 Hesitation
- 93 Antenna Problem
- Fuel leak 99 3.1
- 91' Buick Century stereo advice
- climate control 2000 buick Century
- '03 Buick Century heater/defroster
- Spark plugs
- AMP Install help
- 91 century power windows
- 98 Century Transmission Question - No Reverse
- trunk release button
- 1995 3.1 SFI Century MASS AIR FLOW NUMBERS
- 94 century stalling
- '90 3.3 into '95 3.1 V6 swap?
- 96 Buick Century Power Cable
- 97 buick century day time driving lights
- transmission question, rattling at startup
- 90 century stalls when cooling fan comes on
- Dead electrical 95 Century
- headlight dimmer switch problem
- 1990 Century Possible Fuel Pump Problem
- 1990 stalls when taken out of netural
- keyless program for 1996century
- 1994 Buick Century 3.1 Idle problem
- 3.3 buick century
- Help, century shuts off even with cps replaced!
- 93 Century 3.3L No Start
- keyless remote program 1997 century, help?
- front signals not working - 98 Century
- Dual Climate Control Panel Light Problem
- banging noise
- power windows
- 1993 buick century valve lash adjustment
- 94 buick century help
- Cd player in 2003 century
- 1993 century wont start
- Century 2000 power window switch
- 1990 Buick Century misses
- Interior,exterior lights lights slow dim, go out
- 1990 Buick Century nes fuel pump and filter
- 1989 Century Cooling fan won't come on
- 1993 buick century timing
- parts interchange
- 98 Century, brake *clunk* when I shift from P to D.
- Reprogram Odometer
- 94 century vibration under load
- 1994 Buick Century stalls at stop
- Dead
- Need some help with 1998 Buick Century, any input appreciated.
- fuel pump fuse
- 2003 C Custom - replace radio/cassette unit?
- anti lock brake light
- 1984 Buick Century Cowl Install
- 1993 buick century 3.3 timing chain replacement
- Lights out?
- 1994 Buick Overheating, stalling
- 1988 Century stereo installation problem
- random engine misfire - P0300
- radiator
- pressure switch a/c
- Dash Lights
- wheel speed sensor
- Coolant probs 2001 century
- 88 Buick Century
- 1994 buick century TCC troubles
- your new moderator
- 1999 Buick electric windows
- 1993 Century - climate control $.02 clip broke!
- 94 century 2.2L engine misses
- 96 Century not sparking after a rebuild
- 98 Buick Century cooling system
- 2003 Buick Century Gas Guage
- '87 Buick Century 2.8 Cooling Fan
- rotating tires
- Where Is Turn Signal Flasher???
- 2003 century remote programming
- 92 Century ft left caliper lockup
- Check engine light
- 98 century split zone AC not working right
- 98 Century Hard Starting when cold
- HELP! Car adding miles all by its self...IN PARK
- Service engine light and gas tank
- 1994 century no TCC lockup when hot
- Electrical, Crank bolt, CPS
- Please help,tell me where the cps sensor is in my engine I have pics inside!!
- checking codes??
- please help transmission won't down shift??????????
- 1991 Buick Century Check engine light
- 89 Century shuts off in the middle of driving please help!!!!!
- 00 3.1 Code P0410
- 98 A/C comp knocking
- Supercharger for 97 century?
- Service Engine Soon Light-Need ideas
- Buick Century 2003 Air Condition Does Not Work
- 1998 Buick Century issues
- A/T shifting very hard into 2nd gear
- 3.1 Liter Idle Problem
- What oil do you use?
- 1993 Buick Century Tranmission automatic
- Weird fan problem
- Need help on Changing a thermostate on a 89 Centruy w/3.3 V6
- considering 93 Century- 6cyl engine questions
- 95 century intermittent starting/power problems
- 1994 Buick Century no start
- Dirty coolant and burnt smelling trands fluid on a 96 Century Custom 3.1L V6
- 2005 Buick Century
- mech stumpped 2000 centry no start
- WHEEL LUG '95 Century
- '99 fuel injection harness puzzle
- 96 buick century
- 1999 Buick Century starting problem!!
- Power window problems
- Crank position sensor - 91 Buick 3300
- 91 buick century sputters from idle roll outs
- 2002 century remote program
- 91 Century Custom's Bench seats
- 96 century hesitation while at high speed
- 93 buick 3.3 - No fuel
- 2001 buick century stereo info
- 92 Buick Power window problem
- Engine Hammers when cold - Colapsed Lifters?
- Crank Position Sensor - 94 Century 3100
- 94 Buick Century cruise control stopped working after battery went dead
- Upgraded front brakes
- 93 Buick Century shifting kills motor
- Need help with removal of back seat in 1994 Buick Century
- 1996 Buick Limted
- Wheel Hub
- '93 Century. Weird ALDL. How do I check codes?
- Trouble with Buick
- A/C clutch will not engage
- code 0341 cam sensor
- belt question...
- 2003 century NSS
- 91 century stalling at times
- Hey its me again..
- Is there transmission dipstick in 03 Century?
- I need Help, My Buick wont shift right
- oil light on at idle ..any ideas
- Malibu vs Olds Intrigue vs Grand Am
