View Full Version : LeSabre
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14
  1. Need Help Please!!!
  2. dead battery 99 lesaber
  3. LCD temp control display
  4. 02 Lesabre Alternator gets hot
  5. Weird Power Steering
  6. engine knock
  7. 2004 Buick lesabre speedometer problems
  8. jon 111
  9. P0404 and P0405
  10. 98 buick lesabre upper and lower intake
  11. tranny shudder fix?
  12. 1997 lesabre electrical transmission problem
  13. 90 Lesabre deceleration miss......
  14. engine temp guage showing lil cool
  15. does fram xtra guard have drain back valves in them?
  16. HVAC won't switch to Heat/floor vents?
  17. need to replace the heater core???
  18. Lifter noise at cold start up
  19. Engine vibration at idle
  20. Idle not steady - moves up/down 150rpm
  21. Frozen gas lines?! What is there to do?
  22. Cigarette lighter 2003 Lesabre
  23. Re: need help with wipers II
  24. REPOST 2 OF UMI JOB pics inside (maybe)
  25. tranny problem or engine/tranny mount?
  26. AC compressor noise
  27. Blower Mystery... 1992 Lesabre (Getting COLD in ND)
  28. Strange Vibration - 2002 LeSabre
  29. You guys or gals are great!
  30. 1994 Lesabre....question about starting.
  31. 1994 Lesabre Intake Manifold....Problem Solved!
  32. Looking at a 95 Lasabre, Need help
  33. cold start problem
  34. Radio stays on with key out?
  35. UIM gasket
  36. 91 Lesabre stalling, sputtering, hard to start
  37. 88 Buick LeSabre Starter Replacement
  38. 1997 Tensioner Adjustment
  39. Upgrade Radio Advice Please : 1994
  40. Hard brake pedal and comp code 1406
  41. coolant loss 1997 popular problem i guess
  42. Re: Plugs and Wires sounds easy huh?? Take Two
  43. Door panel leaking - solution
  44. massive vibration on acceleration and when shifting into overdrive
  45. Coolant system pressure test?
  46. Tie-rod ends on '90 Lesabre
  47. 97 Lesabre headlight / turn signal problem
  48. 2000 LeSabre help no heat
  49. Lifter noise (cold) and misfire code 301
  50. '97 UIM letting go
  51. Comfortemp Display 95 Buick Lesabre
  52. Help with 92 LeSabre
  53. Harsh shift in reverse only when hot
  54. 98 LeSabre voltage gage variation
  55. Need Help - 2002 LeSabre
  56. 97 Lesebre Power Steering Mount Bracket
  57. No Ext Temp reading??
  58. Buick LeSabre 98 With 230k Miles on it. got it or not
  59. Please Help! 96 Park Ave Motor into 97 leSabre
  60. HVAC code 38 Serial Data failure to PCM
  61. odd service engine soon light
  62. high idle on cold start
  63. Replacing LCDs in HVAC and Radio
  64. Fuel Pump
  65. Vacuum sender to Brake Canister
  66. code 38 on HVAC control
  67. P0171 Dtc
  68. Fuel tanks interchangeable???
  69. 1995 Buick LeSabre Hybrid check engine light on first drive of the day
  70. MY CAR DIED......can I sue GM for not recalling the UIM?
  71. Gas pedal hard to push
  72. 95 LeSabre, DRLs do NOT shut off
  73. 1997 Lesabre Wiring/Climate Controls
  74. Rain X Latitude Wipers for 2001 Lesabre
  75. Broke the latch on the console
  76. Just changed fuel sender. Too sensitive!
  77. Rear coil spring question
  78. ICM testing
  79. 2002 LeSabre directional issue....
  80. 2001 lesabre evap canister location
  81. 2000 Lesabre Trunk leak on right side of trunk
  82. buick sputtering and now wont start
  83. 2001 Lesabre Gas Gauge part two
  84. 2001 - lights flickering every now and then
  85. service engine soon light- 2002 buick lesabre
  86. Drain holes in front fenders
  87. 1989 LeSabre loping
  88. 93 LeSabre power steering problems
  89. Drip, Drip, Drip....Follow the Drip!
  90. 3.8 Series II identification
  91. '97 Headlights
  92. abs pump assy
  93. harmonic balancer
  94. Struts and shock auto leveling replacement?
  95. UIM Replacement
  96. 1995 lesaber air conditioning compressor
  97. Drilling the firewall for Subs
  98. Speedometer problem
  99. 2000 Suspension Question
  100. Mirror with outside temp want to replace
  101. 1994 LeSabre Shop Manual
  102. 1988 V-6 Buick LaSabre Cruise Control Inoperable
  103. 94 Buick Lesabre 3.8 Upon RPM increase car stumbles and bumbles, no power at all.
  104. Bang the Drum slowly.......
  105. 1990 Buick Lesabre won't start
  106. Rear Brake Rotors
  107. Shake, rattle, and roll..........
  108. 92 Buick Electrical Problem
  109. * * 2000 with no guage lights
  110. Upper Cylinder head Gasket Repair kit Fel Pro
  111. Oil Pressure Sensor Location
  112. Running Rich?
  113. misfire
  114. photos of 1992 lesabre 3800 series 1 engine bay
  115. Need DTC (CODES) Help
  116. 2001 lesabre
  117. got to hot, head or intake gasket???
  118. 98 lesabre hvac codes
  119. Decoding paper tag on springs
  120. Timing
  121. gas leak from fuel filter 97 lesabre
  122. dash pad seperating
  123. 94 Lesabre-no start
  124. 2000 Lesabre Transmission shutter
  125. Dash popping up in front of driver
  126. Air rushing sound when cold
  127. 1997 LeSabre Theft Deterrent Problems - Trunk
  128. 97 Buick Lesabre
  129. Spring interchange
  130. 1988 Lesabre Cruise Control problems
  131. 2001 lesabre "Traction Off" light
  132. Door actuator left hot air
  133. air conditionor problems
  134. 00 Heated Seat
  135. Engine Swap: Help with choices and other questions
  136. 94 lesabre infl rest intermittent
  137. Clunking sound from front end
  138. No air through vent duct
  139. 2000 Buick LeSabre security light.
  140. Buick lesabre 94 idles but no power
  141. Can your ac cause low coolant in the reservoir?
  142. Ticking 97 Lesabre
  143. When to change a timing chain.....
  144. 97 lesabre engine computer compatibility
  145. 2000 Buick LeSabre Limited window disfunction
  146. Radio goes silent - 2000 LeSabre
  147. 04 Lesabre - Strange Grinding Noise On Acceleration
  148. fuel pump
  149. High Idle
  150. 2002 Lesabre....Good buy?
  151. Need HELP removing trim
  152. Blown motor. What do these symptoms mean?
  153. 2000 Buick LeSabre Limited Door Locks going Crazy
  154. mysterious mid 90's trim options
  155. bad wheel bearing hub or bad CV joint 01 LeSabre
  156. Code PO1870
  157. 1992 Lesabre - List of Issues
  158. 1988 lesabre harmonic balancer
  159. 3800 Engine swap troubles. Need GM Guru
  160. Parts for 1985 Collector's Edition
  161. Fuel Filter Location 2000
  162. Dual Climate Control
  163. Changed fuel filter and gas brand...Great gas mileage!!
  164. need help, fuel gauge jumping all around
  165. 91 lesabre starting probs
  166. '97 PCV problem
  167. 94 lesabre electrical problems, very strange
  168. Anything else I can check for Cruise problem?
  169. Free Online Service Manuals including TSB and RECALL
  170. 2002 Buick LeSabre Battery
  171. Need help 2000 lesabre
  172. Intermittent Window, Door Lock, Window Problem
  173. Intake Manifold Removal
  174. 94 lesabre brake bleeding
  175. How do I replace thermostat? 1990 leSabre
  176. Urgent!!! Fuel Resending Unit Question
  177. How do I replace a power steering cooler?
  178. Daytime Running Light problem
  179. check tire pressure alarm
  180. PLEASE HELP! Idling and Stalling Problem!!!
  181. 97 How to remove relays
  182. Ignition Fuse & Starting Failure
  183. 96 3.8 MAP Sensor question
  184. P0440 Code
  185. 92 trannie trouble
  186. '89 Running Rich
  187. 2004 LeSabre Cruise not working. Where to look?
  188. Does the fan run on vacuum?
  189. Front and back caliper bolt torque
  190. LeSabre 1993
  191. Air Compressor Clutch 98 LeSabre
  192. 1991 lesabre stating probs
  193. Fuel related?
  194. 92 LeSabre electric window problem
  195. 91 LeSabre Tilt Wheel: Not The Three Bolts
  196. Air Hose to Shocks
  197. 98 Le Sabre broken front sway/stabilizer bar
  198. timing set nut size
  199. 1988 le sabre seat not wk'ing
  200. 94 Lesabre
  201. 2000 Lesabre lost power during driving
  202. 2002 Lesabre AC blower problem
  203. High Idle--Please Help
  204. 93 LaSabre sounds like a Diesel
  205. Horn Blasting Spontaneously
  206. AC adapter
  207. installing down stream o2 sensor
  208. TPS problem 95 Lesabre
  209. 98 LeSabre won't start
  210. 2004 lesabre ticking upon acceleration
  211. 2002 Limited RDS Radio Aux Port Auxilary
  212. 1991 Buick wont start
  213. About to do suspension work, what else...
  214. 92 LeSabre Hood Latch
  215. The tire wobble check.
  216. code reader for 95 Lesabre
  217. Suspension/control problems
  218. 05 LeSabre shocks
  219. 93 Lesabre, need more HVAC airflow
  220. 02 lesabre 3.8 oil light /fuel gauge problem
  221. Is there a way to figure Overdrive or not at a certain speed?
  222. !992 Buick LeSabre A/C problem
  223. 1999 3.8L intermittent P0303 code
  224. 2000 LeSabre Headlight Switch Repair
  225. 95 LeSabre - Diagram of Fuse Panel Available?
  226. 1997 lesabre a/c compressor bypass?
  227. 2000 buick lasabre intermittent starting problem
  228. Remove Window Paint - But Can't See It
  229. 440-t4 trans parts needed...
  230. 1991 4t60 TCC wiring
  231. coolant leak/check engine light
  232. Steering Wheel Lights - I have replaced bulbs
  233. Heater Control Illumination
  234. wheel whistling sound
  235. 95 LeSabre - Interior Lights Stay On
  236. 96 LeSabre brake light and chime...
  237. what temp should cooling fans come on
  238. 97 LaSabre Battery Drain...
  239. Help with fuel level sending unit replacement
  240. 1995 Buick Lesabre Idling Fast And Speedometer Not Working
  241. Ash Tray Light
  242. 97 Lesabre Hard Starting
  243. Christmas Tree lights from A/C Control Panel, '93 Lesabre
  244. knocking noise
  245. AC problem help needed 2000 Buick Lesabre
  246. Any way to change all the fluid in Transmission 1997
  247. P.S pump noise
  248. 2000 Le Sabre security light issue
  249. 1989 rear disc brakes?
  250. 92 LeSabre...PLEASE HELP
