View Full Version : LeSabre
Pages :
1 2 3 4 5 6 7 8 [ 9]
10 11 12 13 14 15 16 17 18 19
- 1998 LeSabre driver tail light keeps burning out.
- 92 LeSabre stalling, erratic idle
- 97 Lesabre ABS Light On and No ABS
- Air in Rear Brakes
- Power Windows revisited
- '89 Le Sabre - Check Engine light-stalling
- 98 buick 3.8L seriesll
- What is an Adaptive lamp monitor?
- Front Brakes Problem!.. Streering Wheel
- Lesabre Front Bumper
- 97 LeSabre EGR problem
- Odometer Reading
- Hubcap/wheel cover locks
- cooling fan
- Lesabre keeps stalling out...FRUSTRATED
- 2000 LeSabre Service Manual
- Rear turnsignals not working
- 2005 LeSabre Transmission chatters slightly when shifting from 1st to2nd
- what transmissions will mate with and 80's 3.8l v6?
- 92 Lesabre part changed , code and problem still there
- 92 lesabre rear brakes
- 95 LeSabre oil leak
- "Tune-up" or maintenance questions
- What years (if any) LeSabres got the L27 Series III?
- fuel pump issues
- A/C problem
- 93 Lesabre Stalling and no one knows why
- A/C Clutch
- 95 paint code
- 1994 Lesabre Steering Column
- Tail Light Bulb Mystery - Wow!
- Rear Windows De-childproofing
- 95 Buick LeSabre Power Lock Problem
- 94 lesabre tranny
- 87 lesabre problems....need ideas
- 97 only starts on the second try
- ODC II code P-0113 IAT sensor
- Oil Pressure Sender
- 95 LeSabre Hesitates During Heavy Acceleration
- Beware: Cooling System Leak On 1995 LeSabre (3.8)
- Rounding torx bolt on motor mount
- 94 LeSabre SES COdes
- Car just shuts off
- ABS , tracktion off lights are on after i start the car
- leather top
- 1989 LeSabre Intake Manifold Coolant Leak
- May buy 97 LeSabre: will they go 150k to 250k miles?
- 2000 LeSabre Dual Climate Control
- Changing struts on 98 LeSabre
- IAC/TPS Adustment '89 3800 Series
- How difficult is to replace Camshaft Position Sensor
- 91 lasebre idling poorly
- accessing rear door handle in 2000 lesabre
- remote entry doesnt work and a few other problems
- outside rear door handle
- Swapping a L26 Aluminum Intake Onto The L36 Engine
- I let my stupid sister drive my car!
- Engine code #17 and #24
- power steering pump 1998 la sabre
- interchangable parts
- tranny swap
- Full Size LeSabre Estate Wagon Downshifting Wrong
- 2000 Lesabre Noise in Rear
- AC crapped out-1999 lesabre
- 91' Lesabre stalling when coming to a stop/pushing brake pedal
- power door locks
- Diagnostic Questions
- Power Antenna Plug
- Help with car hesitating on idle.....
- 97 Buick Stalling
- Do you live in Raleigh, NC and know of a good place to diagnose A/C
- 1993 Radio Wiring Diagram
- 96 LeSabre AC Losing Vaccume - Electric?
- Fixed my stalling problem 97 Buick Lesabre
- 1995 LeSabre Insurance Total Loss Advice Needed
- How to remove rear trans mount on 92 Lesabre?
- 97 lesabre A/C compressor noise
- Fuse Box
- What is that big black box under the cowling on the passenger side??
- 2000 Dash pad problem
- '93 Lock-up torque converter problem
- 1995 Buick LeSabre Paint Peeling
- A/C blowing fog and won't defrost windows
- heater problems
- Wet Carpet
- Readdy to do my upper intake, few questions
- 88 LeSabre stalling
- '93 Tranny Swap
- 95 lesabre a/c comes on with heat
- where is the fuel filter fuse 97 Buick lesabre
- Engine Coolant Sensor Location ??
- 1992 LeSabre condenser
- 1995 Buick Lesabre A/C Problem
- 95 lesabre quit, won't start
- 2000 LeSabre blower fan location
- fuel pump?
- 88 lesabre cranks but don't start
- 94 Master Cylinder Questions
- 99 LeSabre Heater Fan
- cofused
- 97 Buick Lesabre speedometer works occasioinally.
- A helpful link about engine vacuum
- 1995 buick lasabre fuel problems
- 94 Buick Lesabre stalling
- '94 Buick LeSabre, please help.
- Urgent car dies when I first try to start it!!!!!
- knocking problem under acceleration
- No acceleration
- correct operating temp for a 2001 lesabre?... and coolant leak
- still have a bad miss
- fuel pump
- rear lower control arm ball joint
- Nut Size Help ????
- 1993 Spark Problem
- 92 HVAC controls non-responsive
- Gas pedal sticking
- NOISE: ONLY @top/TB end of engine, ONLY at start up, 3.8 '97 LeSabre
- harmonic balancer bolt
- Getting ready for a long drive
- 1993 Buick Le Sabre won't start
- 2001 LeSabre, possible oil leak... questions
- Vacuum diagram for 92 Lesabre
- 92 suspension question
- trouble code P1870
- 1994 Sputter/surging/stumbling issue
- 97 Lesabre stalls while driving
- Trouble codes on a 1993 Lesabre
- EGR was bad replaced and still stalling HELP
- 1997 3.8 headlamp problem
- 92 Dies when turning on headlights!!!
- O-rings inside fuel rail quick disconnects
- 95 buick Lasabre please help
- 92 LeSabre Stalling - MAF Code
- camshaft
- 1997 Buick LaSabre Heater Control
- Suds coming through bottom ac vents when in car wash with ac on....
- Case Closed
- Chime stays on constantly
- Rough Idle and runs rough around 55
- oil leak and shaking
- 97 Buick LeSabre Won't Start
- Fuel Tank Capacity?
- Lowering the Thermostat
- Recirc stuck on open position
- gas gauge wacky?
- 300 lb safe dropped on Buick LeSabre
- Front wheel studs
- horn fuse
- 85 AC/Heat controls
- Supercharger questions.
- Any way to get both high and low beams?
- Last problem now... LOL, at 65mph engine sputters, and 3 crank cold crank
- Clicking Sound When I Accelerate?
- Tranny Flush
- stalling problems
- 97 lesabre dies while driving
- Turn off security light
- security light flashing
- 98 3800 II, How long will my Intake last?
- 94 Buick climate control gremlins
- fuse diagram for 1994 buick lesabre
- rusting out
- Ac vents were fine and now only defroster blows
- 96 oil pressure gauge question
- '97 With 170,000 Miles--Oil Pressure?
- 94 Buick stalls when raising windows...
- Headers for 85 LeSabre
- 94 Clunk noise
- front license bracket
- Tranny pan reusable gasket
- Disable Security System
- serpentine belt change
- Tranny does not switch from Park when cold. (93 LeSabre)
- 1992 Le Sabre dies.
- Codes
- (1992) Cruise Control Disengages Itself
- R & R of accessory lighting
- 1994 Buick Lesabre, starts and runs for about 30 minutes stalls loses all power
- '99 LeSabre Not Cranking
- Ignition!
- Fuse box's
- Service engine light goes on and off
- 91 LeSabre won't start
- vibration while in the gas
- 1992 engine rebuild--need new connecting rod, how to separate?
- 95 lesabre coolant leak???
- bad gas mileage
- exhaust work questions
- brake pads question..
- Code 22 - Tps Signal Voltage Low
- checking OBD II codes... dumb question
- service manual for 2001 lesabre?
- 2000 LeSabre won't go forward
- Pcv
- 94 lesabre stalling
- Fuel line leak
- passkey wire locations
- Newbie With Ac issue
- 1992 LeSabre-Front End Noise
- window motors
- LeSabre Custom -partial heat problem
- 1990 buick lesabre shock issues
- Sail Away
- 2000 Lesabre - No Heat
- 97 lesabre ignition module
- Snow in Cowl
- 2000 lesabre-hard starting sometimes
- 96 LeSabre - crank, no start.
- '92 Lesabre starts intermittently
- Is My Tranny Headed For An Early Grave?
- 95 buick lesabre rod bearings
- 93 lesabre where is data link connector
- Tachometer
- HELP! 93 Lesabre tranny issue
- 97 LeSabre failed smog
- Sea Foam
- 97 Lesabre - Very Hesitant Transmission
- Buick Headquarters Address
- 02 Lesabre handling issues-steering?
- 92 lesabre stereo
- Code 14 (Kiss of Death?)
- Clicking Sound Coming From Alternator Area??...
- 87 LesabreCustom, replaced steering column and now no ignition
- 93 lesabre Tranny Issue
- please help: 95 lesabre charging system problem
- 96 lesabre trouble
- 96 lesabre charging/battery issues
- leather seat help
- Will rotors cause high speed vibration?
- 97 front end noise help
- how to test the rear defrost 1986 lesabre
- 97 Lesabre trans convertor going bad?
- 2001 Buick LeSabre Dash reads "John"
- Rear Window Defogger
- How can I check the voltage on a TPS if it's not plugged in
- Floorboard wet.....where is it coming from.
- Harmonic Balancer
- car dies when I hit the breaks
- 97 LeSabre washer fluid leaking
- Harsh shift into reverse!
- 94 starts then dies
- No Check Engine Light On, But Still Scan for Code?
- 95 buick lesabre help
- 1995 Environment Control Labels
- Code P0171 help
- 91 lesabre heat problem
- 1995, Stereo Displays "ERR" With Casette
- 93' Abs Not Working!
- 96 LeSabre error code
