View Full Version : LeSabre
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16
  1. LeSabre 1999 Problems
  2. 92 LeSabre tranny or sensor?
  3. sluggish93 88olds question for you buick pros
  4. 1998 Lesabre Transmission help!
  5. How to repair passenger outside mirror - 1995 Buick LeSabre Custom
  6. Springtime for the Buick
  7. RPM question-99 Lesabre- is there something wrong?
  8. For all those with no spark but will crank:
  9. 92 Buick Lasabre Power Locks &seats
  10. 00 lesabre
  11. 2000 lesabre
  12. 95 le sabre - no heat
  13. slow to start
  14. Oil psi down due to fuel in oil! Why?
  15. Oil change for my 90 LeSabre
  16. '92 lesabre no start, no fire
  17. Ok to run without EGR valve???
  18. Removing Balancer Bolt... Concerned
  19. DIC Oil Pressure
  20. heat
  21. 95 Lesabre stalls and won't start
  22. 93 lesabre air intake kit
  23. Removing the Throttle Body- Help! (94)
  24. 99, MAF was flaky-here's my symptoms
  25. 92 Lesabre -ABS light -wheel Sensor
  26. '94 Buick LeSabre Custom Power Windows
  27. Intermittent SES Light - 94 LeSabre
  28. 2001 lesabre dash
  29. Ya Gotta Love IT! Free LeSabre in Great Shape!
  30. chuggle, and rough idle. compression test
  31. 2001 Cornering Lights
  32. 94 starts and dies
  33. 92 LeSabre
  34. Hows your mileage?
  35. 89 lesabre fuel tank removal help
  36. 02 Lesabre fan motor location
  37. 3057 problem
  38. 2000 LeSabre Battery drains
  39. 1st time SHE ever STALLED!
  40. A/C problems
  41. Pcm Codes - Where Is The Connector.
  42. Woo Hoo!!! I passed inspection!!! :-D
  43. Headlight clear cover replacemet
  44. Replacing Flasher Unit-'89 Le Sabre
  45. 1990 buick lesabre custom fuel lines
  46. 5w30 vrs. 5w50 in 2000 LeSabre
  47. 03 driver door panel
  48. 91 Exhaust Problem
  49. 1992 Lesabre Limited Start Problem
  50. 92 Lesabre wire wheel cover locks
  51. Diagnostic-Connector missing..
  52. 94 Buick wont start
  53. Remote control
  54. Questions to learn
  55. 1992 buick lesabre limited
  56. will not down shift...
  57. Any GM parts people here can help me?
  58. dead 94
  59. Possible transmission noise?
  60. 1990 le sabre parked for 3 years
  61. Who has traction control???
  62. 1995 Buick LeSabre Stalling Problem
  63. How can I replace tail light?
  64. R-12 or R-134a???
  65. 93 lesabre transmission prob
  66. Any Ideas
  67. about to buy 03'
  68. 93 Lesabre turn signal issues
  69. Oil Change Warning
  70. 95 Lesabre misfire while at idle, and overdrive shudder
  71. Replacement of self-leveling rear shocks
  72. Aftermarket speakers with stock radio?
  73. Buick died in Garage - please help
  74. Please Help...rough start in the morning and now check engine light on...
  75. vacuum modulator
  76. custom vs limited
  77. Question about 2002 Lesabre Radio
  78. '93 Buick Problem
  79. Follow up to post "LeSabre 94 dies sometimes"
  80. 88 lesabre ran perfect until this morning...
  81. 94 Lesabre gas mileage terrible
  82. 99 buick la sabre 3.8 stalls after running for 30 min. or so
  83. '90 LeSabre steering column noise
  84. 2003 LeSabre rear disc brake pad replacement
  85. Fuel Filter
  86. 00 lesabre gas
  87. Burning Electrical 1999 Lesabre- Please Help
  88. security light is on
  89. cutting out when accelerating
  90. Steering Wheel Gadgets - 1995 Buick LeSabre
  91. A Question of Speed...
  92. 89 lesabre Fuel Gauge
  93. External temp sensor
  94. all of the warning lights abs,check engine,
  95. 2001 LeSabre water in right rear floor
  96. '97 Buick LeSabre
  97. LS Ltd vs PA
  98. wheel size help
  99. Tim Rice's problem *please read*
  100. 2000 buick lesabre engine quits while driving
  101. Alternator woes
  102. LeSabre A/C Fan Problem
  103. 1992 lasabre stuck in park
  104. 1992 buick lesabre limited
  105. Disable Automatic Door Locking when shifted into drive 2000 Lesabre
  106. How many miles on your LeSabre?
  107. Headlights Stopped Working!!!
  108. 2000 lesabre brakes
  109. 86 le sabre won't start after new head gasket
  110. 93 Lesabre not starting
  111. 89 lesabre will not run.
  112. 1999 lesabre radio
  113. I Love Buicks But...95 quits!
  114. Coolant Leak in 93 Buick LeSabre
  115. delayed starting 2000 lesabre
  116. '87 - Fuel Gauge Wire
  117. Blinking Temperature Display
  118. 92 lesabre trouble code 26 qdm "A" circuit
  119. 92 Lesabre anti-theft relay
  120. Brake problem - Urgent
  121. 2003 LeSabre: Power door locks, windows won't work
  122. Help No Start
  123. Ceramic Brake Pads
  124. Engine Vibration '00 Lesabre
  125. how to remove rear door panel 01 LeSabre
  126. Re: 92 LeSabre Transmission
  127. Lost PCV valve?
  128. AC Fluid
  129. 01 turn signal flasher?
  130. Speedometer problem (2000)
  131. Turn signal lever
  132. car wont start
  133. car wont start
  134. 98 lesabre intake plenum safe removal
  135. 89 le sabre
  136. 1990 (or possibly 1991) LeSabre loud metal clunking noise
  137. Shocks and Struts? NOSIE?
  138. Harmonic Balancer - NO SCREWS, 3 SLOTS - HELP!
  139. Update on BCM - Interior Lights Blinking, I can't believe this!!!!!
  140. LeSabre code PO 440
  141. 1986 Lesabre Estate Wagon Not Charging
  142. Heater/AC control module???
  143. 92 LeSabre noisy rear end
  144. steering fluid leak
  145. belt tensioner +coolant lines removal on a 99
  146. 79 Secondary Coil
  147. gas pedal sticking
  148. '87 - Inst Panel problems when dimmer is on
  149. Strange Ticking Noise, Goes and Comes
  150. 94 LeSabre
  151. 94 LeSabre
  152. oil selection
  153. Autozone lists recall but can't get the info
  154. Door Poppers
  155. 00 lesabre will not start
  156. One more stalled Buick...
  157. Ken-co repair kit?
  158. Heal-A-Seal Gasket Repair
  159. Buicks Hate Bosch!
  160. '92 tranny: what is this sound?
  161. Has anyone ordered from oehq.com?
  162. Replacing struts..Monro, Gabriel
  163. 91 lesabre starts then turns off after 2 seconds
  164. Speed-related noise in 2001 Buick
  165. Replace coil packs or not???
  166. need help with wipers
  167. 95 fit a 96?
  168. keep it, or bail?
  169. Need Help From the PROS!!!
  170. Door parts
  171. '97 3800 engine squeal issue
  172. can't shift
  173. 91 LeSabre cuts out after warm up
  174. 1996 Buick Lesabre engine
  175. 1996 Buick Lesabre Blown Head Gasket
  176. Pimpin' My Buick
  177. DTC's on 95 Chevy Tahoe
  178. P 0507 Engine Code/intake replacement
  179. Fuel gauge acts weird
  180. air ride
  181. windsheild wipers wont shut off
  182. 1990 Buick LeSabre cold starting problem
  183. 1990 Lasabre inner door panel
  184. Are Radiatos a "Throw a way item" now?
  185. heater and a/c blower quit working
  186. heater and a/c blower quit working
  187. 97 lasabre fuel pump amperage
  188. grinding noise...
  189. Leaking fluids overnight????? help!@!
  190. 94 LeSabre- starts, shuts off right away
  191. power seat
  192. 2001-Tranny/Computer Dying?
  193. 91 rear brakes
  194. performance
  195. new to forum
  196. Dex-Cool and Sludge
  197. 1994 Buick Lesabre Custom
  198. 1986 Buick LeSabre
  199. LeSabre 94 dies sometimes
  200. 1994 Buick Lesabre Custom Interchangable Parts
  201. Clean oil in pistons 5 & 6
  202. 97 buick door locking system
  203. 89 century runs rich after warmed up(no response on century forum)
  204. '87 LeSabre - Problems shifting 2nd->3rd when cold
  205. Drive Ratio from: 2.95 to 3.05 ?
  206. 2000 lesabre
  207. Starter location???
  208. 1990 into a 1986 3.8
  209. '00 "garage lurch" need help PLEASE!!
  210. Air vent buttons troubles
  211. Buick Lesabre custom
  212. 2001 Buick Lesabre Delco Theftlock Help!
  213. abs problems
  214. 98 lesabre limited...pcv location
  215. '87 - No Cruise Control
  216. thermistat position
  217. 92 lesabre, no air flow
  218. Can anybody tell me how to take the grill off my 99 lesabre??
  219. Slow Weak Window Motors on '90 Lesabre
  220. 97 Lesaber Belt
  221. what the bloody hell...My windshield wipers will NOT shut off!!
  222. Trouble codes: P0121, P0300, P1406
  223. Drivers Rear door, no power lock or window
  224. 1997 Buick LeSabre Digital Climate Control
  225. heater
  226. 1993 LeSabre Custom-several issues
  227. 96 Buick LeSabre Climate Control Trouble
  228. Voltage Problem
  229. 1995 LeSabre Custom Right Turn Vibration (Read In)
  230. 98 Buick Lesabre running rough and now not starting!
  231. 2000 LeSabre- no power to diagnostic port
  232. 1995 Buick LeSabre Electrical Problems
  233. 1994 Buick Lesabre won't start
  234. Windshield washer pump/rear side marker
  235. Which scanner to buy?
  236. Programing a Body Control Module
  237. Good parts needed at a good price
  238. 92 buick makes a dinging sound and break light stays on
  239. 98 le sabre lowering springs/better suspension
  240. Aircon or computer problem or ?
  241. Blowing white smoke
  242. 95 lesabre Growel :disappoin
  243. 1997 LaSabre radio doesn't work after battery disconnected - not anti theft problem.
  244. Power Window Problem
  245. PLENUM Intake Failure, What kind of fluid did you use?
  246. Difficulty Starting (Episode 2)
  247. T-Type questions
  248. 3800 C - Misses When Hot
  249. rims
  250. no fuel to injector rail
